其它各类仪器
ABB\21662018-1
ABB\21662018-1
进口
瑞典
22136950-206 Ball b
21662018-2 Clamp21662018-7 Clamp21662018-8 Clamp21662018-9 Clamp21662055-1 Cable straps, outdoors21662055-3 Cable straps, outdoors21662055-4 Cable straps, outdoors21662055-6 Cable straps, outdoors21662057-1 Mounting base, indoors鸿飞达自动化科技---机器人配件专家21662057-4 Mounting base, indoors21662057-5 Mounting base, indoors21662058-2 Mounting base, outdoors21662058-4 Mounting base, outdoors21662421-1 Bushing21662421-2 Bushing21662421-5 GROMMET21662421-6 Bushing2166548-7 Plastic clamp2166619-2 Mounting base21670006-50 Latch21670072-43 LOCKING DEVICE21670072-48 KEY SF 10121670072-54 LOCK WITH KEY21670072-56 KEY SF 20321670072-57 LOCK WITH KEY21670072-58 LOCK WITH KEY2169071-1 Straing frame2171205-134 Hose clip2171205-94 Socket2171212-19 TURNING DISC鸿飞达自动化科技---机器人配件专家2171212-22 TURNING DISC21720492-104 SENSOR PLATE21720492-109 FLANGE21720492-285 MOUNTING PLATE21720492-312 Stop Spacer21720492-39 STOP LUG21720492-419 BRACKET21720492-475 BRACKET21720492-53 HOLDER21720932-65 Cover plate2172476-1 ANGLE CLAMP鸿飞达自动化科技---机器人配件专家21740022-111 SYNCHRONISATION BAR21740022-150 BRACKET21750034-122 BRACKET21750034-127 Yoke USA21750034-59 Fastener21750034-81 CAM2181125-1 TOOTH BELT21841621-7 Middle ring21850438-4 LINEAR BALL BEARING KBO 3068PP21850441-1 ROLLER BLOCK21850442-3 LINEARSTEERING21850442-9 Guiderail 25鸿飞达自动化科技---机器人配件专家21850443-1 CARRIAGE21850445-1 BALL ELEMENT21850445-4 CARRIAGE21850446-1 STAR21850446-10 LINEAR SUPPORT21850446-2 LINEAR GUIDE21850446-3 STAR2185417-114 SLIDING SURFACE2185417-76 CAM CURVE2185417-78 SEALING RING2185417-82 Slipcloth2185576-4 BALL RETURN ELEMENT2185577-4 BALL RETURN ELEMENT2185579-G BALL ELEMENT2185590-1 SEALING RING2185590-2 3EALING RING2185590-3 SEALING RING21860001-10 X-RING21860001-11 GASKET RING21860001-12 QUADRING21860001-9 X-RING21860010-1 ROTOGLIDE RING21860010-10 ROTOGLYDE RING鸿飞达自动化科技---机器人配件专家21860010-5 ROTO GLYD RING21860010-8 ROTO GLYD RING21860010-9 ROTO GLYDE RING2186007-1 VARISEAL M2186007-2 VARISEAL M2186007-3 VARISEAL M2186007-5 VARISEAL M2186677-14 RING2186690-E SEALING KIT21880186-1 HANDLE21880286-3 Guard/bracket2192159-27 COMPRESSION SPRING2192232-1 COMPRESSION SPRING2192232-2 COMPRESSION SPRING2193010-5 COMPRESSION SPRING21952011-67 Disk spring21952011-77 Disc spring21952011-93 Disc spring2196065-23 SEGMENT鸿飞达自动化科技---机器人配件专家2196065-31 BUFFER2196065-32 BUFFER2196065-49 BUMPER, RUBBER2196065-52 Mech Stop Ax.522130047-4 Ball bearing22130084-2 BEARING FOR SLIPRING22131000-203 Self-align ball bearing22131905-1 Roller bearing22131905-21 Clamping sleeve22131905-23 Shaft Washer22131905-24 Case Washer22131905-26 Shaft Washer22131905-27 Case Washer鸿飞达自动化科技---机器人配件专家22131923-4 CAM ROLLER22131926-10 GROOVE BALL BEARING22131926-2 GROOVE BALL BEARING2213253-12 Ball bearing2213253-2 Radial ball bearing2213253-5 Ball bearing2213253-8 Ball bearing2213256-1 TAPER ROLLER BEARING2213256-2 Taper roller bearing2213256-4 TAPER ROLLER BEARING2213256-5 TAPER ROLLER BEARING2213256-7 Taper roller bearing2213259-3 Ball bearing four point鸿飞达自动化科技---机器人配件专家2213298-5 Needle Roller Bearing2213298-6 Side Washer2213298-7 Needle bearing2213298-8 Needle bearing22133000-204 Taper roller bearing22133802-11 Taper roller bearing22133802-8 Taper roller bearing22134998-6 Washer22136000-203 Deep groove ball bearing22136000-301  eep groove ball bearing
福建鸿飞达自动化科技有限公司
福建鸿飞达自动化科技有限公司位于沿海福建省会中心,依托福州市马尾保税区报关优势,专业从事全球各类工业自动化产品及技术进出口,长年与欧美,北美等全球知名工业厂商建立起稳定的合作关系,产品直接国外进口,省掉中间环节,为广大企业用户节约开支!目前公司业务遍布全国各省市,经过多年的服务,总结出专为系统用户服务的成熟模式,实现服务的人性化、流程的简单化以及管理的规范化,有效帮助客户延长电气设备的使用周期,降低运营成本,控制停产风险、提高生产效率!
公司专注钢厂、电厂、水泥、化工、造纸、CNC数控机床等行业,主要供应产品:DCS系统卡件、各类进口机器人备件、伺服控制器、电源模块等。我们有强大的供货物流体系,优势齐全的各大品牌备货,诚信至上的经营理念,做大做强的精神、努力打造成为国内最强大多最多元化的自动化产品供应商!
畅销品牌:美国霍尼韦尔Honeywell:TDC2000、TDC3000ESD、S9000等系列板卡!
美国AB全系例如:1771、1746、1756、1785、等PLC模块!
美国福克斯波罗FOXBORO:TRICONEX系统、CUP、I/A、I/O系列板卡!
德国西门子SIEMENS:S5S7TI等停产DCS系统PLC板卡!
德国REXROTH力士乐伺服驱动、伺服电机及各类控制板卡!
瑞典ABB机器人DSQC、3HAC全系备件。460、S500S800、MOD全系列板卡!
德国E+H流量计、GEFanuc伺服驱动电源模块及板卡!
日立HITACHI伺服驱动器,YASKAWA安川伺服驱动!
美国西屋Westinghouse模块板卡、美国瑞恩RELIANCE变频及模块等!
福建省福州市自贸区江滨东大道68-1号蓝波湾2号楼17层
