抗体
CD3/CD20双特异性抗体(>98%)
百奥莱博
MQ0128
特别提示:包括CD3/CD20双特异性抗体在内,本公司的所有产品仅可用于科研实验,严禁用于临床医疗及其他非科研用途!
产品名称:CD3/CD20双特异性抗体
产品货号:MQ0128
产品规格:100μg
AMMSTMCD3/CD20 BsAB是一种双特异性T细胞连接蛋白,这种蛋白可以连接T细胞和癌细胞,令T细胞可以选择性地接近癌细胞而达到特异性杀伤的治疗效果。AMMSTMCD3/CD20 BiMaB不仅是简单地把T细胞与肿瘤细胞相结合,还通过与T细胞表面CD3受体相结合形成复合物,进一步激活T细胞信号通路,使T细胞表达CD69、CD25,上调细胞黏附分子(CD2)、短暂释放炎症因子,令T细胞活化,并促使T细胞增殖。
纯度:>98%
浓度:100μg/mL
性状:本品为无色透明液体
保存温度:2-8℃
应用:
» 体外细胞培养
产品特性:
» GMP级生产环境,行业最高标准
» 基因工程人源化改造
» CHO稳定细胞株表达,无血清培养基生产
» GE Wave生物反应器培养
根据您的关注的CD3/CD20双特异性抗体(>98%),您可能还对以下产品有需求:
货号 名称 规格
K10597 植物生长激素ABP1抗体 0.1ml
K11076 磷酸化Bcl-2抗体 0.1ml
K12460 CDK2相互作用蛋白抗体 0.1ml|0.2ml
K13506 中心体蛋白70/p10结合蛋白抗体 0.1ml|0.2ml
K14738 抗肌萎缩蛋白抗体 0.1ml|0.2ml
K15928 X三体综合症相关蛋白FUNDC1抗体 0.1ml|0.2ml
K18151 舞蹈症相关蛋白1抗体 0.1ml
关注CD3/CD20双特异性抗体(>98%),的同时,为您推荐更多您可能感兴趣的产品:
名称:兔抗Desmin抗体
货号:YT708
规格:50μl
本品为来源于兔的抗Desmin的多克隆抗体。
宿主:兔
克隆性:多克隆抗体
用途:WB,ICC, IHC,IF
交叉反应性:人,小鼠
分子量:53KDa
推荐稀释比例:WB(1:1000-1:2000),IF(1:200),IHC(1:200),ICC(1:200)
About this Antibody
Name Desmin Rabbit Polyclonal Antibody
Category Polyclonal antibody(pAb); Primary antibody
Isotype IgG
Purification Peptide affinity purified
About the Immunogen
Immunogen This antibody is produced by immunizing rabbits with a synthetic peptide (KLH-coupled) corresponding to Desmin.
Gene ID 1674
SwissProt P17661
Synonyms Desmin
Category Cytoskeletal Signaling
Background Desmin is one of the earliest protein markers for muscle tissue in embryogenesis as it is detected in the somites. Although it is present early in the development of muscle cells, it is only expressed at low levels, and increases as the cell nears terminal differentiation. Desmin is also important in muscle cell architecture and structure since it connects many components of the cytoplasm. Finally, desmin may be important in mitochondria function. Desmin-related myopathy (DRM or Desminopathy) is a subgroup of the myofibrillar myopathy diseases and is the result of a mutation in the gene that codes for desmin which prevents it from forming protein filaments, instead forming aggregates of desmin and other proteins throughout the cell. Recently, mutations were identified in patients suffered by an arrhythmogenic right ventricular cardiomyopathy (ARVC).
注意事项:
1. 如果本抗体用于Western blot (WB)、免疫荧光(IF)、免疫细胞化学(ICC)等实验,请注意回收使用过的稀释抗体。回收的抗体通常至少可以重复使用5-10次。稀释后的抗体,包括已经使用过的稀释抗体,请4℃保存。
2. 回收后重复使用的抗体,使用方法同新鲜稀释的抗体。如果在重复使用过程中发现抗体出现轻微混浊现象,可以10,000g离心1-3分钟,取上清用于后续检测。如果回收的抗体出现明显的絮状物或长霉长菌等情况,则可以考虑废弃该抗体。
3. 提供的Western一抗稀释液也可以用于免疫荧光(IF)、免疫组化(IHC)、免疫细胞化学(ICC)等适当用途。如果希望获得最佳的检测效果,请考虑使用上述检测专用的一抗稀释液。
储存条件:-20℃,有效期一年。
北京百奥莱博科技有限公司一家专注于生命科学研究领域的生物技术公司,坚持“质量至上,服务为本,全心全意助力生命科学”的理念,为广大用于提供稳定、可靠、专业的产品和服务支持,产品线包括分子生物学,细胞生物学,免疫检测,抗体,重组蛋白,血液制品等系列。“忙忙碌碌的平凡,铸就事业的不凡”。让我们携起手来,共同创造生命科学的蓬勃发展。
海淀区紫雀路33号院3号楼
