振荡培养箱
KUHNER摇床
KUHNER摇床
进口
kuhner
瑞士阿道夫科耐Adolf Kuhner
询价13816550546
IST1-4-X 是一款能替代恒温房而设计的大容量柜式摇床,一台柜式摇床可装4-5个完全独立的摇动单元,每个摇动单元间的高度可以任意调节。腔体内部包括驱动马达的外壳都为全不锈钢材质。具备低能耗的优化制冷、加热系统。可选加热、制冷、湿度控制、二氧化碳控制的功能和UV、光照拉出式夹盘、静止盘等配件。
• Very reliable electromagnetic direct drives 非常可靠的磁力驱动
• All stainless steel interior 全不锈钢内腔
• Foamed insulation  无空隙绝缘泡沫保温材料
• Hermetically sealed double glazed windows  双层密闭玻璃视窗
• User-friendly operation 友好操作界面
• Energy conscious drives and cooling system 低能耗驱动及制冷系统
•(for each parameter it’s own control) 每一位参数独立控制
A 5 YEAR WARRANTY   5 年质保
Technical data 技术参数 SMX1600 SMX1601 SMX1603
Refrigerator 制冷 no yes * yes *
Humidity control 温度控制 no no yes
Temperature minimum 最低温度 ambient + 10°C ambient - 15°C ambient - 15°C
Temperature maximum 最高温度 80°C 80°C 80°C
Humidity maximum 最大湿度 - - 85 % r.h.
Power consumption 功率 < 1700W < 2000W < 2600W
Machine (incubator) 设备参数
Volume 容积 800 litre
Weight (without SF-X) 重量 520kg (with cooling)
Illumination 照明 Halogen
Operating menu in 操作界面 English, French, German, Italian, Spanish 英文,法文,德文,意大利文,西班牙文
Interface, standard 标准界面 CAN-Bus
Interface, optional 选择界面 USB, Ethernet, digital, analogue
Ambient temperature 环境温度 10°C up to 35°C
Temperature
Setting, digital 0.1°C
Accuracy, absolute ± 0.30°C (37°C)
Principle of sensor Pt-100
Power of heating 1000W
Power of cooling * 250...420W
Air circulation Air circulation
Shaking unit SF-X
(up to 5 units)
(SMX1610)
Tray, size F (800x420mm)
Loading, maximum 25kg
Setting, digital 1 rpm
Accuracy, absolute ± 0.1 rpm
Timer 1s ... 999h
Acceleration controlled
Active brake adjustable
Stop on position adjustable
Shaking unit-weight 55 kg each. (max. 5 units)
Shaking motion Speed
* orbital, Ø 12.5mm 20...500 rpm
* orbital, Ø 25.0mm 20...400 rpm
* orbital, Ø 50.0mm 20...300 rpm
* linear, 12.5mm 20...400 rpm
* linear, 25.0mm 20...300 rpm
* linear, 50.0mm 20...200 rpm
* can be changed
Humidity (SMX1603)
maximum at 25..55°C 85% r.h.
Setting, digital 1% r.h.
Accuracy, absolute ± 2% r.h.
Principle of sensor capacitive
Water refill automatic
Water heater 300W
Door heater 220W
CO2 (SMX1034)
Principle of sensor Infrared, NDIR
Measuring range 0...20% CO2
Setting, digital 0.1%
Accuracy, absolute ± 0.42% at 20% CO2
Non-linearity < 0.1%
Temperature range 5...60°C
CO2-supply max. 1 bar overpressure
Mains: (SMX1034)
SMX1021: 220-240V / 50-60Hz
SMX1022: 190-210V / 50-60Hz
上海帝博思生物科技有限公司2013年成立于上海,主要目的是为了服务生物科学,医学,微生学物等各行业,公司提供各类产品包括:KUHNER,IBS(INTEGRA),Satorious,compodock,miele,GONOTEC等仪器,各类产品公司均有大量现货。经过数年的磨砺,公司开发出自有品牌:帝博思(TIPS),近年来市场占有率迅猛增长。我公司愿携手各界,共同进步,欢迎新老客户来公司参观指导。
上海市奉贤区望园南路1588弄1号绿地未来中心A3 2110室
