生物芯片
16室围栏片、生物芯片
16室围栏片、生物芯片
Multi-well slide format
进口
德国肖特(SCHOTT)
NEXTERION® MPX
NEXTERION® MPX-16 Slides
The special 16-well architecture of NEXTERION® Slide MPX allows the parallel analysis of multiple biological samples against focused subsets of probes on a single slide. The dimensions of the microarray slide are fully compatible with all microarray printers and scanners, allowing users to run multiple samples on a single slide without any additional hardware.
Overview
Key product features
•Standard slide format compatible with all standard commercial micro array printing, liquid handling and scanning equipment
• Simultaneous analysis of 16 biological samples on one slide
• Excellent reproducibility compared to conventional single-array applications
Immobilization chemistry
NEXTERION® MPX-16 slides are available with most of the NEXTERION® functional coatings (see table immobilization chemistryin the general multi-well section).
This coating is identical to the respective coating on NEXTERION® Slides. Please refer to the table in the section “General information coated slides” in order to find the appropriate coating chemistry for your specific application.
Product details
High quality glass substrate
The ultra flat, glass slide is manufactured from low auto-fluorescent borosilicate glass with the dimensions 75.6 mm x 25.0 mm x 1 mm. The uniform flatness of the borosilicate glass ensures highly reproducible contact printing and scanning across the wells. The glass slides are partitioned into 16 wells by an ultra-hydrophobic patterning layer. The dimensions and locations of the wells are fully compatible with standard microarray printing parameters.
QQ截图20160725171738
16-well silicone superstructure and sealing strip
The optional superstructure is self-adhesive, and adheres to the 16-well patterning of the glass slide, increasing the well volume to between 30 and 130 μL. Placing the adhesive on the superstructure rather than on the glass slide, avoids the risk of adhesive contamination in the wells. The clear selfadhesive sealing strip seals all the individual wells during hybridization preventing evaporation and cross contamination. If necessary, the superstructure and sealing strip may be removed prior to scanning.
!! Attention: Please store superstructures flat, and do not bend as performance may be impaired !!
NEXTERION® IC-16
This is a reusable 16-well incubation chamber consisting of a flexible, black silicon superstructure held within a high quality, black anodized aluminium holder. The silicone superstructure is tightly held against the glass slide surface by two aluminium plates to create a leak-proof seal around each well. The press-fit silicone superstructure eliminates the need for adhesives that are autofluorescent, and can increase background signal of the slide coating. The superstructure forms sixteen, 7 by 7 mm wells with 9 mm center-to-center spacing, in a 2 x 8 format (identified as 1-2 and A–H). It is ideal for use with multi-channel pipettes or automated liquid handling systems. The chamber is designed to be re-usable, replaceable components are available to maximise the usable life.
Note: The 16-well superstructure is asymmetric, so for the correct orientation, ensure that the wider well wall side of the superstructure is fitted into the upper plate, and the thinner portion is against the glass slide surface.
Packaging and storage
NEXTERION® MPX slides are available as 5-slide packs sealed in stable plastic boxes under an inert atmosphere. The slides are ready-to-use from the box. The exact shelf life of the slides is determined by the coating and is indicated on the external packaging. The 16-well superstructures are not included with the slides and must be ordered separately.
Accessories
Product
Item number
Pieces per pack
NEXTERION® MPX-4 tray
1180496
1
NEXTERION® 16-well self-adhesive superstructure and sealing strip
1178061
5
NEXTERION® IC-16
1 x Re-usable 16-well Incubation chamber consisting of lower tray (in black aluminium), upper plate (in black aluminium), 16-well black silicone superstructure, and four corner screw fasteners.
1262705
1
NEXTERION® IC-16s
16-well black silicon superstructure for use in the NEXTERION® IC-16 incubation chamber
1262706
1
肖特集团是全球领先的特种玻璃及相关特种材料、元件和系统制造公司。公司创始人Otto Schott先生于1887年发明了抗化学侵蚀的硼硅酸盐玻璃,能耐高温及温度骤变,并在1938年注册了商标DURAN ™(杜安),125余年以来高硼硅玻璃已成为高品质实验室玻璃器皿的材料标准。集团目前拥有约17,000名员工,肖特集团的主要市场涉及医药、生命科学、光学、家用电器、新能源、航空铁路交通以及建筑行业等领域。2010/2011财年全球销售额近29亿欧元。
Duran™(杜安)主要产品:
实验室试剂瓶(蓝盖瓶)
配套瓶盖及连接系统
容量瓶
烧杯
烧瓶
培养试管
培养皿
移液管
滴定管
干燥器
上海市虹梅路1801号凯科国际大厦301室
