抗体
兔抗人Tau
兔抗人Tau
Rabbit Anti-Human Tau
进口
DAKO
A002401,现货
优惠
Introduction: Tau is one of the microtubule-associated proteins (MAPs) in the central nervous system. In phosphorylated form, tau is a major component of the paired helical filaments of the neurofibrillary tangles developed in Alzheimer's disease (1,2). One of the functions of tau is to stabilized microtubules. Phosphorylation of tau reduces the stabilizing effect. The C-terminal part of the tau protein shows a high degree of homology with other MAPs, such as MAP2, and it is suggested that it might serve as a microtubule-binding domain (3). DAKO Rabbit Anti-Human Tau does cross-react with MAP2.
Presentation: Rabbit Anti-Human Tau is the purified immunoglobuolin fraction of rabbit antiserum.
Solvent: 0.1 M NaCl, 15 mM NaN3.
Protein concentration: 6.8 g/L.
Storage: 2-8 ºC.
Immunogen: The C-terminal part of human tau protein expressed in E. coli. The immunogen contains the four repeated sequences involved in microtubule binding.
Specificity: The antibody reacts on immunoblots with tau protein and with tau from Alzheimer paired helical filaments.
Application: Brain tissue from patients with Alzheimer's disease is characterized by several histopathological lesions, such as neurofibrillary tangles and senile plaques (1). For the study of lesions associated with Alzheimer's disease DAKO Rabbit Anti-Tau can be used in combination with DAKO Mouse Monoclonal Anti Beta-Amyloid (code No. M 0872) and DAKO Rabbit Anti-Ubiquitin (code No. Z 0458). Neurofibrillary tangles are labelled by anti-tau, while the senile plaques are labelled by the beta amyloid and the ubiquitin antibodies (1,4).
Staining procedure:
Formalin-fixed and paraffin-embedded sections: Can be used on formalin-fixed, paraffin-embedded tissue sections.
A number of staining techniques are suitable, including the labelled streptavidin-HRP technique, the streptavidin-biotin complex technique and the peroxidase anti-peroxidase (PAP) technique.
The antibody has been shown to give optimal staining at a dilution of 1:100 - 1:200 when tested on formalin-fixed, paraffin-embedded sections of brain from patients with Alzheimer's disease using the streptavidin-based staining techniques mentioned above. The given antibody dilutioin range is a guideline only; an optimal dilution should be determined by the individual laboratory.
References
(1) Brion JP. Molecular pathology of Alzheimer amyloid and neurofibrillary tangles. Neurosciences 1990;2:89-100.
(2) Goedert M, Wischik C, Crowther R, Walker J, Klug A. Cloning and sequencing of the cDNA encoding a core protein of the paired helical filament of Alzheimer disease. Proc Natl Acad Sci 1988;85:4051-5.
(3) Butner KA, Kirschner MW. Tau-protein binds to microtubules through a flexible array of distributed weak sites. J Cell Biol 1991;115:717-30.
(4) Behrouz N, Defossez A, Delacourte A, Hublau P, Mazzuca M. Alzheimer's disease: glycolytic pretreatment dramatically enhances immunolabelling of senile plaques and cerebrovascular amyloid substance. Lab Invest 1989;61:576-83.
我们提供世界著名品牌的百万种优质产品:
部分仪器>
三维细胞组织培养系统
微囊发生器
微量注射器、助吸器
转定子式均质器、碾槌式匀质器、混涡混合器、旋转器、细胞破碎器、振荡器、搅拌器
加热套
吸入暴露系统/气溶胶发生器
所售仪器类商品,保修一年,终身维修。
上海市徐汇区云锦路500号绿地汇中心A座809,在中国主要城市有销售支持,见www.equl.cn
2380088352, 390113670
上海:021-64280805
22817530
