其他实验耗材
D-Torch Quartz Outer Tube 4/5/7300 V
进口
PerkinElmer/珀金埃尔默
N0777053
面议
D-Torch w/ Quartz Outer Tube for Optima 4300/5300/7300 V[3-Slot Quartz Outer Tube for Optima]
[3-Slot Quartz Outer Tube for Optima]Quartz outer Tube for D-Torch™ used with Optima™ 4300 V, 5300 V, and 7300 V ICP-OES series instruments.
部件号 N0777053
The D-Torch is a revolutionary new demountable torch design with interchangeable outer Tubes. Quartz outer Tubes are ideal for most aqueous samples, while ceramic outer Tubes last longer for samples with high dissolving solids or for organic applications, such as wear metals in engine oils.
规格
材料 Quartz
型号兼容 Optima 5300 V, Optima 7300 V, Optima 4300 V
产品品牌名称 D-Torch
产品组 Outer Tubes
技术类型 ICP-OES
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
上海市松江区涞寅路1025号立同商务广场3067室
