抗体
NALP12抗体科研
NALP12抗体科研
Anti-NALP12
博湖
0.2ml/200μg
抗体是用于化学反应、分析化验、研究实验、教学实验、化学配方使用的纯净化学品,产品品质卓越,价格实惠,多种规格供应,售后完善。
英文名称   Anti-NALP12
中文名称 NALP12抗体科研
别    名  CLR19.3; FCAS2; Monarch 1; Monarch-1; NACHT, leucine rich repeat and PYD containing 12; NACHT, LRR and PYD containing protein 12; NACHT, LRR and PYD domains-containing protein 12; NAL12_HUMAN; NLR family, pyrin domain containing 12; NLRP12; Nucleotide-binding oligomerization domain, leucine rich repeat and pyrin domain containing 12; PAN6; PYPAF7; PYRIN containing APAF1 like protein 7; PYRIN-containing APAF1-like protein 7; Regulated by nitric oxide; RNO; RNO2.
浓    度  1mg/1ml
规 格  0.2ml/200μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Dog, Pig, Cow, Horse, Rabbit, Sheep
产品类型  一抗
研究领域  细胞生物 信号转导 细胞凋亡 转录调节因子
蛋白分子量  predicted molecular weight: 117kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated synthetic peptide derived from human NALP12
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
产品应用   WB=1:100-500  ELISA=1:500-1000  IP=1:20-100  IHC-P=1:100-500  IHC-F=1:100-500  IF=1:100-500
(石蜡切片需做抗原修复)
 not yet tested in other applications.
 optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
granulysin是近年来新发现的一种细胞毒性效应蛋白,是由激活的细胞毒性T淋巴细胞(cytotoxic T lymphocytes, CTL)和自然杀伤细胞(natural killer, NK)产生的一种阳离子蛋白质.能够杀伤微生物和肿瘤细胞.
抗体的生活习性:
(1)结合特异性抗原:抗体与其他免疫球蛋白分子区别,就在于抗体能与相应抗原发生特异性结合,在体内导致生理或病理效应;在体外产生各种直接或间接的可见的抗原抗体结合反应。抗体是靠其分子上的特殊的结合部位与抗原结合的。
(2)激活补体:抗体与相应抗原结合后,借助暴露的补体结合点去激活补体系统、激发补体的溶菌、溶细胞等免疫作用。
(3)结合细胞:不同类别的免疫球蛋白,可结合不同种的细胞,产生不同的疚,参与免疫应答。
(4)可通过胎盘及粘膜:免疫球蛋白G(IgG)能通过胎盘进入胎儿血流中,使胎儿形成自然被动免疫。免疫球蛋白A(IgA)可通过消化道及呼吸道粘膜,是粘膜局部抗感染免疫的主要因素。
(5)具有抗原性:抗体分子是一种蛋白质,也具有刺激机体产生免疫应答的性能。不同的免疫球蛋白分子,各具有不同的抗原性。
(6)抗体对理化因子的抵抗力与一般球蛋白相同:不耐热,60~70℃即被破坏。各种酶及能使蛋白质凝固变性的物质,均能破坏抗体的作用。抗体可被中性盐类沉淀。在生产上常可用硫酸铵或硫酸钠从免疫血清中沉淀出含有抗体的球蛋白,再经透析法将其纯化。
一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
IL17Rd / SEF 抗體, 兔多抗ELISA   400 µg
IL17Rd / SEF 抗體, 兔多抗, 抗原親和純化ELISA   50 µg
TPSB2 / Tryptase Beta 2 抗體, 鼠單抗ELISA   50 µg
IL17Rd / SEF 抗體, 兔單抗ELISA   50 µg
Cystatin D / CST5 抗體, 兔多抗ELISA   400 µg
Tie1 抗體 (PE), 鼠單抗FCM   25 Test
Tie1 抗體, 鼠單抗ELISA   50 µg
Tie1 抗體, 兔多抗ELISA   400 µg
Tie1 抗體, 鼠單抗IHC-P   50 µg
Carboxypeptidase B1 / CPB1 抗體, 鼠單抗ELISA   50 µg
NALP12抗体科研亚油酸油醇酯(C18:2-C18:1)美国亚油酸油醇酯(C18:2-C18:1),标准品,有证书 ,100mg/500mg/1gm
醋酸亮丙瑞林 Leuprorelin Acetate74381-53-6中检所20mg/支,HPLC含量测定
藕节1g
恶喹酸-D5Oxolinic acid-D525mg
甲基泼尼松龙醋酸酯 Methylprednisolone53-36-1中检所50mg,供HPLC法含量测定用
肠膜状明串珠菌0.2ml
常山5g
二十一烷酸甘油三酯(C21:0)26536-14-1美国二十一烷酸甘油三酯(C21:0),标准品,有证书 ,100mg/500mg/1gm
二十碳二烯酸(顺-11,14)(C20:2)2091-39-6美国二十碳二烯酸(顺-11,14)(C20:2),标准品,有证书 ,100mg/500mg
花生四烯酸十四烷醇酯/花生四烯酸肉豆蔻醇酯(C20:4-C14:0)美国花生四烯酸十四烷醇酯/花生四烯酸肉豆蔻醇酯(C20:4-C14:0),标准品,有证书 ,100mg
抗甘露聚糖肽血清 Anti-mannatide Serum中检所1 : 8,供鉴别、检查用
磺胺二甲氧嘧啶,纯品型,标准品,有证书122-11-2中国磺胺二甲氧嘧啶,纯品型,标准品,有证书 ,0.25g
抗体的生物素化标记实验要点:
1.如在反应混合液中有叠氮钠或游离氨基存在,会抑制标记反应。因此,蛋白质在反应前要对 0.1mol/L碳酸氢钠缓冲液或0.5mol/L硼酸缓冲液充分透析;
2.所用的NHSB及待生物素化蛋白质之间的分子比按蛋白质表面的ε-氨基的密度会有所不同,选择不当则影响标记的效率,应先用几个不同的分子比来筛选最适条件;
3.用NHSB量过量也是不利的,抗原的结合位点可能因此被封闭,导致抗体失活;
4.由于抗体的氨基不易接近可能造成生物素化不足,此时可加入去污剂如 Triton x-100, Tween20等;
5.当游离ε-氨基(赖氨酸残基的氨基)存在于抗体的抗原结合位点时,或位于酶的催化位点时,生物素化会降低或损伤抗体蛋白的结合力或活性;
6.生物素还可能与不同的功能基团,如羰基、氨基、巯基、异咪唑基及苯酚基,也可与糖基共价结合;
7.交联反应后,应充分透析,否则,残余的生物素会对生物素化抗体与亲和素的结合产生竞争作用;
8.在细胞的荧光标记实验中,中和亲和素的本底低,但由于链霉亲和素含有少量正电荷,故对某些细胞可导致高本底。
上海博湖生物科技有限公司(Shanghai Bohu Biological Technology Co., Ltd.,China) 是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海博湖生物科技有限公司(Shanghai Bohu Biological Technology Co., Ltd.,China) 先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海闵行区碧泉路36弄银宵大厦B102
