细胞生物学试剂
盐酸氨溴索(23828-92-4)(≥99%)
Ambroxol HCl
百奥莱博
特别提示:包括盐酸氨溴索在内,本公司的所有产品仅可用于科研实验,严禁用于临床医疗及其他非科研用途!
产品名称:盐酸氨溴索
英文名称:Ambroxol HCl
产品货号:L10031
产品规格:5g|25g
属性
CAS号 23828-92-4,18683-91-5
分子式 C13H18Br2N2O·HCl
分子量 414.56
溶解性 Soluble in methanol,water(~5mg/ml),ethanol(~5mg/ml),and DMSO(50mM).Insoluble in ether.
描述
应用 An expectorant antioxidant and antiinflammatory agent
产品介绍 Ambroxol HCl是有效的神经性钠离子通道抑制剂,抑制抗TTX的钠离子电流,相位性阻滞,IC50为22.5μM,抑制对TTX敏感的钠离子电流,IC50为100 μM。Phase 3。
备注 AmbroxolHCl is a potent inhibitor of the neuronalNa+ channels,inhibits TTX-resistant Na+ currents withIC50of 35.2 μM and 22.5μM for tonic and phasic block,inhibits TTX-sensitive Na+ currents withIC50of 100 μM.Phase 3.
生化机理 Ambroxol hydrochloride is a small molecule expectorant and mucolytic agent with antioxidant and antiinflammatory effects.Ambroxol stimulates the secretion of surfactant which decreases mucus adhesion to the bronchial lining and produces expectorant effects.The antioxidant effects of Ambroxol are well demonstrated,where lipid peroxidation initiated by t-butyl hydroperoxide or doxorubicin is suppressed in the presence Ambroxol,and scavenging of hydroxyl radicals and cellular superoxide radical anions is also observed.Ambroxol produces antiinflammatory effects by blocking the expression of proinflammatory messengers,inhibiting the release of histamine from mast cells and the generation of cytokines and interleukins.Ambroxol hydrochloride is an inhibitor of Sodium Channel Protein.
别名 氨溴索盐酸盐;2-氨基-3,5-二溴-N-(反式-4-羟基环己基)苄胺;Ambroxol Hydrochloride;trans-4-[(2-Amino-3,5-dibromobenzyl)amino]cyclohexanol Hydrochloride;2-Amino-3,5-dibromo-N-(trans-4-hydroxycyclohexyl)benzylamine
根据您的关注的盐酸氨溴索(23828-92-4)(≥99%),Ambroxol Hydrochloride,trans-4-[(2-Amino-3,5-dibromobenzyl)amino]cyclohexanol Hydrochloride,2-氨基-3,5-二溴-N-(反式-4-羟基环己基)苄胺,2-Amino-3,5-dibromo-N-(trans-4-hydroxycyclohexyl)benzylamine,氨溴索盐酸盐,您可能还对以下产品有需求:
KFS267 Ac-YVAD-FMK(caspase 4 抑制剂) 20μl
M00157 caspase-3抑制剂(Z-DEVD-FMK) 1mL(10mM)|1mg|5mg|10mg
M00519 CDK7抑制剂(BS-181) 1mL(10mM)|2mg|5mg|10mg|50mg
M01365 Aurora A/Aurora B和Aurora C抑制剂(PHA-680632) 1mL(10mM)|5mg|10mg|50mg|100mg
M01644 p70S6K信号转导抑制剂(LY-2584702 free base) 1mL(10mM)|5mg|50mg
M01910 FGFR1-4抑制剂(PRN1371) 1mL(10mM)|1mg|5mg|10mg|50mg|100mg
M02120 Mps1抑制剂(Mps1-IN-2) 1mL(10mM)|5mg|10mg|50mg|100mg
关注盐酸氨溴索(23828-92-4)(≥99%),Ambroxol Hydrochloride,trans-4-[(2-Amino-3,5-dibromobenzyl)amino]cyclohexanol Hydrochloride,2-氨基-3,5-二溴-N-(反式-4-羟基环己基)苄胺,2-Amino-3,5-dibromo-N-(trans-4-hydroxycyclohexyl)benzylamine,氨溴索盐酸盐的同时,为您推荐更多您可能感兴趣的产品:
名称:TRPV1激动剂(Capsaicin)
货号:M00170
规格:1mL(10mM)|50mg|100mg
Capsaicin是一种TRPV1激动剂,作用HEK293细胞,EC50为0.29±0.05μM。
注:本品仅可用于科研实验,严禁用于临床医疗及其他用途!
CAS号:404-86-4
别名:(E)-Capsaicin;8-Methyl-N-vanillyl-trans-6-nonenamide
纯度:98.39%
分子式:C₁₈H₂₇NO₃
分子量:305.41
结构式:
Capsaicin结构式
储存条件:-20℃,有效期2年,溶入溶剂后-20℃请尽量在一个月内使用。
名称:B-RafV600E抑制剂(PLX-4720)
货号:M00369
规格:1mL(10mM)|5mg|10mg|25mg|50mg|100mg|200mg
PLX-4720是一种有效的,选择性的B-RafV600E抑制剂,IC50值为13nM;与对c-Raf-1的选择性相同,是对野生型B-Raf选择性的10倍。
CAS号:918505-84-7
纯度:99.62%
分子式:C₁₇H₁₄ClF₂N₃O₃S
分子量:413.83
结构式:
PLX-4720结构式
名称:广谱吡咯-嘧啶抑制剂
货号:M00652
规格:1mL(10mM)|10mg|50mg
A419259trihydrochloride是一种广谱的吡咯-嘧啶抑制剂,增强对Src家族的选择性,作用于Src,Lck和Lyn,IC50分别为9nM,<3nM和<3nM。
CAS号:1435934-25-0
别名:RK 20449 trihydrochloride
纯度:96.98%
分子式:C₂₉H₃₇Cl₃N₆O
分子量:592.0
结构式:
A 419259 trihydrochloride结构式
北京百奥莱博科技有限公司一家专注于生命科学研究领域的生物技术公司,坚持“质量至上,服务为本,全心全意助力生命科学”的理念,为广大用于提供稳定、可靠、专业的产品和服务支持,产品线包括分子生物学,细胞生物学,免疫检测,抗体,重组蛋白,血液制品等系列。“忙忙碌碌的平凡,铸就事业的不凡”。让我们携起手来,共同创造生命科学的蓬勃发展。
海淀区紫雀路33号院3号楼
