全自动菌落计数仪菌落计数器菌落仪
全自动菌落计数仪/菌落计数器/菌落仪
一、用途
用于微生物、菌落总数的自动计数分析,快速、有效替代半自动计数菌落的落后工作方式。
二、主要技术指标
1、用大景深的1200万像素拍摄仪拍照菌落平皿,悬浮暗视野、背光可切换成像分析,超薄LED背光成像装置使自动计数识别更稳定,可长时间工作。
2、适应培养皿直径:50~120mm平皿(倾注、膜滤、3M纸片)。
3、可自动计数和输出菌落总数,自动识别计数≥0.1mm的菌落,自动计数精度≥98%,由添加、删除的个别指点修正,可使计数值达100%准确。分析速度:50~500个菌落/s(计数分析耗时1~4秒)。
4、可自动分割链状或团状粘连的各类菌落。
5、可自动过滤剔除杂质和点击修正等操作,有效支持复杂微生物统计。
6、可查看结果表、并导出至EXCEL,可存上万张图片及其对应的数据,并无线上网来远程发送图片、结果数据。
三、标准配置
1、HiCC-B全自动菌落计数仪系统软件U盘及软件锁1套
2、大景深的1200万像素拍摄仪1台
3、A5幅面白底背光板和平皿定位挡1套
4、暗视野背景黑片1片
备注:
可以定制适合更大平皿的。本产品需使用电脑,推荐选配:品牌电脑(14代酷睿i5 CPU / 16G内存/ 21.5”彩显/无线网卡,1个USB3.0+1个USB2.0口,运行环境Windows 10或11完整专业版)。
WSeen’s HiCC-B automatic colony counter
Overview:
WSeen’s HiCC-B automatic colonies counter from the PC, automatic colony counting software, backlight imaging device. Mainly used for micro-organisms, the total count of the automatic count analysis, rapid and effective alternative to manual or semi-automatic counting of colony lagging work.
Features:
1, by a PC, the software will automatically count and output the number of colonies with Ai support.
2, by adding, deleting the individual pointing correction, can make a few grains up to 100% accuracy.
3, can view the results table, export to EXCEL, and to the designated recipient to upload data.
4, highlight LED backlight device to colony count recognition more stable, can work long hours.
5, Windows system environment, user-friendly, concise, intelligent.
Technical Parameters:
1, with a 1200 megapixel color camera, the highest resolution of 0.05mm, can identify as small as 0.1mm colony
2, the backlight can be switched on imaging analysis
3, to adapt Petri dishes diameter: 50 ~120mm plate (pouring, membrane filtration, 3M paper)
4, automatic segmentation of chain or lumps of various types of colonies adhesion
5, automatic counting accuracy ≥ 98%, with very few amendments up to 100% correct. Analysis speed: 50 - 300 colonies / s
5, automatic removal of impurities, click on the touch screen correction, effective support for complex microbiological statistics
6, can save tens of thousands of pictures and their corresponding data, and wireless Internet to send pictures remotely, the result data
Availability list:
a 1200 megapixel color camera, a software lock (under windows 10 Professional edition) and a software U disk, a LED backlight device (for DC5V), a dark field of a black film
其具有全英文版,已多批次出口国外并有效使用。检测仪器操作由复杂化到“傻瓜式”的自动化趋向,操作的便捷化是对检测技术的更高要求。
万深推出随手拍精确计数的低价全自动菌落计数仪,详见:http://wseen.com/News.aspx?id=12
超高性价比的万深HiCC-B型全自动菌落计数仪,以平板电脑一键搞定,具体参数和价格咨询 详见:http://www.wseen.com/ProductDetail.aspx?id=45&classid=27
万深《HiCC-B型全自动菌落计数仪》实测视频 http://wseen.com/Video.aspx?id=434&classid=22
万深菌落仪(第五代)以不变应百变,傻瓜式一键6平皿全自动菌落计数:http://www.wseen.com/Paper.aspx?id=418
若有万深HiCC技术,连手机拍照的菌落,也能自动计数了。
杭州万深检测科技有限公司座落在杭州西湖区的高新技术园区内,是一家从事顶尖的检测计量分析软件系统及仪器、智能检测监控系统及工程、软件信息系统及多媒体技术研发、集成、销售与服务的高技术公司。公司在产品线的研发上紧密依托浙江理工大学视觉检测研究所,响应国家对产、学、研整合,开发自主知识产权的号召,只做对人类进步有重要意义的静态、动态机器视觉自动检测产品与研发,可按您的特殊需要定制开发(www.wseen.com)。公司因卓越的博士群体和软硬件工程师的大量加入而自豪,事业蒸蒸日上。公司追求:正气、争气、人气、通气;做一流的研究,出一流的产品。组织管理原则:让每位有志向者充分地展示自我才能。
【万深】被广泛认可产品:
•高清晰全自动菌落计数分析仪、全自动抑菌圈测量仪、抗生素药敏效价分析、β-内酰胺酶测量仪、生物显微图像分析系统、浮游生物藻类计数及辅助鉴定系统,全自动LED芯片计数仪,处于领先地位。其它包括:生物芯片分析系统;生物显微镜的智能化与镜检图像管理系统;精微颗粒自动视觉分析系统;超大景深多聚焦高清成像与自动拼图系统。
•全能型植物图像分析系统(叶面积、病斑叶面积、虫损叶面积、叶色分档分析、根系分析、年轮分析、瓜果剖切面分析),种子大米外观品质检测分析仪、自动实粒种子考种分析及千粒重仪(含出苗计数、虫口计数)、高精度超快千粒重自动分析仪系统,均处于领先地位。其它包括:水稻群丛氮肥状态远程自动诊断推荐系统。
•动态环境下的早期烟雾火苗事件视频检测系统,仪表状态智能视觉值班报警系统,处于领先地位。其它包括:警戒线自动监视与报警系统,电器产品冒烟、着火点温度的自动监控记录仪,多目标主动视觉实时跟踪与监控系统。
•服装尺寸自动测量系统,圆周孔组的孔径-位置度自动测量仪,织物缺陷自动在线检测系统,装箱缺瓶自动检测系统,瓶装液洁净度自动检测系统,瓶口瓶盖缺陷自动检测系统,电镀件表面缺陷检测系统,生产流水线中的异物自动排查系统,平行组合反应器计算机自动控制系统,LCD背光均匀度色差检测系统,多用途自动比色配色系统,学习型印染配色处方服务支持系统,等。
【万深】已获认证与荣誉:
1.信息产业部软件产品证书备案,证书编号:浙DGY-2010-0215; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字5173号
2.信息产业部软件产品证书备案,证书编号:浙DGY-2010-0310; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字5174号
3.信息产业部软件产品证书备案,证书编号:浙DGY-2010-0316; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字5175号
4.信息产业部软件产品证书备案,证书编号:浙DGY-2010-1103; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字7480号
5.信息产业部软件产品证书备案,证书编号:浙DGY-2010-1104; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字7478号
6.信息产业部软件产品证书备案,证书编号:浙DGY-2010-1105; 通过浙江省软件评测中心评测,证书编号:(2010)电检软字7479号
7. 计算机软件著作权登记证书,登记号:2012SR075860,证书号:软著登字第0443896号,全部权利
8.信息产业部软件产品证书备案,证书编号:浙DGY-201401607; 通过浙江省软件评测中心评测,证书编号:No.14BD1651
9.取得国家发明专利(授权日:2015.9.2),发明专利号:ZL 2013 1 0172280.
10. 获【高新技术企业】证书(2016.11.21),证书编号:GR201633001966
理念与方针:
永不欺诈。以人为本、以质取信、以科技创造价值。创造、服务、回报客户。
| 单位名称: |
杭州市西湖区文二西路11号嘉乐金座418室
| 联系电话: |
| Email: |
