12通道肌电设备
AnEMG12
12-channel EMG (surface/intramuscular)
and EEG amplifier with BNC and SCSI Analog output
12通道肌电图(表面/肌肉)
与BNC和SCSI模拟输出的脑电放大器
General Description: AnEMG12 is a multichannel analog amplifier for bioelectrical signals surface electromyographic signals (sEMG), intramuscular electromyographic signals (iEMG), electroencephalographic signals (EEG) and electrocardiographic signals (ECG). The AnEMG12 can amplify 12 bioelectrical signals in two modalities monopolar and differential. Selectable gain can be modified for each inputs. AnEMG12 instrument is completely safe for the patient. The safety is achieved by means of medical grade electrical insulation of all the circuitry connected to the patient.The signals acquired by the instrument are amplified, filtered, digitally converted optocoupled and than analogue converted and then available at BNC or SCSI Analog Output connectors.
Deatails: AnEMG12 allow acquiring, in any configuration, 4 additional signals on the auxiliary inputs (AUX-INPUTS). The signals can be generated by other amplifiers (e.g. force, torque, angle, position or trigger signals) that do not need an optical insulation.
Developped with: Ernest N. Kamavuako, Head of Laboratory for Invasive Myoelectric Control, Department of Health Science and Technology, Aalborg University, Denmark
Class | II BF |
Numer of Channels | 12 channels iEMG, sEMG, EEG ed ECG + 4 Auxiliary Inputs |
Selectable Gains | OFF, 100, 200, 500 1000, 2000, 5000, 10000 V/V |
Selectable bandwidth | High pass filter: 3, 10, 100, 200 Hz Low pass filter: 130, 500, 900, 4400Hz |
Input range | 0 - 50 mVPP |
Noise level referred to input | < 4 μVRMS |
Input impedance | > 1012 Ω |
CMRR | > 95 dB |
Output Range | 0 - 5 VPP |
Dimensions | 350 mm x 85 mm x 250 mm |
瑞鸿安(广东)医疗器械有限公司是意大利OT Bioelettronica在中国的总代理,总部坐落于中国广州,主要经营各类实验室仪器、分析仪器以及最新的健身、体能测试、体能训练、体能恢复、生物医学、运动心理学、运动生理学、运动员选材、康复医疗、康复指导、仿生假肢设计、负荷评估、生物反馈训练、人体工程学、机器人技术、脑机接品可用生测试等产品、并提供设计、安装、培训等 全方位服务,以及实验室建设。公司现在主要代理和经销意大利OT 各类高密度肌电、穿戴式无线高密度肌电、无线表面肌电,脑电等采集分析系统。
OT Bioelettronica 公司2007年在意大利都灵成立。OT公司的高密度肌电、无线表面肌电、动态高密度肌电采集分析等设备已在200多个学术期刊上发表论文超过1000篇,其中包括Nature、Science等国际顶尖科学分票,充分证明了其在生物电信号研究领域的卓越性能和广泛认可。
