机器人
鸿飞达自动化科技---机器人配件专家
鸿飞达自动化科技---机器人配件专家
进口
ABB/瑞典
2213844-1 BALL BEAR
2213851-3 Ball bearing2213862-12 Axial washer2213862-14 Axial washer2213862-15 Axial washer2213862-18 Needle bearing2213862-19 Axial washer2213862-2 AXIAL NEEDLE ROL. BEARING2213862-20 Needle bearing2213862-3 SHAFT WASHER鸿飞达自动化科技---机器人配件专家2213862-4 Needle roller bearing2213862-5 Washer2213862-7 Needle bearing2213862-8 Axial washer2213874-12 BALL2213874-9 BALL2213875-1 Ball bearing four-point2213894-1 Needle bearing22160085-5 Nilos ring22160086-4 Sealing (Nilos) 鸿飞达自动化科技---机器人配件专家22160089-1 RING FOR COVER22160089-2 SEALING RING22160089-9 SEALING RING22162051-12 V-RING22162051-18 V-ring22162051-6 V-ring22162051-70 V-ring22162054-1 SEALING RING (V-RING)2216261-10 PACKING RING2216261-14 Sealing ring2216261-15 Sealing鸿飞达自动化科技---机器人配件专家2216261-16 Sealing2216261-18 Sealing2216261-6 Sealing2216262-10 Sealing2216262-15 Sealing2216262-17 Sealing2216262-18 Sealing2216262-19 Sealing2216263-9 Sealing2216264-10 V-Ring2216264-14 Cover plug2216264-16 Sealing ring2216264-22 SEALING RING2216264-23 SEALING RING2216264-24 Sealing2216264-27 SEALING RING2216264-5 RINGS HOLDER2216264-7 Cover2216294-2 SEALING RING2235038-10 Turning shaft2238047-1 SHAFT JOURNAL2239055-P TUBULAR SHAFT2239056-17 SHAFT2239056-20 STUD2239056-61 SHAFT鸿飞达自动化科技---机器人配件专家2239056-62 SHAFT2284260-A BRAKE2284261-P BRAKE2295213-13 SEGMENT2295213-26 RING2295213-331 SYNC CAM2295213-51 Ring23210848-14 GEAR ROD23210848-8 GEAR ROD23210849-7 PINION23210885-22 PINION鸿飞达自动化科技---机器人配件专家2322121-L GEAR23340001-10 GEARBOX 440023340001-14 GEARBOX23340001-16 GEARBOX23340001-17 GEARBOX23340001-7 GEARING23340001-8 GEAR TRANSMISSION2399058-AB Gearbox2515278-B Hydraulic hose2515278-F Hydraulic hose2522101-3 Plug2522108-5 Plug25222021-109 Plug25222021-113 Plug25222101-15 Protective hood25222101-17 Protection hood25222101-5 Protection hood25222101-8 Protective hood25222101-9 Protective hood2522253-4 Sealing plug2522290-20 SEALING COVER2522290-21 SEALING COVER2522290-22 SEALING COVER2522290-24 SEALING COVER鸿飞达自动化科技---机器人配件专家2522290-25 SEALING COVER2522290-26 SEALING COVER2522290-29 GASKET2522290-30 GASKET2522290-32 Gasket2522291-6 OIL PLUG2522291-7 Push Button Protector2522726-11 Protection plug2522726-18 Protective hood2522726-3 Protective hood2522726-4 Protective hood2528448-3 Plug2529168-10 Adapter2529168-11 ADAPTER/NIPPLE2529168-35 NIPPLE2529168-37 NIPPLE2529168-41 NIPPLE2529168-44 NIPPLE2529168-48 Pipe coupling2529168-53 INLET2529168-54 BULKHEAD FITTING2529168-56 ADAPTER鸿飞达自动化科技---机器人配件专家2529171-4 Connection25291920-2 Plug25291921-2 REDUCING NIPPLE25291921-3 REDUC.NIPPLE25291921-7 REDUCING NIPPLE25291926-4 Svivel joint25291926-7 HOLE SCREW25291928-3 BREAKER COUPLING25291936-4 HOSE COUPLING25291937-1 PLUG25292031-103 Hose clip25292031-110 Hose clip25292084-32 Hose nipple2529222-1 HOSE COUPLING2529222-2 STRAIGHT CONNECTION2529256-1 Nipple2529256-3 Nipple鸿飞达自动化科技---机器人配件专家
福建鸿飞达自动化科技有限公司
福建鸿飞达自动化科技有限公司位于沿海福建省会中心,依托福州市马尾保税区报关优势,专业从事全球各类工业自动化产品及技术进出口,长年与欧美,北美等全球知名工业厂商建立起稳定的合作关系,产品直接国外进口,省掉中间环节,为广大企业用户节约开支!目前公司业务遍布全国各省市,经过多年的服务,总结出专为系统用户服务的成熟模式,实现服务的人性化、流程的简单化以及管理的规范化,有效帮助客户延长电气设备的使用周期,降低运营成本,控制停产风险、提高生产效率!
公司专注钢厂、电厂、水泥、化工、造纸、CNC数控机床等行业,主要供应产品:DCS系统卡件、各类进口机器人备件、伺服控制器、电源模块等。我们有强大的供货物流体系,优势齐全的各大品牌备货,诚信至上的经营理念,做大做强的精神、努力打造成为国内最强大多最多元化的自动化产品供应商!
畅销品牌:美国霍尼韦尔Honeywell:TDC2000、TDC3000ESD、S9000等系列板卡!
美国AB全系例如:1771、1746、1756、1785、等PLC模块!
美国福克斯波罗FOXBORO:TRICONEX系统、CUP、I/A、I/O系列板卡!
德国西门子SIEMENS:S5S7TI等停产DCS系统PLC板卡!
德国REXROTH力士乐伺服驱动、伺服电机及各类控制板卡!
瑞典ABB机器人DSQC、3HAC全系备件。460、S500S800、MOD全系列板卡!
德国E+H流量计、GEFanuc伺服驱动电源模块及板卡!
日立HITACHI伺服驱动器,YASKAWA安川伺服驱动!
美国西屋Westinghouse模块板卡、美国瑞恩RELIANCE变频及模块等!
福建省福州市自贸区江滨东大道68-1号蓝波湾2号楼17层
