细胞计数
Brand 细胞计数板-718605
Brand 细胞计数板-718605
Brand
进口
USA
血细胞计数板,Neubauer型,不含
Brand 细胞计数板
Brand 细胞计数板、BRAND全线产品欢迎询价
细胞计数板, Neubauer型, BLAUBRAND®, CE
CE-marked according to IVD-Directive 98/79 CE. Manufactured according to DIN 12 847, including 2 haemacytometer cover glasses.
The ruling shows 9 large squares of 1 mm² each.
The four large squares in the corners marked "L" for counting leucocytes are each subdivided into 16 squares with 0.25 mm sides. The large square in the center is subdivided into 16 squares with 0.25 mm sides.
Each group square consists of 16 mini squares with 0.05 mm sides, each having an area of 0.0025 mm².
The 5 group squares in the large central square are used for counting thrombocytes and erythrocytes. Contrary to the more advanced Improved Neubauer counting chambers, the counting area of each group square is limited by the outer one of the triple boundary lines.
货号 Produktname
718605 血细胞计数板,Neubauer型,不含弹簧夹           998RMB
718620 血细胞计数板,Neubauer型,含弹簧夹               1481RMB
细胞计数板, Thoma 型, BLAUBRAND®, CE
Rulings correspond to the central large square of the Neubauer chamber. The mini squares have an area of 0.0025 mm² each. Since the outer large squares are not completed, the Thoma chamber is only used for counting thrombocytes and erythrocytes.
货号 Produktname
718005 血细胞计数板,Thoma型,不含弹簧夹       998,00 RMB
718020 血细胞计数板,Thoma型,含弹簧夹           1.481,00 RMB
细胞计数板, Bürker 型, BLAUBRAND®, CE
The ruling shows 9 large squares of 1 mm² each. These are used for counting leucocytes.
Each large square is subdivided by double lines (0.05 mm apart) into 16 group squares with 0.2 mm sides. The group squares correspond in size to the Neubauer counting chamber, but have no further subdivisions. They are used for counting thrombocytes and erythrocytes. The double lines from mini squares with an area of 0.0025 mm².
货号 Produktname
718905 血细胞计数板,Buerker型,不含弹簧夹               998RMB
718920 血细胞计数板,Buerker型,含弹簧夹                   1481RMB
细胞计数板, Malassez 型, BLAUBRAND®, CE
The ruling is rectangular, covering an area of 5 mm². The large rectangles measure 0.25 x 0.20 = 0.05 mm². They are each subdivided into 20 mini squares with an area of 0.0025 mm².
This chamber is commonly used for counting cells in the cerebro-spinal fluid, or for counting nematodes.
货号 Produktname
719005 血细胞计数板,Malassez型,不含弹簧夹                                     998,00 RMB
细胞计数板, Bürker-Türk 型, BLAUBRAND®, CE
Combination of the Bürker and Thoma systems.
The ruling shows 9 large squares of 1 mm² each. The large squares are subdivided into 16 group squares with 0.2 mm sides. in the central large square, each group square is subdivided into 16 mini squares with 0.05 mm sides (= 0.0025 mm²).
货号 Produktname
719505 血细胞计数板, Buerker-Tuerk型,不含弹簧夹                      998元
719520 血细胞计数板,Buerker-Tuerk型,不含弹簧夹                       1481元
细胞计数板, Fuchs-Rosenthal 型, BLAUBRAND®, CE
The ruling differs from the customary systems for blood cell counts by its large area of 16 mm2.
The ruling shows 16 large squares of 1 mm2. Each large square is subdivided into 16 mini squares with 0.25 mm sides and an area of 0.0625 mm2.
This chamber is frequently used for counting cells in the cerebro-spinal fluid.
货号 Produktname
719805 血细胞计数板,Fuchs-Rosenthal型,不含弹簧夹                            998元
719820 血细胞计数板,Fuchs-Rosen型,含弹簧夹                                      1481元
细胞计数板, Nageotte 型, BLAUBRAND®, CE
The square area of 100 mm² is subdivided into 40 rectangles with an area of 2.5 mm² each.
货号 Produktname
721305 血细胞计数板,Nageotte型,不含弹簧夹                               2736RMB
细胞计数板, 改进Neubauer型, BLAUBRAND®, CE
The large square in the center is subdivided into 25 group squares of 0.2 mm sides. Each group square consists of 16 mini squares with 0.05 mm sides, each having an area of 0.0025 mm².
The 5 group squares in the large central square are used for counting thrombocytes and erythrocytes. All group squares have triple boundary lines on each side. The central line is the limiting line and determines whether cells in the marginal area shall be included in the count or not.
货号 Produktname
717805 血细胞计数板,BLAUBRAND®, 改进Neubauer型                           998元
717820 血细胞计数板,改进Neubauer型,含弹簧夹                                   1481元
细胞计数板, 改进Neubauer,亮线, BLAUBRAND®, CE
Same ruling as Improved Neubauer, but with rhodium coated chamber bottom. Rulings are engraved into the rhodium layer and appear bright under normal microscope settings. By altering the contrast, the microscope image can be reversed, so that the rulings appear brighter or darker, as required.
货号 Produktname
717810 血细胞计数板,改进Neubauer型,明线型                             2060元
Haemacytometer-盖玻片 用于细胞计数板, CE-IVD
Borosilicate glass, DIN ISO 8255. Refractive index ne = 1.52 ± 0.01, Abbe number ve = 56.5 ± 0.5. Flatness tolerance ± 3 µm. They differ from ordinary cover glasses by their plain ground and polished surface. CE-marked according to IVD-Directive 98/79 CE. Packing: 2 cover glasses in a plastic bag, separated by tissue paper.
货号 Produktname
723014 血细胞计数板专用盖玻片,适用于血细胞计数板,硼硅酸盐玻璃,24x24mm,符合IVD标准                                                       4189元
723015 血细胞计数板专用盖玻片,适用于血细胞计数板,硼硅酸盐玻璃,20x26mm, 符合IVD标准                                                        3214元
723016 血细胞计数板专用盖玻片,适用于血细胞计数板,硼硅酸盐玻璃,22x30mm,符合IVD标准                                                        5438元
上海辅泽商贸有限公司代理THERMO FISHER 实验室常规设备、检测分析仪器、实验室耗材如下:
实验室常规设备:净化防护、清洁纯化、温度控制、冷冻冷藏、混合破碎、离心浓缩、泵与真空、标签扫描
实验室检测分析仪器:生命科学与生化分析、理化性质分析、小型计量仪、
实验室耗材与安全防护:生物培养、样品采集与保存、离心与过滤、液体处理、色谱耗材、实验室常规耗材、安全防护
实验室常规设备
净化防护:生物安全柜、超净工作台、防护罩台、手套箱
清洁防护:洗瓶机、超声波清洗器、纯水设备
温度控制:培养箱(CO2细胞培养箱、微生物培养箱、低温培养箱、特殊培养箱、通用培养箱)、烘箱、炉具(马弗炉、灰化炉、箱式炉、管式炉)、水浴及水循环、干浴
冷冻冷藏:4℃冰箱、-20℃冰箱、-30℃冰箱、-40℃冰箱、超低温冰箱、深低温冰箱、液氮罐、液氮储存箱、程控降温仪
混合破碎:磁力搅拌器、顶置式搅拌器、振荡器、摇床、研磨机、分散机、超声波破碎仪、匀浆机
离心浓缩:离心机、离心浓缩仪、生物浓缩仪、冷冻干燥系统、快速蒸发系统、旋转蒸发仪
泵与真空设备:蠕动泵、活塞泵、隔膜泵、旋片泵、杂交泵、螺旋泵等
标签扫描:标签书写仪、编码扫描仪、标签生成器
实验室检测分析仪器
生命科学与生化分析:微孔板读数仪、酶标仪、洗板机、微孔板上样辅助仪、微孔板振荡器、热封仪、自动移液工作站、自动分液器、磁珠提取纯化系统、PCR仪、干胶仪、流式细胞仪、细胞离心涂片机
理化性质分析:天平、水分测定仪、电化学(卡尔费休水分仪、电位滴定、水质分析、PH计、电导率计、多叁数测试仪、电极、标准液)、折光仪、分光光度计、浊度仪、胆红素测定仪、热值分析、溶解氧分析、粘度计
小型计量仪:温/湿度计、风速计、转速计、计数器、流量计、压力计、数据采集、声光测定等
实验室耗材与安全防护
生物培养:细胞培养瓶/管、细胞培养皿、细胞培养板、细胞培养小室、细胞培养玻片、细胞培养载体、细胞刮刀/刮铲、多层细胞培养瓶、细胞工厂、果蝇培养、细胞培养皿、涂布与接种、红外接种环灭菌
样品采集与保存:样品采集、样品运输、样品保存、样品冻存(冻存管及配件、冻存管架、梯度降温盒、冻存盒、冰盒、真空绝热瓶、2D冻存系统)
微孔板与PCR耗材:Nunc微孔板、96孔板、384孔板、微孔板配件、PCR耗材
离心与浓缩:离心管、离心瓶、离心管架、过滤器、漏斗、过滤接收瓶、滤膜/滤纸
液体处理:手动移液器、电动移液器、连续分配器、瓶口分配器、分液器、移液吸头、移液管、滴管、滴定管、移液配件/储液槽、胶管、胶管连接
色谱耗材:National样品瓶和样品盖、气相色谱柱、液相色谱柱
实验室常规耗材:试剂瓶/罐、量筒、烧杯、容量瓶、锥形瓶、洗瓶、试管、称量器具、载玻片/盖玻片、磁力搅拌子、搅拌棒、比色皿、电容孔杯、干燥器/干燥柜、封口膜/铝箔、袋子、实验室文具/工具、推车、实验室清洁、坩埚/喂养针/研体
安全防护:生物废物处理、危险品存放、医药急救用品、个人防护、擦拭用品、环境防护
耗材: Axygen、BD、Corning、Schott、NUNC、millipore、merck
分子生物学:电泳、凝胶成像、分光光度计、酶标仪、洗板机、杂交仪、摇床等
细胞生物学:显微镜、CO2培养箱、液氮罐、细胞破碎仪、渗透压计等
药品食品:溶出度仪、硬度仪、崩解时限仪、粉碎机、制粒机、压片机、旋转蒸发仪、熔点仪等
物理化学:浊度计、光泽度计、白度计、色度计、防爆冷柜、氮吹仪、密度计、水分测定仪、定氮仪等
微生物学:微好氧/厌氧工作站、菌落计数仪、蠕动泵、培养基制备分装仪等
通用仪器:超净台、超声波清洗机、PH计、天平、磁力搅拌器、培养箱、水浴箱、灭菌器、离心机、安全柜、切片机、层析柜、制冰机、干式恒温器、混匀小精灵、微孔板的恒温振荡器、烘箱等
    Thermo:CO2培养箱、纯水、液氮罐、马弗炉、细胞破碎仪、摇床、搅拌器、金属浴、超     低温冰箱、离心机、安全柜、离心浓缩仪、酶标仪、洗板机、分光光度计移液器等系列产品
Zealway:高校系列、GIT系列、GR系列
SCILOGEX:离心机、混匀仪、磁力搅拌器、摇床、旋转蒸发仪、金属浴、PCR仪、大容量电动移液器
金凤液氮罐:液氮生物容器、大口径液氮容器、自增压式液氮容器、贮奶桶
超微量分光光度计:Thermo NanoDrop™ One/OneC 、德国IMPLEN NP60/80 Touch
      Hair、-AUCMA:-86℃、-60℃、-50℃、-40℃、-25℃、2-8℃系列冰箱
SANTN:霉菌培养箱、恒温培养箱、光照培养箱、精密鼓风干燥培养箱、恒温恒湿箱、生化培养箱、
试剂:Thermo、Gibco、invitrogen、pierce、life、hyclone、peprotech、biolegend、assay biotech、Simga-aldrich、Qiagen、CST、Abcam、R&D、Vector、santa cruz、Novus、Jackson、MN、corning、Sciencell、ZYMO、eBioscience、NEB、oxoid、wako、amresco、biovison、biotium、takara、roche、promega、bio-rad、selleck、abnova、bd、cayman、merck millpore、yeasen、solarbio、excell bio、KleanAB、Sangon、rhawn、macklin、aladdin、Energy Chemical、biomerieux
      耗材: Corning、Axygen、BD、NUNC、nalgene、Schott、、Millipore、Merck、          QSP、nest、pall、 merck millpore、JET、AMMES、Bio-rad、Eppendorf、            brand、Thermo Fisher、百得BIOHIT、BIO-DL
上海辅泽商贸有限公司,是一家专注于生命科学领域的企业,是中国领先的实验室消耗品供应商。我们提供涉及分子生物学、细胞生物学、生物化学、免疫学、生态学、生物安全食品药品检验及临床检测等诸多领域的仪器和消耗品。
我们专业,所以值得信赖;我们专注,所以我们高速发展;我们信奉“客户第一,员工第二,股东第三”;我们坚持“团结创新,合作共赢”;我们将竭尽所能,为您提供最便捷、最专业的采购服务,节省您的时间和成本。
上海市虹口区曲阳路910号复城国际1101
021-65010900
