其它各类仪器
紫外线防护眼罩
紫外线防护眼罩
进口
美国路阳
LUV-20
美国LUYOR公司生产的的紫外防护眼镜防止紫外线,保护眼睛及脸部,经过滤后的所有紫外光辐射低于10-5,大大低于NIOH(美国职业安全及健康协会)中HSM73-11009所规定的ZUIDA允许紫外辐射水平。
LUV-10紫外防护眼镜保护眼睛免受零星低强度的紫外辐射。
LUV-30(黄色), LUV-20保护眼睛,可防止高强度紫外线辐射,满足ANSI(美国标准协会)Z87.1及OSHA(美国职业安全及健康管理机构)1910.133关于眼睛保护的安全规范。其中LUV-30(T黄色)带有荧光增强功能。
LUV-20紫外线防护眼罩
上图为美国路阳生产的LUV-20紫外线防护眼罩
LUV-80保护眼睛及面部,防止高强度紫外线。满足ANSI,Z87.1及OSHA 1910.133关于眼睛及面部保护的安全规范。
 LUV-80紫外线防护面罩
上图为美国路阳生产的LUV-80紫外线防护面罩
This Model LUV-20 Ultraviolet blocking goggles block ultraviolet radiation while providing optimum contrast in viewing and lessened eye fatigue.
Goggles are constructed of specially-formulated plastic. The lightweight design and flexible rubber trim of the goggles fit comfortably on the face, even over prescription glasses. Air vents are located on each side of the goggles to allow air flow while blocking UV. Goggles comply with ANSI-Z87.1 1986 specifications for eye and face protection devices. Dimensions: 3"H x 6"W.
Eye and face protection is essential for anyone working with shortwave ultraviolet sources. Shortwave UV radiation can cause delayed reaction of sunburn to unprotected eyes and skin. The eyewear also minimizes "blue haze" associated with the longwave ultraviolet.
LUV-10 Spectacles, LUV-20Goggles and LUV-80 Faceshield Operating Manual
Ultraviolet Blocking Eyewear
Eyewear block ultraviolet radiation while providing optimumcontrast in viewing and lessened eye fatigue. The LUV-20 Goggles have air ventsthat are located on each side of the goggles to allow air flow while blockingthe ultraviolet radiation. The LUV-10 Spectacles are lightweight and fitcomfortably on the face, even over prescription glasses. Side arm panels giveadditional eye protection. The LUV-80 Faceshield covers the neck and face area.
Important: The eyewear are intended to protect theeyes from harmful ultraviolet radiation emitted from UV lamps.The eyewear isdesigned for eye protection from lamps emitting wavelengths of 254nm to 365nm(nanometers).These Ultraviolet Blocking Eyewear also reduce longwave ultraviolet“blue haze” for optimum viewing.
For exposure periods other than eight hours or for ultravioletwavelength emissions other than 254nm to 365nm, consult Document HSM 73-11009“Criteria for a Recommended Standard ... Occupational Exposure to UltravioletRadiation published by the US Department of Health, Education and Welfare.”
Caution: Although the Goggles and Spectacles areintended to protect the eyes and the Faceshield to protect the face and neck,care must be taken to protect other parts of the body from severe skin burnassociated with shortwave UV wavelengths. Avoid shining any ultraviolet lamp onreflective surfaces. Wear protective clothing and skin cream.
Eyewear meet performance standards of ANSI Z87.1-1989.Spectacles and Goggles lenses are impact resistant, but not unbreakable. Cleanand inspect frequently. Pitted or scratched eyewear reduce protection — replaceimmediately. Clean all eyewear surfaces with a mild soap solution. Do not usesolvent on lenses. Carefully rinse off all soap. Air dry or pat dry with aclean, soft cloth or tissue.
上海路阳仪器有限公司美国路阳仪器有限公司在中国投资设立的独资公司,公司是致力于紫外线灯、黑光灯、UV灯、紫外透射台、紫外观察箱、led紫外线灯研究开发的专业公司,先后成功开发了LUV-400大面积辐照紫外线灯、LPX-365、LUYOR-2130超便携手持式紫外线灯、LP-365DLUYOR-2120B电池操作高强度紫外线灯、LUYOR-3130、LUYOR-365L、LUYOR-365A手电筒式led紫外线灯、LEAC-280L、LEAC-260L系列便携式双波长紫外线灯以及LUV-10、LUV-30紫外线防护眼镜、紫外线防护眼罩、LUV-40紫外线防护面罩等产品。公司为了更便于服务中国市场,在中国成立了分公司,负责中国市场的产品的开发、生产以及售后服务。上海路阳紫外线产品已经广泛应用于荧光检测、GFP荧光观察、聚合反应、矿石、珠宝检验、刑侦检测等行业。
上海市闵行区浦锦路2049弄39号521室 万科vmo,521室
