免疫学/诊断检测试剂
FABP人脂肪酸结合蛋白检测试剂盒
FABP人脂肪酸结合蛋白检测试剂盒
Human fatty acid-binding protein,FABP ELISA kit
XY-Bioscience
FABP-Hu
FABP人脂肪酸结合蛋白检测试剂盒双抗体夹心法检测抗原,间接法检测抗体,为客户提供各种ELISA技术进行样本检测。
英文缩写:FABP Elisa kit
产品关键词:脂肪酸结合蛋白酶联免疫试剂盒
规格96T/48T
保存条件:2-8℃低温保存
运输:快递运输(可根据客户要求,选择具体的运输方式,无特殊要求我公司一般为顺丰)。
FABP人脂肪酸结合蛋白检测试剂盒样品准备:
1. Acidify the plasma/serum with an equal amount of buffer A. For example, if you are using 1ml of plasma/serum, add 1 ml of buffer A. Mix and centrifuge at 6,000 to 17,000 x g for 20 minutes at 4°C.
2. Equilibrate a SEP-COLUMN containing 200 mg of C18 (Catalog No.: RK-SEPCOL-1) by washing with buffer B (1 ml, once) followed by buffer A (3 ml, 3 times).NOTE: From steps 3-5, no pressure should be applied to the column.
3. Load the acidified plasma/serum solution onto the pre-treated (Step 2) C-18 SEP-COLUMN.
4. Slowly wash the column with buffer A (3 ml, twice) and discard the wash.
5. FABP人脂肪酸结合蛋白检测试剂盒Elute the peptide slowly with buffer B (3 ml, once) and collect eluant into a polystyrene tube.
6. Evaporate eluant to dryness in a centrifugal concentrator or by a suitable substitute method.
7(i). For EIA kits, Fluorescent EIA kits and Chemiluminescent EIA kits, keep the dried extract at -20°C and perform the assay as soon as possible. For normal subject extracted from 1 ml original plasma/serum, use 125 ul 1x assay buffer to reconstitute the dried extract. Aliquot 50 ul into two designated assay wells (25 ul is left over). the concentration factor in this case is 8. (1 ml / 125 ul = 8). The original plasma peptide level is 1/8 of the level of final extracted plasma.
FABP人脂肪酸结合蛋白检测试剂盒样本要求:
在收集标本前都必须有一个完整的计划,必须清楚要检测的成份是否足够稳定。我们提倡新鲜标本尽早检测,对收集后当天就进行检测的标本,及时储存在4℃备用,如有特殊原因需要周期收集标本,请造模取材后,将标本及时分装后放在-20℃或-70℃条件下保存。因冰室与室温存在一定温差,蛋白极易降解,直接影响实验质量,所以避免反复冻融。代测放免标本的客户取材前须向我司销售人员索要说明书,具体操作注意事项请与我司技术人员沟通。
XY3590    小鼠干细胞因子 (mouse SCXY)检测试剂盒    ELISA    96T    ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。    美国 R&D    小鼠
XY3591    mouse SDXY-1 a    ELISA    96T    ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。    美国 R&D    小鼠
XY3592    小鼠可溶性 E- 选择素 (mouse sE-Selectin/ sCD62E)检测试剂盒    ELISA    96T    ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。    美国 R&D    小鼠
XY3593    小鼠可溶性 L- 选择素 (mouse sL-Selectin/ sCD 62L )检测试剂盒    ELISA    96T    ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。    美国 R&D    小鼠
XY3594    小鼠可溶性 P- 选择素 (mouse sP-Selectin/ sCD62P)检测试剂盒    ELISA    96T    ELISA常用的方法:双抗体夹心法、间接法、竞争法以及BAS-ELISA等。    美国 R&D    小鼠
上海信裕生物科技有限公司是一家生物高新技术企业,主要从事免疫学、分子生物学和常规生化试剂的研发、销售。并代理销售Amresco,qiagen,GenWay,Sciencell,Millipore,eBioscience,Sigma、R&D、GBD、ATCC、HYCLONE等二十多家国内外知名品牌,致力于为广大高校、科研院所和企业单位提供的科研试剂和完善的技术服务,满足生物化学、分子生物学 、细胞生物学、免疫学 ELISA试剂盒等生物科技实验需求。
上海信裕先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
上海市松江区卖新公路2077号(新九广场)3楼8306室
