美国Hausser Bright-Line血球计数板
美国Hausser scientific血球计数板,霍华德霉菌计数板,准确计算白细胞、红细胞、血小板、组织培养细胞、细菌和精子
The Bright-Line Hemacytometer is of one piece construction, ensuring long term durability and accuracy. An H-shaped moat forms two counting areas, or plateaus. A "V" slash at the loading side of each plateau facilitates charing and reduces the possibility of overflow into the moat. Each plateau features enhanced Neubauer rulings. The ruled surface is 0.1mm below the cover glass, limiting the volume of blood or fluid over a square mm at 0.1cu.mm and over each of 400 squares (within the central square mm) to 0.00025 cu. mm. Contact of the flat, polished cover glass surfaces with cover glass supports produces an exact volume of fluid over the counting area. The difference in surface tension characteristics between the metallic surface on the chamber and the polished cover glass assures smooth capillarity for precise loading and more even cell distribution.
Directions for Use用法:
Bright-Line / Dark-Line Counting Chambers Catalog Numbers: 3100, 3110, 3200, 3500, 1490, 1492, 1475, & 1483
Usage: Cell Counts
Cell Depth: 0.100mm +/- 2% (1/10mm)
Volume: 0.1 Microliter
Ruling Pattern: Improved Neubauer, 1/400 Square mm
Rulings cover 9 square millimeters. Boundary lines of the Neubauer ruling are the center lines of the groups of three. (These are indicated in the illustration below.) The central square millimeter is ruled into 25 groups of 16 small squares, each group separated by triple lines, the middle one of which is the boundary. The ruled surface is 0.10mm below the cover glass, so that the volume over each of the 16 small squares is .00025 cubic mm.
The number of cells per cubic millimeter =
Number of cells counted per square millimeter X dilution (if used) X 10
The number of cells per milliliter =
Number of cells counted per square millimeter X dilution (if used) X 10,000
One (1) Milliliter = 1000 cubic millimeters (cu mm)
One (1) Microliter (ul) = One (1) cubic millimeter (cu mm)
To clean the counting chamber: After completing the count, remove the cover glass and clean the counting chamber with water or a mild cleaning solution (10% solution of bleach). Dry the counting chamber with a soft cloth or wipe, or rinse with acetone.
货号 产品描述
3110 美国Hausser Bright-Line血球计数板,仅Counting chamber
3100 美国Hausser Bright-Line血球计数板,含Counting chamber、2盖玻片
3120 美国Hausser Bright-Line血球计数板,套装
3102 Chamber with 2 cover glass (no grid)
3200 Phase Counting Chamber w/2 cover glass (used with Phase microscope)
5000 备用Cover Glass
上海新领生物科技发展有限公司是集全球多个研制、开发、生产、规模销售及生物技术开发的厂商,在美国东西海岸都有公司和仓库 可海外代购 在上海联合销售与服务而设立的具有独立法人资格的综合性公司。本公司不仅为用户提供知名厂商在实验方面的强势产品。同时与国内外各大优秀企业合作,得到各实验室器材厂商的全力支持,为用户在生物实验室仪器和器材方面提供全面而优质的服务。本公司为客户提供生物实验室的各种仪器维修保养业务: 冷冻干燥机、真空离心浓缩仪、冷冻离心机、通用离心机、高压灭茵器、恒温水浴、摇床、真空泵、制冰机、低温冰箱、冷却水循环器eppendorf 各种离心机 雷勃LabsystemsMK3、伯乐Bio-rad680、宝特Elx-800 808、奥地利安图斯2010、伯乐Bio-rad1575、宝特Elx-50洗板机 BIORAD pcr仪 t100 s1000 c1000 CFX96 QX200 ABI7500 7300 Veriti 等系列产品。
另外可国外代购 各类试剂耗材 目前 BD 耗材做的比较多
BD 试剂
1, 货号231141, M. Tuberculosis H37 Ra, Desiccated
BD 耗材
1, 货号305215, Needle Admix Nokor 18X1-1/2 Tw
2. 货号309628, 1mL Syringe Only, Luer-Lok Tip
3. 货号309657, 3mL Syringe Only, Luer-Lok Tip
4. 货号309646, 5mL Syringe Only, Luer-Lok Tip
5. 货号309604, 10mL Syringe Only, Luer-Lok Tip
6. 货号302832, 30mL Syringe Only, Luer-Lok Tip
7. 货号305165, NEEDLE, 21 g x 1'
8. 货号305195, Regular Bevel Needles, 18G x 1”
9, 货号305110, 26 G x 3/8 in. BD general use sterile hypodermic needle. Regular wall,
10. 货号305199, BD PrecisionGlide Single-use Needles Short Bevel - Regular Wall ; Pack of 100
11. 货号309659, BD Slip Tip Sterile Syringes
12. 货号305559, BD Safety-Lok Syringes
单位名称: |
603 Room, Xinwu Building, No.698 Guangzhong Road, Jing an District, Shanghai, China.
联系电话: |
Email: |
