分子生物学试剂
重组大鼠IL-33
重组大鼠IL-33
Recombinant Rat Interleukin 33
百奥莱博
GS4577
特别提示:包括重组大鼠IL-33在内,本公司的所有产品仅可用于科研实验,严禁用于临床医疗及其他非科研用途!
产品名称:重组大鼠IL-33
英文名称:Recombinant Rat Interleukin 33
产品货号:GS4577
产品规格:2μg
分子量:Approximately 17.4kDa,a single non-glycosylated polypeptide chain containing 156 amino acids.
储存条件:冷冻(-20℃)
概述
Interleukin-33(IL-33),also known as NF-HEV and DVS 27,is a cytokine belonging to the IL-1 superfamily.It is also a proinflammatory protein that may regulate gene transcription and it induces helper T cells,mast cells,eosinophils and basophils to produce type 2 cytokines.The induction of type 2 cytokines by IL-33 in vivo is believed to induce the severe pathological changes observed in mucosal organs following administration of IL-33.IL-33 is constitutively expressed in smooth muscle and airway epithelia and it binds to a high-affinity receptor family member ST2.In vivo administration of mature IL-33 promotes increased production of IL-5,IL-13,IgE,and IgA,as well as splenomegaly and inflammatory infiltration of mucosal tissues.Recombinant rat IL-3 contains 156 amino acid residues and it shares 59%a.a.and 90%sequence identity with human and murine IL-33.
使用说明
This material is offered by Biorab Biotech for research,laboratory or further evaluation purposes.NOT FOR HUMAN USE.
技术规格
外观 Sterile Filtered White lyophilized(freeze-dried)powder.
纯度 >95%by SDS-PAGE and HPLC analyses.
来源 Escherichia coli.
生物活性 Fully biologically active when compared to standard.The ED50 as determined by a cell proliferation assay using murine D10S cells is less than 0.5ng/ml,corresponding to a specific activity of>2.0×106 IU/mg.
成分 Lyophilized from a 0.2μmfiltered concentrated solution in 20mMTris,300 mM NaCl,pH 8.5.
内毒素 Less than 1 EU/μg of rRtIL-33 as determined by LAL method.
复溶 We recommend that this vial be briefly centrifuged prior to opening to bring the contents to the bottom.Reconstitute in sterile distilled water or aqueous buffer containing 0.1%BSA to a concentration of 0.1-1.0mg/mL.Stock solutions should be apportioned into working aliquots and stored at ≤ -20 ℃.Further dilutions should be made in appropriate buffered solutions.
氨基酸序列 SIQGTSLLTE SCALSTYNDQ SVSFVLENGC YVINVEDCGK NQEKDKVLLR YYESSFPAQS GDGVDGKKLM VNMSPIKDTD IWLNANDKDY SVELQKGDVS PPDQAFFVLH KKSSDFVSFE CKNLPGTYIG VKDNQLALVE ENDESCNNIM FKLSKM
根据您的关注的重组大鼠IL-33,IL-33, Rat,重组Interleukin 33,Recombinant Rat Interleukin 33,重组大鼠Interleukin 33,您可能还对以下产品有需求:
名称:重组人VEGF-A(血管内皮生长因子)(VEGF164)
货号:JN0252
规格:10μg|50μg|500μg|1mg
本品由我们的酵母表达系统制备,目的基因编码的Ala27-Arg190表达纯化而来。
VEGF164质量控制:>95%(还原性SDS-PAGE)。
VEGF164制剂:冻干品
VEGF164保存
冻干蛋白可在-20℃长期保存,室温也可稳定保存3周。
复溶蛋白溶液可在4~7℃保存2~7天。
复溶后建议分装冻存在-20℃,可保存3个月,应避免反复冻融。
VEGF164复溶
1、试剂开盖前请先离心。
2、复溶浓度应大于100 μg/ml.
3、冻干蛋白溶于ddH2O中
4、复溶后根据使用量分装保存,避免反复冻融。
关于VEGF164
Mouse Vascular endothelial growth factor (VEGF or VEGF­A), is a potent mediator of both angiogenesis and vasculogenesis in the fetus and adult. It is a member of the PDGF/VEGF growth factor family that is characterized by a cystine knot structure formed by eight conserved cysteine residues. Alternately spliced isoforms of 120, 164 and 188 aa found in mouse. VEGF binds the type I transmembrane receptor tyrosine kinases VEGF R1 (also called Flt­1) and VEGF R2 (Flk­/KDR) on endothelial cells.Although affinity is highest for binding to VEGF R1, VEGF R2 appears to be the primary mediator of VEGF angiogenic activity. VEGF is required during embryogenesis to regulate the proliferation, migration, and survival of endothelial cells.It may play a role in increasing vascular permeability during lactation, when increased transport of molecules from the blood is required for efficient milk protein synthesis.
关注重组大鼠IL-33,IL-33, Rat,重组Interleukin 33,Recombinant Rat Interleukin 33,重组大鼠Interleukin 33的同时,为您推荐更多您可能感兴趣的产品:
JN0266 重组人肝细胞生长因子(HGF) 10μg|50μg|500μg|1mg
JN0372 重组人白介素18结合蛋白 10μg|50μg|500μg|1mg
JN0403 重组人白介素IL-23(白细胞介素23) 10μg|50μg|500μg|1mg
JN1904 重组小鼠补体C5 10μg|50μg|500μg|1mg
JN1905 重组人膜联蛋白A1(Annexin A1) 10μg|50μg|500μg|1mg
JN1993 重组人真核翻译起始因子1A,X染色体(EIF1AX) 10μg|50μg|500μg|1mg
JN0519 重组人柯萨奇-腺病毒受体(CAR) 10μg|50μg|500μg|1mg
北京百奥莱博科技有限公司一家专注于生命科学研究领域的生物技术公司,坚持“质量至上,服务为本,全心全意助力生命科学”的理念,为广大用于提供稳定、可靠、专业的产品和服务支持,产品线包括分子生物学,细胞生物学,免疫检测,抗体,重组蛋白,血液制品等系列。“忙忙碌碌的平凡,铸就事业的不凡”。让我们携起手来,共同创造生命科学的蓬勃发展。
海淀区紫雀路33号院3号楼
