特别提示:包括重组小鼠TNFRSF1B在内,本公司的所有产品仅可用于科研实验,严禁用于临床医疗及其他非科研用途!
产品名称:重组小鼠TNFRSF1B
英文名称:Recombinant Mouse Tumor Necrosis Factor Receptor II
产品货号:JN0472
产品规格:10μg|50μg|500μg|1mg
本品由我们的哺乳动物细胞表达系统制备而成,目的基因编码的Val23-Gly258在C端含有His标签。
TNFRSF1B质量控制:>95%(还原性SDS-PAGE)
TNFRSF1B制剂:冻干品
TNFRSF1B保存:
冻干蛋白置于-20℃以下可长期保存,室温条件下可稳定保存3周。
复溶蛋白溶液可在4~7℃保存2~7天,可分装后置于-20℃保存三个月。
TNFRSF1B复溶:
打开试剂管前请先离心。
复溶浓度推荐大于100 μg/ml。
冻干蛋白请溶于ddH2O。
复溶后,请根据用量分装冻存,避免反复冻融。
关于TNFRSF1B:
Tumor Necrosis Factor Receptor Superfamily Member 1B (TNFRSF1B) is a member of the Tumor Necrosis Factor Receptor Superfamily. TNFRSF1B contains four TNFR-Cys repeats. TNFRSF1B can be cleaved into the following 2 chains: Tumor necrosis factor receptor superfamily member 1b and membrane form and Tumor necrosis factor-binding protein 2. TNFRSF1B is a receptor with high affinity for TNFSF2/TNF-α and approximately 5-fold lower affinity for homotrimeric TNFSF1/lymphotoxin-α. TNFRSF1B mediates most of the metabolic effects of TNF-α. TNF-α-induced apoptosis suggests that it regulates TNF-α function by antagonizing its biological activity.
根据您的关注的
重组小鼠TNFRSF1B,重组Tumor Necrosis Factor Receptor II,重组小鼠Tumor Necrosis Factor Receptor II,Recombinant Mouse Tumor Necrosis Factor Receptor II,您可能还对以下产品有需求:
名称:重组小鼠DR6(TNFRSF21)
货号:JN0465
本品由我们的哺乳动物细胞表达系统制备而成,目的基因编码的Gln42-His349在C端含有Fc标签和His标签
DR6/TNFRSF21质量控制:>95%(还原性SDS-PAGE)
DR6/TNFRSF21制剂:冻干品
DR6/TNFRSF21保存:
DR6/TNFRSF21复溶:
打开试剂管前请先离心。
复溶浓度推荐大于100 μg/ml。
冻干蛋白请溶于ddH2O。
关于DR6/TNFRSF21:
Tumor necrosis factor receptor superfamily member 21(DR6) is a single-pass type I membrane protein and contains 1 death domain and 4 TNFR-Cys repeats. The protein may activate NF-kappa-B and promote apoptosis and it may activate JNK and be involved in T-cell differentiation.It is required for both normal cell body death and axonal pruning. Trophic-factor deprivation triggers the cleavage of surface APP by beta-secretase to release sAPP-beta which is further cleaved to release an N-terminal fragment of APP (N-APP). N-APP binds TNFRSF21 triggering caspase activation and degeneration of both neuronal cell bodies (via caspase-3) and axons (via caspase-6).
.jpg)
关注
重组小鼠TNFRSF1B,重组Tumor Necrosis Factor Receptor II,重组小鼠Tumor Necrosis Factor Receptor II,Recombinant Mouse Tumor Necrosis Factor Receptor II的同时,为您推荐更多您可能感兴趣的产品:
