标准品/对照品
生育三烯酚 β-Tocotrienol 490-23-3现货
β-Tocotrienol
进口
HC
5mg
咨询17715331663
生育三烯酚 β-Tocotrienol 490-23-3 上海惠诚生物提供
上海惠诚生物科技有限公司 “惠质产品,挚诚服务”。生育三烯酚 β-Tocotrienol 490-23-3
上海惠诚生物特色产品:糖类标准品,脂肪酸标准品,花青素标准品,类胡萝卜素,人乳寡糖等食品分析标准品。
生育三烯酚 β-Tocotrienol 490-23-3,分子式:C28H42O2,分子量:410.63,上海惠诚生物提供
咨询电话: 17715331663  QQ:2303607288
Chemical Name
生育三烯酚 β-Tocotrienol
CAS Number
490-23-3
Mol. Formula
C28H42O2
Mol. Weight
410.63
Qty 1
5mg
Appearance
Yellow oil
Synonym
EINECS 207-708-0;EPSILON-TOCOPHEROL
Melting Pt.
<25 C
Storage condition
-20C
Description
The four tocopherols (α, β, δ, and γ) and four tocotrienols (α, β, δ, and γ) are forms of vitamin E, which is known for its antioxidant activity.1 Tocotrienols are found at high concentrations in palm oil and rice bran. Recent studies show tocotrienols may be more effective antioxidants than α-tocopherol, the most abundant form of vitamin E.2 Compared to other tocotrienols, α-tocotrienol exhibits the most potent neuroprotective actions in rat striatal neurons. At concentrations of 0.1-10 µM, α-tocotrienol significantly suppresses H2O2-induced cell death and provides protection against S-nitrocysteine-induced cell death and SIN-1 toxicity in a concentration dependent manner.2 HT4 cells, that are microinjected with 10−19 mol of α-tocotrienol into the cytosolic, are protected against glutamate-induced cell death by suppressing early activation of c-Src kinase and 12-lipoxygenase.3
1 Kamal-Eldin, A., and Appelqvist, L. The chemistry and antioxidant properties of tocopherols and tocotrienols. Lipids 31 671-701 (1996).
2 Osakada, F., Hashino, A., Kume, T., et al. α-Tocotrienol provides the most potent neuroprotection among vitamin E analogs on cultured striatal neurons. Neuropharmacology 47 904-915(2004).
3 Khanna, S., Roy, S., Slivka, S., et al. Neuroprotective properties of the natural vitamin E α-tocotrienol. Stroke 36 2258-2264(2005).
其它相关产品:
三烯生育酚α-Tocotrienol
生育三烯酚β-Tocotrienol​
三烯生育酚γ-Tocotrienol
三烯生育酚
δ-Tocotrienol
生素E系列产品如下:
Vitamin E: Tocopherols & Tocotrienols
生育酚
Contents:
d-α-tocopherol, 98.5+% [CAS 59-02-9] 1 vial x 250 mg
d-β-tocopherol, 98.5+% [CAS 148-03-8] 1 vial x 250 mg
d-γ-tocopherol, 98.5+% [CAS 54-28-4] 1 vial x 250 mg
d-δ-tocopherol, 98.5+% [CAS 119-13-1] 1 vial x 250 mg
2,2,5,7,8-Pentamethyl-6-hydroxychroman (PMC), 99.0+% [CAS 950-99-2] 1 vial x 250 mg
Note: PMC is used as the internal standard for HPLC analysis of tocopherol, but not for GC analysis.
Storage condition:
Each vial is aluminum-packed with an oxygen adsorbent. One opening the vials, store the reagent under inert gas in a refrigerator in the dark. Under such conditions, the reagents are stable for 6 months.
Instruction for use (Preparation of each solution)
Weigh 50 ~ 100 mg of each reagent by chemical balance, to the nearest 0.1mg.
Add ethanol or hexane to dissolve the reagent to the final concentration of 1 mg vitamin homologue/mL as the stock solution. The stock solution in tightly capped vials are stable at 5 degrees C for a month.
The standard solutions for each homologue can be prepared by dilution the stock solution just before use.
1072                     rac-α-Tocopherol 50 mg  95+% TLC/98+% GC
1071                     rac-β-Tocopherol 50 mg  95+% TLC/98+% GC
1073                     rac-γ-Tocopherol  50 mg  95+% TLC/98+% GC
1790                     δ-Tocopherol        50 mg   95+% TLC/98+% GC
1074           rac-5,7-Dimethyltocol    50 mg  95+% TLC/98+% GC
1797                      Tocol                      50 mg  95+% TLC/98+% GC
α β γ δ -   三烯生育酚 标准品
Research use only. Do not administer it to human.
2109          α-Tocotrienol    25 mg  98+% TLC/98+% GC
2110          β-Tocotrienol    25 mg  98+% TLC/98+% GC
2111          γ- Tocotrienol    25 mg  98+% TLC/98+% GC
2112          δ-Tocotrienol    25 mg  98+% TLC/98+% GC
References:
1. Ahn, K., et al. (2007) J Biol Chem. 282:809-820
2. Kannappan, R., et al. (2010) J Biol Chem. 285:33520
3. Tan, B., (2005) The Journal of the American Neutricutical Association 8(1):35
4. Kannappan, R., et al. (2012) Genes Nutr. 7:43-52
5. Mangialasche, F., et al. (2012) Neurobiol. Aging 33(10):2282-2290
6. Patel, V., et al. (2011) Indian J Exp Biol. 49(10):732-738
7. Vasanthi, HR., et al. (2011) Curr Pharm Des. 17(21):2170-2175
     Vitamin E consists of four tocopherols and four tocotrienols that demonstrate important and far reaching biological activities.  These essential lipids contain a common chromanol ring and either a saturated (tocopherol) or unsaturated (tocotrienol) side chain.  The eight common vitamin E isoforms (α-, β-, γ-, and δ-tocopherols and α-, β-, γ-, and δ-tocotrienols) are differentiated based on the number and position of methyl groups on the chromanol ring and the presence of a saturated or unsaturated side chain (figure 1 (pg. 2)).  The vitamin E vitamers are commonly found in vegetables, fruits, seeds, nuts, grains and oils, where they exist in various ratios with each other.  The unsaturated side chain in tocotrienols gives them physical properties different from tocopherols, such as an increased ability to cross the cell membrane bilayer (1).  Vitamin E has become well known for its role as an antioxidant, in lowering cholesterol and other lipids, as a neuroprotective and anti-cancer agent, and in cardiovascular disease protection.  Most vitamin E supplements contain (and many studies use) only α-tocopherol; however, several of the above biological effects are mostly or exclusively found in the other vitamers, making it critical for them to be included in future research.  Indeed, the tocotrienols in general may have greater physiological functions than tocopherols (2) and may even be inhibited by an unbalanced excess of α-tocopherol supplements (3).
    Scientists at the MD Anderson Cancer Center wrote an excellent article entitled “Tocotrienols fight cancer by targeting multiple cell signaling pathways” (4).  Here it is suggested that since tumor cells result from dysregulation of multiple genes a drug is needed that will also target multiple genes.  Tocotrienols affect numerous pathways linked with tumorigenesis and thus have potential in both the prevention and treatment of cancer as an active and mild anti-cancer drug.
     A recent report from the Karolinska Institute in Sweden described the neuroprotective activity of tocopherols and tocotrienols (5).  It is indicated that low plasma tocopherol and tocotrienol levels are associated with an increased incidence of mild cognitive impairment and Alzheimer’s disease.  Another report indicates that α-tocotrienol is the most potent neuroprotective form of vitamin E, inhibiting 12-LOX, c-Src, and PLA2, up-regulating MRP1, and inducing arteriogenesis through induction of TIMP1 and decreased activation of MMP2 (6).
     Another beneficial function of tocopherols and tocotrienols is their role in preventing cardiovascular disease.  The tocotrienols particularly have gained eminence recently due to an increased understanding of their antioxidant effects.  Cardioprotective effects of tocotrienols include antagonizing the oxidation of low density lipoproteins, anti-atherosclerotic properties, inhibiting platelet aggregation and monocytes adhesion, and preventing smooth muscle proliferation (7).
    Since its discovery, vitamin E has been shown to be a versatile and potent component of biological systems.  α-Tocopherol has received much praise over the years due to its remarkable functions; now the less prevalent tocopherols and tocotrienols are starting to gain recognition as indispensable components of the vitamin E family.  As Kannappan et al. point out more than 25,000 studies have been conducted on tocopherol while very few studies have considered the role of tocotrienols (4).
But this is sure to change as more scientists become aware that “The multitargeted role of tocotrienols in most degenerative diseases proves it to be an ideal candidate as a nutraceutical/pharmaceutical agent for useful exploitation” (7).  Matreya is pleased to introduce the full line of highly purified Tocopherols and Tocotrienols along with Tocols as internal standard markers.  We have the capability to produce these compounds in multigram sizes to accommodate your research.
母育酚
dl-Tocol         250mg    97+ %
用途:生体内等のビタミンEの定量に使用される内標準物質「トコール」です    30306921
其它维生素 系列产品 Vitamin
水溶性维生素
烟酸    Nicotinic acid    C 15521000/250mg
盐酸吡哆醛(B6)    Pyridoxal hydrochloride    /
二盐酸吡哆胺(B6)    Pyridoxamine dihydrchloride    /
抗坏血酸钠    Sodium ascorbate    C 10303900/250mg
盐酸硫胺(B1)    Vitamin B1 hydrochloride    C 17455000/250mg
硝酸硫胺(B1)    Vitamin B1 mononitrate    C 17455500/250mg
核黄素(B2)    Vitamin B2    C 16813600/250mg
烟酰胺(B3/B5)    Nicotinamide    C 15519500/250mg
泛酸钙(B3/B5)    Calcium pantothenate    CA15845000/250mg
泛酸钠    D-Pantothenic acid sodium salt    C 15845100/250mg
吡哆素(B6)    Vitamin B6    /
盐酸吡哆素(B6)    Vitamin B6 hydrochloride    C 16652000/250mg
氰钴胺素(B12)    Vitamin B12    CA11798500/50mg
对氨苯甲酸Bx    Vitamin Bx    C 10171400/100mg
抗坏血酸(C)    Vitamin C    C 10303000/250mg
抗坏血酸钙(C)    Calcium ascorbate    C 10303100/250mg
异抗坏血酸    D(-)-Isoascorbic acid    C 14379000/250mg
生物素(H)    Vitamin H    C 10625000/250mg
叶酸    Folic acid    C 13888000/250mg
脂溶性维生素
视黄醇    Retinol    R7632-100mg
维生素A酸    Tretinoin    C 17608000/250mg
维生素A乙酸酯    Retinol acetate    CA17923820/150mg
维生素A棕榈酸酯    Retinol palmitate    CA17923840/150mg
胆钙化甾醇(D3)    Cholecalciferol    CA17924000/150mg
DL-a-生育酚(E)    DL-a-Tocopherol    CA17924300/500mg
DL-a-生育酚乙酯    DL-a-Tocopherylacetate    CA17924320/500mg
维生素K1    Phytonadione    C 17924400/250mg
甲萘醌(K3)    Menadione    C 14863000/250mg
b-胡萝卜素    b-Carotene    CA11045800/250mg
虾青素    Astaxanthin    CA10307000/250mg
角黄素    Canthaxanthin    CA10947000/150mg
硫辛酸    DL-6,8-Thioctic acid    /
麦角钙化甾醇(D2)    Ergocalciferol    CA17923900/150mg
a-琥珀酸(E)    a-Tocopheryl acid succinate    /
叶黄素    Lutein    CA14652000/50mg
维生素E相关产品:
订货号
中文名称
英文名称
CAS#
规格
价格
VIT-001N
盐酸硫胺/维生素B1
[67-03-8]
1g
询价
VIT-002N
核黄素/维生素B2
Vitamin B2
[83-88-5]
1g
询价
C16813600
维生素B2
(-)-Riboflavin (Vitamin B2)
[83-88-5]
0.25g
330
VIT-005N
烟酸/维生素B3
Nicotinic Acid
[59-67-6]
1g
询价
C15519500
烟酰胺/维生素PP
Nicotinamide
[98-92-0]
0.25g
330
VIT-006N
烟酰胺
Nicotinamide
[98-92-0]
1g
询价
VIT-003N
盐酸吡哆辛/维生素B6
Vitamin B6
[58-56-0]
1g
询价
C13888000
叶酸/维生素Bc
Folic acid
[59-30-3]
0.25g
330
VIT-007N
叶酸 (维生素M)
Vitamin M
[59-30-3]
1g
询价
C10625000
维生素B7/维生素H/D-生物素
D (+)-Biotin
[58-85-5]
0.25g
360
VIT-009N-R1
D-生物素/维生素H
Vitamin H
[58-85-5]
100mg
询价
CA11798500
维生素B12/腈钴胺
Vitamin B12
[68-19-9]
50mg
330
VIT-010N-R1
腈钴胺 (维生素B12)
Vitamin B12
[68-19-9]
25mg
询价
C16880000
维生素P/ 芦丁水合物
Rutin hydrate
[153-18-4]
0.5g
300
VIT-004N
L-抗坏血酸/维生素C
Vitamin C
[50-81-7]
1g
询价
C10303000
L-抗坏血酸/维生素C
L- (+)-Ascorbic acid
[50-81-7]
0.25g
300
VIT-008N
泛酸
D-Pantothenic acid
[137-08-6]
100mg
询价
CA11045800
β-胡萝卜素
beta-Carotene
[7235-40-7]
0.25g
450
CA17923820
维生素A乙酸酯
Vitamin A acetate
[127-47-9]
0.15g
870
VIT-014N
维生素A棕榈酸酯
Vitamin A palmitate
[79-81-2]
100mg
询价
CA17923840
维生素A棕榈酸酯
Vitamin A palmitate
[79-81-2]
0.15g
870
CA17924300
DL-α-维生素E
DL-alpha-Tocopherol
[10191-41-0]
0.5g
405
CA17924320
DL-α-维生素E乙酸酯
DL-alpha-Tocopherylacetate
[7695-91-2]
0.5g
450
CA17923900
维生素D2
Vitamin D2
[50-14-6]
0.1g
405
C13201500
麦角固醇 (维生素D2原)
Ergosterol (Provitamin D2)
[57-87-4]
0.1g
360
CA17924000
胆钙化固醇/维生素D3
Vitamin D3
[67-97-0]
0.15g
450
VIT-013N
胆钙化固醇 (维生素D3)
Vitamin D3
[67-97-0]
100mg
询价
CA17924100
25-羟基-维生素D3一水合物
Vitamin D3 25-hydroxy monohydrate
[63283-36-3]
50mg
945
C17924400
维生素K1
Vitamin K1
[84-80-0]
0.25g
450
VIT-017N
甲萘醌/维生素K2
Vitamin K2
[11032-49-8]
100mg
询价
C14863000
维生素K3
Menadione (Vitamin K3)
[58-27-5]
0.25g
405
011-16641
抗坏血酸标准品
L (+)-Ascorbic Acid Standard
[7488-99-5]
10mg
2,810
035-17981
α-胡萝卜素标准品
α-Carotene Standard
[7235-40-7]
10mg
900
032-17991
β-胡萝卜素标准品
β-Carotene Standard
[79-81-2]
20capsules
560
188-01331
维生素A棕榈酸酯标准溶液
Retinol Palmitate Standard Solution
[83-88-5]
200mg
560
182 -01611
维生素B2标准品
Riboflavin Standard
[58-56-0]
200mg
560
168-20031
吡哆醇盐酸盐标准品
Pyridoxine Hydrochloride Standard
[65-22-5]
200mg
560
165-20041
吡哆醇盐酸盐标准品
Pyridoxal Hydrochloride Standard
[524-36-7]
200mg
1,120
162-20051
盐酸吡多胺标准品
Pyridoxamine DiHydrochloride Standard
[50-81-7]
200mg
400
011-16641
维生素C标准品
[84-80-0]
200mg
2,240
167-19011
维生素K1标准品
Phylloquinone Standard
[27750-10-3]
200mg
790
084-07821
(-)-羟基柠檬酸钙标准品
(-)-Hydroxycitric Acid Calcium Salt Standard
[2124-57-4]
20mg
3,030
133-14331
甲萘醌-7标准品/维生素K2 (35)
Menaquinone-7 Standard
[863-61-6]
100mg
2,470
136-16641
甲萘醌-4标准品/维生素K2 (20)
Menaquinone-4 Standard
1 set
4,900
上海惠诚生物科技有限公司
上海惠诚生物优势品牌系列:
药物: TRC  LGC  USP  LKT
植提标准品: Extrasynthese  PhytoLab  Chromadex  CaroteNature
糖类: Elicityl  TDB  Ludger  Megazyme  Glycarbo
脂类: Nu-Chek  Larodan  Avanti  Matreya
其他: TCI  ERM  Wako  Jackson  Cayman  laysan  Alfa  阿拉丁  麦克林
手机微信:17715331663   QQ:2303607288
上海惠诚生物科技有限公司,成立于2010年,企业宗旨“惠质产品,挚诚服务”。惠诚生物自成立以来,一直致力于为客户提供一站式科学服务,产品覆盖设计开发全过程,提供实验室设计、实验室建设、仪器设备、耗材、试剂、技术服务等专项配套服务。上海惠诚生物按照客户的研发、生产和质量控制环节整合各种优质资源,优化资源组合,为客户提供整体解决方案。
上海惠诚生物在上海建立研发中心,在湖北和江苏有生产基地,在广州和深圳建立子公司,立足上海,销售网络遍布全国,为客户提供全方位的综合服务。
“不忘初心,砥砺前行”。 上海惠诚生物经过多年不懈努力,目前产品线包括:生命科学,分析化学,生化试剂和仪器耗材。客户遍布:生物医药,体外诊断,食品行业,石油化工,科研院校和研究所等领域。
特色产品:
生命科学:Crispr系列产品,组织因子,电泳预制胶,荧光染料,核酸探针,大包装新冠抗原抗体,工业用酶
分析化学:糖化学研究,脂类分析,植物分析,聚合物分析,医药分析,试剂盒
生化试剂:PEG衍生物,多肽,大包装胶体金辅料,大包装生物医药辅料,通用生化试剂
仪器耗材:生物上游工艺,生物下游工艺,细胞治疗,微生物监测,理化分析,公用系统。
 品牌服务:
生命科学:
Abcam、AdooQ、ALPCO、Biolegend、Cytiva、Cayman、Dojindo、Immunostar、Invitrogen、Jackson、美天旎Miltenyi、Novoprotein近岸、Prozyme、R&D、SinoBiological义翘、Stratagene、SYSY、Thermo Fisher、Wako、Topoen
分析化学:
AOCS、Carotenature、CIL、DR、Elicityl、EP、Glycarbo、Larodan、Matreya、Megazyme、Nu-Chek、Olchemim、Phytolab、QCC、Reagecon、TLC、TRC、USP
生化试剂:
Aladdin阿拉丁、Avanti、Broadpharm、Focus、Laysan、LKT、Macklin麦克林、Sigma、TCI、Thermo Fisher、vivitide
仪器耗材:
湘仪、精骐、Corning、Eppordorf、浙江孚夏、力康、海尔、汇松、赫西、Mettler Toledo、Millipore、NEST、松下、Pall、Rainin瑞宁、Whatman、上海一恒
专业服务团队:公司创始人及团队全部拥有生物医药专业学术背景,有多年科研产品从业经验,能为客户提供良好的产品解决方案。
浦东新区
