倒置显微镜
U-LGPS LED and LDP Light Source
OLYMPUS
进口
OLYMPUS
U-LGPS
Enhance your fluorescence imaging with our high-brightness U-LGPS light source. Using solid state LED and LDP (laser-diode-pumped phosphor) technology, the U-LGPS light source delivers accurate, reproducible, and efficient illumination.
Mercury-Free
To maintain proper illumination, the bulbs of mercury and metal halide light sources must be changed on a routine basis, involving costly mercury disposal procedures. The U-LGPS light source is mercury free, eliminating the inconveniences and costs associated with the disposal of bulbs containing mercury.
Perform Reliable and Efficient Experiments
When combined with an optimized microscope, the U-LGPS light source makes it possible to perform reliable experiments easily and efficiently:
  • Accurate data acquisition and processing due to uniform illumination
  • Illumination method through the liquid light guide minimizes equipment vibration and heat conduction, enabling stable experiments
  • Turns on and off rapidly
  • Reproducible and stable light intensity
  • Control through cellSens imaging software helps mitigate human error, and programmable experiments in combination with coded/motorized units improve efficiency
BPAE cells with MitoTracker Red CMXRos, Alexa Fluor 488 Phalloidin, and DAPI.
Increase Your Lab’s Equipment Uptime
Save on labor and costs and increase the uptime of your lab equipment thanks to the U-LGPS light source’s easy upkeep:
  • Free optical adjustment with precentered design
  • Long life of solid-state light source―more than 25,000 hours―nearly eliminates maintenance
  • Economical running costs due to lower power consumption
U-LGPS with liquid light guide
产品详情请点击链接:https://www.olympus-lifescience.com.cn/zh/light-sources/u-lgps/
在 Evident,我们以科学精神引领——创新和探索是我们工作的核心。我们致力于让人们的生活更健康、更安全、更充实。我们为客户提供解决他们所面临的挑战及工作中的解决方案;从研究医学突破、检测基础设施,到航空航天,电子半导体中的隐藏隐患,都会有我们的参与。
Evident 工业领域解决方案,从显微镜、视频内窥镜到用于维护、制造和环境应用的无损检测设备及 X 射线分析仪。 Evident的产品以最先进的技术为后盾,广泛用于质量控制、检验和测量。
Evident 生命科学领域解决方案,通过将尖端的生命科学解决方案融入科学家和科研人员的研究工作中,为他们提供强有力的支持。 Evident生命科学领域解决方案,致力于应对各种挑战并满足客户不断变化的需求,致力于推进全面的临床研究、教育和优质显微镜及显微镜系统的开发及应用。
售后服务热线:400 801 5530
上海市徐汇区淮海中路1010号嘉华中心32F
