DNA甲基转移酶2抗体说明书
DNA甲基转移酶2抗体说明书英文名称 Anti-Dnmt2
中文名称 DNA甲基转移酶2抗体
别 名 dDNMT; DmMT 2; DmMT2; DNA (cytosine 5 ) methyltransferase 2; DNA (cytosine 5) methyltransferase like protein 2; DNA (cytosine-5)-methyltransferase-like protein 2; DNA 5 cytosine methyltransferase; DNA methyltransferase 2; DNA methyltransferase homolog HsaIIP; DNA MTase homolog HsaIIP; Dnmt 2; Dnmt2; M.HsaIIP; MHsaIIP; nmt 2; nmt2; OTTHUMP00000045198; PuMet; RNMT 1; RNMT1; TRDMT 1; TRDMT_HUMAN; TRDMT1; tRNA (cytosine 5 ) methyltransferase; tRNA (cytosine(38)-C(5))-methyltransferase; tRNA aspartic acid methyltransferase 1; tRNA aspartic acid methyltransferase 1 variant 1; tRNA aspartic acid methyltransferase 1 variant 2; tRNA aspartic acid methyltransferase 1 variant 3; tRNA aspartic acid methyltransferase 1 variant 4; tRNA aspartic acid methyltransferase 1 variant 5; tRNA aspartic acid methyltransferase 1 variant 8.
浓 度 1mg/1ml
规 格 0.2ml/200μg
抗体来源 Rabbit
克隆类型 polyclonal
交叉反应 Human, Mouse, Rat, Pig, Cow, Sheep
产品类型 一抗
研究领域 细胞生物 信号转导 表观遗传学
蛋白分子量 predicted molecular weight: 45kDa
性 状 Lyophilized or Liquid
免 疫 原 KLH conjugated synthetic peptide derived from human Dnmt2
产品应用 WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
亚 型 IgG
纯化方法 affinity purified by Protein A
储 存 液 Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件 Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
抗体制备过程:
1.材料与试剂
a.提取的动物 Ig
b.弗氏完全佐剂和弗氏不完全佐剂
c.青霉素和链霉素
d.实验动物 兔
e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
AntiGABA Transporter 2 (GAT2) GABA Transporter 2 (GAT2)抗体(50 ul)
AntiGABA Transporter 2 (GAT2) GABA Transporter 2 (GAT2)抗体(0.2 ml)
AntiGABA Transporter 1 (GAT1) (extracellular) GABA Transporter 1 (GAT1) (胞外)抗体(50 ul)
AntiGABA Transporter 1 (GAT1) (extraceyMDMmcDM9MS4wLjEuNzMmcDQ9NDIwNTkw꤇뙚ḙaꚨℍ怘RPXNzX2lkbGVfcGxndXNlcjQmcDY9d3BzJnA3PTEmcDg9MzYwMCZwOT0mcDEwPQ==
>90%,进分LAsparticAcidPotassiumSalt(≥98%,...
>90%,IndGradeThidiazuron
>99%,BRSodiumHydroxide(≥98%)
BCLithiumHydroxideMonohydrate(98.510...
>98%,BRLithiumCitrateTribasicTetrahydrate...
>99%,BRLithiumdodecylsulfate(≥98.5%,GC)
>98%,BRLithiumChloride(≥99%,ACS)
>96%,BRTetrahydrofuran(≥99.9%)
>98%,BRSqualane(99.0%)
1mM,BCTetraethylammoniumChloride(≥99.0%)
BCDimethylPimelate(≥97.0%,GC)
>98%,BR8Azaguanine
>99%,BC1Naphthol(≥99.0%)
>99%,BC3PhenoxybenzoicAcid(98%)
>99.8%,BRPiperonylicAcid(99%)
DNA甲基转移酶2抗体说明书一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
单位名称: |
上海市金山区金山大道2788号
联系电话: |
Email: |
