其它各类仪器
KEWLAB CL-UV 准直透镜
KEWLAB CL-UV 准直透镜
KEWLAB CL-UV Collimating Lens
KEWLAB
CL-UV
请电话咨询15168427495
产品概述:
CL-UV 准直透镜是常用的光纤耦合组件,可以与光纤、支架、积分球等各种采样附件进行连接,构成光谱测量系统。CL-UV准直透镜带有螺纹内管,用于连接标准SMA905接头。同时,内管相对于透镜可以滑动,实现工作距离调整。其它焦距、接口可定制。
产品特点:
• 可准直输出,发散角≤2°
• 焦距10mm,工作距离可调
• 工作波长200-2000nm
• 标准SMA905接口
应用:
• 光谱测量系统
• 激光准直系统
技术参数:
型号 CL-UV 准直透镜
工作波长 200-2000nm
直径 5mm
焦距 10mm
工作距离 可调
工作温度 120℃
连接器 SMA-905接头
更多准直透镜产品,请移步KEWLAB中国官网
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
