医学检验仪器
美国模体实验室ECTPHAN 330模体
ECTPHAN 330
进口
美国模体实验室
ECTPHAN 330
The ECTphan™模 体是一个圆柱形的,液体填充的容器,可进行单光子发射断层摄影(SPECT)系统的质量监测的各种测试。模体可用来评估以下的SPECT系统参数:重构的 均匀性,空间分辨率,低对比度分辨率,像素尺寸,切片宽度和旋转中心(COR)。此外,ECTphan™幻影数据适合于上面列出的系统参数的计算机分析。
Configurations: The phantom lends itself to a number of user configurations The phantom has an end plate with 4 threaded holes (one in the center and three in a radial pattern)  that can be filled with fillable ‘hot’ or ‘cold’ solid low contrast inserts. The contrast inserts can be replaced by plugs when not needed or to increase the uniformity area.  A point source holder can be positioned at the phantom center for measurements of PSF, MTF and center of rotation. The test plate can also be removed easily to create a larger uniformity area.
Test-Summary
The ECTphan™ phantom consists of three main test areas: the test plate, a uniformity area and the end plate for inserts.
  • Test Plate
      - Pixel Size
      - Slice Width
      - Spatial Resolution
  • Uniformity Section
      - Integral Uniformity
      - Noise Statistics
  • End Plate
      - Low Contrast Measurements (‘Hot’ or ‘Cold’)
      - PSF
      - MTF
      - Center of Rotation.
ECTPHAN 330模体
Phantom Components
Test Plate: The test plate has 4 ‘hot’ holes spaced 120mm apart for measuring pixel size in X and Y axes. Four bar patterns up to 2.5lp/cm are available for visual evaluation of spatial resolution. Two opposed angled ramps provide the ability to measure slice thickness.
Uniformity Section: The uniformity section provides a 20cm diameter area that can be visually examined for artifacts and non-uniformities. The integral non-uniformity and RMS noise statistics can be calculated from the pixel values in the area.
End Plate: The end plate has threaded holes to mount the point source holder and the ‘hot’ and ‘cold’ low contrast inserts. When tests are not needed the holes may be plugged with SMR 168 plugs.
The point source holder can be positioned and imaged at the phantom center. The holder is designed for imaging the point sources in air and with scatter. From the reconstructed point source data, a point spread function (PSF) is generated and the full width at half maximum (FWHM) and full width at tenth maximum (FWTM) values can be measured. The modulation transfer function (MTF) may be generated from the PSF if software is available.
The external point source insert can be used to evaluate tilt of the camera heads. This is done by visual inspection of a rotating cine of the point source projection data and noting any significant change in the y-axis position of the point source.
The reconstructed point source data can also be used to demonstrate errors in the center of rotation (COR). Items to note on the reconstructed data are point source width in three dimensions, shape, and indications of streaking or other artifacts.
The ECTphan™ Phantom is supplied with either 3 solid or 3 hollow low contrast inserts. These inserts can be threaded into the phantom end plate in a radial pattern 75mm off the center axis, or one can be placed in the phantom’s central axis. The inserts are comprised of three sections: 10, 15, and 20mm in diameter and 40mm long.
The hollow inserts are filled through a port at the threaded end. The hollow inserts are used to simulate “hot” lesions. The solid inserts are used to simulate “cold” lesions.
Note: ECTphan™ phantoms are not supplied with contrast fill solutions. Customers are required to add their own fill solutions.
深圳市展业达鸿科技有限公司
联系人:吕先生   手机:15920060912    QQ:8329063  邮箱:15920060912@139.com
办公地址:深圳市福田区八卦四路22号华晟达大厦7楼5A
深圳市展业达鸿科技有限公司核心业务是满足对质量、货期和售后服务要求严格的行业用户,为客户提供测试设备及相关器材的供应服务。创业至今,与国内外著名仪器、仪表生产厂商进行稳固而广泛的技术与销售合作,真正帮助企业"提高采购效率,降低采购成本"。
我们坚持“客户是根,服务至上;创新为本,随需而变”的服务宗旨;
我们坚持“市场指引销售,技术提升销售”的营销理念;
我们坚持“以诚感人、以质取人、以信待人”的经营方针;
结合市场变化和客户要求,致力于同客户建立长期的合作伙伴关系,为客户提供“技术分析、产品选型、人员培训和售后服务”等一体化的系统服务,以专业品质与诚信服务赢得行业认可和客户青睐。
深圳市展业达鸿科技有限公司
联系人:朱小姐  手机:13530850680   QQ:8329063  邮箱:8329063@qq.com
办公地址:深圳市福田区八卦岭工业区615栋419
深圳市福田区八卦岭工业区615栋419
