其他同位素仪器
高剂量X-ray辐照仪
高剂量X-ray辐照仪
进口
美国
RS 2400系列
经典产品:RS2000系列生物学辐照仪畅销全球300多座权威科学研究与政府机构,全球zui为广泛的用户群体。生物学X-ray辐照仪在剂量均一性、安全性等核心技术方面具有无与伦比的性能优势,为科学实验所要求的剂量均一性、稳定性、重复性和结果精确性提供保障,本系列生物学辐照仪已占据生命科学研究领域中的主流地位!
RS2400高剂量X射线辐照仪
Rad Source Technologies, Inc.
Leading the Way In Non-nuclear Irradiation!
高剂量率X射线辐照仪,非同位素辐照技术的领导者!
RS2400系列辐照仪是一款中等容量、高剂量率的辐照装置,具有高剂量均一性和低环境辐射剂量的特点,可取代昂贵的小型钴和铯源同位素辐照仪;
RS2400系列具有众多科技:专利4pi金靶发射与过滤技术、安全屏蔽性、易操作编程,剂量均一性优于±7%,剂量率10~40Gy/ min可调;
获得的科技专利:Patented* RAD+ chamber --* Patent No; 6,389,099;
* US Patent 7346147 − X−ray tube with cylindrical anode
部分应用领域:
昆虫绝育(SIT)
小型医疗器材灭菌
聚合物--聚合、交联、断裂
食品辐照研究
病毒灭活
及其它
昆虫绝育(SIT)领域应用
Insect population control& Research
The Rad Source Technologies RS 2400 provides a safe and reliable radiation source for Sterile Insect Technique (SIT). Unlike the other radiation sources,cobalt-60 and cesium-137, Rad Source utilizes their patented X-ray technology to generate a 4pi ionizing radiation field without a radioactive source. Because there is no radioactive source, the RS 2400 is much safer, less expensive to own and operate,and can be easily shipped to almost anywhere in the world.
Current Customers
     ·   IAEA
     ·   USDA-APHIS-PPQ-CPHST
     ·   University of Sao Paulo, Brazil
     ·   Ambriex Brazil
The RS 2400’s new carousel system, combined with the light-weight, waterproof,carbon fiber reinforced resin canisters, maximizes the utilization of the unique Rad Source 4pi radiation field, resulting in a more uniform dose delivery.
What is Sterile Insect Technique?
Sterile Insect Technique or SIT is a technique used to control or eliminate an insect population? This is achieved through reproductive mate attrition. Generally, the male insect is exposed to radiation and thereby rendered sexually sterile. By mass rearing male insects, sterilizing them, and then releasing them into the desired area the treated males will seek out and mate with the native female insects and their offspring is non-viable. If this process is repeated enough times the insect population can be controlled and or even eliminated. Are Irradiated Insects Radioactive?No, insects that have been sterilized using radiation are not radioactive.
食品辐照研究应用领域
Food Irradiation Testing & Research--RS2400
The RS 2400 is currently being used in 2 different industries which are food irradiation research and insect population control. Food Irradiation Research – Radiation Effects on Seafood and Produce Pathogens The first RS 2400 was installed in 2003 at Mississippi State University for the evaluation of radiation effectiveness in the reduction of dangerous bacteria, such as salmonella, E. coli, vibrio, shigella and listeria on seafood and fresh produce. It is actively being used by Barakat Mahmoud PhD. Food Irradiation Research – Detection of Irradiated Food In April of 2009, an RS 2400 was installed in Foggia, Italy at the Istituto Zooprofilattico Sperimentale della Puglia e della Basilicata (IZS) and is used in the research of detecting food irradiated with ionizing radiation. In Europe, as in many countries of the world, the irradiation of food is an acceptable method of food preservation. The European Union (EU) approves which foods can be irradiated and to what range of radiation doses. It requires that all irradiated foods be clearly labeled and that market-level inspections are completed to ensure compliance with the regulations. IZS is using their RS 2400 to develop testing methods to determine whether or not a food has been irradiated.
Current Customers
·         Mississippi State University
·         Istituto Zooprofilattico Sperimentale della Puglia e della Basilicata (IZS)
RS2400 Features and Benefits
? Just-In-Time supply management helps to control costs
? Safe, the unit is self-shielded with no radioactive source
? Secure, system is password protected ?
   Turn-key installation
? Easy to operate using a simple, easy-to-read touch pad
? Service and Support – 12 month full warranty and a 24 month X-ray tube warranty
? 5SAP – 5-year Source Assurance Program eligible
? Does not require a US Nuclear Regulatory Commission (NRC) license
RS2400 Technical Specifications*
? Dose Rate: 18 - 70 Gy per minute based on product density and canister size
? Beam Uniformity: Better than ± 7%
? Number of Canisters: 5 – 7 per cycle based on product density and unit configuration
? Processing Canisters: Diameter 3” (7.62 cm) to 7” (17.78 cm), Height 6” (15.24 cm)
? Cabinet Dimensions: Length 72” (183 cm),Width 33” (84 cm), Height 51” (130 cm)
? Cabinet Weight: Net 2350 lbs (1066 kg)
? Power Requirements: US 208 VAC,European 400 VAC
? Cooling system with high capacity water to air heat exchanger (external unit)
? Single 4pi Au Target Emitter
*Technical specifications are subject to change, please contact your Rad Source representative for the most current information.
RS 2400
Length 72” (183 cm),Width 33” (84 cm),Height 51” (130 cm),Weight: 2,350 lbs (1,066 kg)
RS 2400V Mosquito Irradiator
Length 82”,Width 52”,Height 42”,Weight: 2,200 lbs
我公司2017年成立。
致力于开发小动物肺部给药系统。
开发的产品小动物肺部给药装置将近10年,使用我公司产品发表的Paper总影响因子达到了400+,Paper  30+篇。
伯建生物科技有限公司专注于开发、生产和销售结构生物学领域相关耗材,仪器等。
目前公司业务主要提供蛋白质晶体培养所需的耗材、试剂与仪器。其中包括:
耗材:坐滴板 悬滴板(预涂胶) 硅化盖玻片 封板膜 悬滴膜 Loop与底座 LCP耗材 结晶筛选试剂盒等
工具:Puck工具套装 CX100液氮罐 CX100运输箱 泡沫杜瓦 低温操作工具等
仪器:蛋白结晶点样工作站 筛选试剂盒分液工作站 蛋白结晶培养箱 晶体观察显微镜等
上海市浦东新区环桥路555弄42号502室
