其它各类仪器
LaserPoint FIT-LPL-R 能量计
LaserPoint FIT-LPL-R Power Meter
进口
意大利
FIT-LPL-R
请电话咨询15168427495
产品概述:
LaserPoint FIT-LPL-R 能量计可以测量闪光灯的单发脉冲能量,最高可测量350J或者最高平均功率100W,测量的动态范围大,最低可测量满量程的1%。
产品特点:
• 可以测量脉冲能量范围7~350J
• 当用burst mode工作时平均功率最高为100W
• 1%重复性
• 3%准确度
• 10秒钟测量和显示读数
• 分辨率为10mW和100mJ
• 输出数据单位可选择J/cm2,配1cm2孔的金属板
产品参数:
功率模式
最大平均功率 100W
最小功率 1W
功率分辨率 100mW
测量和显示时间 10sec
单发能量模式
最大能量(100ms脉冲) 350 J
最小能量 3.5 J
能量分辨率 100mJ
吸收体规格
孔径 20×60mm
类型 LPL-R
吸收体光谱范 0.4~2.1um
校准光谱范围 0.4~2.1um
最大功率密度 10kW/cm2@40W
最大能量密度 10ms脉宽:30J/cm2
1ms脉宽:6J/cm2
100us脉宽:2J/cm2
更多能量计产品,请移步KEWLAB中国官网。
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
