NanoDrop One/OneC微量核酸蛋白浓度测定仪
NanoDrop™ One/OneC微量紫外-可见光分光光度计(内置 Wi-Fi)技术参数
| 产品名称 | NanoDrop OneC Microvolume UV-Vis Spectrophotometer with Wi-Fi | NanoDrop One Microvolume UV-Vis Spectrophotometer with Wi-Fi |
| 产品货号 | ND-ONEC-W | ND-ONE-W |
| 应用 | Nucleic Acid A260, A260/A280, A260/A230 and Labeled Nucleic Acids; Protein A280 and A205, Protein Pierce 660, Protein Bradford, Protein BCA, Protein Lowry, Labeled Proteins, OD600, Kinetics, UV-Vis, and Custom Methods | Nucleic Acid A260, A260/A280, A260/A230 and Labeled Nucleic Acids; Protein A280 and A205, Protein Pierce 660, Protein Bradford, Protein BCA, Protein Lowry, Labeled Proteins,OD600, Kinetics, UV-Vis, and Custom Methods |
| 认证/合规 | All NanoDrop instruments are approved to CE and UL/CSA. | All NanoDrop instruments are approved to CE and UL/CSA. |
| 兼容性 | DYMO LabelWriter 450 printer, Bluetooth keyboard, mouse and barcode reader | DYMO LabelWriter 450 printer, Bluetooth keyboard, mouse and barcode reader |
| 浓度 | Maximum dsDNA: Pedestal: 27,500 ng/µL BSA (IgG): Pedestal: 820 (400) mg/mL | MaximumdsDNA: Pedestal: 27,500 ng/µLBSA (IgG): Pedestal: 820 (400) mg/mL |
| 连接 | Three USB-A ports, Ethernet, Bluetooth™ and Wi-Fi (Only available on instruments with Wi-Fi/Bluetooth support) | Three USB-A ports, Ethernet, Bluetooth™ and Wi-Fi(Only available on instruments with Wi-Fi/Bluetooth support) |
| 描述 | NanoDrop OneC Microvolume UV-Vis Spectrophotometer with Wi-Fi | NanoDrop One Microvolume UV-Vis Spectrophotometer with Wi-Fi |
| 检测范围 | dsDNA: Pedestal: 2.0 ng/µL; Cuvette: 0.2 ng/µL BSA (IgG): Pedestal: 0.06 (0.03) mg/mL; Cuvette: 0.006 (0.003) mg/mL | dsDNA: Pedestal: 2.0 ng/µL; Cuvette: 0.2 ng/µLBSA (IgG): Pedestal: 0.06 (0.03) mg/mL; Cuvette: 0.006 (0.003) mg/mL |
| 检测器类型 | 2048-element CMOS linear image sensor | 2048-element CMOS linear image sensor |
| Dimensions (L x W x H) | 20 x 25.4 x 32.3 cm (8 x 10 x 12.7 in.) | 20 x 25.4 x 32.3 cm (8 x 10 x 12.7 in.) |
| 显示 | 7-inch, 1280 x 800 high-definition color display | 7-inch, 1280 x 800 high-definition color display |
| 键盘 | Built-in touchscreen, multipoint capacitive touch | Built-in touchscreen, multipoint capacitive touch |
| 灯 | Xenon flash lamp | Xenon flash lamp |
| 语言 | English, Spanish, Polish, Korean, Japanese, German, French, Chinese | English, Spanish, Polish, Korean, Japanese, German, French, Chinese |
| 测量时间 | Measurement and Data Processing Time 8 seconds | Measurement and Data Processing Time 8 seconds |
| 操作系统 | Android™ | Android™ |
| 路径长度(公制) | 0.030 to 1.0 mm auto-ranging | 0.030 to 1.0 mm auto-ranging |
| Photometric Accuracy Instrument | 3% at 0.97 A, 302 nm (Absorbance expressed at Abs/mm at 25°C) | 3% at 0.97 A, 302 nm(Absorbance expressed at Abs/mm at 25°C) |
| Photometric Range | 10 mm equivalent: Pedestal: 0–550 A; Cuvette: 0–1.5 A | 10 mm equivalent: Pedestal: 0–550 A; Cuvette: 0–1.5 A |
| 功耗 | Operating: 12–18 W Standby: 5 W | Operating: 12–18 WStandby: 5 W |
| 重复性 | Measurement repeatability: Typical: 0.002 A (1.0 mm path) or 1%CV, whichever is greater (SD of 10 individual measurements at 0.97 A) | Measurement repeatability: Typical: 0.002 A (1.0 mm path) or 1%CV, whichever is greater(SD of 10 individual measurements at 0.97 A) |
| 样品温度 | Temperature Control (cuvette only) 37 °C | Temperature Control (cuvette only) 37 °C |
| 样品体积(公制) | Minimum 1µL | Minimum 1µL |
| 光谱带宽 | ≤1.8 nm (FWHM at Hg 254 nm) | ≤1.8 nm (FWHM at Hg 254 nm) |
| 系统要求 | Windows™ 8.1 and 10, 64 bit | Windows™ 8.1 and 10, 64 bit |
| 电压 | 12 V (DC) | 12 V (DC) |
| 波长精度 | ±1 nm | ±1 nm |
| 波长范围 | 190–850 nm | 190–850 nm |
| 重量(英制) | 7.9 lbs. | 7.9 lbs. |
| 重量(公制) | 3.6 kg | 3.6 kg |
上海创萌生物科技有限公司 是国内专业的生命科学研究仪器经营公司,产品涉及细胞及分子研究在内的:医药研究;食品研究;化工研究;科研院校等行业机构的实验室仪器、试剂和耗材。在全国各省市均有销售合作商。
创萌公司自成2010年立以来,以服务生物科研事业为宗旨,通过对各大品牌市场的了解情况为广大用户和经销商推荐质量优,售后服务好,价格合理的产品,从而为广大科研研究者节省科研经费的同时,节省了茫茫仪器海洋中寻找所需仪器的时间,深得广大用户老师、同学和同行商业界的推荐和赞同!我们将用百倍的热情和踏实朴素的工作作风回报广大用户对我们的抬爱。在此,愿我们共同携手走向灿烂的明天,创萌公司的努力服务定能成为您我明天的骄傲!
联系人:吴先生 生物器材部 中国销售
QQ:308964358
电话:021-55883460 / 18917198166 / 15000536120
邮箱: edikar@126.com
网址: ;www.lab-eye.com
| 单位名称: |
上海市闸北区河南北路485号504室
| 联系电话: |
| Email: |
