PET CT模体™
【PET CT模体™™】
PET CT Phantom™
型号/Model:PET/CT/P
PET CT模体™主要特点:
-该PET-CT模体™内部含三个冷棒及六个实心球,成像时可清晰体现两者的位置精确度和几何形变情况。
The PET-CT Phantom™ includes internal structures (three rods and six spheres) which when imaged with both modalities can demonstrate how accurately the two image sets are aligned.
-此外,经水、骨骼及CT对比显影物质(或仅通过空气)等介质衰减后的放射性水样本可用于判定基于CT的PET衰减校正准确性。
In addition, a single sample of radioactive water is attenuated by water, bone, and CT contrast material (as well as air only) to determine how accurately the CT-based PET attenuation correction works.
PET CT模体™主要应用领域:
-PET/CT(正电子发射断层显像/X线计算机体层成像)及SPECT/CT(单光子发射断层显像/X线计算机断层显像)系统验收测试
Acceptance testing of PET/CT and SPECT/CT system
-PET/CT及SPECT/CT系统例行质量评估
Routine quality evaluation of PET/CT and SPECT/CT Systems
-新图像融合软件的评估
Evaluation of new image fusion software
-新衰减校正算法的评估
Evaluation of new attenuation correction algorithms
-含配准用铝管
Aluminum tubes are for registration
-外部直径2英寸(5.08cm)微型圆筒用于比较衰减区域和不衰减区域
The outer 2” OD micro cylinder is for comparing attenuation region to non attenuation region
-6英寸(15.24cm)圆环用于防止对比显影液
The 6” ring is for contrast solution
-科研应用
Research
模体规格:
主体圆柱/Main Cylinder:
-模体内部长度/Interior length of phantom: 18.0 cm
-五个填充球内直径/Fillable spheres (5) inner diameter: 10 mm, 13 mm, 17 mm, 22 mm, and 28 mm.
-球体表面至内壁距离/Distance from sphere plane to inside wall: 7.0 cm
-空柱容积/Volume of empty cylinder: ~9.7 L
主体圆柱插件规格/Main Cylindrical insert dimension:
-外部直径/Outside diameter: 5.1 cm
-长度/Length: 18.0 cm
顶部圆柱/Top Cylinder:
-圆柱外部直径/Cylinder outside diameter: ~5.1 cm
-圆柱内部直径/Cylinder inside diameter: ~4. cm
-圆柱内部高度/Cylinder inside height: ~8.2 cm
-圆柱外部过度/Cylinder outside height: ~12.0 cm
-空柱容积/Volume of empty cylinder: ~408 mL
三根铝管/Three Aluminum Tubes:
-其中一根5英寸(12.7 cm)长/One 5 inch long: ~1.7 mL
-另外两根7英寸(17.78cm)长/Two 7 inch (ea): ~ 2.5 mL
阶梯式骨环/Stepped Bone Ring:
-预装液体骨质合成物,无法打开/Pre-filled with liquid bone composition, not to be opened
-骨环容积/The volumes for the bone ring are:
-外部容积/Outer volume: ~256 mL
-内部容积/Inner volume: ~110 mL
美国Data Spectrum Corporation PET CT模体™中国地区代理经销商:
辽宁飞勒科技有限责任公司
联系人:刘女士
联系电话:0415-3791189 18241547308
公司官网:www.fiatlux.tech
电子信箱:sales@fiatlux.tech
辽宁飞勒科技有限责任公司是一家专业从事核医学及放射影像医学检测设备与服务的供应商。公司自成立以来,一直致力于核医学检测设备的开发与进口核医学检测模体的销售,公司现为众多世界知名品牌的实验室模体设备(美国High Precision Devices、 美国QalibreMD、 美国Data Spectrum Corporation、 美国Portal Medical、 美国West Physics、 美国Supertech、 英国Leeds Test Objects等)在华的合作供应商及独家代理商,我们利用自身的优势,为国家各级医疗器械科研机构、医疗器械生产企业、医疗器械检测中心、国家质检部门、各级医院以及各级疾控部门、全国各大高校等单位,提供优质、专业的医疗器械测试技术服务与检测产品。
我们将不断创新,提升专业技术、专业产品和专业服务,我们秉承“热情、专注、高效、负责”的经营理念,确保医疗器械产品的精准品质,保障患者得到安全而有效的诊断和治疗,与我们的客户共创未来,回馈社会。
辽宁飞勒科技有限责任公司
联系人:刘女士
电话:18241547308
| 单位名称: |
辽宁省丹东市振兴区湾景街16号3栋2层
| 联系电话: |
| Email: |
