杜恩斯组织匀浆器885300-0002线粒体提取
名称: 美国KIMBLE杜恩斯玻璃组织匀浆器
品牌:美国KIMBLE
全WHEATON33低溶出硼硅酸盐玻璃制作,符合ASTM Type Ⅰ Class A和USP type Ⅰ 标准。
为高的细胞核和线粒体保留率设计;每一匀浆器配有松型和紧型两根槌,松形槌管间隙0.0035"-0.0055",紧型槌管间隙0.0010"-0.0030";
在实际操作中,先用松型槌初步匀浆,再用紧型槌终匀浆;适用于酶科学研究。
产品编号 产品描述 产品包装 产品价格 数量(库存)
885300-0040 匀浆体积:40ml;紧0.0010-0.0030松0.0030-0.0060 1套/箱 ¥3632.00 现货
885300-0015 匀浆体积:15ml紧0.0010-0.0030;松0.0035-0.0065 1套/箱 ¥2917.00 现货
885300-0007 匀浆体积:7ml;紧槌0..0008-0.0022;松0.0028-0.0047; 1套/箱 ¥2538.00 现货
885300-0002 匀浆体积:2ml;紧0.0030-.0050;松0.0005-0.0025 1套/箱 ¥2917.00 现货
885300-0001 匀浆体积:1ml;紧0.0030-0.0050;松0.0010-0.0020; 1套/箱 ¥2538.00 现货
885300-0000 匀浆体积:0.5ml;紧槌0.0025-0.0055;松0.0005-0.0025; 1套/箱 ¥2305.00 现货
坦布鲁克组织匀浆器(磨砂内面) 品牌:KIMBLE 885000
Tenbroeck, All-Glass
用途:可手动也可连接马达使用。
简介:885000
All-glass construction.
Popular style which affords the choice of hand or motor operation.
Pestle is tooled for an appropriately sized single hole rubber stopper (not supplied).
By inserting a short metal rod in the stopper, these grinders can be motor driven at slow speeds by inserting the metal rod into the motor chuck.
Replacement components are available and completely interchangeable.
Clearance between pestles and tubes is 0.004" to 0.006".
货号杵长度×外径(mm)管长度×外径(mm)处理量(mL)包装(个/件)单价(RMB)
885000-0002 160×50 100×30 2 1 1426.00
885000-0007 195×50 125×30 7 1 1597.00
885000-0015 250×65 157×38 15 1 1775.00
885000-0040 315×90 215×55 40 1 2434.00
杜阿尔组织匀浆器(磨砂内面) 品牌:KIMBLE 885450
DUALL?, All-Glass
用途:研磨肌肉,心脏、肺等器官或组织。
简介:885450
Combines both conical and cylindrical surfaces to effectively reduce tissue and produce a uniform homogenate.
This ground glass model is ideal for connective tissue such as muscle, heart and lung.
Construction is strong enough to allow the pestle to be motor driven.
Pestles are designed to be used with 788000 Stirrer Adapters.
货号规格(mm)杵长度×外径管长度×外径(mm)处理量(mL包装(个/件)单价(RMB)
885450-0020 20 155×6 80×13 1 1 2049.00
885450-0021 21 207×6 120×16 3 1 2049.00
885450-0022 22 220×8 150×18 5 1 2066.00
885450-0023 23 278×10 175×25 15 1 2357.00
885450-0024 24 310×10 215×32 30 1 2511.00
885450-0025 25 345×16 225×38 50 1 3189.00
微量杜阿尔组织匀浆器(磨砂内面) 品牌:KIMBLE 885490
Micro DUALL?, All-Glass with Screw-Cap
用途:研磨肌肉,心脏、肺等器官或组织。
简介:885490
Can serve as a storage vessel following homogenization.
Centrifugation, concentrations, and lyophilization can be accomplished without a transfer.
Flat base allows tube to stand upright without support.
Heavy wall construction minimizes breakage.
Capacities shown are without the pestle inserted.
Supplied complete with a pestle, tube, phenolic cap and a PTFE liner.
货号 规格 杵长度 (mm) 外径 (mm) 处理量 (mL) 包装 (个/件) 单价 (RMB)
885490-0017 17 148 6 0.3 1 1710.00
885490-0019 19 148 6 1 1 1808.00
885490-0020 20 165 9 3 1 2091.00
885490-0021 21 165 9 5 1 2186.00
电动微量组织研磨槌-一次性-无DNA、RNA、热原质-独立包装 品牌:KIMBLE
RNase-Free Disposable PELLET PESTLES? with Microtubes
用途:连接马达、微量离心管使用。聚乙烯材质。
简介:
RNase, DNase and Pyrogen-free
Individually wrapped to ensure purity
货号 Description 包装(个/件) 单价(RMB)
749520-0090 Rnase Free Pellet w/tube 1.5ml 100 2795.00
749520-0590 Rnase Free Pellet w/tube 0.5ml 100 2795.00
749521-0590 Rnase Free Pellet only 0.5ml 100 2266.00
749521-1590 Rnase Free Pellet only 1.5ml 100 1820.00
749510-0590 Rnase Free Microtube only 0.5ml 100 681.00
749510-1590 Rnase Free Microtube only 1.5ml 100 681.00
电动微量组织研磨槌-一次性-可高压灭菌 品牌:KIMBLE
简介:
Autoclavable blue polypropylene
Pestles specially designed to match microtubes
Can be driven by Cordless Motor 749540-0000
749520-0500 0.5ml Pellet Pestle with matching microtubes 100 2088.00
749520-0000 1.5ml Pellet Pestle with matching microtubes 100 2088.00
749521-0500 0.5ml Pellet Pestle Only 100 1820.00
749521-1500 1.5ml Pellet Pestle Only 100 1820.00
电动微量组织研磨槌-可重复使用-可高压灭菌-CTFE、不锈钢材质 品牌:KIMBLE
Reusable PELLET PESTLES?, CTFE/Stainless Steel Tissue Grinders
用途:连接马达、微量离心管使用。
简介:
For 500 μL and 1.5 mL micro centrifuge tubes
Autoclavable CTFE/stainless steel
Specially designed to match microtubes
货号 规格 长度(cm) 包装(个/件) 单价(RMB)
749516-0500 0.5ml 6 1 1820.00
749515-0000 1.5ml 14 1 1820.00
微量电动组织匀浆器 品牌:KIMBLE
Pellet Pestle Cordless Motor
用途:驱动电动微量组织研磨槌。
简介:749540
For all Pellet Pestle mixers
Complete with two AA batteries
Resuspend Protein and DNA Pellets or Grind Soft Tissues in Micro Centrifuge Tubes
Operates at 2000 - 3000 RPM's with fresh batteries and no load.
749540-0000 Pellet Pestle Cordless Motor 1 2300.00
749541-0000 Replacement Motor Adapter 1 170.00
操作方法建议:缓冲液在磨样的时候只加一小部分,其他的就是在磨完后冲洗匀浆器的
如, 最常用的匀浆介质为等渗的蔗糖(0.25mol/L)和氯化钾(0.154mol/L)。蔗糖为经典亚细胞组分分离研究所选用,而氯化钾更适合外源化学物代谢酶的研究,如它可更有效除去微粒体制备物中的血红蛋白,减少光谱测定的干扰。匀浆介质在使用前应将pH调至7.4左右。匀浆缓冲液可含有5~50mmol/L的Tris或Hepes。 大多数研究中常用的匀浆缓冲液为含0.154mol/L KCl的50mmol/L Tris?HCI缓冲液,pH7.4。此缓冲液在4℃条件下,至少贮存12周不变质。
特色优势产品 美国Kimble微量电动匀浆器 美国W.s.tyler筛分仪 加拿大Labplas无菌采样袋 美国Miliipore细胞电阻仪 瑞士Keller热珠灭菌器 杜恩斯组织匀浆器 Gelred核酸染料等
美国Kimble/Fisher德国SCHOTT肖特国产蜀牛蓝盖试剂瓶
现货销售!订货优惠!欢迎致电!
联系电话:15011527870(吴先生)QQ1170535434
美国Kimble蓝盖试剂瓶
由符合USP Type Ⅰ 标准硼硅酸盐玻璃制作;有可永久保存的瓷釉刻度及标签位,45mm的宽瓶口操作更方便,有透明聚丙烯(PP)倾倒环在倾倒溶液时不会滴液,带有蓝色聚丙烯(PP)旋盖;整个瓶可高压灭菌(最大操作温度达140℃)。
蓝盖试剂瓶(带不同颜色的盖) 品牌:KIMBLE 14395
GL 45 Storage/Media Bottles with Blue Polypropylene Caps
用途:盛装试剂。
简介:14395
KIMAX? bottles have enhanced graduations and marking spot are permanent white enamel. This general use bottle is provided with wide opening (approx. 30 mm ID) GL 45 screw thread and supplied with linerless autoclavable (140 oC max) polypropylene blue cap. Bottle design includes a clear (natural) drip free polypropylene pour ring which is replaceable.
货号 瓶容量 直径-高度(mm) 刻度范围 (mL) 包装 单价
14395-100 100 56-100 20-80 10 10 846
14395-250 250 70-138 50-200 25 10 940.00
14395-500 500 86-176 100-400 50 10 1124.00
14395-1000 1000 101-225 100-900 50 10 1367.00
14395-2000 2000 136-262 400-1800 100 4 1441.00
14395-5000 5000 186-355 1000-4000 250 1 1193.00
14395-10000 10000 234-435 2000-8000 500 1 2059.00
14396-100 仅瓶无盖 10 719.00
14396-250 仅瓶无盖 10 799.00
14396-500 仅瓶无盖 10 955.00
14396-1000 仅瓶无盖 10 1163.00
14396-2000 仅瓶无盖 4 1225.00
14396-5000 仅瓶无盖 1 1014.00
14396-10000 仅瓶无盖 1 1750.00
德国SCHOTT肖特实验室瓶DURAN试剂瓶
与所有其它的DURAN?产品相同,DURAN?实验室瓶也具有耐化学侵蚀及耐热冲击的性能。其瓶口倾倒环的独特设计,避免了使用时滴漏现象的发生。为方便用户的使用,100ml及以上容量规格的DURAN?实验室瓶都采用了统一的、可互相替换的螺旋瓶盖及倾倒环。瓶子、瓶盖和倾倒环均可消毒。
LABORATORY BOTTLE,DURAN,WITH SCREW-CAP, COMPLETE
货号 规格 价格
DU218019157 volume(ml):20000 ¥4,800
DU218018855 volume(ml):15000 ¥2,885.71
DU218018658 volume(ml):10000 ¥2,085.71
DU218017353 volume(ml):5000 ¥1,082.86
DU218016357 volume(ml):2000 ¥198.57
DU218015455 volume(ml):1000 ¥80
DU218014459 volume(ml):500 ¥57.14
DU218013651 volume(ml):250 ¥45.71
DU218012458 volume(ml):100 ¥41.43
DU218011753 volume(ml):50 ¥48.57
容 积 宽度x高度 瓶 口 材 质 颜 色 货 号
50ml 46mm x 87mm GL32 DURAN? 透明 S21801175
100ml 56mm x 100mm GL45 DURAN? 透明 S21801245
250ml 70mm x 138mm GL45 DURAN? 透明 S21801365
500ml 86mm x 176mm GL45 DURAN? 透明 S21801445
1000ml 101mm x 225mm GL45 DURAN? 透明 S21801545
2000ml 136mm x 262mm GL45 DURAN? 透明 S21801635
美国FisherBrand蓝盖试剂瓶
有聚丙烯螺旋盖和聚丙烯倾倒环(蓝色)100ml-2000ml蓝盖瓶:无倾倒环,但带有特殊成型的玻璃唇,有效防渗漏
1.耐化学性:符合ISO 3585和4796标准;耐水性符合ISO 719(一级)SCHOTT DURAN 符合 USP EP一类玻璃;耐酸性符合DIN 12 116(一级);耐碱性符合 ISO 695二级)
2.耐热性:具有良好的热冲击性能,盛放高温物质的理想容器,可高温杀菌作业,适用于微波炉, 适用于任何实验室,存放化学腐蚀性或普通试剂
3.质量管理:为确保产品的稳定性及可靠性达到高标准,生产中植入了严格的质量管理;统一的壁厚标准;精确、一致的玻璃成分;精确的尺寸和严格控制的公差;良好的稳定性
货号 容量(ml) 瓶盖规格(GL) 直径(mm) 高度(mm) 包装 报价
FB33144 100 45 56 105 10/PK 234
FB33145 250 45 70 143 10/PK 264
FB33146 500 45 86 181 10/PK 332
FB33147 1000 45 101 230 10/PK 466
FB33148 2000 45 136 265 EA 询价
国产蜀牛蓝盖瓶
又称丝口试剂瓶。用于存放水溶性试剂,特别是生物技术实验室储存试剂的首选。广泛用于各工厂,学校,科研单位。瓶身材质:玻璃; 瓶盖材质:PE材质;
产品特点: 1、瓶盖和瓶身具有很好的耐腐蚀及耐热性能, 可高温(140℃)高压灭菌,故可重复使用; 2、防漏外旋盖,瓶口O形防滴漏圈!能将瓶盖和瓶身完全紧密的密封,不漏液体; 3、具有大开口,方便倾倒与配置溶液; 4、优质材料,高硬度,高透明度; 5、全自动设备生产,品质优良一致!
产品规格:
100ML:瓶高99MM,瓶身直径57MM,瓶口内径30MM,瓶口外径40MM(有误差) 250ML:瓶高138MM,瓶身直径70MM,瓶口内径30MM,瓶口外径40MM(有误差) 500ML:瓶高178MM,瓶身直径87MM,瓶口内径30MM,瓶口外径40MM(有误差) 1000ML:瓶高230MM,瓶身直径99MM,瓶口内径30MM,瓶口外径40MM(有误差)
名称 规格 单位 单价 包 装
蓝盖丝口试剂瓶(白色) 100ml 个 7.3 10只/盒;120只/箱
蓝盖丝口试剂瓶(白色) 250ml 个 9.5 8只/盒;48只/箱
蓝盖丝口试剂瓶(白色) 500ml 个 11.5 6只/盒;24只/箱
蓝盖丝口试剂瓶(白色) 1000ml 个 21.6 4只/盒;20只/箱
蓝盖丝口试剂瓶(茶色) 100ml 个 14 10只/盒;120只/箱
蓝盖丝口试剂瓶(茶色) 250ml 个 18.7 8只/盒;48只/箱
蓝盖丝口试剂瓶(茶色) 500ml 个 23.4 6只/盒;24只/箱
蓝盖丝口试剂瓶(茶色) 1000ml 个 34.3 4只/盒;20只/箱
我们是以专业经营进口、国产生物科研仪器、试剂、耗材,专业进行生物及环保产品的技术开发与技术服务的高科技公司。
北京萌壮科技有限公司是专业经营进口、国产生物科研仪器、试剂、耗材,专业进行生物及环保产品的技术开发与技术服务的高科技公司。目前经营的产品品牌有:雷勃、伯乐、宝特、梅特勒、赛多利斯、大龙、SANYO、Shellab、eppendorf、Gilson、Heraeus、ABI、REVCO、Sigma、Fluka、Amresco、Merck、Roche、Pharmacia、Gibco、HyClone、Omega、Promega、Corning、Costar、Orang、Greiner、Axygen、Brand、SCHOTT、RD、cytimmune、peprotech、diaclone、biotium、biocytex、PeproTech 、DSL 等。
| 单位名称: |
北京市朝阳区双营路11号美立方3号楼2单元2108室3单元2101室
800111347 转2号客服
| 联系电话: |
| Email: |
