环境监测仪器
美国2B Technologies公司臭氧分析仪
Model 202 Ozone Monitor™
进口
美国2B Technologies
Model 202
2B Technologies公司代理商,2B Technologies公司销售商。
The 2B Technologies Model 202 Ozone Monitor™ is designed to enable accurate and precise measurements of ozone ranging from low ppb (precision of ~1 ppb) up to 250,000 ppb (0-250 ppm) based on the well-established technique of absorption of UV light at 254 nm.  The Model 202 Ozone Monitor™ is lightweight (4.7 lb., 2.1 kg.) and has a low power consumption (12V DC, 0.33 amp, 5 watt) relative to conventional instruments and is therefore well suited for applications such as:
  • Vertical profiling using balloons, kites, RPVs and light aircraft where space and weight are highly limited
  • Long-term monitoring at remote locations where power is highly limited
  • Urban arrays of ground-based detectors
  • Personal exposure monitoring for studies of health effects of air pollutants
  • Environmental health and safety monitoring
  • Laboratory studies of the effects of ozone exposure on materials and organisms
Flash card memory is now provided standard on the Model 202 Ozone Monitor.
The Model 202 has been designated by the EPA as a Federal Equivalent Method (FEM): EQOA-0410-190.
Options
  • GPS for continuous logging of latitude, longitude, and altitude
  • Bluetooth for wireless data transmission
  • Rechargeable lithium-ion battery provides 12 hours of continuous operation
  • External particle filter
  • Serial-to-USB adapter
  • Cold-weather package (pump, lamp heater for use down to -20 degrees C)
  • High-altitude upgrade (pressure sensor for use up to 25 km altitude)
  • Long-life internal air pump
  • 4-20 mA analog current output
  • Rack-mount case configuration
Specifications
Measurement Principle UV Absorption at 254 nm
Federal Equivalent Method (FEM) Yes, EQOA-0410-190
Linear Dynamic Range 0 to 250 ppm
Resolution 0.1 ppb
Precision (1σ; rms noise) Greater of 1.5 ppb or 2% of reading
Accuracy Greater of 1.5 ppb or 2% of reading
Limit of Detection (2σ) 3.0 ppb
NIST-Traceable Calibration Yes
Measurement Interval 10 s (Data averaging options: 1 min, 5 min, 1 hr)
Flow Rate (nominal) ~1 Liter/min
Flow Rate Requirement >0.6 L/min
Baseline Drift < 2 ppb/day
< 5 ppb/year
Sensitivity Drift < 1%/day
< 3%/year
Measurement Time, Frequency 10 s, 0.1 Hz
Response Time, 100% of Step Change 20 s, 2 points
Averaging Times 1 min, 5 min, 1 hr
Internal Data Logger Capacity 16,383 lines (10-s meas. = 1.9 days; 1-min avg = 11 days; 5-min avg = 1.9 mo;
1-hr avg = 1.9 yr)
SD Card Logger Capacity Minimum 2 GB (> 5-year capacity for 10-s measurement mode)
Ozone Units ppb, ppm, pphm, μg m-3, mg m-3
Pressure Units mbar, torr
Temperature Units °C, K
T and P Corrected Yes
Operating Temperature Range 0 to 50 °C standard; optional -20 to 50 °C with low temperature modifications (pump and lamp heater cold-weather package)
Operating Altitude Range ~0-13.5 km (150-1,013 mbar) standard; optional ~0-25 km (30-1,013 mbar) with upgraded pressure sensor
Power Requirement;
Supplied by battery or 110/220 VAC Power Pack
12 V dc or 120/240 V ac, 470 mA, 5 watt (4 watt with cell heater unplugged)
Size 3.5 x 8.5 x 11 inches (9 x 21 x 29 cm)
Weight 5.3 lb (2.4 kg); 2.6 lb (1.2 kg) without instrument case
Analog Inputs for Internal Logging of Other Instruments 3 Analog Inputs, 0-2.5 V; For example could log external T, P and RH
Data Outputs RS232, 0-2.5 V Analog, LCD Display: (Optional 4-20 mA Current, External USB Converter; request quote)
Data Transfer Baud Rates 2400, 4800, 19200
Output Ranges User-Defined Scaling Factor in Menu
DewLine™ Yes
Backup Air Pump Yes
Flow Meter Yes
Options Battery; External Particle Filter; Serial-to-USB Converter; GPS; Bluetooth; 4-20 mA Current Output; Cold-Weather Package (pump, lamp heater); High-Altitude Upgrade; Long-Life Internal Air Pump; Rack-Mount Case Configuration
Upgradable to Model 205 Dual Beam Yes
System Includes
  • Model 202 Ozone Monitor
  • AC Power Adapter (100-240 VAC to 12 VDC) with Country-Specific Plug
  • Flash Card Memory for virtually unlimited data storage
  • SD Card
  • SD Card Reader
  • Cigarette Lighter Adapter
  • Zeroing Cartridge
  • Operation Manual on USB Stick
  • Calibration Data and NIST-Traceable Calibration Certificate
  • Instrument Birth Certificate
  • One-Year Warranty
2
长沙巴溪仪器有限公司多年来始终致力于提升中国的实验仪器水平,始终服务于中国科学事业的发展——从提供世界一流品质的实验仪器和科学设备,到尽心尽力为客户量身定制实验室系统解决方案,通过专业细致和精益求精的技术服务为客户创造更多价值,努力成就中国科学的美好未来。
巴溪仪器,总部现设于湖南长沙,自创立以来始终恪守“诚信品质、精益求精”的宗旨,以诚信的经营之道赢得客户的信任,以过硬的技术水平赢得客户的尊重和认可。我们注重品质,强调发展,着力引进国际先进仪器和理念,大力推广国产尖端设备和品牌文化,在业内具有深远的影响力,中国科学院和众多国内知名高校皆已成为巴溪的尊贵客户。
巴溪仪器不仅仅是提供单纯的产品,而是集产品、应用和服务于一体,提供实验室整体解决方案。凭借多年积累的丰富销售经验、完善的售后服务以及雄厚的技术支持力量,辅以准确的市场定位,巴溪仪器已成为诸多世界著名品牌的独家代理、一级代理和特约代理。目前,巴溪仪器主要经营欧、美、日、韩等实验室仪器领域的顶级品牌产品,同时经营国内高尖端产品,旗下产品种类十分齐全,如:美国Glas-Col加热套/3D振荡器/蒸发仪/气溶胶发生机、美国Diversified Biotech低温标签及耗材、日本HONDA兆声波清洗设备、加拿大PolymerSource特种聚合物、美国CERAC特种无机材料及PVD靶材、爱尔兰Megazyme生物试剂检测盒、瑞士Kinematica均浆机/乳化器、美国C.B.S.电泳仪/耗材、美国Hybrid Plastics POSS试剂、美国大洋OceanNanoTech量子点、美国Rieke Metals导电聚合物、美国Wale Apparatus毛细玻璃管、美国LaysanBio聚合物、美国GrafTech石墨材料、荷兰Solenne B.V.PCBM富勒烯衍生物试剂等 ,产品涵盖光谱色谱、光电化学设备、材料制备设备、计量仪器、实验室通用仪器、化学分析和物理测试等仪器,如原子吸收光谱ICP、色谱-质谱联用GC-MS、强度调制光电流/光电压谱IMPS/IMVS、原子层沉积系统ALD、离子刻蚀机、天平、滴定仪、水分仪、粘度计、搅拌器、烘箱、色差计、分光光度计等,涉及到高校和研究所等众多科研机构的实验室。
巴溪仪器拥有一批一流的专业人才,致力于产品开发和市场推广。展望将来,巴溪仪器将会引进更多优质的实验室产品,并将更多专业的应用技术渗透到日常服务中去,更便捷、更周到地满足客户需求。对巴溪而言,满足不同行业、不同应用、不同需求的用户是我们孜孜以求的目标和不断超越的动力!在未来充满机遇和挑战的市场竞争中,巴溪将与科研客户一起携手并进,共创中国科学事业的辉煌。
长沙市芙蓉区远大路408号泰禹公馆2期中栋2单元406室
