其它各类仪器
KEWLAB HLS-1 卤钨灯光源
KEWLAB HLS-1 卤钨灯光源
KEWLAB HLS-1 Halogen Light Source
KEWLAB
HLS-1
请电话咨询15168427495
产品概述:
HLS-1是一款通用风冷型卤钨灯光源,具有输出稳定,强度可调,便携,可靠和长寿命等特点。
产品特点:
•  波长范围可覆盖 360 - 2500nm 的可见光和近红外波段
•  采用风扇散热方式,可使整机保持在较低温状态,配合高效的电路控制与高品质的卤钨灯泡,确保光源稳定输出
•  具有高输出光强,通过旋钮可调节其输出强度
•  可直接出光,也可由SMA905端口连接光纤耦合输出
•  光源前端设有支架,可根据需要安装滤波片或衰减片
产品应用:
• 光谱分析、吸收光谱测量
• 透射/反射率测量
• 颜色测量
技术参数:
型号 HLS-1
光谱强度分布图
波长范围 360~2500nm
光纤输出功率             ≥5 mW(基于光纤芯径:400μm;NA 0.22)
色温 3000K
电源 24V/2A
灯泡功耗 12V/20W
强度调节 0~100%
灯泡寿命 2000小时
预热时间 ~10min
功率稳定性 ±0.1%
散热方式 风冷
光纤接口 SMA905
尺寸(长x宽x高) 136x101x70mm
更多光源产品,请移步KEWLAB中国官网
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
