抗体
DNA聚合酶λ/DNA pol λ抗体说明书
Anti-DNAPolymeraselambda
邦景
0.2ml/200μg
DNA聚合酶λ/DNA pol λ抗体说明书几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
DNA聚合酶λ/DNA pol λ抗体说明书英文名称  Anti-DNA Polymerase lambda
中文名称  DNA聚合酶λ/DNA pol λ抗体
别    名  BETA N; BETAN; DNA directed DNA polymerase lambda; DNA polymerase beta 2; DNA polymerase beta-2; DNA polymerase kappa; DNA polymerase kappa DNA polymerase beta N; DNA polymerase lambda; DNA polymerase lamda2; DPOLL_HUMAN; EC 2.7.7.7,EC 4.2.99.; FLJ46002; OTTHUMP00000020321; OTTHUMP00000020323; OTTHUMP00000059179; Pol beta2; POL KAPPA; Pol Lambda; POLKAPPA; POLL; Polymerase DNA directed lambda.
浓    度  1mg/1ml
规 格  0.2ml/200μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Chicken, Dog, Pig, Cow, Rabbit, Sheep
产品类型  一抗
研究领域  细胞生物 表观遗传学
蛋白分子量  predicted molecular weight: 63kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated synthetic peptide derived from human DNA Polymerase lambda
产品应用   WB=1:100-500  ELISA=1:500-1000  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 癈 for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20癈. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 癈.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
Gamma Tubulin Mouse Monoclonal Antibody(4A4) Gamma 微管蛋白 小鼠单克隆抗体(4A4)
Galectin9 Antibody,ECALECTIN,HUAT,LGALS9,MGC117375,MGC125973,MGC125974,galectin 9,galectin9 Galectin9抗体
Galectin7 Antibody,Galectin7,Galectin 7,Galectin7,Gal7; Gal7,GAL7,GAL7,HKL14; PI7;yMDMmcDM9MS4wLjEuNzMmcDQ9NDIwNTkw꤇뙚ḙaꚨℍ怘RPXNzX2lkbGVfcGxndXNlcjQmcDY9d3BzJnA3PTEmcDg9MzYwMCZwOT0mcDEwPQ==
>98%,BCTriphenylethylene,99%
>98%,BR2,4,6Trimethylstyrene,95%
>80%,IndGradeTriisobutylene
>98%,BRcis9Tricosene,97%
>45%,BRTriOacetylDgalactal,97%
>98%,BC1,1,2,2Tetraphenylethylene,≥99%HPLC
BR1,1,4,4Tetraphenyl1,3butadiene,≥9...
>90%,进分Poly(tetrafluoroethylene)
>97%,BStransAnethole,99%
>98%,IndGrade2,5Dimethoxyβnitrostyrene,97%
>99%,医药级Fenazox
>98%,BRα,α,α′,α′Tetrabromooxylene,97%
>98%,BRRubrene,≥98%
BRtransStilbeneoxide,99%
>98%,PractGradeOcimene,≥90%
抗体制备过程:
1.材料与试剂
  a.提取的动物 Ig
  b.弗氏完全佐剂和弗氏不完全佐剂
  c.青霉素和链霉素
  d.实验动物 兔
  e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海市金山区金山大道2788号
