生化试剂
LONZA内毒素检测(LAL 试剂)
LONZA内毒素检测(LAL 试剂)
LONZA内毒素检测(LAL 试剂)
进口
LONZA内毒素检测(LAL 试剂)
LONZA内毒素检测(LAL 试剂)
始于1994年的毕特博生物(毕龙转基因 http://www.bilong.com)是中国大陆第一家把LONZA(原Cambrex)引入中国大陆市场的代理商,20多年来毕特博生物一直致力把Lonza公司产品推介给中国各科研机构。
Lonza内毒素检测试剂目录表
终点荧光分析法鲎试剂
PyroGene®重组因子C分析
目录号   单位 价格
50-658U PyroGene 192 Test Kit EA 询价
50-658NV Pyrogene Bulk Kit 2880 Test Kit EA 询价
胶凝法鲎试剂
PYROGENT® 胶凝LAL
目录号   单位 价格
N194-03 PYROGENT 250 Tests 0.03 EU/ml Sens KT 询价
E194L-03 PYROGENT 25 VIALS/KIT 0.03 EU/ML KT 询价
E194U-03 PYROGENT 100 VIALS/KIT 0.03 EU/ML KT 询价
N189-06 PYROGENT 25 Single Tests 0.06 EU/ml Sens KT 询价
N183-06 PYROGENT 80 Tests 0.06 EU/ml Sensitivity KT 询价
N194-06 PYROGENT 250 Tests 0.06 EU/ml Sens KT 询价
E194L-06 PYROGENT 25 VIALS/KIT 0.06 EU/ML KT 询价
E194U-06 PYROGENT 100 VIALS/KIT 0.06 EU/ML KT 询价
N189-125 PYROGENT 25 Single Tests 0.125 EU/ml Sen KT 询价
N183-125 PYROGENT 80 Tests 0.125 EU/ml Sens KT 询价
F211U-125 PYROGENT SINGLE BULK KIT, 0.125 EU/ML KT 询价
N194-125 PYROGENT 250 Tests 0.125 EU/ml Sens KT 询价
E194L-125 PYROGENT 25 VIALS/KIT 0.125 EU/ML KT 询价
E194U-125 PYROGENT 100 VIALS/KIT 0.125 EU/ML KT 询价
N189-25 PYROGENT 25 Single Tests 0.25 EU/ml Sens KT 询价
N184-25 PYROGENT 250 Tests 0.25 EU/ml Sens KT 询价
F245U-06 PYROGENT BULK KIT 0.06 EU/ML SENSITIVITY KT 询价
F245U-125 PYROGENT BULK KIT 0.125 EU/ML SENSITIVE KT 询价
E209L-25 Pyrogent Bulk Kit 0.25 EU/ml Sensitivity KT 询价
E209U-25 Pyrogent Bulk Kit 0.25 EU/ml Sensitivity KT 询价
PYROGENT® Plus胶凝LAL
目录号   单位 价格
N294-03 PYROGENT Plus 200 Tests 0.03 EU/ml Sens KT 询价
N494-03 PYROGENT Plus 4000 Tests 0.03 EU/ml Sens KT 询价
N289-06 PYROGENT Plus 24 Single Tests 0.06 EU/ml KT 询价
N283-06 PYROGENT Plus 64 Tests 0.06 EU/ml Sens KT 询价
N294-06 PYROGENT Plus 200 Tests 0.06 EU/ml Sens KT 询价
N494-06 PYROGENT Plus 4000 Tests 0.06 EU/ml Sens KT 询价
N289-125 PYROGENT Plus 24 Single Tests 0.125EU/ml KT 询价
N283-125 PYROGENT Plus 64 Tests 0.125 EU/ml Sens KT 询价
N294-125 PYROGENT Plus 200 Tests 0.125 EU/ml Sens KT 询价
N494-125 PYROGENT Plus 4000 Tests 0.125 EU/ml Sen KT 询价
N289-25 PYROGENT Plus 24 Single Tests 0.25 EU/ml KT 询价
N284-25 PYROGENT Plus 200 Tests 0.25 EU/ml Sens KT 询价
N288-25 PYROGENT Plus 4000 Tests 0.25 EU/ml Sens KT 询价
PYROGENT® Ultra 胶凝LAL
目录号   单位 价格
N594-03 PYROGENT Ultra 200 Tests 0.03 EU/ml Sens KT 询价
N594-06 PYROGENT Ultra 200 Tests 0.06 EU/ml Sens KT 询价
N594-125 PYROGENT Ultra 200 Tests 0.125 EU/ml Sen KT 询价
动态浊度法鲎试剂
PYROGENT® - 5000 动力学浊度法
目录号   单位 价格
N383 PYROGENT-5000 100 Test Kit KT 询价
N384 PYROGENT-5000 200 Test Kit KT 询价
N588 Pyrogent-5000 Bulk Kit 2250 Test Kit KT 询价
N688 Pyrogent-5000 Bulk Kit 4500 Test Kit KT 询价
T50-300L Pyrogent-5000 Bulk Kit 25 Vials/Kit KT 询价
T50-300U Pyrogent-5000 Bulk Kit 100 Vials/Kit KT 询价
T50-600L Pyrogent-5000 Bulk Kit 25 Vials/Kit KT 询价
T50-600U Pyrogent-5000 Bulk Kit 100 Vials/Kit KT 询价
T50-600 Pyrogent-5000 Lysate Vial 10.4 ml VIA 询价
7460 Endotoxin Vial for Pyrogent - 5000 VIA 询价
7460L Endotoxin, E. coli O55:B5 25 Vials/Kit KT 询价
B50-300L PYROGENT-5000 RECONSTITUTION BUFFER KT 询价
B50-300U PYROGENT-5000 RECONSTITUTION BUFFER KT 询价
B50-600L PYROGENT-5000 RECONSTITUTION BUFFER KT 询价
B50-600U PYROGENT-5000 RECONSTITUTION BUFFER KT 询价
动态显色法鲎试剂
Kinetic-QCL® 动态显色法
目录号   单位 价格
50-650U Kinetic-QCL 192 Test Kit EA 询价
K50-643U Kinetic-QCL Bulk Kit 100 Vials/Kit KT 询价
K50-643L Kinetic-QCL Bulk Kit 25 Vials/Kit KT 询价
50-650H Kinetic-QCL Bulk Kit 2400 Test Kit EA 询价
50-650NV Kinetic-QCL Bulk Kit 2040 Test Kit EA 询价
E50-643 Endotoxin, E. coli O55:B5 for K-QCL VIA 询价
E50-643L Endotoxin, E. Coli O55:B5 25 Vials/Kit KT 询价
终点显色法鲎试剂
QCL-1000® 终点显色法
目录号   单位 价格
50-647U QCL-1000 120 Test Kit EA 询价
50-648U QCL-1000 300 Test Kit EA 询价
E50-640 ENDOTOXIN FOR QCL-1000 1 VIAL VIA 询价
鲎试剂附属产品
内毒素
目录号   单位 价格(¥)
00193783 Endotoxin, E. coli O55:B5 KT 询价
N185 Endotoxin, E. coli O55:B5 2.5 mg/vial KT 询价
N186 Endotoxin, E.coli O55:B5 KT 询价
C50-500 Endotoxin, Vial for Single Test Vial VIA 询价
E700 USP REFERENCE STANDARD ENDOTOXIN VIA 询价
7360 Endotoxin, E. coli O55:B5 Vial Pyrogent VIA 询价
7360L Endotoxin, E. coli O55:B5 25 Vials/Kit KT 询价
内毒素挑战管\指示剂
目录号   单位 价格
00192568 Endotoxin Challenge Vials 25 vials/kit KT 询价
LAL反应水\无热原水\细菌内毒素检查用水
目录号   单位 价格
W50-640 LAL Reagent Water- 30ml VIA 询价
W50-100 LAL Reagent Water - 100ml BOT 询价
W50-500 LAL Reagent Water - 500ml BOT 询价
W50-1000 LAL Reagent Water, 1000ml BOT 询价
无热原检测管
目录号   单位 价格
N205 Pyrogen-Free Test Tubes 10x75mm w/oCap PKG 询价
N201 Pyrogen-Free Test Tubes 10x75mm w/Caps PKG 询价
N207 Pyrogen-Free Dilution 13x100mm w/oCaps PKG 询价
Eppendorf® 吸头
目录号   单位 价格
25-415 EPPENDORF BIOPUR TIPS 200 UL BX 询价
25-416 EPPENDORF BIOPUR TIPS 300 UL BX 询价
25-417 EPPENDORF BIOPUR TIPS 1000 UL BX 询价
Tris缓冲液
目录号   单位 价格
S50-642 Tris Buffer,50mM Solution For Use w/ LAL VIA 询价
氯化镁溶液
目录号   单位 价格
S50-641 MgCl2, 10mM Solution For Use with LAL VIA 询价
PYROSPERSE®分散剂
目录号   单位 价格
N188 Pyrosperse Kit Dispersing Reagent KT 询价
LAL多孔板
目录号   单位 价格
25-340 LAL REAGENT GRADE MULTI-WELL PLATES CAS 询价
ß-G Blocker
目录号   单位 价格
N190 Beta-G-Blocker Kit KT 询价
Stepped Neutral Density Plate
目录号   单位 价格
25-342 Stepped Neutral Density Plate EA 询价
Ground aluminum block, with lid
目录号   单位 价格
25-038 ALUMINUM BLOCK W/LID EA 询价
试剂储存容器
目录号   单位 价格
00190035 Reagent Reservoirs, 10/pk PKG 询价
Inhibition Control
目录号   单位 价格
50-506U INHIBITION CONTROL 5 VIALS/KIT EA 询价
I211U INHIBITION CONTROL BULK KIT KT 询价
样品管
目录号   单位 价格
80-507L SAMPLE VIAL, PYROGEN-FREE 25/KIT KT 询价
80-507U SAMPLE VIAL, PYROGEN-FREE 100/KIT KT 询价
软件 、设备等
目录号   单位 价格
25-501 .WinKQCL 5 Software Package EA 询价
25-502 WinKQCL 5 Workgroup License EA 询价
25-503 WinKQCL 5 Reader License EA 询价
25-504 WinKQCL 5 Qualification Manual EA 询价
25-505 WinKQCL 5 Validation Package EA 询价
05105 BIOTEK READER BULB EA 询价
7260522 Universal test plate EA 询价
00196004 UPS-APC 1500VA w/ LCD EA 询价
00196005 4-Port Serial PCI Card EA 询价
25-315 BIO-TEK READER EA 询价
25-344 FLX800 READER USE W/PYROGENE KIT EA 询价
25-361 USB to Serial Port Converter EA 询价
LNOCODE WinKQCL LNO 1 Code Validity 1 year EA 询价
S50-640 Chromogenic Substrate Vial VIA 询价
00196171 75053 - Serial Communication Cable EA 询价
00196172 76053 - ELx808/FLx800 24V Power Supply EA 询价
00196174 3100340 - ELx808 340nm Filter EA 询价
00196175 3100405 - ELx808 405nm Filter EA 询价
00196441 7080500 - FLx800 Lamp Assembly EA 询价
00196453 7340506 - Lamp Socket/Cable Assembly EA 询价
00196455 7341000 - ELx808 Operator's Manual EA 询价
00196470 7343000 - ELx808 Shipping Box w/ Packing EA 询价
25-339S System Qualification EA 询价
00194692 ELX-GEN5 Validation Package EA 询价
00194693 ELX-GEN5 Secure Software EA 询价
00196135 ELx808 Qualification Package EA 询价
85-011-SND SND Plate Recertification EA 询价
85-012-SND SND Plate Recert. - Add Wavelengths EA 询价
25-443 All-in-One PC w/ BT kybd/mouse (US Eng) EA 询价
25-444 Color Laser Printer (US-Letter format) EA 询价
详见如下网页:
http://www.bitebo.com/a/gb2312/gongsixinxi/shichanghuodong/2017/0129/5788.html
北京毕特博生物技术有限责任公司
400热线:400-833-9299
电话:010-82015225 13366202681 张钰
QQ:1050524889
传 真:010-62015131
北京毕特博生物技术有限责任公司(Beijing Bitab Biotech Co.,Ltd)是一家成立于2001年(始于1994年的毕龙转基因),经营生命科学用品的高科技企业。全国最早的生物代理公司之一,多个国际知名品牌国内第一家代理。公司主要代理各大国际著名生物公司的试剂、仪器、设备和耗材等。同时提供各类生物技术服务、协助科研设计和数据处理、组织国内和国际学术会议、提供相关网络服务等。
目前,主要代理和经销的国外生物公司有:CryologicCorningLonza(原Cambrex)、MP Biomedicals(MP、Qbiogene、ICN)、ENZO Life Sciences (Alexis、Biomol、Enzo)、Axxora(Alexis)、Mobitec、Tharmac、Biotex、Randox、和Eurobiosciences(CD抗体)。产品涉及:细胞生物学、分子生物学、免疫学、食品与水质检测、实验室及医疗试剂、设备等。
MP Biomedicals生物医学公司是位于美国加利福尼亚州的知名生命科学和生物技术厂商。它致力于生命科学领域的基础研究和探索。目前它提供55000多种产品,是世界上能全面提供生命科学产品和临床诊断产品的唯一几家厂商之一。
lonza(原为美国Cambrex成立于1981年),是全球人类健康与生物科学产品最主要的供应商,同时还是饲料添加剂的生产商和动物健康/农业市场的媒介以及优质化学试剂的制造商。主要有细胞株、培养基、分子生物学产品、内毒素检测试剂等
Alexis公司是一家集生命科学试剂研发、生产和销售于一体的综合性私营企业,它已经在世界范围内成功建立了稳定的市场达10年之久,具备超强的管理体系和电子商务能力。Alexis公司总部在美国,并在英、德、瑞士均设有分部,便于试剂的运输和调配。此外,该公司还拥有资深的生物领域专家做为技术支持,并且代理其它品牌的一些生命科学领域主要研究方向的产品。
以色列Prospec公司是一家世界著名的重组细胞因子、生长因子、趋化因子、激素、病毒抗原蛋白、相关抗体的供应商。
ICN生物医学化学药品公司从1960年成立以来,随着其生物医学科研产品的开发和扩展,现在已经成为整个世界上生物技术科研产品和医学临床诊断产品的身居主导地位的供应者。ICN现在供应数千种化学药品、化学试剂、实验设备和诊断器械,能够满足整个生物技术领域的全部需求。
北京毕特博生物技术有限责任公司
400热线:400-833-9299
电话:010-82015225
传真:010-62015131
联系人:张钰
手机:13366202681
QQ:1050524889
公司微信号:毕特博生物
经理微信:13366202681
北京市海淀区北太平庄路月华轩2号院2号楼1901室
