光谱/分光光度计
Varian适配炬管、雾化室、雾化器和备件
Varian Liberty Series and Vista
进口
Varian Liberty Seri
Varian Liberty Seri
Torches and Accessories - Radial 炬管
Description Cross Reference Catalog Number
Torch, Low Flow, ICP-AES 20-100696-00 / 20-100696-90 020-050-140
Torch, Varian ICP-AES with Ball Joint 20-100696-00B 020-050-022
Torch, Extended for Nitrogen determination 20-100764-00 020-050-001
Torch Kit, ICP-AES demountable, HF resistant 99-100568-00 020-050-130
Demountable Torch Body Only, HF resistant 20-100729-90 020-050-142
Alumina injector - 1.8mm 24-100675-90 020-050-145
Alumina injector - 2.5mm --- 020-052-346
Quartz injector - 1.8mm 99-100570-00 (3/pack) / 20-100730-00 020-050-144
Quartz injector - 0.8mm 20-100775-00 (3/pack) 020-052-301
Teflon® injector holder, Varian 99-100573-00 020-050-199
Torch bonnet (2/pack) 20-100707-90 020-050-143
Fixed, Radial, 1.5mm injector, 12/5 Female 7910052900 020-054-236
Glass transfer 12/5 male-160, Radial 7910052700 020-050-209
Fixed torch, radial, 2.3mm injector 12/5 female --- 020-054-235
Radial torch, 1.4mm injector, 12/5 2010117500 020-054-234
Torches and Accessories - Axial 炬管
Torch, Low Flow, One piece 20-100812-00 020-052-002
Torch, Low Flow, One piece w/90° stem bend 20-100904-00 020-054-125
Torch, Low Flow, One piece, High Solids 20-100948-00 020-054-080
Torch kit, demountable, HF resistant 99-100847-00 020-052-003
Demountable Torch body only 20-100834-00 020-052-300
020-050-144
Varian Teflon® injector holder 99-100573-00 020-050-199
Glass transfer 12/5 male-206, Axial 7910052800 020-050-194
Quartz Injector, 1.4 mm 9910057000 020-052-302
Torch, Axial 90 degree bend, 2.3mm injector, 12/5 female 7910050700 020-054-225
Axial torch, 1.4mm injector, 12/5 2010104800 020-054-224
Spray Chambers and Accessories 雾化室
Cyclonic Spray Chamber, 12/5 socket top, 4mm drain --- 020-060-124
Optimization solution, Mn, 5 ppm, 125ml --- 140-130-251
Cyclonc Spray Chamber, 50ml 4 drain baffle, 12/5,
short neck, T-Insert
--- 020-054-074
Nebulizers 雾化器
Concentric (C-Type, 1ml/min Ar @ 35psi) 20-100765-00 / 20-100816-00 020-060-003
Concentric (C-Type, 2.5-3.5 ml/min Ar @ 25-40 psi), High Solids 20-100765-00 020-060-006
Concentric (K-Type, 1.0-2.2 ml/min Ar @ 25-40 psi), Low Flow 20-100695-00 020-060-008
Concentric (K-Type, 2.3-4.0 ml/min Ar @ 25-40 psi), Low Flow 20-100816-00 020-060-009
Noordermeer V-Groove MDSN Nebulizer, 0.7L/min to 1.0 @ 35 psi --- 020-060-602
High Solids V-Groove Nebulizer, 0.7L/min Ar @ 35 psi) 99-100574-00 020-060-607
Burgener MiraMist, 0.2-2.5ml/min @ 45 psi (Teflon®) --- 020-060-306
Burgener PEEK MiraMist, 0.2-2.5ml/min @ 45 psi (PEEK) --- 020-060-308
Peristaltic Pump Tubing
Black/Black, 0.030", PVC, 2-Stops, 12/pak 37-100272-00 020-030-007
White/White, 0.040", PVC, 2-stops, 12/pack 37-100344-00 020-030-009
Grey/Grey, 0.050", PVC, 2-stops, 12/pack 37-100345-00 020-030-011
Blue/Blue, 0.065", PVC, 2-stops, 12/pack 37-100346-00 020-030-013
Purple/Black, 0.090", PVC, 2-stops, 12/pack 37-100273-00 020-030-016
Black/Black, 0.030", Solvent Flex, 2-stops, 12/pack 37-100348-00 020-030-107
White/White, 0.040", Solvent Flex, 2-stops, 12/pack 37-100350-00 020-030-109
Grey/Grey, 0.050", Solvent Flex, 2-stops, 12/pack 37-100352-00 020-030-111
我公司主要经营现经营“DUKSAN”“SCP SCIENCE”“CONOSTAN”“J.T.Baker”“Fisher”等品牌的色谱试剂    农残试剂  、电子试剂 、超干级试剂、LC/MS试剂、SPE产品及耗材等。
另我公司专业销售原装进口的ICP-OES发射光谱和ICP-MS等离子体质谱仪相关备件及消耗品,产品包括两大类:
一、ICP-OES及ICP-MS的备品备件,适用于铂金埃尔默(PE)、热电(Thermo)、安捷伦(Agilent)、瓦里安(Varian)、斯派克(Spectro)、利曼(Leeman)、岛津(Shimadzu)等国内主流品牌仪器
1、各种炬管,包括一体或可拆卸,以及相应的组成部件如炬管体、石英、刚玉喷射管
2、各种雾室,从材质分,包括常规的玻璃、石英雾化室以及耐腐蚀的Ultem和TeflonScott雾室;从构造分,提供Scott、旋流、梨形、有缓冲和无缓冲等各种形式。
3、各类型雾化器:同心、巴宾顿、十字交叉、耐高盐、耐HF等各种材质、各种构造的雾化器,满足各种应用
4、蠕动泵管、排液管,包括各种口径和不同材质,适用于水相和各种有机相基体样品
5、ICP-MS质谱仪采样锥和截取锥,均采用电铸工艺制造,比常规加工的锥体更具优越的边缘和内部的几何结构,降低了气流的干扰,使用寿命更长。
二、各种水基标准溶液和油基标准品
1、Conostan油标,由全资子公司、全球著名的油基标准生产厂家CONOSTAN公司生产,广泛用于ICP光谱和ICP质谱以及粘度计和颗粒计数器。在润滑油、石化、原油、机械、军事、电力等行业有大量应用
2、各种水基标准,原子吸收级单标;ICP-OES、ICP-MS级高纯单标、种类繁多的混合标液;针对特定应用的定制混合标样;
我公司产品由著名的加拿大SCP SCIENCE提供,其为各大品牌的光谱生产厂商提供了大量优质贴牌产品,保质保用,同时提供优惠的价格和优质的服务。本公司常年备有大量库存,第一时间解决客户不时之需
北京海淀区增光路
