光谱/分光光度计
Thermo适配炬管、雾化室、雾化器和备件
Thermo 6300/6500
进口
SCP SCIENCE
Thermo 6300/6500
Nebulizers 雾化器
Description Category Cross Reference Catalog Number
Concentric (Type K, 2 ml/min @ 35 psi) Nebulizer 842312051431 020-060-008
Noordermeer V-Groove  Nebulizer Nebulizer 842312051321  020-060-602
Mira Mist®, Teflon® (0.2 - 2.5 ml/min @ 40 psi) Nebulizer 842312051471  020-060-306
Concentric (C-Type, 2.0 ml/min, Ar @ 35 psi) Nebulizer 842312051331  020-060-006
Torches 炬管
iCAP 6000 Radial Torch Torch 842312051141 020-049-002
iCAP Duo Torch Torch 842312051241 020-049-001
Injector 1.0 mm, iCAP 6x00 Injector 842312051341 020-050-107
Injector 1.5 mm, iCAP 6x00 Injector 842312051351 020-050-105
Injector 2.0 mm, iCAP 6x00 Injector 842312051371 020-050-106
iCAP6x00 Alumina injector 2.0mm Injector 842312051361 020-050-122
Spray Chambers and accessories  雾化室
Cyclonic spray chamber iCAP 6500,
18/9 Socket, 4mm drain
Spray chamber 842312051411 020-050-001
Spray chamber adaptor 18/9 ball joint Spray chamber 842312051251 020-050-103
Cyclonic spray chamber adapter, Radial, iCAP 6x00 Spray chamber 842312051151 020-050-104
Cyclonic non-baffle, 12/5, jacket, quartz Spray chamber --- 020-057-125
Cyclonic, 10 mm drain, non-baffle, 12/5 top
with jacket
Spray chamber --- 020-057-124
Cyclonic iCAP 6000 with baffle, 18/9 socket Spray chamber 842312051311 020-049-003
Cyclonic iCAP 6000 with baffle with jacket Spray chamber 842312051441 020-049-004
Conical spray chamber, Ultem Spray Chamber 4600295 020-051-128
Ultem cyclonic spray chamber, no baffle Spray Chamber --- 020-051-111
Cyclonic spray chamber (with baffle) Spray Chamber --- 020-051-211
Spray chamber adaptor for iCAP6x00 Duo, Ultem (connects to Ultem spray chamber 020-051-111 or 020-051-211 to become iCAP inert spray chamber 842312051461) Adapter --- 020-050-456
Spray chamber adaptor for iCAP6x00 Radial, Ultem (connects to Ultem spray chamber 020-051-111 or 020-051-211 to become iCAP inert spray chamber 842312051451) Adapter --- 020-050-457
Peristaltic Pump Tubing 蠕动泵管
Pump sample tubing, aqueous Peristaltic Pump Tubing 842312051511 020-030-006
Pump drain tubing, aqueous Peristaltic Pump Tubing 842312051521 020-030-009
我公司主要经营现经营“DUKSAN”“SCP SCIENCE”“CONOSTAN”“J.T.Baker”“Fisher”等品牌的色谱试剂    农残试剂  、电子试剂 、超干级试剂、LC/MS试剂、SPE产品及耗材等。
另我公司专业销售原装进口的ICP-OES发射光谱和ICP-MS等离子体质谱仪相关备件及消耗品,产品包括两大类:
一、ICP-OES及ICP-MS的备品备件,适用于铂金埃尔默(PE)、热电(Thermo)、安捷伦(Agilent)、瓦里安(Varian)、斯派克(Spectro)、利曼(Leeman)、岛津(Shimadzu)等国内主流品牌仪器
1、各种炬管,包括一体或可拆卸,以及相应的组成部件如炬管体、石英、刚玉喷射管
2、各种雾室,从材质分,包括常规的玻璃、石英雾化室以及耐腐蚀的Ultem和TeflonScott雾室;从构造分,提供Scott、旋流、梨形、有缓冲和无缓冲等各种形式。
3、各类型雾化器:同心、巴宾顿、十字交叉、耐高盐、耐HF等各种材质、各种构造的雾化器,满足各种应用
4、蠕动泵管、排液管,包括各种口径和不同材质,适用于水相和各种有机相基体样品
5、ICP-MS质谱仪采样锥和截取锥,均采用电铸工艺制造,比常规加工的锥体更具优越的边缘和内部的几何结构,降低了气流的干扰,使用寿命更长。
二、各种水基标准溶液和油基标准品
1、Conostan油标,由全资子公司、全球著名的油基标准生产厂家CONOSTAN公司生产,广泛用于ICP光谱和ICP质谱以及粘度计和颗粒计数器。在润滑油、石化、原油、机械、军事、电力等行业有大量应用
2、各种水基标准,原子吸收级单标;ICP-OES、ICP-MS级高纯单标、种类繁多的混合标液;针对特定应用的定制混合标样;
我公司产品由著名的加拿大SCP SCIENCE提供,其为各大品牌的光谱生产厂商提供了大量优质贴牌产品,保质保用,同时提供优惠的价格和优质的服务。本公司常年备有大量库存,第一时间解决客户不时之需
北京海淀区增光路
