其它各类仪器
LaserPoint A-200-D25-HPB 热探头
LaserPoint A-200-D25-HPB Thermal Probe
进口
意大利
A-200-D25-HPB
请电话咨询15168427495
产品概述:
该型号具有灵活方便,价格低廉,间歇性测量最大功率可以测到800W,最大能量可以测到600J,能量损伤阈值高达250J/cm2,波长0.19~11um。
产品特点:
• 灵活的USB和RS232接口
• 电脑直接显示数据和分析数据
• 风冷连续使用模式下可测量600W,间歇性测量可达800W
• 能量测量模式可达600J
• 高电阻涂料:最大额定功率下高达12KW/cm2
• 能量损失阈值高达250J/cm2
• NIST和 PTB (Physikalisch-Technische Bundesanstalt) 可追溯性
产品参数:
型号 A-200-D25-HPB-U热探头 A-200-D25-HPB-R热探头
接口 USB2.0 RS232
功率模式
最大平均功率 200W
最大间歇功率 250W
最小功率 200mW
功率分辨率 10mW
响应时间(0~90%) 2.2sec
单发能量模式
最大能量(100ms脉冲) 250J
最小能量 0.5mJ
能量分辨率 10mJ
吸收体规格
孔径 25mm
类型 HPB
吸收体光谱范围 0.19~11um
校准光谱范围 0.19~2.1um,2.94um,9~11um
最大功率密度 4kW/cm2@200W
最大能量密度 5ms脉宽:36J/cm2
10us脉宽:1.2J/cm2
10ns脉宽:0.3J/cm2
冷却方式 风扇
更多LaserPoint 热探头产品,请移步KEWLAB中国官网。
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
