抗体
白喉酰胺生物合成样蛋白2抗体说明书
白喉酰胺生物合成样蛋白2抗体说明书
Anti-DPH2
邦景
0.2ml/200μg
公司专业供应的抗体,抗体是用于化学反应、分析化验、研究实验、教学实验、化学配方使用的纯净化学品,产品品质卓越,价格实惠,多种规格供应,售后完善。
产品名称  白喉酰胺生物合成样蛋白2抗体说明书
英文名称 Anti-DPH2
规格 0.2ml/200μg
英文名称  Anti-DPH2
中文名称  白喉酰胺生物合成样蛋白2抗体
别    名  Diphthamide biosynthesis like protein 2; Diphthamide biosynthesis protein 2; Diphthamide biosynthesis protein 2 homolog like 2; Diphthamide biosynthesis protein 2 homolog-like 2; Diptheria toxin resistance protein required for diphthamide biosynthesis like 2; Diptheria toxin resistance protein required for diphthamide biosynthesis like 2 S. cerevisiae ; DPH 2; DPH2; DPH2 homolog; DPH2 homolog S. cerevisiae; DPH2 like 2; DPH2 like 2 S. cerevisiae; DPH2-like 2; DPH2_HUMAN; DPH2L2; HsDph2; OTTHUMP00000010007; Protein DPH2 homolog.
浓    度  1mg/1ml
规 格  0.2ml/200μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Chicken, Dog, Cow, Horse, Rabbit, Sheep
产品类型  一抗
研究领域  肿瘤 细胞生物 免疫学 细胞膜受体
蛋白分子量  predicted molecular weight: 52kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated synthetic peptide derived from human DPH2
产品应用   WB=1:100-500  ELISA=1:500-1000  IP=1:20-100  IHC-P=1:100-500  IHC-F=1:100-500  IF=1:100-500
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
实验流程:
基本概述:
乙肝表面抗体是人体的保护性的抗体,主要是乙肝病毒表面抗原刺激人体免疫系统而产生的抗体。它的出现,能中和掉人体内的乙肝病毒。具体保护人体的作用。其英文简写为HBsAb。
1、单项抗-HBs阳性
(1)接种乙肝疫苗成功的标志。
(2)抗-HBs阳性单价格低,有时为非特异性反应。
2、与抗-HBc、抗-HBe同时阳性
3、与HBsAg同时阳性
(1)感染了不同的乙肝病毒亚型。
(2)感染了S基因变异的乙肝病毒。
(3)免疫功能低下,抗-HBs不能清除HBsAg。
4、正处于抗原-抗体动态平衡阶段
实验原理 :
(1)特异性结合抗原:抗体本身不能直接溶解或杀伤带有特异抗原的靶细胞,通常需要补体或吞噬细胞等共同发挥效应以清除病原微生物或导致病理损伤。然而,抗体可通过与病毒或毒素的特异性结合,直接发挥中和病毒的作用。
(2)活补体:IgM、IgG1、IgG2和IgG3可通过经典途径激活补体,凝聚的IgA、IgG4和IgE可通过替代途径激活补体。
(3)结合细胞:不同类别的免疫球蛋白,可结合不同种的细胞,参与免疫应答。
(4)可通过胎盘及粘膜:免疫球蛋白G(IgG)能通过胎盘进入胎儿血流中,使胎儿形成自然被动
免疫。免疫球蛋白A(IgA)可通过消化道及呼吸道粘膜,是粘膜局部抗感染免疫的主要因素。
(5)具有抗原性:抗体分子是一种蛋白质,也具有刺机体产生免疫应答的性能。不同的免疫球蛋白分子,各具有不同的抗原性。
(6)抗体对理化因子的抵抗力与一般球蛋白相同:不耐热,60~70℃即被破坏。各种酶及能使蛋白质凝固变性的物质,均能破坏抗体的作用。抗体可被中性盐类沉淀。在生产上常可用硫酸铵或硫酸钠从免疫血清中沉淀出含有抗体的球蛋白,再经透析法将其纯化。
抗体的鉴定:
1)抗体的效价鉴定:不管是用于诊断还是用于治疗,制备抗体的目的都是要求较高效价。不同的抗原制备的抗体,要求的效价不一。鉴定效价的方法很多,包括有试管凝集反应,琼脂扩散试验,酶联免疫吸附试验等。常用的抗原所制备的抗体一般都有约成的鉴定效价的方法,以资比较。如制备抗抗体的效价,一般就采用琼脂扩散试验来鉴定。
2)抗体的特异性鉴定:抗体的特异性是指与相应抗原或近似抗原物质的识别能力。抗体的特异性高,它的识别能力就强。衡量特异性通常以交叉反应率来表示。交叉反应率可用竞争抑制试验测定。以不同浓度抗原和近似抗原分别做竞争抑制曲线,计算各自的结合率,求出各自在IC50时的浓度,并按公式计算交叉反应率。
如果所用抗原浓度IC50浓度为pg/管,而一些近似抗原物质的IC50浓度几乎是无穷大时,表示这一抗血清与其他抗原物质的交叉反应率近似为0,即该血清的特异性较好。
3)抗体亲和力:是指抗体和抗原结合的牢固程度。亲和力的高低是由抗原分子的大小,抗体分子的结合位点与抗原决定簇之间立体构型的合适度决定的。有助于维持抗原抗体复合物稳定的分子间力有氢键,疏水键,侧链相反电荷基因的库仑力,范德华力和空间斥力。亲和力常以亲和常数K表示,K的单位是L/mol。抗体亲和力的测定对抗体的筛选,确定抗体的用途,验证抗体的均一性等均有重要意义。
白喉酰胺生物合成样蛋白2抗体说明书Bax Mouse Monoclonal Antibody(6F11) BCL2关联X蛋白小鼠单克隆抗体(6F11)
Bax Mouse Monoclonal Antibody(1C1) BCL2关联X蛋白小鼠单克隆抗体(1C1)
BNIPL Polyclonal Antibody BCL2/腺病毒E1B19kD结合蛋白样 多克隆抗体
BNI3L Polyclonal Antibody BCL2/腺病毒E1B19kDa结合蛋白3样 多克隆抗体
BCHE Antibody (Center) (BCHE; C
月桂(标准品) >99%,BR Imiquimod
月桂卓; HPLC>98%,标准品 Imiquimod
远志皂苷元(标准品) >98%,BR Irinotecan
远志(标准品) HPLC>98%,标准品 Irinotecan
远志口山;远志山III >99%,BR,三水合物 Irinotecan HCl Trihydrate
远华蟾蜍精(标准品) HPLC>98%,标准品 Irinotecan HCl Trihydrate
猿猴病毒40大肿瘤抗原氨基段肽段 >99%,BR Isoconazole Nitrate
原苏木素B/原巴西苏木素(标准品) HPLC>98%,标准品 Isoconazole Nitrate
原薯蓣皂苷(标准品) >99.0%,BR Isotretinoin
原人参三(标准品) HPLC>99%,标准品 Isotretinoin
液相内毒素清除剂APPPS11000 U
固相内毒素清除剂Aprotinin1000 U
固相内毒素清除剂Aprotinin Solution1000 U
柱式内毒素清除剂Apyrase1000 U
内毒素清除专用亲和介质Arginase1000 U
内毒素清除专用亲和介质Aspartate Aminotransferase1000µg
终点显色法内毒素定量试剂盒AsPC110000mU
动态显色法内毒素定量试剂盒ATA(Aurintricarboxylic Acid)10000U
动态浊度法内毒素定量试剂盒ATP Dependent DNase10000U
凝胶法内毒素半定量试剂盒ATP Luminescent Cell Viability Assay Kit 10000U
非酶RNA清除剂1.0ATP Na210000U
非酶RNA清除剂2.0ATP Solution1000mL
柱式腐殖清除剂ATP Solution,1 mM1000mL
柱式腐殖清除剂ATP Solution,100mM1000mL
非酶多糖清除剂(DNA专用)ATP Sulfurylase1000mL
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海市金山区金山大道2788号
