AKTA Process 6mm PP isocratic
现货供应 - 九成新 AKTA Process 6mm PP isocratic (2015年生产)
系统规格
System configuration |
ÄKTAprocessTM 6mm PP Isocratic |
Maximum operating flow rate |
180 l/h |
Minimum operating flow rate |
4 l/h |
Gradient function |
No |
Pressure flow control |
Yes |
Number of inlets pump A |
10 |
Number of outlets |
4 |
Column connections |
1 |
Level detection (air trap) |
Yes |
Air trap, automated fill |
1 |
Filter housing |
Yes |
Pumps type |
Diaphragm, triple headed |
Pumps amount |
1 |
Conductivity meter, post pump |
1 |
Conductivity meter, post column |
1 |
Pressure meter, post pump |
1 |
Pressure meter, pre column |
1 |
Pressure meter, post column |
1 |
pH meter, pre column |
1 |
pH meter, post column |
1 |
UV meter, post column |
Fixed 280nm |
Flow meter, pre column |
1 |
Temperature, integrated in conductivity meter |
2 |
Air detection, sample inlet |
1 |
Air detection, pre column |
1 |
Serial number 29133552 |
Document revision AA |
GE Healthcare Bio-Sciences AB AxiChrom, ÄKTAprocess and UNICORN are trademarks of GE Healthcare companies. All third party trademarks are the property of their respective owners. © 2008 General Electric Company – All rights reserved. First published Jan. 2008 |
Document number ÄKTAprocess-100023441-20150114102617-GS |
Configurator version 5.04.1011 |
Page number 1 of 14 |
Document template 28926472-AA
External communication interface |
PROFIBUS gateway |
1.2. Environmental ranges
1.3. Dimensions
1.4. Enclosure protection class
1.5. Cable lengths
1.6. Warning labels
Maximum operating pressure |
6 bar |
Ambient temperature range |
2 - 30 degrees Celsius |
Process temperature range |
2 - 60 degrees Celsius |
max 3 bar at 40 - 60 degrees Celsius |
Space requirements system, W x L x H |
850 x 1236 x 1670 mm |
Enclosure protection class |
See applicable codes and standards |
Cabinet |
IP 56 (NEMA 4X) |
Field mounted instruments, motors |
≥ IP 55 |
Power supply cable |
5m |
Language |
English |
我公司所有产品均通过完整的测试流程且保养状况良好.
联系方式:
苏州谱特科学仪器有限公司
地址:苏州市工业园区新平街388号腾飞产业园
电话:13917070728 (微信同号)张先生
邮箱:yanhui.zhang@potosci.com
苏州谱特科学仪器有限公司位于苏州工业园区腾飞创新园内,专注于制药企业及生物医药等科研单位,提供完整的实验室设备、配套耗材及售后维修整体解决方案。
公司与ThermoFisher、Beckman Coulter、Biotage、SP Scientific等公司有着密切合作,产品包括了分析仪器、质谱、光谱、样品前处理设备、离心机及颗粒物分析、冻干机、离心浓缩仪等设备及其相关消耗品,另外,公司也提供二手GE Akta 蛋白纯化及相关设备的销售和售后维修服务。目前,产品广泛应用在医药、食品、化工、环境、等领域。
我们坚持 “尊重、务实、专业、创新”的企业文化,基于客户的真实需求,提供最优质的服务和相关技术咨询等。
以诚相待,实现多赢。
