动物器具
PennCentury动物肺部喷雾给药系统
MicroSprayer® Aerosolizer
进口
美国/PennCentury
MicroSprayer Aeroso
请致电:15800528412
PennCentury
联系电话:15800528412
此产品适用于各种动物喷雾给药系统,肺部液体定量喷雾器,是一款能够在动物气管内将液体样品直接精确定量喷成气态,实现气态肺部给药的装置。通过精密的高压推送装置,将微量的液体定量传输至装置微喷头,微喷头集成在不锈钢细管中,纤细的细管可深入小鼠或大鼠的气管内,进而对动物肺部直接给药。
可重复使用/灭菌:可以清洗和消毒很热(过滤或蒸馏)水、有机溶剂、高压蒸汽或超声波。
可把液体雾化装置,装置升入动物气管,均匀的喷出雾状液体。
可以广泛用于:病毒的液体或药物溶液或悬浮液,包括制药和生物制剂。
 技术参数:
外径:0.64毫米,内径:0.43毫米
弯曲度:120°
Penn-Century MicroSprayer® Aerosolizer - Model IA-1C (liquid)
part number
model
description
MSA-250
MicroSprayer® Aerosolizer and FMJ-250 High-Pressure Syringe Assembly (Suitable for mouse and larger species)
Penn-Century MicroSprayer® Syringe Assembly. Includes one standard MicroSprayer® Aerosolizer - Model IA-1C and one FMJ-250 High-Pressure Syringe (required for operation of the MicroSprayer® Model IA-1C). Standard sizes for mouse (1-1/4") or for rat (2") (Please specify). Both MicroSprayer® and syringe are autoclavable. Each device includes a set of five 25-µl stops and five 50-µl stops for precise dosing of smaller quantities.
MSA-250-M
For Mouse
Standard size for mouse (1.25" after 120-degree bend)
MSA-250-R
For Rat
Standard size for rat: (2" after 120-degree bend)
MSA-250-C
Custom Length
Penn-Century MicroSprayer®/Syringe Assembly. Includes one custom length MicroSprayer® Aerosolizer - Model IA-1C and one FMJ-250 High-Pressure Syringe (required for operation of the Model IA-1C). MicroSprayer® Aerosolizer can be made to any length or configuration (e.g. short, long, with or without standard 120-degree bend), as specified by customer. Long lengths may be used with an endotracheal tube or bronchoscope.
MSA-50
NEW!
MicroSprayer® Aerosolizer and FMJ-50 High-Pressure Syringe Assembly (Suitable for mouse and larger species)
Penn-Century MicroSprayer® Syringe Assembly. Includes one standard MicroSprayer® Aerosolizer - Model IA-1C and one FMJ-50 High-Pressure Syringe (new product for administration of up to five 10-µl doses) required for operation of the MicroSprayer® Model IA-1C. Standard sizes for mouse (1-1/4") or for rat (2") (Please specify). Both MicroSprayer® and syringe are autoclavable.
MSA-50-M
For Mouse
MSA-50-R
For Rat
MSA-50-C
Custom Length
Penn-Century MicroSprayer®/Syringe Assembly. Includes one custom length MicroSprayer®Aerosolizer - Model IA-1C and one FMJ-50 High-Pressure Syringe (required for operation of the Model IA-1C). Each device includes a set of five 10-µl stops for precise dosing of smaller quantities. MicroSprayer® Aerosolizer can be made to any length or configuration (e.g. short, long, with or without standard 120-degree bend), as specified by customer. Long lengths may be used with an endotracheal tube or bronchoscope.
Model IA-1C
Additional MicroSprayer® Aerosolizers - Standard (Suitable for mice and all larger species.)
With 23-gauge, stainless steel delivery tube, o.d. of 025" (.64 mm). NOTE: Must be operated with FMJ-250 High-Pressure Syringe. Standard sizes: 1-1/4" for mouse and 2" for rat after 120-degree bend. Fully autoclavable.
IA-1C-M
For Mouse
IA-1C-R
For Rat
IA-1C-C
Custom Length
Custom sizes: any length or configuration (e.g. short, long, with or without standard 120-degree bend), as specified by customer. Long lengths may be used with an endotracheal tube or bronchoscope. Operated with FMJ-250 High-Pressure Syringe.
^ back to top
Penn-Century High-Pressure Syringes
part number
model
description
FMJ-250
Additional FMJ-250 High-Pressure Syringe
Manually-operated, high-pressure syringe required for operating MicroSprayer® Aerosolizer - Model IA-1C. Operates at 3000 psi. Stainless steel construction with glass insert, 250 µl capacity. Replaceable plunger with Teflon® tip. Each device includes a set of five 25-µl stops and five 50-µl stops for precise dosing of smaller quantities. Fully autoclavable.
PLU-250
Replacement Plunger for FMJ-250
Replacement plunger for FMJ-250 High Pressure Syringe - with anodized aluminum thumb button and Teflon® tip.
FMJ-50
NEW!
Additional FMJ-50 High-Pressure Syringe (for precise administration of up to five 10-µl doses)
New low-dose model. Manually-operated, high-pressure syringe required for operating MicroSprayer® Aerosolizer - Model IA-1C. Operates at 3000 psi. Stainless steel construction with glass insert, 50 µl capacity. Replaceable plunger with Teflon® tip. Each device includes a set of five 10-µl stops for precise dosing of smaller quantities. Fully autoclavable.
CBA
Custom Bronchoscopic Adaptor
NOTE: Longer, straight custom lengths of MicroSprayer® Aerosolizers - Model IA-1C can be ordered for insertion into the working channel of a bronchoscope for administration to a lobe of the lung. Depending on the configuration of the instrument port of the bronchoscope, an adaptor may be required to stabilize the FMJ-250 High Pressure Syringe and prevent bending of the MicroSprayer® during insertion and removal. The adapter must be custom fitted to your equipment in our shop. Please contact us for details.
^ back to top
Penn-Century MicroSprayers® (liquid) - Model IA-1B
part number
model
description
Model IA-1B
MicroSprayer® Aerosolizer with 1 ml disposable polycarbonate syringe (Suitable for rat and all larger species)
Made with stainless steel 19-gauge delivery tube that measures .048" (1.2 mm) at the very tip. Luer hub. Operates with 1-ml polycarbonate syringe (provided), or any commercially available 1-ml polycarbonate, or 0.5 ml glass, gas-tight syringe. Fully autoclavable.
IA-1B-R
For Rat
IA-1B-GP
For Guinea Pig
Standard size for guinea pig (3" after 120-degree bend)
IA-1B-C
Custom Length
Custom length MicroSprayer® Aerosolizers are available in any length or configuration (short, long, with or without standard 120-degree bend). May also be used via an endotracheal tube. Specify dimensions.
^ back to top
Penn-Century Dry Powder Insufflators™
part number
model
description
Model DP-4
Dry Powder Insufflator™ with disposable 3 ml air syringe
Made of chemically resistant PEEK™ construction, silicone rubber valves, and hollow stainless steel delivery tube for precise administration of dry powders. Accepts all powder sizes. Air supply: 3 ml disposable air syringe (included). Standard sizes available for intratracheal administration to rat (2") or guinea pig (3").
DP-4-R
For Rat
DP-4-GP
For Guinea Pig
DP-4-C
Custom length
Custom size DP-4 with delivery tube: any length or configuration (straight or with standard 120-degree bend), as specified by customer.
DP-EXT-R
For Rat
Extra delivery tube for DP-4 for Rat
DP-EXT-GP
For Guinea Pig
Extra delivery tube for DP-4 for Guinea Pig
DP-EXT-C
Custom length
Custom length tips for the Penn-Century Dry Powder Insufflator™ - Model DP-4 may be ordered in any length, straight or with a 120-degree bend, or with custom, flexible delivery tube options. Longer lengths may be inserted into an endotracheal tube or bronchoscope. (Specify dimensions)
SC-X
Sample Chamber Extension
100 mg Sample Chamber Extension - attaches to Model DP-4 for administration of large doses
DPM-APA
Penn-Century Dry Powder Insufflator™/Air Pump Assembly for Mouse
The only light, purely mechanical, manually operated method for intratracheal administration of dry powders to mouse. Includes (1) Penn-Century Dry Powder Insufflator™ for Mouse and (1) Penn-Century Air Pump with adjustable air volume setting (set for mouse at 200 µl). Insufflator made of chemically resistant PEEK™ construction with removable stainless steel delivery tube sized for intratracheal administration of dry powders to mouse. Operates with spring-loaded, Penn-Century Air Pump for easy, rapid administration of 200 µl pulses of air.
Model DP-4M
Additional DP-4M Dry Powder Insufflator™ for Mouse
Dry Powder Insufflator™ with valve assembly for mouse. PEEK™ construction with silicone rubber valving. Can be used with any animal, including mouse, depending upon delivery tube dimensions. Comes with 23-gauge delivery tube (1.25" after the 120-degree bend). Operates with spring-loaded, Penn-Century Air Pump for easy, rapid administration of 200 µl pulses of air.
DPM-EXT
Extra delivery tube
Extra delivery tube for DP-4M for Mouse
^ back to top
Penn-Century accessories for precise intratracheal aerosol administration
part number
model
description
AP-1
Air Pump
Hand-held precision air pipette with spring-loaded thumb button for easy, fast administration of air pulses. Attaches to any size Penn-Century Dry Powder Insufflator™. Plastic construction with rubber square-ring seal. Outlet: male luer slip. Adjustable air volume setting: 0 - 5 ml. Required for use with DP-4M in mice. Recommended for use in rat, or in other applications requiring rapid dosing of multiple subjects with minimal hand motion. Specify animal to be used.
LS-2
Small-Animal Laryngoscope
Designed to clearly illuminate the trachea and epiglottis for intubation and insertion of a Penn-Century MicroSprayer® or Dry Powder Insufflator™. Now with a fiberoptic LED light source for clear, bright illumination. Each device comes with a custom-made small, tapered stainless steel blade for moving aside the animal's tongue. (Specify animal when ordering). New easy-grip handle with curved ergonomic shape fits securely in the palm of the hand. Coated with non-slip Santoprene™ rubber. Operates with one 3-volt lithium battery (included). Autoclavable.
LS-2-M
For Mouse
With blade sized for use in Mouse
LS-2-R
For Rat
With blade sized for use in Rat
LS-2-GP
For Guinea Pig
With blade sized for use in Guinea Pig
LS-2-C
For larger species
Custom blade for larger species. Please specify when ordering.
MIP
Mouse Intubation Platform
For safe, rapid, easy intratracheal intubation of mice. Adjustable posts for stabilizing anesthestized animal. Unique swiveling neck support permits clearer visualization and access to trachea. Made of sterilizable Plexiglass®/Perspex® with stainless steel and Delrin® fittings. Can be attached to any standard lab clamp stand (not included.) NOTE: $50 discount is offered when Platform is purchased with any Penn-Century MicroSprayer® or Dry Powder Insufflator™.
我公司2017年成立。
致力于开发小动物肺部给药系统。
开发的产品小动物肺部给药装置将近10年,使用我公司产品发表的Paper总影响因子达到了400+,Paper  30+篇。
伯建生物科技有限公司专注于开发、生产和销售结构生物学领域相关耗材,仪器等。
目前公司业务主要提供蛋白质晶体培养所需的耗材、试剂与仪器。其中包括:
耗材:坐滴板 悬滴板(预涂胶) 硅化盖玻片 封板膜 悬滴膜 Loop与底座 LCP耗材 结晶筛选试剂盒等
工具:Puck工具套装 CX100液氮罐 CX100运输箱 泡沫杜瓦 低温操作工具等
仪器:蛋白结晶点样工作站 筛选试剂盒分液工作站 蛋白结晶培养箱 晶体观察显微镜等
上海市浦东新区环桥路555弄42号502室
