抗体
磷酸化γ1氨基丁酸受体GABAA Rβ1抗体科研
Anti-phospho-GARB1 (Ser434)
博湖
0.1ml/100μg
公司专业供应的抗体,抗体是用于化学反应、分析化验、研究实验、教学实验、化学配方使用的纯净化学品,产品品质卓越,价格实惠,多种规格供应,售后完善。
英文名称  Anti-phospho-GARB1 (Ser434)
中文名称  磷酸化γ1氨基丁酸受体GABAA Rβ1抗体科研
别    名  GABA A Receptor beta 1 (phospho S434); phospho-GARB1 (Ser 434); GABA(A) receptor subunit beta-1; GABA-A receptor, beta-1 polypeptide; Gabrb-1; Gamma Aminobutyric Acid A Receptor Beta 1; Gamma Aminobutyric Acid Receptor , beta-1; Gamma-aminobutyric acid (GABA) A receptor, subunit beta 1; Gamma-aminobutyric acid receptor subunit beta-1; GARB1; GABRA1; AW061132; B230208N19Rik; GABA(A) receptor beta 1; GABA(A) receptor subunit beta-1; GABA-A receptor, beta-1 polypeptide; Gabrb-1; GABRB1; Gamma aminobutyric acid (GABA) A receptor beta 1; Gamma Aminobutyric Acid A Receptor Beta 1; Gamma Aminobutyric Acid Receptor , beta-1; Gamma-aminobutyric acid (GABA) A receptor, subunit beta 1; Gamma-aminobutyric acid receptor subunit beta-1; GARB1; GBRB1_HUMAN.
浓    度  1mg/1ml
规 格  0.1ml/100μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Pig, Cow, Horse, Rabbit, Sheep
产品类型  一抗  磷酸化抗体
研究领域  神经生物学 细胞膜受体 新陈代谢
蛋白分子量  predicted molecular weight: 51kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated synthesised phosphopeptide derived from human GARB1 around the phosphorylation site of Ser434
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
产品应用   WB=1:100-500  ELISA=1:500-1000  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
(石蜡切片需做抗原修复)
 not yet tested in other applications.
 optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
实验流程:
实验原理 :
(1)特异性结合抗原:抗体本身不能直接溶解或杀伤带有特异抗原的靶细胞,通常需要补体或吞噬细胞等共同发挥效应以清除病原微生物或导致病理损伤。然而,抗体可通过与病毒或毒素的特异性结合,直接发挥中和病毒的作用。
(2)活补体:IgM、IgG1、IgG2和IgG3可通过经典途径激活补体,凝聚的IgA、IgG4和IgE可通过替代途径激活补体。
(3)结合细胞:不同类别的免疫球蛋白,可结合不同种的细胞,参与免疫应答。
(4)可通过胎盘及粘膜:免疫球蛋白G(IgG)能通过胎盘进入胎儿血流中,使胎儿形成自然被动
免疫。免疫球蛋白A(IgA)可通过消化道及呼吸道粘膜,是粘膜局部抗感染免疫的主要因素。
(5)具有抗原性:抗体分子是一种蛋白质,也具有刺机体产生免疫应答的性能。不同的免疫球蛋白分子,各具有不同的抗原性。
(6)抗体对理化因子的抵抗力与一般球蛋白相同:不耐热,60~70℃即被破坏。各种酶及能使蛋白质凝固变性的物质,均能破坏抗体的作用。抗体可被中性盐类沉淀。在生产上常可用硫酸铵或硫酸钠从免疫血清中沉淀出含有抗体的球蛋白,再经透析法将其纯化。
抗体的鉴定:
1)抗体的效价鉴定:不管是用于诊断还是用于治疗,制备抗体的目的都是要求较高效价。不同的抗原制备的抗体,要求的效价不一。鉴定效价的方法很多,包括有试管凝集反应,琼脂扩散试验,酶联免疫吸附试验等。常用的抗原所制备的抗体一般都有约成的鉴定效价的方法,以资比较。如制备抗抗体的效价,一般就采用琼脂扩散试验来鉴定。
2)抗体的特异性鉴定:抗体的特异性是指与相应抗原或近似抗原物质的识别能力。抗体的特异性高,它的识别能力就强。衡量特异性通常以交叉反应率来表示。交叉反应率可用竞争抑制试验测定。以不同浓度抗原和近似抗原分别做竞争抑制曲线,计算各自的结合率,求出各自在IC50时的浓度,并按公式计算交叉反应率。
如果所用抗原浓度IC50浓度为pg/管,而一些近似抗原物质的IC50浓度几乎是无穷大时,表示这一抗血清与其他抗原物质的交叉反应率近似为0,即该血清的特异性较好。
3)抗体亲和力:是指抗体和抗原结合的牢固程度。亲和力的高低是由抗原分子的大小,抗体分子的结合位点与抗原决定簇之间立体构型的合适度决定的。有助于维持抗原抗体复合物稳定的分子间力有氢键,疏水键,侧链相反电荷基因的库仑力,范德华力和空间斥力。亲和力常以亲和常数K表示,K的单位是L/mol。抗体亲和力的测定对抗体的筛选,确定抗体的用途,验证抗体的均一性等均有重要意义。
Human Immunodeficiency Virus 1(HIV-1)人免疫缺陷病毒I型通用染料法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1)人免疫缺陷病毒I型通用探针法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M)人免疫缺陷病毒1型M群RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M)人免疫缺陷病毒1型M群染料法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M)人免疫缺陷病毒1型M群探针法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M-A)人免疫缺陷病毒1型M群A型RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M-A)人免疫缺陷病毒1型M群A型染料法荧光定量RT-PCR试剂盒
n C(HLA-C)ELISA Kit
人类白细胞抗原E(HLA-E)elisa试剂盒价格 Human leukocyte antigen E(HLA-E)ELISA Kit
人类风湿因子(RF)elisa试剂盒说明书 Human rheumatoid factor(RF)ELISA Kit
人类嗜T淋供应商 Human lymphocyte functionassociated antigen 1(LFA-1/CD11a+CD18)ELISA Kit
人淋巴细胞功能相关抗原2(LFA-2/CD2)elisa试剂盒图片 Human lymphocyte functionassociated antigen 2(LFA-2/CD2)ELISA Kit
人淋巴细胞功能相关抗原3(LFA-3/CD58)elisa试剂盒说明书 Human lymphocyte functionassociated antigen 3(LFA-3/CD58)ELISA Kit
人淋巴细胞趋化因子(Lptn/LTN/XCL1)elisa试剂盒价格 Human lymphocytechemotacticfactor(Lptn/LTN/XCL1)ELISA Kit
人淋巴细胞因子elisa试剂盒供应商 Human lymphocyte factorELISA Kit
人磷酸化蛋白激酶C(P-PKC)elisa试剂盒图片 Human phospho proteinkinase C(P-PKC)ELISA Kit
人磷酸化细胞外信号调节激酶(pERK)elisa试剂盒说明书 Human phosphorylatedextracellular signal regulatedkinase(pERK)ELISA Kit
人磷酸肌醇3激酶(PI3K)elisa试剂盒价格 Human phosphotylinosital 3kinase(PI3K)ELISA Kit
人磷酸葡萄糖变位酶(PGM)elisa试剂盒供应商 Human Phosphoglucomutase(PGM)ELISA Kit
人磷酸烯醇式丙酮酸羧激酶(PCK)elisa试剂盒图片 Human phosphoenolpyruvate carboxykinase(PCK)ELISA Kit
人磷脂酶A2(PL-A2)elisa试剂盒说明书 Human phospholipase A2(PL-A2)ELISA Kit
人磷脂酰肌醇抗体IgG/IgM(PI Ab-IgG/IgM)elisa试剂盒价格 Human phosphatidylinositolantibody IgG/IgM(PIAb-IgG/IgM)ELISA Kit
人磷酯酶C(PLC)elisa试剂盒供应商 Human phospholipase C(PLC)ELISA Kit
HIV-1M-A)人免疫缺陷病毒1型M群A型探针法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M-B)人免疫缺陷病毒1型M群B型RT-PCR试剂盒
磷酸化γ1氨基丁酸受体GABAA Rβ1抗体科研 Human Immunodeficiency Virus 1(HIV-1M-B)人免疫缺陷病毒1型M群B型染料法荧光定量RT-PCR试剂盒
Human Immunodeficiency Virus 1(HIV-1M-B)人免疫缺陷病毒1型M群B型探针法荧光定量RT-PCR试
抗体的制备过程:
1. 免疫原的制备
普通的大分子蛋白,通过分子克隆构建载体并在大肠杆菌中进行诱导表达获得重组蛋白,纯化鉴定后可直接作为免疫原。
小分子蛋白或化合物等分子量小,需要偶联载体对该分子进行改造才能使其成为具有免疫原性的抗原,常见偶联载体如BSA、OVA、HAS等。
2. 免疫动物
常用于制备抗血清的动物有豚鼠、家兔、鸡、大小鼠等,大量生产时需要用到狗、绵羊、山羊等。
3. 免疫血清的收集
一般家兔、绵羊、山羊可采用静动脉采血,家兔、豚鼠、大鼠、鸡可采用心脏采血,家兔、山羊、绵羊可采用静脉采血。
4. 免疫血清的纯化与鉴定
得到的抗血清需要进一步的纯化,利用偶联了抗原的亲和柱进行层析,具有高效,特异性强,纯度高的特定。接着要鉴定纯化蛋白的含量、相对分子的质量、纯度以及特异性。
5. 免疫血清的保存
建议将抗体分装后进行保存。抗体一般比较稳定,在-80℃ ~-20 ℃可以保存约5年而不会影响效价,而真空干燥保存时间可以更久。保存前需经除菌并添加防腐剂。
上海博湖生物科技有限公司(Shanghai Bohu Biological Technology Co., Ltd.,China) 是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海博湖生物科技有限公司(Shanghai Bohu Biological Technology Co., Ltd.,China) 先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海闵行区碧泉路36弄银宵大厦B102
