酸度计/PH计
Fisherbrand 实验室产品- T_70109-328-4
Fisherbrand
进口
Fisherbrand
NBS CONDUCTVTY STDS
Fisherbrand 询13816982406
Fisherbrand 实验室全线产品-2欢迎询价
T_70109-328-4 EA NBS CONDUCTVTY STDS .0001 MEG 电导率标准液
T_701093282 EA NBS CONDUCTVTY STDS .01 MEG 电导率标准液
T_70106-664-265 EA Traceable® Conductivity Standards (CRM), 150,000 microsiemens Traceable® 电导率标准液(CRM),150,000 微欧(ms),16oz/450mL
T_7011166113 EA HUMIDITY TEMP MIN/MAX MEMORY 温湿度结露点计
T_70106-664-259 EA Traceable® pH Buffer Standards (CRM) 4.005 Traceable® pH标准液(CRM),pH值4.005,16oz/450mL
T_70106-664-260 EA Traceable® pH Buffer Standards (CRM) 7.000 Traceable® pH标准液(CRM),pH值7.000,16oz/450mL
T_70106-664-261 EA Traceable® pH Buffer Standards (CRM) 10.012 Traceable® pH标准液(CRM),pH值10.012,16oz/450mL
T_70109-328-9 EA CONDUCT 1-SHOT 10000UMHOS 6/PK 一次性电导率标准液
T_701093287 EA CONDUCT ONE-SHOT 100UMHOS 6/PK 一次性电导率标准液
T_7010932812 EA CONDUCTVTY 1-SHT 1413 FSR 6/PK 一次性电导率标准液
T_701093288 EA CONDUCT ONE-SHT 1000UMHOS 6/PK 一次性电导率标准液
T_701093286 EA CONDUCT ONE-SHOT 10UMHOS 6/PK 一次性电导率标准液
T_70106-664-268 EA Traceable® One-Shot™ Conductivity Standards (CRM), 150,000 microsiemens Traceable® One-Shot™一次性电导率标准液(CRM),150,000 微欧(ms),6/pk
T_70115-079-609 EA Replacement Probe for 4132 Model 备用探针
T_70115-081-107 EA Platinum High-Accuracy Refrigerator Thermometer with Bullet Probe 冰箱冰柜高精度铂金温度计(子弹探针)
T_70115078180 EA THERMOMETER NARROWRANGE HI ACC 高精温度计
T_7011209920 EA CALCULATOR BIG DIGIT SOLARPWRD 大数字太阳能计算器
T_70115-077-10 EA THERMOMETER EXPAND RANGE FRNH 扩展量程温度计
T_70115-077-11 EA THERMOMETER EXPAND RANGE CENTR 超宽量程温度计
T_70115-081-101 EA Extra-Extra Long-Probe Waterproof Thermometer Extra-Extra超长防水温度计
T_70115-081-129 EA Excursion Trac USB Therm, 2 SS probes Excursion Trac USB温度记录仪,2个不锈钢探针
T_70115-081-126 EA Excursion Trac USB Therm, 2 Bullet™ probes Excursion Trac USB温度记录仪,2个子弹头探针
T_7011507839 EA DUAL THERMOMETER W/OFFSETS 9V 用户调节偏移量温度计
T_70114-648-40 EA TRACEABLE RECORDER THERM 5 DAY
T_70102-401-5 EA TRACEABLE ENVIRO-METER4 IN1 EA 环境测量计
T_70115077966 EA INFRARED THERMOMETER, 1EA 红外线温度计
T_70122-278-143 EA ACCESSORY PROBE EPXY 环氧材料电导率探头
T_70115-077-946 EA CONDUCTIVITY CAL STD  A2LA 1EA a2la认证电导率标准液
T_701093262 EA CONDUCTIVITY METER PORTABL 便携式导电率测量计
T_7010666261 EA FISHER SCI DUAL DISPLAY COND 双显导电率表
T_70115-077-940 EA THERMOMETER DIGITAL NIST 1 EA ultra满标温度计
T_70109-330 EA CONDUCTIVITY BENCH FISHER 台式电导率仪
T_701093262A EA REPLACE PROBE CONDUCTIVITY GLS 玻璃电导率探头
T_70115-077-977 EA CONDUCTIVITY METER 扩展量程电导率计
T_70115-077-9D EA WATER-RESISTANT THERMOMETER F 防水温度计
T_70115-078-195 EA ANEMOMETER 风速/温度/湿度/结露点指示器
T_7011258825 EA SLIDE HOLDER 12/PK 载玻片托架
T_70115-078-200 EA Conductivity Meter 导电率测量计
T_70115-077-948 EA CONDUCTIVITY CAL STD  A2LA 1EA a2la认证电导率标准液
T_70115-077-951 EA CONDUCTIVITY CAL STD  A2LA 1EA a2la认证电导率标准液
T_70115-077-950 EA CONDUCTIVITY CAL STD  A2LA 1EA a2la认证电导率标准液
T_70115-077-953 EA CONDUCTIVITY CAL STD  A2LA 1EA a2la认证电导率标准液
T_70106-664-274 EA Traceable® Conductivity Standards (CRM), Individually tested 200,000 microsiemens Traceable® 电导率标准液(CRM),经每瓶独立测试,200,000 微欧(ms)
T_70106-664-24 EA TRACEABLE CONDCTVTY STD 5UM 电导率标准液
T_70115077945 EA CONDUCTIVITY CAL STD  NIST 1EA 电导率标准液
T_70115078206 EA LAB LABEL TAPE BLUE 4PK 实验室商标胶卷纸卷(蓝)
T_70115078205 EA LAB LABEL TAPE RED 4PK 实验室商标胶卷纸卷(红)
T_70115078207 EA LAB LABEL TAPE GREEN 4PK 实验室商标胶卷纸卷(绿)
T_7010666425 EA TRCABLE COND 1-SHOT 5UM 6PK 一次性电导率标准液
T_70115078204 EA LAB LABEL TAPE BLACK 4PK 实验室商标胶卷纸卷( 黑)
T_7011507751 EA FISHER SCI SENSOR MODULE 远程组件
T_70106-662-63 EA FISHER SCI LIGHT METER 双量程亮度计
T_70114-648-16 EA FISHER SCI BATTERY TESTER 电池测试器
T_7011464918 EA STOPWATCH DIGITAL JUMBO FISHER 超大显示数字跑表
T_7010666264 EA FISHER SCI LIGHT METER FOR PC 双显亮度计
T_701116616A EA FISHER SCI SOUND LEVEL METER 声级计
T_70106-664-18 EA TRACEABLE MANOMETER 0-5 PSI 测压真空计
T_70106-664-19 EA TRACEABLE MANOMETER 0-15PSI 测压真空计
T_70106-664-21 EA TRACEABLE MANOMETER 0-30PSI 测压真空计
T_70106-664-22 EA TRACEABLE MANOMETR 0-100PSI 测压真空计
T_70115078196 EA ANEMOMETER 风速/温度/湿度/结露点指示器/气压计
T_70113383E EA SCIENT MARKING PENS BLUE 6/PK 套装永久标签笔
T_70113383D EA SCIENT MARKING PENS RED 6/PK 套装永久标签笔
T_70113383C EA SCIENT MARKING PENS BLACK 6/PK 套装永久标签笔
T_70113383F EA SCIENT MARKING PENS GREEN 6/PK 套装永久标签笔
T_70115078190 EA MANOMETER 测压真空计(带打印和数据记录功能)
T_70115078193 EA MANOMETER 测压真空计(带打印和数据记录功能)
T_70106-662-65 EA FISHER SCI UV LIGHT METER 紫外线亮度计
T_70111-661-23 EA ADAPTOR ACCESSARY FISHER
T_70115078199 EA OXYEGEN METER 溶解氧测量笔
T_7010666267 EA FISHER SCI MOISTURE METER 湿度计
T_70105-028-24 EA TACHOMETER TOUCHLESS DIGITAL 数字式激光转速计
T_7010666266 EA FISHERBRAND DIS OXYGEN METER 溶解氧测量计
T_7010502823 EA TACHOMETER PHOTO/CONTACT 接触式/非接触式转速计
T_70106-662-68 EA FISHER SCI PRESSURE/VAC METER 压力真空计
T_70115078194 EA ANEMOMETER 风速温度计
T_70106-662-69 EA FISHER SCI SENSOR +-14.5PSI 压力真空计
T_70106-664-30 EA TRACEABLE DIAL THRERM.F 0.2 ultra型数字表盘式温度计
T_7011464976 EA TOOL, LAB 1EA 迷你实验室工具
T_701024012 EA TRACEABLE TACHOMETER TOUCH EA 非接触式转速计
T_7011507750 EA FISHER SCI WIRELESS THERMOMET 射频信号远程温度计
T_7010666437 EA TRACEABLE HUMIDITY  DEWPNT 口袋式结露点温湿度计
T_701150782A EA PROBE FOR SURFACE MEASUREMENT k型表面探针
T_7010666439 EA TRACEABLE INFRARED THRMOMTR 带记忆警报功能的红外线温度计
T_70115-078-179 EA THERMOMETER NARROWRANGE HI ACC 高精温度计
T_70106-662-10 EA INTERVAL TIMER 60MINUTE 60分钟间隔定时器
T_70115-081-125 EA Excursion Trac USB Therm, 1 Bullet™ probe Excursion Trac USB温度记录仪,1个子弹头探针
T_70103405A EA WASH BTL ADJUSTABLE 235ML 3/PK 可调式喷洒清洗瓶
T_70115078188 EA CLOCK MINI 迷你钟
T_70113383 EA SCIENT MARKING PENS ASST 12/PK 套装永久标签笔
T_7011464845 EA TRACE-FLIP-STICK THERMOMETER flip-stick温度计
T_70115-078-184 EA THERMOMETER MIN/MAX TIME STAMP 双联式传感器
T_70115-081-100 EA Traceable® Extra, Extra, Large Digit Countdown Timer 超大数字倒数定时器
T_70115-077-23 EA THERMOMETER FULL SCALE 满标温度计
T_70115078L EA DIAL THERMOMTR F/C JUMBO-DSPLY 超大显示屏表盘式温度计
T_701024020 EA TRACEABLE THERMOMETER ULTRA EA 配探针电缆的ultra温度计
T_70115-079-601 EA Replacement Halogen Bulb for 3095 and 3096 替换灯泡
T_70115077943 EA THERMOMETER, DIGITAL NIST 1EA 配探针卡式组件温度计
T_70115-079-614 EA Traceable® Digital Humidity/Temperature/Dew Point Meter Traceable®数字式湿度/温度/露点计
T_701058151F EA CLAMP TUBING .597-.665 100/PK 软管接管夹头
T_70115078212 EA ANTI-STAT STAT-AWAY HNDLE BRUS 防静电刷
T_70115-077-975 EA THERMOMETER, DIGITAL NIST 1EA ultra经济型冰箱温度计
T_7011464977 EA COUNTER-PEN, 1EA 计数笔
T_70106-664-270 EA Traceable® 5ml Vaccine Jumbo Thermometer Traceable®冰箱冰柜/水浴/加热块/培养箱温度计,带5mL转瓶
T_701150779E EA WATER-RESISTANT THERMOMETER C 配探针电缆防水温度计
T_701024016 EA FISHER SCI LASER KEYCHAIN EA 激光笔
T_70114649101 EA THERMOMETER  WATERPRF FOOD 1EA 带夹座ultra防水食品温度计
T_70115078177 EA THERMOMETER REFRIG HI ACCURACY 高精0.01探针温度计
T_7010666427 EA TRACEABL LOLLIPP THRMOM 0.2 ultralollipop防震防水温度计
T_70115077941 EA THERMOMETER DIGITAL NIST 1 EA 监控型温度计
T_701150779A EA TRIPLE PURPOSE PROBE SS 微探针
T_7011464846 EA TRACE 10 MEMORY THERMOMETER 记忆型防水温度计
T_70115-077-959 EA THERMOMETER, DIGITAL 1 EA 大数字透明温度计
T_70115077960 EA THERMOMETER, DIGITAL 1 EA 大数字透明温度计
T_70101241 EA DIGITAL ANEMOMETER 数字式风速计
T_70115-078-3A EA DUAL CHANNEL THERMOMETER 双通道温度计
T_70115077969 EA INFRARED THERMOMETER, 1EA 红外线宽量程测温枪
T_70115077961 EA THERMOMETER, DIGITAL 1EA 欧铂金冰柜温度计
T_70115-081-124 EA Excursion Trac USB Therm, 2 bottle probes Excursion Trac USB温度记录仪,2个瓶装探针
T_70115-081-127 EA USB Therm, 2 probes, 1 bottle and 1 Bullet™ Excursion Trac USB温度记录仪,1个瓶装探针和1个子弹头探针
T_70115-081-128 EA Excursion Trac USB Therm, 1 SS probe Excursion Trac USB温度记录仪,1个不锈钢探针
T_7011507726 EA DBL THERMOMTR W/COMPUTER OUTPT 双联温度计
T_70114649100 EA THERMOMETER  WATERPRF FOOD1EA 带夹座防水食品温度计
T_7010666426 EA TRACEABLE FLPSTCK THRMO.0.2 ultraflip-stick温度计
T_7011464851 EA FISHER SCI DIAL BAROMETER 高精度表盘式气压计
T_70115-081-133 EA Memory Loc USB Therm, 2 Bullet™ probes Memory Loc USB温度记录仪,2个子弹头探针
T_7011166116 EA BASIC HUMIDITY METER 湿度/温度结露点计
T_7011166120 EA HUMIDITY METER W/RECORDERJACK 温湿度计
T_701150782B EA TYPE K PROBE STAINLESS STEEL k型不锈钢探针
T_70111-463-47A EA TEMP CONTROLLR AUTO 2-AAA BTRY 温度控制器
T_70106-664-33 EA TRACEABLE POCKET THRMOMTR.2 ultra型袖珍温度计
T_70114648232 EA JUMBO MEMORY THERMOMETER 超大记忆型监控温度计
T_7011507761 EA FISHERB LONG-STEM THERMOMETER 加长杆宽量程ultra温度计
T_7011507757 EA INFRARED TEMPERATURE INDICATOR 免接触红外线温度计
T_70115077970 EA INFRARED THERMOMETER, 1EA 红外线宽量超配程测温枪
T_701116618 EA NBS HYGROMETER 32.0 TO 140 F 通用湿度/温度计
T_70114-648-52 EA FSBR TRACEABLE RADIO HUMIDIT 射频信号远程温/湿度计
T_70115077968 EA INFRARED THERMOMETER, 1EA 配万用手夹的红外线温度计
T_70115-081-134 EA Memory Loc Therm, 1 bottle & 1 Bullet™ probe Memory Loc USB温度记录仪,1个瓶装探针和1个子弹头探针
T_70115-081-135 EA Memory Loc USB Therm, 1 SS probe Memory Loc USB温度记录仪,1个不锈钢探针
T_7010666273 EA FISHER SCI HOT WIRE ANEMOMETR 热线风速计/温度计
T_7011166118 EA MEMORY HYGROMETER W/PROBE 记忆湿度/温度计
T_7011507717A EA THERMOMETER HI/LO F FISHR 1.5V 温度计
T_701116617B EA HYG/THERMONTR CERT 14.0 TO176F 湿度/温度结露点计
T_70115078187 EA THERMOMETER TYPE K BIG-DIGIT 大数字k型温度计
T_7011166117A EA PRINTING HUMIDITY/THERMOMETER 打印/湿度温度计
T_70106-664-271 EA Traceable® Memory Hygrometer/Thermometer Traceable®记忆型湿度/温度计
T_70106-664-254 EA Traceable® Infrared Dual Lasers Thermometer w/Type-K Probe Traceable®双激光红外温度计(测温范围:-60至550℃),K型温度传感器
T_7010666434 EA TRACEABLE THERMOMTR PLUS0.2 ultra满标超配温度计
T_7011507716 EA THERMOMTR PRINT 50-70C BATT OP 打印功能温度计
T_7011507838 EA THERMOMETER W/RECORDER JACK 9V 带记录输出数字温度计
T_70115-081-104 EA Replacement Platinum Bullet Probe 子弹探针
T_70115-081-105 EA Replacement Platinum Stainless Steel Handle Probe 不锈钢手柄探针
T_70114-648-27 EA FISHER SCI HUMIDITY CONTROLLER 湿度控制器
T_701116617A EA HYG/THERMOMTR CERT 32.0-176.OF 湿度/温度结露点计
T_70115-081-110 EA Memory-Card Refrigerator/Freezer Thermometer with Bottle Probe 记忆型冰箱冰柜温度计(带瓶装探针)
T_70115-081-111 EA Memory-Card Refrigerator/Freezer Thermometer with Stainless Steel Probe 记忆型冰箱冰柜温度计(带不锈钢探针)
T_70115-081-131 EA Memory Loc USB Therm, 2 bottle probes Memory Loc USB温度记录仪,2个瓶装探针
T_7011166119 EA THERMO-HUMIDITY JUMBO FISHER 湿度温度计
T_7011166121 EA THERMOMETER HUMIDITY FISHER 湿度监控温度计
T_70115-081-130 EA Memory Loc USB Therm, 1 bottle probe Memory Loc USB温度记录仪,1个瓶装探针
T_7011507745 EA Fisher Type K Beaded probe(-40 to 250℃) K型小珠探针 (-40 to 250℃)
T_701058151H EA CLAMP TUBING .730-.830 100/PK 软管接管夹头
T_701058151G EA CLAMP TUBING .670-.780 100/PK 软管接管夹头
T_701058151J EA CLAMP TUBING .870-.975 100/PK 软管接管夹头
T_70115-078-2 EA DIG THERM W-RANGE -212TO+1200C 记忆型宽量程温度计
T_70115-078-178 EA THERMOMETER NARROWRANGE HI ACC 高精温度计
T_70114-648-61 EA Traceable® Dishwasher/Metal Thermometer,dishwasher clip 洗瓶机用金属温度计,带固定夹
T_7011507729 EA THERMOMETER C/F TIMER FISHER 报警温度计/闹铃计时器
T_70106-664-35 EA TRACEABLE FOOD THRMOMTR 0.2 ultra型食品防水贯入式温度计
T_7011464980 EA THERMOMETER-DIGITAL, 1EA pocket-sizek型袖珍温度计
T_7011464981 EA THERMOMETER-DIGITAL, 1EA pocket-sizek型袖珍温度计
T_70106-664-36 EA ITRACEABLE THERMOMETER PLUS 满标超配温度计
T_70115-078-198 EA BAROMETER 数字式温湿度/气压/结露点测量笔
T_70115-081-136 EA Memory Loc USB Therm, 2 SS probe Memory Loc USB温度记录仪,2个不锈钢探针
T_70115078185 EA THERMOMETER MIN/MAX TIME STAMP 双联式传感器
T_70115-081-132 EA Memory Loc USB Therm, 1 Bullet™ probe Memory Loc USB温度记录仪,1个子弹头探针
T_7010666438 EA TRACEABLE INFRARED THRMOMTR 红外线测温枪
T_70115-081-108 EA Platinum High-Accuracy Freezer Thermometer with Stainless Steel Handle Probe 冰箱冰柜高精度铂金温度计(探针带不锈钢手柄)
T_70115-081-106 EA Platinum High-Accuracy Refrigerator Thermometer with Bottle Probe 冰箱冰柜高精度铂金温度计(瓶装探针)
T_7011464812 EA LONG STEM THERMOMETER ULTRA ultra型长杆温度计
T_70114-648-41 EA TRACEABLE RECORDER THERM 10DAY 可抛型温度条形图记录器
T_70114-648-42 EA TRACEABLE RECORDER THERM 40DAY 可抛型温度条形图记录器
T_70115-078-181 EA THERMOMETER NARROWRANGE HI ACC 高精温度计
T_70114-649-102 EA THERMOMETER   FOOD HACCP 食品haccp防水温度计
T_70115-077-52 EA FISHER SCI STAINLESS PROBE 不锈钢探针
T_7011507760 EA FISHER LONG-STEM THERMOMETER 表面表盘式温度计
T_70106-664-269 EA Traceable® Memory Monitoring Plus™ Thermometer Traceable®记忆型冰箱冰柜/水浴/加热块/培养箱温度计
T_70106-664-255 EA Traceable® Digital-Bottle™ Refrigerator/Freezer Thermometer  冰箱温度计
T_70106-664-257 EA Traceable® Digital-Bottle™ Refrigerator/Freezer Thermometer 冰箱温度计
T_70115-077-53 EA FISHER SCI BOTTLE PROBE 外部瓶装探针
T_70115077955 EA DESICATOR, 1 EA 真空干燥器
T_70115-081-120 EA Traceable® Waterproof/Steam-proof Timer 防水/防蒸汽定时器
T_7011507727 EA THERMOMETER 4-ALERT FISHER 大数字四警报温度计
T_7011464822 EA FISHER SCI MAGNIFIER 2.0 INCH 免手持的折叠放大镜
T_7010666258 EA FISHER SCI TIGHT TIES ASST tight-ties组合工具箱
T_70115-077-724 EA 5ML SENTRY VACCN THRMTR, 1EA 5毫升疫苗监控型温度计
T_70115-077-725 EA 5ML SENTRY VACCN THRMTR, 1EA 5毫升疫苗监控型温度计
T_70115-077-942 EA THERMOMETER DIGITAL NIST 1 EA 监控型温度计
T_701150778A EA ALARM THERMOMETER F W/PROBE 数字温度计
T_70106-664-272 EA 33% Calibration Standard with calibration instructions 33%校正标准液和校正指南
T_70115078203 EA LAB LABEL MAKER 实验室标签生成器
T_701120716B EA MAGNIFIER ILLUMINAT 3X 10X 照明放大镜
T_7011464847 EA TRCE JMBO DSPLY .2DEGREE ACRTE ultra超大显示屏表盘式温度计
T_70115078F EA DIAL THERM CENT -50 TO +150 数字表盘式温度计
T_70115-078D EA DIAL THERM FRHN -58 TO 302 数显温度计
T_7011464975 EA TOOL, LAB 1EA 创新实验室工具
T_70115077976 EA THERMOMETER, DIGITAL NIST 1EA 带时间日期高低温记忆功能的温度计
T_7011507754 EA FISHER SCI ROBO THERMOMETER robo型温度计
T_7010666211 EA TIMER PLUS 超配型数字计时器
T_70114-648-53 EA FSBR TRACEABLE HUMID MODULE 温湿度计远程传感器
T_70107-580-1 EA HUMDTY SPONG REGEN DESIC 40/PK 可再生吸湿海绵
T_7011507759 EA FISHER LONG-STEM THERMOMETER 加长杆宽量程温度计
T_70115078J EA THERMOMETER LONG STEM FRNH 长杆温度计
T_70115078G EA POCKET/PIERCING THERM FRNH 口袋温度计
T_7011507732 EA MINI-THERMOMETER C/F FISHER 迷你温度计
T_7010666251 EA TIMER FISHER 99M595 99分59秒计时器
T_7011464979 EA THERMOMETER-DIGITAL, 1EA 袋鼠式温度计
T_701143725 EA MICRO SPATULAS 4/PK 微型抹刀
T_70108850 EA MICRO PROBES 6/PK 微型探头
T_701058151A EA CLAMP TUBING .246-.290 100/PK 软管/接管夹头
T_701058151B EA CLAMP TUBING .360-.406 100/PK 软管/接管夹头
T_701058151C EA CLAMP TUBING .410-.468 100/PK 软管/接管夹头
T_701058151D EA CLAMP TUBING .475-.536 100/PK 软管/接管夹头
T_701058151E EA CLAMP TUBING .538-.608 100/PK 软管接管夹头
T_70115077944 EA THERMOMETER, DIGITAL NIST 1EA 经济型冰箱温度计
T_70115-079-608 EA 1/32" ID Silicone Tubing, 25 feet 1/32" 内径硅胶管, 25 英尺
T_7010666450 EA CLOCK/TEMP/HUMIDITY/TRACEABLE 时钟/温度计/湿度计
T_70103-405-1 EA ANTI-STATIC STATICAWAY BRUSH 防静电刷
T_7010666451 EA CLOCK,TEMP,TRACEABLE,NIST 防水户内、户外时钟
T_70105815 EA CLAMP HOSE/TUBING ASST 65/PK 软管接管夹头组合包
T_70115-077-66 EA FISHER FLEXIBLE ARM LIGHT LNG
T_70115078215 EA THERMOMETER REFRIG HI ACCURACY 高精0.01冰箱温度计
T_7010666256 EA FISHER SCI WATERPROOF STOPWTH 防水防震跑表
T_7011507722 EA THERMOMETER BIG DIGIT W/MINMAX 大数字记忆型温度计
T_7011507755 EA FISHER SCI PT THERMOMETER 电阻式铂金温度计
T_70106-662-6 EA 8-CH ALARM TIMER 120VAC 60HZ 八通道报警计时器
T_701119281 EA CART FOLD-UP FISHER 铝制折叠式四轮手推车
T_7010666245 EA TIMER FISHER LAB-TOP 实验室台端计时器
T_7010666248 EA TIMER FISHER JUMBO WHITE 巨型计时器
T_7010666247 EA TIMER FISHER JUMBO BLACK 巨型计时器
T_70115078176 EA THERMOMETER REFRIG HI ACCURACY 高精0.01冰箱温度计
T_701133831 EA SCIENTIF TECH PENS ASST 12/PK 套装针笔
T_7010666250 EA TIMER FISHER TRIPLE-PURPOSE 三用计时器
T_701066628 EA TIMER MEMORY COUNTDOWN 记忆计时器
T_70107-580 EA HUMDTY SPONG INDIC DESIC 40/PK 指示条
T_70106-664-40 EA TRACEABLE TIMER WATR-RESIST 防水闪光计时器
T_701146497 EA UTILITY DIGITAL STOPWATCH 大数字跑表计时腕表
T_7011464915 EA MINI-ALARM TIMER 100小时迷你闹铃计时器跑表
T_7011209921 EA CALCULATOR SCIENTIFIC PCKT-SZ 科学计算器
T_70115077958 EA CALIPER, DIGITAL 1 EA 数字式游标卡尺
T_70115078213 EA ANTI-STAT STAT-AWAY HNDLE BRUS 防静电刷
T_7011507763 EA FISHER OPTIK WIPES 光学湿巾
T_70115-077-65 EA FISHER FLEXIBLE ARM LGHT
T_70115078214 EA ANTI-STAT STAT-AWAY HNDLE BRUS 防静电刷
T_70114-648-35 EA FSHER SCI TRACEABLE TLKNG TIMR 语音计时器
T_7010666225 EA TIMER PORTABLE KEYCHAIN W/ALRM 钥匙链计时器
T_701058151K EA CLAMP TUBING .953-1.093 100/PK 软管接管夹头
T_70106-664-9 EA CLOCK WALL FISHER 炼金术师时钟
T_7011464978 EA COUNTER-DIGITAL, 1EA 钥匙链、腕带数字式计数器
T_70112099 EA METRIC CALCULATOR 公制换算器
T_70114-648-21 EA FISHER SCI MAGNIFIER 3.0 INCH 免手持的折叠放大镜
T_70112-099-23 EA COMPUTER 12 BIG DIGIT FISHERBD 12位数计算器
T_7010666255 EA FISHER SCI ORIGINAL TIMER 创新实验室计时器
T_701119942 EA KEY-CHAIN LASER POINTER FISHER 带钥匙链激光笔
T_7011464820 EA FISHER SCI MAGNIFIER 3.5 INCH 免手持的折叠放大镜
T_701058151M EA CLAMP TUBING 1.25-1.425 100/PK 软管接管夹头
T_701146495 EA STOPWATCH DIGITAL LCD READOUT 数字跑表
T_7011258830 EA CABINET SLIDE HOLDERS 载玻片托架柜
T_7010666216 EA TIMER TIME-LINK MEMORY ALARM 先进记忆计时器
T_701120716D EA LIGHTED POCKET MICROSCOPE 60X 照明显微镜
T_70106-662-40 EA TIMER TRACEABLE BENCHTOP 数字工作台计时器
T_70115078211 EA CHEMICAL-RESISNT CHECK VLVE6PK 耐化学腐蚀止回阀
T_70115078210 EA CHEMICAL-RESISNT CHECK VLVE6PK 耐化学腐蚀止回阀
T_70115078209 EA CHEMICAL-RESISNT CHECK VLVE6PK 耐化学腐蚀止回阀
T_70115-078-208 EA CHEMICAL-RESISNT CHECK VLVE6PK 耐化学腐蚀止回阀
T_70106-662-57 EA WRITE ON METAL TAGS 48/PK 铝制手写标牌
T_701119282 EA HAND TRUCK FOLD-UP FISHER 铝制折叠式平板手推车
T_70112-071-6E EA LIGHTED POCKET MICROSCOPE 30X 照明显微镜
T_7010666416 EA TRACEABLE CALIPERS 8 INCHES 数字式游标卡尺
T_701024013 EA TRACEABLE TACHOMETER LASER EA 带红色LED 指示器的转速计
T_7011464817 EA FISHER SCI DIGITAL CALIPERS 数字式游标卡尺
T_7011464819 EA FISHER SCI MAGNIFIER 4.3 INCH 免手持的折叠放大镜
T_7011464823 EA FISHER SCI MAGNIFIER 1.2 INCH 免手持的折叠放大镜
T_70122-286-439 EA ELECTRODE HOLDER 电极夹
T_70120-324 EA LIQUID ALARM FISHER AA BATTRY
T_70104-681 EA MINI-DOLLY FOLDING CART 迷你折叠式四轮平板手推车
T_701024019 EA SPILLTRAY AND DRYING RACK EA 防漏盘干燥架
T_70115-079-605 EA 3/32" ID Silicone Tubing, 25 feet 3/32" 内径硅胶管, 25 英尺
T_70113-383-1G EA Scientific Technical Pens - 0.2mm Green (6-Pack) 套装永久标签笔-0.2mm 绿色(6支一包)
T_701119941 EA LASER PNTR 650NM WV/L 2N BATRY 激光笔
T_70115-079-606 EA 1/50" ID Silicone Tubing, 25 feet 1/50" 内径硅胶管, 25 英尺
T_70113-383-1D EA Scientific Technical Pens - 0.4mm Red (6-Pack) 套装永久标签笔-0.4mm 红色(6支一包)
T_701146485 EA TRCBLE CLOCK JUMBO 日历、温度计时钟
T_701120716A EA MAGNIFIER ILLUMINATED 2X 4X 照明放大镜
T_70115077957 EA CALIPER, DIGITAL 1 EA 数字式游标卡尺
T_7010666244 EA TIMER FISHR 2-MEMORY COUNTDOWN 双计忆计时器
T_70114-648-25 EA FISHER SCI MAGNIFIER 0.5 INCH 免手持的折叠放大镜
T_7011464824 EA FISHER SCI MAGNIFIER 0.8 INCH 免手持的折叠放大镜
T_7011522320 EA RESCUER GLASSWARE FISHER 玻璃器皿修补锉
T_70115-079-607 EA Replacement Silicone Tubing and Connectors 备用硅胶管和接头
T_70115-079-604 EA Replacement Silicone Tubing and Connectors 备用硅胶管和接头
T_70115-079-600 EA Replacement Silicone Tubing and Connectors 备用硅胶管和接头
T_7011209925 EA SOLAR DESKTOP CALCULATOR 12DIG 太阳能台端计算器
T_7010666249 EA TIMER FISHER QC 质量控制计时器
T_70106-662-26 EA TIMER FINGERTIP REPEAT MEMORY 指尖计时器
T_70122-305-654 EA PLASTIC WRAP 11.5INX100FT RL 实验室用透明塑料膜
T_7011464983 EA TIMER-DIGITAL, 1EA nano计时器
T_701066623 EA TIMER TRIPLE DSPLY 20HR BAT OP 三画面计时器
T_7013135-CTRL EA black replacement pen for 14-649-77 替换墨水筒,用于14-649-77
T_701138764 EA FISHER VARIABLE FLOW PUMP 变速蠕动管式泵(0.005-1.8 ml/min)
T_701138762 EA VARIABLE FLOW PUMP 变速蠕动管式泵(0.4-85 ml/min)
T_701138761 EA VARIABLE FLOW PUMP 变速蠕动管式泵(0.03-8.2 ml/min)
T_70106-664-251 EA Traceable® Flashing LED Alert Big-Digit Alarm Traceable® 数字式大屏幕闪光计时器
T_70122-055-053 EA CHEESECLOTH WH 36INX100YD 1/PK 标准粗棉布抹布
T_7011166114 EA HUMIDITY/TEMP PEN W/MEMORY 温湿度笔
T_70106-662-4 EA TIME  TEMPERATURE WITH MEMORY 数显温度计(带报警功能)
T_70114648233 EA JUMBO MEMORY THERMOMETER 超大型冰箱冰柜温度计
T_70115-077-721 EA 5ML VACCN THRMTR, .5 DEG, 1EA 5毫升疫苗温度计
T_70115-077-723 EA 5ML VACCN THRMTR, W/MEM, 1EA 带时间日期高低温记忆功能的5毫升疫苗温度计
T_7011464826 EA FSHR TRACEABLE THRMTR RCRDNG 带时间日期高低温记忆功能温度计
T_70115-081-112 EA Fisher Scientifi c Traceable® Memory-Card Humidity/Temperature/ Dew Point SD卡温度/湿度/结露点记录仪
T_70115-077-720 EA 5ML VACCN THRMTR, 1 DEG , 1EA 5毫升疫苗温度计
T_70115-081-123 EA Excursion Trac USB Therm, 1 bottle probe Excursion Trac USB温度记录仪,1个瓶装探针
T_7011507714 EA RANGE THERMOMETER F/C 全量程温度计
T_7011464984 EA HYGROMETER-DIGITAL, 1EA 远程相对温湿度监控器
T_70115-077-20 EA THERMOMETER SOLAR W/PROBE F/C 外部太阳能温度计
T_70114648231 EA SPATULABALANCE 天平勺
T_7011464911 EA STOPWATCH WTR/SHOCK RES BAT OP 防水防震跑表
T_7010666246 EA TIMER FISHER 3-LINE ALARM 三通道闹铃计时器
T_7010666223 EA TIMER CLIP-IT 夹子计时器
T_70115-081-109 EA Platinum High-Accuracy Freezer Thermometer with Bullet Probe 冰箱冰柜高精度铂金温度计(子弹探针)
T_7010666414 EA DRY CLEANWIPES 100/PK 干式清洁抹布
T_70115-081-102 EA Platinum Ultra-Accurate Digital Thermometer with Stainless Steel Handle 超高精度铂金温度计(探针带不锈钢手柄)
T_70115-081-103 EA Platinum Ultra-Accurate Digital Thermometer with Bullet Probe 超高精度铂金温度计(子弹探针)
T_7010666528 EA DESC WIPES CHEESECLTH 200/PK 小块粗棉布抹布
T_7010666423 EA TRACEABLE REFRG THERMMTR0.1 冰箱冰柜温度计
T_7011507717B EA THERMOMETER HI/LO C FISHR 1.5V 监控型温度计
T_7011464844 EA TRACE-WATERPROOF THERMOMETER 防水温度计
T_70106-664-252 EA Traceable® Flashing LED Big-Digit Dual Channel Timer Traceable® 双通道数字式大屏幕闪光计时器
T_70102261840 EA MULTI-COLORED TRAC TIMER 多彩计时器
T_701150778D EA MONITORING MEMORY THERMOMETER 记忆型监控温度计
T_70106-665-23 EA WIPES PREMOISTENED DI 100/PK 去离子水擦拭纸
T_701024017 EA TRACEABLE TIMER EA 即时回放记忆计时器
T_70102261839 EA GIANT-DIGIT TIMER 巨型数字计时器
T_701150778 EA THERMOMTR -40 TO 150C/-40/300F 数字式温度计
T_70106-664-11 EA FISHER REFRIG FREZ THERMOMETER 冰箱冰柜温度计
T_7011464917 EA BIG DIGIT ALARM TIMER 4-CHANEL 四通道闹铃计时器
T_70106-662-5 EA 3-CHAN ALARM TIMR BATTERY OPER 三通道闹铃计时器
T_7010666524 EA WIPES ALCOHOL/DI 100/PK 预浸泡异丙醇擦拭纸
T_70103-405 EA WASH BTL 1000ML W/SPRAY 双头喷洒清洗瓶
T_701033919AC PK(包) 1.5ml Thread Vial,9mm, 32 x 11.6mm, amber glass, 1st hydrolytic class, wide opening, label and filling lines色谱进样瓶, 1.5ml, 棕色
T_70103-391-14 PK(包) PP Open Top Cap 9mm, With blue cap,Silicone white/PTFE red Septa色谱进样瓶盖/垫
T_70114955111A CS(箱) BEAKER TRI-CORNER 50ML 100/CS三角烧杯,聚丙烯
T_70114955121B CS(箱) CONTNR MULTIPRP 172OZ WH 10/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,172 oz., 10个/箱
T_70114955121A CS(箱) CONTNR MULTIPRP 172OZ WH 10/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,172 oz., 10个/箱
T_70114955115A CS(箱) CONTNR MULTIPRP 8OZ SQ WH C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,,8 oz., 100个/箱
T_70114955116B CS(箱) CONTNR MULTIPRP 16OZ TR C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,8 oz., 100个/箱
T_70114955175 PK(包) STER SMPL BAG 2OZ CLEAR 500/PK灭菌样品袋(圆线自封),无空白标签,2 oz, 500个/袋,2包/箱
T_70114955117A CS(箱) CONTNR MULTIPRP 16OZ WH C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,16 oz., 100个/箱
T_70114955107 CS(箱) LID ONLY POLYETHYLENE 500/CS样本罐盖子,与不带盖样本罐配套使用,无菌
T_70108-100-241 CS(箱) CELL SCRAPER INDIV WRAP 100/CS小号细胞刮铲,预灭菌,独立包装, 100/箱
T_70114955101 CS(箱) CONTAINER ONLY 4 1/2 OZ 500/CS样本罐,4.5 oz., 无菌,不带盖
T_70114955130 CS(箱) UV CUVETTES DISP 4.5 ML 500/CS比色皿(四面透明型),4.5ml, 异丁烯酸酯材质,500个/盒
T_70114955185 PK(包) STER SMPL BAG 24OZ PRNT 500/PK灭菌样品袋(圆线自封),有空白标签,24 oz, 500个/袋,2包/箱
T_70114955190 PK(包) STR SMPL BG 24OZ PRT FW 500/PK灭菌样品袋(扁线自封),有空白标签,24 oz, 500个/袋,2包/箱
T_70114955111E CS(箱) BEAKER TRI-CORNER 800ML 100/CS三角烧杯,聚丙烯
T_70114955105 CS(箱) CONTAINER W/LID 8 OZ 100/CS样本罐,8 oz., 无菌,带盖
T_70114955192 PK(包) STR SP BG 7X12 55OZ PRT 250/PK灭菌样品袋(圆线自封),有空白标签,55 oz, 250个/袋,4包/箱
T_70114955111C CS(箱) BEAKER TRI-CORNER 250ML 100/CS三角烧杯,聚丙烯
T_70114955116A CS(箱) CONTNR MULTIPRP 8OZ TL WH C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,8 oz., 100个/箱
T_70114-955-181 PK(包) STER SMPL BAG 42OZ CLR 500/PK灭菌样品袋(圆线自封),无空白标签,42 oz, 500个/袋,2包/箱
T_70114955188 PK(包) STR SMPL BG 42OZ CLR FW 500/PK灭菌样品袋(扁线自封),无空白标签,42 oz, 500个/袋,2包/箱
T_70114955178 PK(包) STER SMPL BAG 27OZ CLR 500/PK灭菌样品袋(圆线自封),无空白标签,27 oz, 500个/袋,2包/箱
T_70113681502 CS(箱) PIPET BASIN STR PS 50ML 200/CS移液槽,50ml, 无菌,5/袋,200/箱
T_70114955195 PK(包) STR SP BG 60OZ PRT FW 250/PK灭菌样品袋(扁线自封),有空白标签,60 oz, 250个/袋,4包/箱
T_70114955177 PK(包) STER SMPL BAG 18OZ CLR 500/PK灭菌样品袋(圆线自封),无空白标签,18 oz, 500个/袋,2包/箱
T_70114955186 PK(包) STR SMPL BG 18OZ CLR FW 500/PK灭菌样品袋(扁线自封),无空白标签,18 oz, 500个/袋,2包/箱
T_70114955196 PK(包) STR SP BG 100OZ CLR FW 250/PK灭菌样品袋(扁线自封),无空白标签,100 oz, 250个/袋,4包/箱
T_70114955103 CS(箱) CONTAINR W/O LID NS 4.5 500/CS样本罐,4.5 oz., 未灭菌,不带盖
T_70113681500 CS(箱) PIPET BASIN NS PVC 50ML 100/CS移液槽,50ml, PVC材质,未灭菌,大包装,100/箱
T_70114955129 CS(箱) DISPOSABLE CUVETTES 500/CS比色皿(四面透明型),4.5ml, 聚苯乙烯材质,500个/盒
T_70108100242 PK(包) CELL SCRAPER LG INDIV 100/CS大号细胞刮铲,预灭菌,独立包装, 100/箱
T_70114955194 PK(包) STR SP BG 55OZ PRT FW 250/PK灭菌样品袋(扁线自封),有空白标签,55 oz, 250个/袋,4包/箱
T_70114955184 PK(包) STER SMPL BAG 18OZ PRNT 500/PK灭菌样品袋(圆线自封),有空白标签,18 oz, 500个/袋,2包/箱
T_70114955189 PK(包) STR SMPL BG 18OZ PRT FW 500/PK灭菌样品袋(扁线自封),有空白标签,18 oz, 500个/袋,2包/箱
T_70114955176 PK(包) STER SMPL BAG 4OZ CLEAR 500/PK灭菌样品袋(圆线自封),无空白标签,4 oz, 500个/袋,2包/箱
T_70114955182 PK(包) STER SMPL BAG 2OZ PRNT 500/PK灭菌样品袋(圆线自封),有空白标签,2 oz, 500个/袋,2包/箱
T_70114955104 CS(箱) CONTAINER W/O LID 8 OZ 500/CS样本罐,8 oz., 无菌,不带盖
T_70114955118A CS(箱) 32OZ WHITE CONT. W/LID 100/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,32 oz., 100个/箱
T_70114955118B CS(箱) CONTNR MULTIPRP 64OZ TR 50/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,32 oz., 100个/箱
T_70114-955-112 CS(箱) CONTAINR 6.5OZ W/O LIDS 500/CS带倾倒口烧杯,透明聚苯乙烯材质,6.5 oz., 500个/箱
T_70113681501 CS(箱) PIPET BASIN STRL PS 50ML 80/CS移液槽,50ml, 无菌,单个独立包装,80/箱
T_70114955119A CS(箱) CONTNR MULTIPRP 64OZ WH 50/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,64 oz., 50个/箱
T_70114955119B CS(箱) CONTNR MULTIPRP 86OZ TR 25/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,64 oz., 50个/箱
T_70114955102 CS(箱) CONTAINR W/LID 4 1/2 OZ 100/CS样本罐,4.5 oz., 无菌,带盖
T_70114955111D CS(箱) BEAKER TRI-CORNER 400ML 100/CS三角烧杯,聚丙烯
T_70113681504 CS(箱) PIPET BASN STR PS 100ML 200/CS移液槽, 100ml, 无菌,5/袋,200/箱
T_70114955126 CS(箱) CUVETTE ACRYLIC 4.5ML 500/CS比色皿(标准型),4.5ml, 异丁烯酸酯材质,500个/盒
T_70114955128 CS(箱) CUVETTES DSP SEMI 1.5ML 500/CS比色皿(半微量型),1.5ml, 异丁烯酸酯材质,500个/盒
T_70114955106 CS(箱) CONTAINR W/O LID NS 8OZ 500/CS样本罐,8 oz., 未灭菌,不带盖
T_70114955114A CS(箱) CONT MLTPRP 4OZ GRD TR 300/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,4 oz., 300个/箱
T_70114955180 PK(包) STER SMPL BAG 24OZ CLR 500/PK灭菌样品袋(圆线自封),无空白标签,24 oz, 500个/袋,2包/箱
T_70114-955-187 PK(包) STR SMPL BG 24OZ CLR FW 500/PK灭菌样品袋(扁线自封),无空白标签,24 oz, 500个/袋,2包/箱
T_70114955111F CS(箱) BEAKER TRI-CORNR 1000ML 100/CS三角烧杯,聚丙烯
T_70114955114B CS(箱) CONTNR MULTIPRP 8OZ RD TR C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,5 oz., 300个/箱
T_70114955117B CS(箱) 32OZ TRANS CONT. W/LID 100/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,16 oz., 100个/箱
T_70114955183 PK(包) STER SMPL BAG 4OZ PRNT 500/PK灭菌样品袋(圆线自封),有空白标签,4 oz, 500个/袋,2包/箱
T_70114955191 PK(包) STR SP BG 7X12 55OZ CLR 250/PK灭菌样品袋(圆线自封),无空白标签,55 oz, 250个/袋,4包/箱
T_70114955193 PK(包) STR SP BG 55OZ CLR FW 250/PK灭菌样品袋(扁线自封),无空白标签,55 oz, 250个/袋,4包/箱
T_70114955120B CS(箱) CONTNR MULTIPRP 172OZ TR 10/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,86 oz., 25个/箱
T_70114955125 CS(箱) CUVETTE POLYSTYRN 4.5ML 500/CS比色皿(标准型),4.5ml, 聚苯乙烯材质,500个/盒
T_70114955127 CS(箱) CUVETTE SEMI-MICRO 1.5ML 500CS比色皿(半微量型),1.5ml, 聚苯乙烯材质,500个/盒
T_70114955115B CS(箱) CNTNR MLTPRP 8OZ TL RD TR C/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,白色,8 oz., 100个/箱
T_70114955120A CS(箱) CONTNR MULTIPRP 86OZ WH 25/CS多用途标本储存罐,高密度聚乙烯(HDPE)材质,半透明色,86 oz., 25个/箱
T_70114955108 CS(箱) LID FOR 4.5OZ 8OZ NS 500/CS样本罐盖子,与不带盖样本罐配套使用,未灭菌
T_70108-100-240 CS(箱) CELL LIFTER INDIV WRAP 100/CS细胞推铲,无菌,独立包装  100/箱
T_70111700555 PK(包) FB TNGE DEPSR 6X3/4 NS 500/PK压舌板
T_70114955111B CS(箱) BEAKER TRI-CORNER 100ML 100/CS三角烧杯,聚丙烯
T_70113681503 CS(箱) PIPET BSN LID STRL  50ML 20/CS移液槽盖子,无菌,单个独立包装, 20/包
T_70114-955-113 CS(箱) LID FOR 14-955-112 25/PK烧杯盖子, 25个/盒,500个/箱
T_70114-955-113 PK(包) LID FOR 14-955-112 25/PK烧杯盖, 25个/盒,500个/箱
T_70101-208-87 PK(包) ANIMAL FEED NDL 20GX1.5 100/PK一次性动物喂养针,长度 1.5'', 管径 20G, 100支/盒
T_70101-208-88 PK(包) ANIMAL FEED NDL 18GX2 100/PK一次性动物喂养针,长度 2'', 管径 18G, 100支/盒
T_70101-208-89 PK(包) ANIMAL FEED NDL 15GX3  100/PK一次性动物喂养针,长度 3'', 管径 15G, 100支/盒
T_70123400102 PK(包) PLAIN WOOD APPLICATORS 864/PK棉签
T_70122363547 CS(箱) CELL STRAINER 40UM STER 50/CS细胞过滤网,膜孔径 40um, 蓝色
T_70122363548 CS(箱) CELL STRAINER 70UM STER 50/CS细胞过滤网,膜孔径 70um, 白色
T_70122363549 CS(箱) CELL STRAINER 100UM STER 50/CS细胞过滤网,膜孔径 100um, 黄色
T_70122363552 PK(包) BASE MOLDS FB 7X7X5 500/PK包埋模
T_70122363553 PK(包) BASE MOLDS FB 15X15X5 500/PK包埋模
T_70122363554 PK(包) BASE MOLDS FB 24X24X5MM 500/PK包埋模
T_70122-363-555 PK(包) BASE MOLDS FB 30X24X5MM 500/PK包埋模
T_70122-363-556 PK(包) BASE MOLDS FB 37X24X5MM 500/PK包埋模
T_70123400115 PK(包) APL CTN6  SM ST WD 1/EV 100/PK棉签
T_803309101009 PK(包) 0.2mL PCR Tubes,1000/PK,10PK/CS PCR管
T_803310101010 PK(包) 0.2 mL PCR Tube Strips Kit, 8-Tube Strips with 8-Domed-Cap Strips, Virgin PP, 125 Strips/Pack, 10 Packs/Case8联管,凸盖
T_803310101011 PK(包) 0.2mL PCR Tube Strips Kit,8-Tube Strips with 8-Flat-Cap Strips, Virgin PP, 125 Strips/Pack, 10 Packs/Case8联管,平盖
T_803310101021 PK(包) 0.1ml 定量PCR 8 联管套装;8联管及8联管平盖;(125 Strips/Pack),10包/箱0.1ml qPCR strip tube kit;8-strip Tubes with 8-strip Flat Caps (125 Strips/Pack),10packs/case
T_803310101016 Bag(袋) Aluminum sealing film, 50 sheets/bag, 50 Bags/Case 铝箔
T_803310101015 Bag(袋) PCR Microplate, 96-Well, Semi-Skirt, Clear Well Bottom,Virgin PP,10 Plates/Bag, 5 Bags/Case PCR板,96孔,无盖,半裙边
T_803310109017 CS(箱) LabServ 175cm2 Flask, Plug Seal Cap,sterile,5/40细胞培养瓶,175cm2, 密封盖,灭菌,5/包,40/箱
T_803310109018 CS(箱) LabServ 175cm2 Flask, Vented Cap,sterile,5/40细胞培养瓶,175cm2, 透气盖,灭菌,5/包,40/箱
T_803310109002 CS(箱) LabServ 50mL centrifuge tube, PP,sterile,25/rack,500/case离心管,50ml, 灭菌,支架包装(25个/架) 500个/箱
T_803310109013 CS(箱) LabServ 25cm2 Flask, Plug Seal Cap,sterile,5/200细胞培养瓶,25cm2, 密封盖,灭菌,10/包,200/箱
T_803310109014 CS(箱) LabServ 25cm2 Flask, Vented Cap,sterile,5/200细胞培养瓶,25cm2, 透气盖,灭菌,10/包,200/箱
T_803310109001 CS(箱) LabServ 15mL centrifuge tube, rack, PP,sterile,50/rack,500/case离心管,15ml, 灭菌,支架包装(50个/架) 500个/箱
T_803310109005 CS(箱) LabServ 6-well tissue culture plate,flat bottom with lid,clear,sterile,1/50细胞培养板,6孔,平底,灭菌,1/包,50/箱
T_803310109006 CS(箱) LabServ 12-well tissue culture plate,flat bottom with lid,clear,sterile,1/50细胞培养板,12孔,平底,灭菌,1/包,50/箱
T_803310109007 CS(箱) LabServ 24-well tissue culture plate,flat bottom with lid,clear,sterile,1/50细胞培养板,24孔,平底,灭菌,1/包,50/箱
T_803310109008 CS(箱) LabServ 96-well tissue culture plate,flat bottom with lid,clear,sterile,1/100细胞培养板,96孔,平底,灭菌,1/包,100/箱
T_803310109015 CS(箱) LabServ 75cm2 Flask, Plug Seal Cap,sterile,5/100细胞培养瓶,75cm2, 密封盖,灭菌,5/包,100/箱
T_803310109016 CS(箱) LabServ 75cm2 Flask, Vented Cap,sterile,5/100细胞培养瓶,75cm2, 透气盖,灭菌,5/包,100/箱
T_803310109003 CS(箱) LabServ 15mL centrifuge tube, bulk, PP,sterile,50/bag,500/case离心管,15ml, 灭菌,大包装(50个/包) 500个/箱
T_803310109011 CS(箱) LabServ 100mm Tissue Culture Dish,sterile,20/300细胞培养皿,100mm, 灭菌,20/包,300/箱
T_803310109010 CS(箱) LabServ 60mm Tissue Culture Dish,sterile,20/500细胞培养皿,60mm, 灭菌,20/包,500/箱
T_803310109012 CS(箱) LabServ 150mm Tissue Culture Dish,sterile,5/100细胞培养皿,150mm, 灭菌,5/包,100/箱
T_803310109009 CS(箱) LabServ 35mm Tissue Culture Dish,sterile,20/500细胞培养皿,35mm, 灭菌,20/包,500/箱
T_803310109004 CS(箱) LabServ 50mL centrifuge tube,PP,sterile,25/bag,500/case离心管,50ml, 灭菌,大包装(25个/包) 500个/箱
T_803309101008 PK(包) 2mL Microcentrifuge Tubes,500/PK,10PK/CS微量离心管
T_803309101007 PK(包) 1.5mL Microcentrifuge Tubes,500/PK,10PK/CS微量离心管
T_803309101006 PK(包) 0.6mL Microcentrifuge Tubes,1000/PK,10PK/CS微量离心管
T_803313118002 PK(包) nitrile gloves,powder free,100%latex free, medium, 100/pack丁腈手套
T_803313118001 PK(包) nitrile gloves,powder free,100%latex free, small, 100/pack丁腈手套
T_803313118004 PK(包) nitrile gloves,powder free,100%latex free, Xtra large, 100/pack丁腈手套
T_803317121019 EA LabServ Easy-HC电动触屏移液管助吸器0.1 – 100 mL LabServ Easy-HC Pipet Controller
T_803317121001 CS LabServ Junior单道可调移液器0.1-2.5ul,50支/箱 LabServ Junior Single Channel Pipette 0.1-2.5ul,50EA/CS
T_803317121002 CS LabServ Junior单道可调移液器0.5-10ul,50支/箱 LabServ Junior Single Channel Pipette 0.5-10ul,50EA/CS
T_803317121003 CS LabServ Junior单道可调移液器2-20ul,50支/箱 LabServ Junior Single Channel Pipette 2-20ul,50EA/CS
T_803317121004 CS LabServ Junior单道可调移液器5-50ul,50支/箱 LabServ Junior Single Channel Pipette 5-50ul,50EA/CS
T_803317121005 CS LabServ Junior单道可调移液器10-100ul,50支/箱 LabServ Junior Single Channel Pipette 10-100ul,50EA/CS
T_803317121006 CS LabServ Junior单道可调移液器20-200ul,50支/箱 LabServ Junior Single Channel Pipette 20-200ul,50EA/CS
T_803317121007 CS LabServ Junior单道可调移液器100-1000ul,50支/箱 LabServ Junior Single Channel Pipette 100-1000ul,50EA/CS
T_803317121008 CS LabServ Junior单道可调移液器1-5ML,50支/箱 LabServ Junior Single Channel Pipette 1-5ML,50EA/CS
T_803317121009 CS LabServ Junior单道可调移液器1-10ML,50支/箱 LabServ Junior Single Channel Pipette 1-10ML,50EA/CS
T_803317121027 EA LabServ Junior 8通道手动可调移液器,量程0.5-10μl LabServ Junior 8 Channel Pipette ,0.5-10μl  MOQ=10
T_803317121028 EA LabServ Junior 8通道手动可调移液器,量程5-50μl LabServ Junior 8 Channel Pipette ,5-50μl  MOQ=10
T_803317121029 EA LabServ Junior 8通道手动可调移液器,量程50-300μl LabServ Junior 8 Channel Pipette,50-300μl  MOQ=10
T_803317121030 EA LabServ Junior 12通道手动可调移液器,量程0.5-10μl LabServ Junior 12 Channel Pipette,0.5-10μl  MOQ=10
T_803317121031 EA LabServ Junior 12通道手动可调移液器,量程5-50μl LabServ Junior 12 Channel Pipette,5-50μl  MOQ=10
T_803317121032 EA LabServ Junior 12通道手动可调移液器,量程50-300μl LabServ Junior 12 Channel Pipette,50-300μl  MOQ=10
T_803317121010 CS LabServ Rainbow单道可调移液器0.5-10ul,50支/箱 LabServ Rainbow Single Channel Pipette 0.5-10ul,50EA/CS
T_803317121011 CS LabServ Rainbow单道可调移液器5-50ul,50支/箱 LabServ Rainbow Single Channel Pipette 5-50ul,50EA/CS
T_803317121012 CS LabServ Rainbow单道可调移液器20-200ul,50支/箱 LabServ Rainbow Single Channel Pipette 20-200ul,50EA/CS
T_803317121013 CS LabServ Rainbow单道可调移液器100-1000ul,50支/箱 LabServ Rainbow Single Channel Pipette 100-1000ul,50EA/CS
T_803317121014 CS LabServ Rainbow单道可调移液器1-5ml,50支/箱 LabServ Rainbow Single Channel Pipette 1-5ml,50EA/CS
T_803317121015 CS LabServ Rainbow单道移液器2-20ul,50支/箱 LabServ Rainbow Single Channel Pipette 2-20ul,50EA/CS
T_803317121016 CS LabServ Rainbow单道移液器10-100ul,50支/箱 LabServ Rainbow Single Channel Pipette 10-100ul,50EA/CS
T_803317121023 EA LabServ Rainbow 8通道手动可调移液器,量程5-50μl LabServ Rainbow 8 Channel Pipette ,5-50μl  MOQ=10
T_803317121024 EA LabServ Rainbow 8通道手动可调移液器,量程50-300μl LabServ Rainbow 8 Channel Pipette,50-300μl  MOQ=10
T_803317121025 EA LabServ Rainbow 12通道手动可调移液器,量程5-50μl LabServ Rainbow 12 Channel Pipette,5-50μl  MOQ=10
T_803317121026 EA LabServ Rainbow 12通道手动可调移液器,量程50-300μl LabServ Rainbow 12 Channel Pipette,50-300μl  MOQ=10
T_803117123002 EA LabServ K3 中文触屏酶标仪 LabServ K3 TOUCH Microplate Reader 200-240V 单机操作无需电脑
T_803117122004 EA LabServ 垂直流标准洁净工作台单人单面,型号Protect-1FD LabServ Clean Bench,Protect-1FD  MOQ=5
T_803117122001 EA LabServ 垂直流标准洁净工作台双人单面,型号Protect-2FD-S LabServ Clean Bench,Protect-2FD-S
T_803117122002 EA LabServ 水平流标准洁净工作台单人单面,型号Protect-1FD-H LabServ Clean Bench,Protect-1FD-H 水平流无玻璃门
T_803117122003 EA LabServ 水平流标准洁净工作台双人单面,型号Protect-2FD-H LabServ Clean Bench,Protect-2FD-H 水平流无玻璃门
T_803117122005 EA LabServ 水平流标准洁净工作台双人单面,加宽,型号Protect-2FD-HW LabServ Clean Bench,Protect-2FD-HW 水平流无玻璃门
T_803117122006 EA LabServ 垂直流标准洁净工作台双人单面,加宽1.8m,型号Protect-2FD-W LabServ Clean Bench,Protect-2FD-W
T_803117122018 EA LabServ真空安全吸液系统,含手柄套装 BIO-VACUSAFE
T_803117122019 EA 疏水性过滤器 BIO-VACUSAFE--Hydrophobic filter
T_803117122020 EA 真空泵组件 BIO-VACUSAFE--Vacuum pump component
T_803117122021 EA 瓶盖组件(PP+2根探针) BIO-VACUSAFE--Bottle cap component
T_701318110503 PK Fisherbrand 16孔金属磁力架,1/PK Magnetic Stand-16  MOQ 15PK
T_701318110501 PK Fisherbrand开盖器,1/PK Smart Opener  MOQ 200PK
T_701318110504 PK Fisherbrand 金属冰盒,1/PK Metal Cooling Box  MOQ 50PK
T_701318110505 PK Fisherbrand 0.2ml冰盒管架,96孔1/PK Cooling Block,96-well,0.2 ml  MOQ 50PK
T_701318110506 PK Fisherbrand 1.5ml/2ml冰盒管架,10孔1/PK Cooling Block,10-well,1.5 ml/2 ml  MOQ 50PK
T_70112540A PK 盖玻片 COVER GLASSES
T_70112540B PK 盖玻片 COVER GLASSES
T_70112540C PK 盖玻片 COVER GLASSES
T_70112541A PK 盖玻片 COVER GLASSES
T_70112541B PK 盖玻片 COVER GLASSES
T_70112542A PK 盖玻片 COVER GLASSES
T_70112542B PK 盖玻片 COVER GLASSES
T_70112542C PK 盖玻片 COVER GLASSES
T_70112543A PK 盖玻片 COVER GLASSES
T_70112543D PK 盖玻片 COVER GLASSES
T_701125441 GRO 载玻片
T_7011254418 PK 盖玻片 COVER GLASSES
T_701125442 GRO 载玻片
T_701125444 GRO 载玻片
T_701125445CY GRO 载玻片 FF MCRO SL 3X1 CYTOL FUL 144GR
T_70112544A PK 盖玻片 COVER GLASSES
T_70112544B PK 盖玻片 COVER GLASSES
T_70112544C PK 盖玻片 COVER GLASSES
T_70112544D PK 盖玻片 COVER GLASSES
T_70112544E PK 盖玻片 COVER GLASSES
T_70112545100 PK 盖玻片 COVER GLASSES
T_70112545102 PK 盖玻片 COVER GLASSES
T_7011254580 PK 盖玻片 COVER GLASSES
T_7011254581 PK 盖玻片 COVER GLASSES
T_7011254583 PK 盖玻片 COVER GLASSES
T_7011254588 PK 盖玻片 COVER GLASSES
T_70112545A PK 盖玻片 COVER GLASSES
T_70112545C PK 盖玻片 COVER GLASSES
T_70112545F PK 盖玻片 COVER GLASSES
T_70112-545G PK 盖玻片 COVER GLASSES
T_70112545J PK 盖玻片 COVER GLASSES
T_70112545M PK 盖玻片 COVER GLASSES
T_70112546 PK 盖玻片 COVER GLASSES
T_701125461 PK 盖玻片 COVER GLASSES
T_701125462 PK 盖玻片 COVER GLASSES
T_701125485E PK 盖玻片 COVER GLASSES
T_701125485M PK 盖玻片 COVER GLASSES
T_701125485P PK 盖玻片 COVER GLASSES
T_70112548A PK 盖玻片 COVER GLASSES
T_70112548B PK 盖玻片 COVER GLASSES
T_70112548C PK 盖玻片 COVER GLASSES
T_701125495 GRO 载玻片
T_70112550003 PK 载玻片
T_70112-550-10 GRO 载玻片
T_70112550143 PK 载玻片
T_7011255015 PK 载玻片
T_7011255018 GRO 载玻片
T_70112550A3 PK 载玻片
T_70112550B GRO 载玻片
T_70112550D GRO 载玻片
T_7011518848 PK 载玻片
T_70119050550A PK 手套
T_70119050550B PK 手套
T_70119050550C PK 手套
T_70119050550D PK 手套
T_701191301597B PK 手套
T_701191301597C PK 手套
T_701191301597D PK 手套
T_70122266882 PK    CVR GLA NO1 1/2 24X60 MM 1OZPK
T_70122-339408 PK   MCRSLD FLURO ERSTD 10MM 144/PK
T_70122266858 PK    CVR GLS NO1 1/2 24X30MM 1OZ/PK
T_7011482718 CS   SHARPS CONTNR TRANS 1GAL 12/CS
T_7011482763 EA 存储桶 CONTAINER SHARPS-A-GATOR 1GAL
T_70114827104 EA 储存盒 CONTAINER RECTANGLE PLAS 7GAL
T_70114-827-71 EA   FB SHARPS CONTAINER RECT 10GAL
T_70122037959 EA  利器收集盒 2 GAL FBRAND SHARPS CNTNR EA
T_70114827129 EA 储存盒 CONTAINER LOW TOP TRAN 3.5GAL
上海辅泽商贸有限公司代理THERMO FISHER 实验室常规设备、检测分析仪器、实验室耗材如下:
实验室常规设备:净化防护、清洁纯化、温度控制、冷冻冷藏、混合破碎、离心浓缩、泵与真空、标签扫描
实验室检测分析仪器:生命科学与生化分析、理化性质分析、小型计量仪、
实验室耗材与安全防护:生物培养、样品采集与保存、离心与过滤、液体处理、色谱耗材、实验室常规耗材、安全防护
实验室常规设备
净化防护:生物安全柜、超净工作台、防护罩台、手套箱
清洁防护:洗瓶机、超声波清洗器、纯水设备
温度控制:培养箱(CO2细胞培养箱、微生物培养箱、低温培养箱、特殊培养箱、通用培养箱)、烘箱、炉具(马弗炉、灰化炉、箱式炉、管式炉)、水浴及水循环、干浴
冷冻冷藏:4℃冰箱、-20℃冰箱、-30℃冰箱、-40℃冰箱、超低温冰箱、深低温冰箱、液氮罐、液氮储存箱、程控降温仪
混合破碎:磁力搅拌器、顶置式搅拌器、振荡器、摇床、研磨机、分散机、超声波破碎仪、匀浆机
离心浓缩:离心机、离心浓缩仪、生物浓缩仪、冷冻干燥系统、快速蒸发系统、旋转蒸发仪
泵与真空设备:蠕动泵、活塞泵、隔膜泵、旋片泵、杂交泵、螺旋泵等
标签扫描:标签书写仪、编码扫描仪、标签生成器
实验室检测分析仪器
生命科学与生化分析:微孔板读数仪、酶标仪、洗板机、微孔板上样辅助仪、微孔板振荡器、热封仪、自动移液工作站、自动分液器、磁珠提取纯化系统、PCR仪、干胶仪、流式细胞仪、细胞离心涂片机
理化性质分析:天平、水分测定仪、电化学(卡尔费休水分仪、电位滴定、水质分析、PH计、电导率计、多叁数测试仪、电极、标准液)、折光仪、分光光度计、浊度仪、胆红素测定仪、热值分析、溶解氧分析、粘度计
小型计量仪:温/湿度计、风速计、转速计、计数器、流量计、压力计、数据采集、声光测定等
实验室耗材与安全防护
生物培养:细胞培养瓶/管、细胞培养皿、细胞培养板、细胞培养小室、细胞培养玻片、细胞培养载体、细胞刮刀/刮铲、多层细胞培养瓶、细胞工厂、果蝇培养、细胞培养皿、涂布与接种、红外接种环灭菌
样品采集与保存:样品采集、样品运输、样品保存、样品冻存(冻存管及配件、冻存管架、梯度降温盒、冻存盒、冰盒、真空绝热瓶、2D冻存系统)
微孔板与PCR耗材:Nunc微孔板、96孔板、384孔板、微孔板配件、PCR耗材
离心与浓缩:离心管、离心瓶、离心管架、过滤器、漏斗、过滤接收瓶、滤膜/滤纸
液体处理:手动移液器、电动移液器、连续分配器、瓶口分配器、分液器、移液吸头、移液管、滴管、滴定管、移液配件/储液槽、胶管、胶管连接
色谱耗材:National样品瓶和样品盖、气相色谱柱、液相色谱柱
实验室常规耗材:试剂瓶/罐、量筒、烧杯、容量瓶、锥形瓶、洗瓶、试管、称量器具、载玻片/盖玻片、磁力搅拌子、搅拌棒、比色皿、电容孔杯、干燥器/干燥柜、封口膜/铝箔、袋子、实验室文具/工具、推车、实验室清洁、坩埚/喂养针/研体
安全防护:生物废物处理、危险品存放、医药急救用品、个人防护、擦拭用品、环境防护
耗材: Axygen、BD、Corning、Schott、NUNC、millipore、merck
分子生物学:电泳、凝胶成像、分光光度计、酶标仪、洗板机、杂交仪、摇床等
细胞生物学:显微镜、CO2培养箱、液氮罐、细胞破碎仪、渗透压计等
药品食品:溶出度仪、硬度仪、崩解时限仪、粉碎机、制粒机、压片机、旋转蒸发仪、熔点仪等
物理化学:浊度计、光泽度计、白度计、色度计、防爆冷柜、氮吹仪、密度计、水分测定仪、定氮仪等
微生物学:微好氧/厌氧工作站、菌落计数仪、蠕动泵、培养基制备分装仪等
通用仪器:超净台、超声波清洗机、PH计、天平、磁力搅拌器、培养箱、水浴箱、灭菌器、离心机、安全柜、切片机、层析柜、制冰机、干式恒温器、混匀小精灵、微孔板的恒温振荡器、烘箱等
    Thermo:CO2培养箱、纯水、液氮罐、马弗炉、细胞破碎仪、摇床、搅拌器、金属浴、超     低温冰箱、离心机、安全柜、离心浓缩仪、酶标仪、洗板机、分光光度计移液器等系列产品
Zealway:高校系列、GIT系列、GR系列
SCILOGEX:离心机、混匀仪、磁力搅拌器、摇床、旋转蒸发仪、金属浴、PCR仪、大容量电动移液器
金凤液氮罐:液氮生物容器、大口径液氮容器、自增压式液氮容器、贮奶桶
超微量分光光度计:Thermo NanoDrop™ One/OneC 、德国IMPLEN NP60/80 Touch
      Hair、-AUCMA:-86℃、-60℃、-50℃、-40℃、-25℃、2-8℃系列冰箱
SANTN:霉菌培养箱、恒温培养箱、光照培养箱、精密鼓风干燥培养箱、恒温恒湿箱、生化培养箱、
试剂:Thermo、Gibco、invitrogen、pierce、life、hyclone、peprotech、biolegend、assay biotech、Simga-aldrich、Qiagen、CST、Abcam、R&D、Vector、santa cruz、Novus、Jackson、MN、corning、Sciencell、ZYMO、eBioscience、NEB、oxoid、wako、amresco、biovison、biotium、takara、roche、promega、bio-rad、selleck、abnova、bd、cayman、merck millpore、yeasen、solarbio、excell bio、KleanAB、Sangon、rhawn、macklin、aladdin、Energy Chemical、biomerieux
      耗材: Corning、Axygen、BD、NUNC、nalgene、Schott、、Millipore、Merck、          QSP、nest、pall、 merck millpore、JET、AMMES、Bio-rad、Eppendorf、            brand、Thermo Fisher、百得BIOHIT、BIO-DL
上海辅泽商贸有限公司,是一家专注于生命科学领域的企业,是中国领先的实验室消耗品供应商。我们提供涉及分子生物学、细胞生物学、生物化学、免疫学、生态学、生物安全食品药品检验及临床检测等诸多领域的仪器和消耗品。
我们专业,所以值得信赖;我们专注,所以我们高速发展;我们信奉“客户第一,员工第二,股东第三”;我们坚持“团结创新,合作共赢”;我们将竭尽所能,为您提供最便捷、最专业的采购服务,节省您的时间和成本。
上海市虹口区曲阳路910号复城国际1101
021-65010900
