HSV-Ag2人单纯疱疹病毒抗原2检测试剂盒
HSV-Ag2人单纯疱疹病毒抗原2检测试剂盒双抗体夹心法检测抗原,间接法检测抗体,为客户提供各种ELISA技术进行样本检测。
英文缩写:HSV-Ag2 Elisa kit
产品关键词:单纯疱疹病毒抗原2酶联免疫试剂盒
规格96T/48T
保存条件:2-8℃低温保存
运输:快递运输(可根据客户要求,选择具体的运输方式,无特殊要求我公司一般为顺丰)。
HSV-Ag2人单纯疱疹病毒抗原2检测试剂盒样品准备:
1. Acidify the plasma/serum with an equal amount of buffer A. For example, if you are using 1ml of plasma/serum, add 1 ml of buffer A. Mix and centrifuge at 6,000 to 17,000 x g for 20 minutes at 4°C.
2. Equilibrate a SEP-COLUMN containing 200 mg of C18 (Catalog No.: RK-SEPCOL-1) by washing with buffer B (1 ml, once) followed by buffer A (3 ml, 3 times).NOTE: From steps 3-5, no pressure should be applied to the column.
3. Load the acidified plasma/serum solution onto the pre-treated (Step 2) C-18 SEP-COLUMN.
4. Slowly wash the column with buffer A (3 ml, twice) and discard the wash.
5. HSV-Ag2人单纯疱疹病毒抗原2检测试剂盒Elute the peptide slowly with buffer B (3 ml, once) and collect eluant into a polystyrene tube.
6. Evaporate eluant to dryness in a centrifugal concentrator or by a suitable substitute method.
7(i). For EIA kits, Fluorescent EIA kits and Chemiluminescent EIA kits, keep the dried extract at -20°C and perform the assay as soon as possible. For normal subject extracted from 1 ml original plasma/serum, use 125 ul 1x assay buffer to reconstitute the dried extract. Aliquot 50 ul into two designated assay wells (25 ul is left over). the concentration factor in this case is 8. (1 ml / 125 ul = 8). The original plasma peptide level is 1/8 of the level of final extracted plasma.
HSV-Ag2人单纯疱疹病毒抗原2检测试剂盒样本要求:
在收集标本前都必须有一个完整的计划,必须清楚要检测的成份是否足够稳定。我们提倡新鲜标本尽早检测,对收集后当天就进行检测的标本,及时储存在4℃备用,如有特殊原因需要周期收集标本,请造模取材后,将标本及时分装后放在-20℃或-70℃条件下保存。因冰室与室温存在一定温差,蛋白极易降解,直接影响实验质量,所以避免反复冻融。代测放免标本的客户取材前须向我司销售人员索要说明书,具体操作注意事项请与我司技术人员沟通。
XY6205 胎盘生成素(HPL)检测试剂盒 ELISA 96T ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。 原装进口
XY6209 人绒毛膜促性腺激素(HCG)检测试剂盒 ELISA 96T ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。 原装进口
XY6210 β-人绒毛膜促性腺激素(β-HCG)检测试剂盒 ELISA 96T ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。 原装进口
XY6211 游离β-人绒毛膜促性腺激素(XY-β-HCG)检测试剂盒 ELISA 96T ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。 原装进口
XY6212 17-羟-孕酮(17-OHP)检测试剂盒 ELISA 96T ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。 原装进口
| 单位名称: |
上海市松江区卖新公路2077号(新九广场)3楼8306室
| 联系电话: |
| Email: |
