罗门哈斯1200NA同级别高温混床阳离子树脂
美国杜笙Tulsion® T-42 UPS 阳离子树脂
ISO-9001/ISO-
混床均粒强酸形阳树脂 , 氢 H+ / 钠 Na+均粒强酸性阳离子适用于超 纯水的可再生混床系统
Tulsion® T-42 UPS 强酸型阳性离子交换樹脂 ,是一款有较高的交换容量 ,及同时拥有**的物理及化学稳定品质。可应用于汽电共生发电厂冷凝水处理及混床系統, 去除水中的阳性离子 。
Tulsion® T-42 UPS 其均勻的颗粒直径, 能取代传统的离子交换樹脂, 並可以减少压力损, 可以和Tulsion A-23 UPS 一起搭配使用於2B3T及超纯水可再生的混床。
典型特性(TYPICAL CHARACTERISTICS): Tulsion T-42 UPS
主体结构/Matrix structure Cross linked polystyrene
型式(Type) Strong acid Cation exchange resin
物理型式/Physical form 湿润球状/Moist spherical beads
官能团/Functional group 磺酸基/Sulphonic
粒径Particle size (Mesh) Particle less than 0.3mm max. 1%
均匀系数(Uniformity coefficient) Max. 1.25
平均粒径(Harmonic Mean size) 580 + 50 um
全交换容量(Total Exchange Capacity) 1.80 meq/ ml
离子型式(Ionic form) Hydrogen (H+)
膨胀係数(Swelling (approximately)) 7% from Na+ to H+ form.
湿度/Moisture content 53%
密度(Backwash settled density) 800-840 g/l in H+ form 830-870 g/l in Na+ form
允许温度(Maximum temp. stability) 120°C in H+ form 140°C in Na+form
PH范围/PH range 0 - 14
溶解率(Solubility) Insoluble in all common solvents
操作条件(OPERATION CONDITIONS): Tulsion T-42 UPS
操作溫度(Operating temperature , max 0 C) 120
操作pH 范围(Operating pH range ) 0 – 14
树脂床高度(Bed depth , mini mm) 800**(Service flow rate ,Maxi )
逆洗水量(Backwash flow rate) 9 to 25 m3/hr/ m3
逆洗浮動空間(Back wash expansion) 40 to 75%
再生药剂(Regenerant ) HCl, H2SO4 for H+ form,
再生药剂用量(Regeneration levels. ) 30 to 120 gms HCl/ lit. 40 to 250 gms H2SO4/ lit.
再生药剂浓度(Regeneration concentration) 3 - 5% HCl, 1.5 to 3% H2SO4
通再生药剂时间(Regeneration Contact time, mini) 20 min.
再生流量(Regeneration flow rate ) 5 to 16 m3/hr/ m3Regeneration slow rinse 2 BV mini.
快洗用水(Fast Rinse ) Service flow rate.
快洗水量(Fast Rinse Volume) 2 to 3 BV
| 单位名称: |
孝南区澴川路南方 国际C座写字楼7楼
| 联系电话: |
| Email: |
