Fisherbrand 实验室产品- T_70119-813-259
T_70119-813-259 | EA | None | BACKS |
T_70119-813-260 | EA | None | SHELVNG CLPS F/8000 SERES CABS |
T_70119-813-261 | EA | None | END TIE CLIS |
T_70119-813-262 | EA | None | PRESS TST KT F/LEVEL 'A' SUITS |
T_70119-813-263 | EA | None | TWIST LOCK VLV F/PRESS TST KT |
T_70119-813-298 | CS | None | PLYPR CVRALL WH W/CLR 2X 25CS |
T_70119-813-323 | EA | None | 2X BOOT COVERS NON-SKID GREY |
T_70119-813-331 | CS | None | NON-SKID TYVEK BTIES 200PR/CS |
T_701XX4504700 | EA | None | FLTR HOLDER HIGH PRESS 47MM SS |
T_701XX4504704 | EA | None | FLTR SUPRT SCRN 47MM HIGH PRES |
T_701XX4504705 | PK | None | O-RING INNER TEFVIT 2-030 5/PK |
T_701XX4504710 | PK | None | O-RING OUTR/INNR TF 2-030 5/PK |
T_701XX4504713 | PK | None | O-RING OUTER EPR 2-033 10/PK |
T_701XX5000002 | EA | None | FLOW LIMIT ORIFICE 1 LPM |
T_701XX5000020 | EA | None | FLOW LIMIT ORIFICE 2 LPM |
T_701XX5002501 | EA | None | SUPRT SCREEN 25MM SS VACUU |
T_701XX5004700 | EA | None | FLTR HLDR 47MM AEROSOL STD |
T_701XX5004710 | EA | None | FLTR HLDR 47MM AEROSOL OPEN |
T_701XX5004740 | EA | None | MONITOR FLTR CLEAN ROOM |
T_701XX6200004 | EA | None | AEROSOL ADAPT M-LUER-1/4HO |
T_701XX6210000 | EA | None | BABCOCK+WILCOX COLOR STAND |
T_701XX631K000 | EA | None | ENVIRONMENTAL SC LAB KIT 115V |
T_701XX6370000 | EA | None | U/V STERILIZER 115V/60HZ |
T_701XX63LK115 | EA | None | ENVIRONMENTAL LAB KIT 115V |
T_701XX6403705 | EA | None | REMOTE SAMPLING ASSY |
T_701XX6403708 | EA | None | SAMPLER VALVE HOSE ASSEMBL |
T_701XX6403730 | EA | None | FLUID SAMPLING KIT |
T_701XX6403735 | EA | None | QUCK REL VLV WO ADPTR 1/8IN NT |
T_701XX6403780 | EA | None | BY-PASS HOSE ADAPTERBY-PASS H |
T_701XX6504704 | EA | None | BTL SLVNT DISP 500ML W/HOLE MO |
T_701XX6504707 | EA | None | FLTR HLDR SWINNEX 25MM W/SCRN |
T_701XX6504708 | EA | None | FLTR HOLDER SUPPORT W/BASE SS |
T_701XX6504709 | EA | None | SAMPLE BOTTLE 120ML PVC |
T_701XX6504712 | EA | None | PATCH TEST KIT SPARE PARTS |
T_701XX6504713 | EA | None | NAVAL HYDRAVLIC COLOR GUID |
T_701XX6504730 | EA | None | INDUST PATCH TEST KIT |
T_701XX6602500 | EA | None | DISPENSER SOLVENT FLTR 25MM |
T_701XX6700010 | PK | None | CYLINDER O-RING 3/PK |
T_701XX6700024 | EA | None | VENT RELIEF VALVE 1/4NPTM |
T_701XX6700028 | EA | None | PRESS RELIEF VLV W/TBNG ADPTR |
T_701XX6700030 | EA | None | QUICK RELEAS NIPPL/COUP 1/4NPT |
T_701XX6700034 | EA | None | TUBNG PVC 3/8IN 10FT 125PSI |
T_701XX6700035 | EA | None | TUBNG PVC 1/2IN 10FT 125PSI |
T_701XX6700037 | EA | None | TUBNG SILICN 2IN MED GRD 1/4IN |
T_701XX6700038 | EA | None | TUBNG SILICN 2IN MED GRD 1/2IN |
T_701XX6700059 | EA | None | O-RING VITON A5-381 |
T_701XX67000PK | EA | None | PRESSURE VESSEL REPL KIT |
T_701XX6700101 | EA | None | 1/4IN NPTF TEE SST |
T_701XX6700104 | EA | None | 1/4''NPTF TO MALE STREET ELBOW |
T_701XX6700115 | EA | None | 1/4IN NPTM SS CLOSE NIPPLE |
T_701XX6700118 | EA | None | 1/4INNPTF-1/4 ID HSE NYLN 2/EA |
T_701XX6700125 | EA | None | 1/4IN NPTM 2IN(51MM) HEX NIPLE |
T_701XX6700L11 | EA | None | 1/4IN NPTM HOSE CONNECTR SST |
T_701XX6700L15 | EA | None | ASTM PRES GAUGE SST 0-160PSI |
T_701XX6700L24 | EA | None | PRESS RELIEF VALVE 100PSI ASME |
T_701XX6700P01 | EA | None | 1 GALLON PRESSURE VESSEL |
T_701XX6700P05 | EA | 正压过滤器 | PRESSURE VESSEL ASME 5L |
T_701XX6700P10 | EA | 正压过滤器 | DISP PRESS VESSL ASME SS 10L |
T_701XX6700P20 | EA | 压力罐+泵 | DISP PRESS VESSL ASME SS 20L |
T_701XX6702500 | EA | None | DISPENSER FILTERJET SOLV 25MM |
T_701XX6702502 | PK | None | VALVE SEALS PTFE 4/PK |
T_701XX6702506 | EA | None | PRESSRE TUBNG PP W/1/4IN NPTM |
T_701XX6702507 | EA | None | ADAPTER 1/4INNPTM X 1/4IN TUBE |
T_701XX6702508 | EA | None | TUBING PE 1/4INODX3M |
T_701XX67025RK | EA | None | REPLC KIT F/SLVNT FLTR JET NOZ |
T_701XX7100004 | EA | 90mm 玻璃过滤器瓶架用硅管 | TUBING SILICONE 3/16INID 1.4M |
T_701XX7104712 | EA | None | FLUID CONTAM ANAL KIT 230V 50H |
T_701XX8020EL0 | EA | None | FIXED SPEED PERI PUMP 115V |
T_701XX8023EL0 | EA | None | STERIVEX EASY LOAD PUMP 230V |
T_701XX80EL000 | EA | None | PERSTALTIC PUMP 4-13L/MIN 115V |
T_701XXMULTIMN | EA | None | LABSCALE MULTI-MANIFOLD KIT |
T_701XXPXLGAGE | EA | None | PELLICON XL GAGE KIT |
T_701XXPXLSTND | EA | None | PELLICON STAND |
T_701XXRES05ST | EA | None | 100ML RESERVOIR STAND 1/PK |
T_701ICN15393205 | EA | None | LACTULOSE 5G |
T_701ICN15393710 | EA | None | METHYL A-D-MANNOPYRANOSI 10G |
T_701ICN15393725 | EA | None | METHYL A-D-MANNOPYRANOSI 25G |
T_701ICN15393780 | EA | None | METHYL A-D-MANNOPYRANOSI 100G |
T_701ICN15394810 | EA | None | D-(+)-TREHALOSE 10G |
T_701ICN15394850 | EA | None | D-(+)-TREHALOSE 50G |
T_701ICN15395525 | EA | None | 2,3,5-TRI-O-BENZOYL-1-O- 25G |
T_701ICN15395580 | EA | None | 2,3,5-TRI-O-BENZOYL-1-O- 100G |
T_701ICN15396801 | EA | None | 1,3,5-TRI-O-BENZOYL- A-D 1G |
T_701ICN15398180 | EA | None | OLEANOLIC ACID .1G |
T_701ICN15398190 | EA | None | OLEANOLIC ACID .5G |
T_70114-175H | PK | None | VAC TUB 13/16 1-9/160D 15FT/PK |
T_7011417610 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/8X1/32 50FT/CS |
T_70114-176-12 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/8X1/16 50FT/CS |
T_70114-176-120 | CS | Nalgene 聚乙烯管 | TUBING CPE 3/8 IN ID 100FT/CS |
T_70114176121 | CS | Nalgene 聚乙烯管 | TUBING CPE 1/8 IN ID 100FT/CS |
T_70114-176-123 | CS | Nalgene 聚乙烯管 | TUBING CPE 1/4 IN ID 100FT/CS |
T_70114-176-124 | CS | Nalgene 聚乙烯管 | TUBING CPE 1/2 IN ID 100FT/CS |
T_70114-176-126 | CS | Nalgene 聚乙烯管 | TUBING LDPE 5/8 ID 100FT/CS |
T_70114-176-14 | CS | Nalgene 180透明PVC管 | TUBING PLAS 3/16X1/16 50FT/CS |
T_70114176151 | CS | None | TUBING PP 1/4IDX3/8IN100FTCS |
T_70114-176-172 | CS | None | TUBING PUR 1/4X1/16 50FT/CS |
T_70114-176-173 | CS | None | TUBING PUR 3/8X1/16 50FT/CS |
T_70114176178 | PK | Nalgene 890 PTFE FEP 管 | TUBNG 890FEP 1/8IN OD 25FT/PK |
T_70114176179 | PK | Nalgene 890 PTFE FEP 管 | TUBNG 890FEP 1/4IN OD 25FT/PK |
T_70114-176-180 | PK | Nalgene 890 PTFE FEP 管 | TUBNG 890FEP 5/16IN OD 25FTPK |
T_70114-176-181 | PK | Nalgene 890 PTFE FEP 管 | TUBNG 890FEP 3/8IN OD 25FT/PK |
T_70114-176-182 | PK | Nalgene 890 PTFE FEP 管 | TUBNG 890FEP 1/2IN OD 25FT/PK |
T_70114-176-20 | CS | Nalgene 180PVC真空管 | TUBING PLAS 3/16X3/16 50FT/CS |
T_70114-176-218 | CS | None | TBE PVC 1/4X1/16IN 100FTCS |
T_70114-176-219 | CS | None | TBE PVC 1/4X1/8IN 100FTCS |
T_7011417622 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/4X1/16 50FT/CS |
T_70114-176-221 | CS | None | TBE PVC 3/8X1/16IN 100FTCS |
T_70114-176-222 | CS | None | TBE PVC 3/8X1/8IN 100FTCS |
T_70114-176-228 | CS | None | TBE PVC 3.0X01.0MM 25M/CS |
T_70114-176-229 | CS | None | TBE PVC 4.0X1.0MM 25M/CS |
T_70114-176-236 | CS | None | TBE PVC 8.0X2.0MM 25M 1/CS |
T_70114-176-238 | CS | None | TBE PVC 10.0X2.0MM 25M 1/CS |
T_7011417624 | CS | Nalgene 180PVC真空管 | TUBING PLAST 1/4X3/16 50FT/CS |
T_70114176247 | PK | PVC管 | TUBE 180PVC 5/16X1/16 10FT/PK |
T_70114-176-254 | CS | None | TUBE 870PFA 3/8X1/16IN 25FTCS |
T_70114176256 | CS | None | TUBE 870PFA 1/4X1/16IN 25FTCS |
T_70114176258 | PK | None | TUBE 870PFA 5/32X1/16IN 25FTPK |
T_70114176259 | PK | None | TUBE 870PFA 1/8X1/32IN 25FTPK |
T_7011417626 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/4X3/32 50FT/CS |
T_70114-176-260 | PK | None | TUBE 870PFA 1/16X1/32IN 25FTPK |
T_70114176271 | PK | Nalgene 890 PTFE FEP 管 | TUBING FEP 1/8 X 3/16 25FT/PK |
T_70114-176-272 | PK | Nalgene 890 PTFE FEP 管 | TUBING FEP 3/8 X 7/16 25FT/PK |
T_70114-176-273 | PK | Nalgene 890 PTFE FEP 管 | TUBING FEP 1/2 X 9/16 25FT/PK |
T_70114-176-278 | CS | Nalgene 50铂金固化硅管 | TUBING SIL.255X.385 25FT 1/CS |
T_70114-176-279 | CS | Nalgene 50铂金固化硅管 | TUBING SIL.313X.443 25FT 1/CS |
T_7011417628 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/4X1/8 50FT/CS |
T_70114-176-282 | CS | Nalgene 50铂金固化硅管 | TUBING SIL.193X.323 25FT 1/CS |
T_70114-176-294 | CS | Nalgene 50铂金固化硅管 | TUBING SIL .375 X .625 25FT/CS |
T_70114-176-295 | CS | Nalgene 50铂金固化硅管 | TUBING SIL .500 X .750 25FT/CS |
T_7011417630 | CS | Nalgene 180透明PVC管 | TUBING PLAS 5/16X1/16 50FT/CS |
T_70114-176-307 | CS | None | TBG SIL BRD 1/4 X .520 25FT/CS |
T_70114176308 | CS | None | TBG SIL BRD 3/8 X .655 25FT/CS |
T_70114-176-309 | CS | None | TBG SIL BRD 1/2 X .800 25FT/CS |
T_70114-176-32 | CS | Nalgene 180透明PVC管 | TUBING PLAS 5/16X3/32 50FT/CS |
T_70114176332A | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/16X1/8 50' 1/CS |
T_70114176332B | CS | Nalgene 50铂金固化硅管 | TBG SILICONE 1/8X1/4 50' 1/CS |
T_70114-176-332C | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/16X5/16 50' 1/CS |
T_70114176332D | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/16X3/8 50' 1/CS |
T_70114176332E | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/4X3/8 50FT 1/CS |
T_70114176332F | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/4X7/16 50' 1/CS |
T_70114-176-332G | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/4X1/2 50FT 1/CS |
T_70110255 | EA | None | BIURET REAGENT TS, 20 L |
T_70110-260A | PK | None | FLASK VOL KOHLR 100ML 2/PK |
T_70110-260B | PK | None | FLASK VOL KOHLR 200ML 2/PK |
T_70110-265-140 | EA | None | XPERT BULK POWD SYSTM 5 -L 115 |
T_70110-265-141 | EA | None | XPERT BULK POWD SYSTM 5 -C 115 |
T_70110-265-144 | EA | None | XPERT BULK POWD SYSTM 6 -L 115 |
T_70110-265-145 | EA | None | XPERT BULK POWD SYSTM 6 -C 115 |
T_70110-265-148 | EA | None | XPERT BULK POWD STATN 5 -L 115 |
T_70110-265-149 | EA | None | XPERT BULK POWD STATN 5 -C 115 |
T_70110-265-152 | EA | None | XPERT BULK POWD STATN 6 -L 115 |
T_70110-265-153 | EA | None | XPERT BULK POWD STATN 6 -C 115 |
T_70110-265-156 | EA | None | XPERT BULK POWDR ENCL 5 -L 115 |
T_70110-265-157 | EA | None | XPERT BULK POWDR ENCL 5 -C 115 |
T_70110-265-160 | EA | None | XPERT BULK POWDR ENCL 6 -L 115 |
T_70110-265-161 | EA | None | XPERT BULK POWDR ENCL 6 -C 115 |
T_70110-265-164 | EA | None | XPERT BULK POWDR ENCL 8 -L 115 |
T_70110-265-165 | EA | None | XPERT BULK POWDR ENCL 8 -C 115 |
T_70110-265-168 | EA | None | RETAINING RING - 19.62 IDRETA |
T_70110-265-169 | EA | None | RETAINING RING - 17.5 IDRETAI |
T_70110-265-171 | EA | None | RETAINING RING - 11.5 IDRETAI |
T_70110-265-172 | PK | None | SAFETY SLEEVE PKG OF 100/PK |
T_70110-265-173 | PK | None | SAFETY SLEEVE PKG OF 500/PK |
T_70110-265-174 | PK | None | RETAINING BANDS PKG OF 5/PK |
T_70110-265-175 | EA | None | ACCESS OPENING COVER |
T_70110-265-176 | EA | None | REPLACEMENT TRANSFER CADDY |
T_70110-266 | CS | None | FLASK SUGAR 100ML |
T_70110-269-104 | EA | None | HEATED SHELF W/SENSOR 115V |
T_70110-269-106 | EA | None | FREEZE DRY BULK TRAY SST |
T_70110-269-131 | EA | None | OPEN ACCESS TRANSFER STN 115V |
T_70110-269-133 | EA | None | ANIMAL TRANSFER STATION 115V |
T_70110-269-135 | EA | None | BEDDING DISPOSAL STAT 3' 115V |
T_70110-269-250 | EA | None | IV BAR 3 PURIFIER LOGIC CABIV |
T_70110-269-251 | EA | None | IV BAR 4 LOGIC & PROCED STATI |
T_70110-269-252 | EA | None | IV BAR 5 PURIFIER LOGIC CABIV |
T_70110-269-253 | EA | None | IV BAR 6 LOGIC & PROCED STATI |
T_70110-269-254 | EA | None | TURNTABLE -LOGIC & PROCED STAT |
T_70110-269-255 | EA | None | INTER SHELF-LOGIC PROCED STAT |
T_70110-269-256 | EA | None | CORD SYSTEM-LOGIC PROCED STAT |
T_70110-269-257 | EA | None | LAPTOP ARM FOR SOLO BASE STAND |
T_70110-269-258 | EA | None | LAPTOP ARM - TELESCOPING STAND |
T_70110-269-259 | EA | None | SUPPORT SHELF FOR TELES STAND |
T_70110-269-260 | EA | None | SUPPORT SHELF-HYDRAULIC STAND |
T_70110-269-261 | EA | None | UV LAMP-LOGIC & PROCED STA 115 |
T_70110-269-262 | EA | None | UV LAMP-LOGIC & PROCED STA 100 |
T_70110-269-263 | EA | None | UV LAMP-LOGIC & PROCED STA 230 |
T_70110-269-273 | EA | None | COATED STEEL BLOWER 12 2 HP |
T_70110-269-280 | EA | None | ULPA SUPPLY FILTER FOR 3 |
T_70110-269-281 | EA | None | ULPA SUPPLY FILTER FOR 4 |
T_70110-269-282 | EA | None | ULPA SUPPLY FILTER FOR 5 |
T_70110-269-283 | EA | None | ULPA SUPPLY FILTER FOR 6 |
T_70110-269-284 | EA | None | ULPA EXHAUST FILTER FOR 3 |
T_70110-269-285 | EA | None | ULPA EXHAUST FILTER FOR 4 |
T_70110-269-286 | EA | None | ULPA EXHAUST FILTER FOR 5 |
T_70110-269-287 | EA | None | ULPA EXHAUST FILTER FOR 6 |
T_70110-269-294 | EA | None | REPL HEPA SUPPLY FILTER FOR 3 |
T_70110-269-295 | EA | None | REPL HEPA SUPPLY FILTER FOR 4 |
T_70110-269-296 | EA | None | REPL HEPA SUPPLY FILTER FOR 5 |
T_70110-269-297 | EA | None | REPL HEPA SUPPLY FILTER FOR 6 |
T_70110-269-298 | EA | None | REPL HEPA EXHAUST FILTER 3 |
T_70110-269-299 | EA | None | REPL HEPA EXHAUST FILTER 4 |
T_70110-269-300 | EA | None | REPL HEPA EXHAUST FILTER 5 |
T_70110-269-301 | EA | None | REPL HEPA EXHAUST FILTER 6 |
T_70110-269-302 | EA | None | SEISMIC SUPPORT BRACKETS |
T_70110-269-303 | EA | None | ACCESSORY SHELF-2 BASE STANDA |
T_70110-269-304 | EA | None | ACCESSORY SHELF-3 BASE STANDA |
T_70110-269-305 | EA | None | ACCESSORY SHELF-4 BASE STANDA |
T_70110-269-306 | EA | None | ACCESSORY SHELF-5 BASE STANDA |
T_701AA45791KS | EA | MAG OXID RECTNGLR TRA 25.4 1EA | |
T_701AA4579203 | EA | BIS(TRICYCLHXYLPHOSINE)PALL 1G | |
T_701AA45792MD | EA | BIS(TRICYCLHXYLPHOSINE)P 250MG | |
T_701AA45793N6 | EA | CPPR TUBNG 6.35MMOD 4.72M 10FT | |
T_701AA4579406 | EA | MOLY NANOPWR 60-80NM 99% 5G | |
T_701AA4579414 | EA | MOLY NANOPWR 60-80NM 99% 25G | |
T_701AA4579503 | EA | SILCA GEL HPLC/UHPLC 99.99+ 1G | |
T_701AA4579506 | EA | SILCA GEL HPLC/UHPLC 99.99+ 5G | |
T_701AA4579603 | EA | SILCA GEL HPLC/UHPLC 99.99+ 1G | |
T_701AA4581403 | EA | BIS(TRI-O-TOLYLPHOSINE)PALL 1G | |
T_701AA45814MD | EA | BIS(TRI-O-TOLYLPHOSINE)P 250MG | |
T_701AA4581606 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4581614 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4581906 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4581914 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4582406 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4582506 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4582514 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4582522 | EA | SILCA GEL PREPARAT 99.99+ 100G | |
T_701AA45827KS | EA | MAG OXID RECTNGLR TRA 12.7 1EA | |
T_701AA4583006 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4583014 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4583022 | EA | SILCA GEL PREPARAT 99.99+ 100G | |
T_701AA4583106 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4583114 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4583122 | EA | SILCA GEL PREPARAT 99.99+ 100G | |
T_701AA4583206 | EA | SILCA GEL PREPARATIV 99.99+ 5G | |
T_701AA4583214 | EA | SILCA GEL PREPARATI 99.99+ 25G | |
T_701AA4583222 | EA | SILCA GEL PREPARAT 99.99+ 100G | |
T_701AA45834KS | EA | ZINC SELIDE OPTCL WINDOW 2 1EA | |
T_701AA4583614 | EA | SILCA GEL PREPARATIV 99.9+ 25G | |
T_701AA4583622 | EA | SILCA GEL PREPARATI 99.9+ 100G | |
T_701AA45839QA | EA | SLVR FIXING BATH TST STPS 1KT | |
T_701AA4584122 | EA | GALL METL PKGD IN PO 99.9 100G | |
T_701AA4584136 | EA | GALL METL PKGD IN PO 99.9 500G | |
T_701AA45850KS | EA | BORN NRIDE RD;DIA MM 6 300 1EA | |
T_701AA4585303 | EA | BIS(DI-TERT-BUTL-PHENLPHOSI 1G | |
T_701AA45853MD | EA | BIS(DI-TERT-BUTL-PHENLPH 250MG | |
T_701AA45854KS | EA | MAG OXID CRUCBL CYLNDRL 32 1EA | |
T_701AA45865KS | EA | MAG OXID RECTNGLR TRA 25.4 1EA | |
T_701AA45885KS | EA | ZINC SELIDE OPTCL WINDOW 2 1EA | |
T_701AA45900KS | EA | MAG OXID CRUCBL CYLNDRL 76 1EA | |
T_701AA45912KS | EA | BORN NRIDE RD;DIA MM 1 300 1EA | |
T_701AA4591303 | EA | BIS 12345-PENTPHENL-1F-(DI- 1G | |
T_701AA45913MD | EA | BIS 12345-PENTPHENL-1F-( 250MG | |
T_701AA45954KS | EA | MAG OXID RECTNGLR TRA 25.4 1EA | |
T_701AA45955KS | EA | ZINC SELIDE OPTCL WINDOW 5 1EA | |
T_701AA4600003 | EA | BIS DI-TERT-BUTL-(4-DIMETHL 1G | |
T_701AA46000MD | EA | BIS DI-TERT-BUTL-(4-DIME 250MG | |
T_701AA46107KS | EA | GALL ARSIDE OPTCL WINDOW 2 1EA | |
T_701AA4611422 | EA | MAG THIOSFAT HXHYD 99% 100G | |
T_701AA4611436 | EA | MAG THIOSFAT HXHYD 99% 500G | |
T_701AA4612022 | EA | MAG BRMIDE HXHYDRATE 98+% 100G | |
T_701AA4612036 | EA | MAG BRMIDE HXHYDRATE 98+% 500G | |
T_701AA46120A3 | EA | MAG BROMIDE HXHYDRATE 98+% 2KG | |
T_701AA4811222 | EA | POT MOLYBDENUM OXIDE 95% 100G | |
T_701AA4811236 | EA | POT MOLYBDENUM OXIDE 95% 500G | |
T_701AA4811722 | EA | MOLYBDENUM(IV) OXIDE 99% 100G | |
T_701AA4911309 | EA | SILCN IV NRIDE ELEC GR 99. 10G | |
T_701AA4911318 | EA | SILCN IV NRIDE ELEC GR 99. 50G | |
T_701AA5110809 | EA | NIOBIUM(V) CHLORIDE 99% 10G | |
T_701AA5110822 | EA | NIOBIUM(V) CHLORIDE 99% 100G | |
T_701AA5110836 | EA | NIOBIUM(V) CHLORIDE 99% 500G | |
T_70117-987-114B | EA | None | APRON CT VINYL 6ML SNAP TIES M |
T_70117-987-114C | EA | None | APRON CT VINYL 6ML SNAP TIES L |
T_70117-987-114D | EA | None | APRON CT VINYL 6ML SNAP TIE XL |
T_70117-987-116A | EA | None | APRON CT VINYL 8ML SNAP TIES S |
T_70117987116B | EA | None | APRON CT VINYL 8ML SNAP TIES M |
T_70117987116C | EA | None | APRON CT VINYL 8ML SNAP TIES L |
T_70117987116D | EA | None | APRON CT VINYL 8ML SNAP TIE XL |
T_70117-987-119A | PK | None | APRON VNL 6ML BL 35X40 12/PK |
T_70117-987-119D | CS | None | APRN VNL 6M DC 35X48 BL 72/CS |
T_70117-987-11B | EA | 安全罐 | CAN TRN PLT SAFETY 1QT RED T1 |
T_70117-987-11C | EA | None | WASH TANK TRN PLT 8 GAL RED |
T_70117-987-122D | PK | None | APRON VNL 8M SWN 35X45 B 12/PK |
T_70117-987-128C | PK | None | APRON VNYL 6ML 35X45 BL 12/PK |
T_70117-987-128E | PK | None | APRON VNYL 6ML 35X50 BL 12/PK |
T_70117-987-128F | PK | None | APRON VNYL 6ML 35X55 BL 12/PK |
T_70117987130B | PK | None | APRON VNL 6M 35X45 SWN B 12/PK |
T_70117-987-130C | PK | None | APRON VNL 6M 35X48 SWN B 12/PK |
T_70117-987-133B | EA | None | APRON DENIM 28X36 W/BIB POCKET |
T_70117-987-133C | CS | None | APRON DENIM 28X36 2 POCKETS |
T_70117-987-140A | EA | None | PROT SHIELD 16X12 IN 3/8 THICK |
T_70117-987-140B | EA | None | PROT SHIELD 12X12 IN 3/8 THICK |
T_70117-987-140C | EA | None | PROT SHIELD 16X12 IN 1/4 THICK |
T_70117-987-140D | EA | None | PROT SHIELD 12X12 IN 1/4 THICK |
T_70117-987-140E | EA | None | WIPE HOLDER WHITE |
T_70117987140F | EA | 护目镜储放架 | SAFETY GLASS DISPENSER |
T_70117987140G | EA | 护目镜储放架 | 20UNIT SAFETY GLASS HOLDER |
T_70117987140H | EA | None | 12UNIT GOGGLE HOLDER DOOR |
T_70117-987-140I | EA | None | 2 COMP ALL PURPOSE DISPENSER |
T_70117-987-140J | EA | None | FINGER COT DISPENSER LARGE |
T_70117987140K | EA | None | BOOTIE BOUFFANT DISPENSER |
T_70117-987-140L | EA | None | CONTAINER BIN |
T_70117-987-140M | EA | None | FACE MASK DISPENSER |
T_70117-987-140N | EA | None | FACE VEIL DISPENSER |
T_70117-987-140P | EA | None | GLOVE LINER DISPENSER |
T_70117-987-140R | EA | None | ACCESSORY BIN CLEAR |
T_70117-987-140X | EA | None | FNGR COT CLEAR DISPENSER SMALL |
T_70117-987-140Y | EA | None | LITERATURE HOLDER |
T_70117-987-140Z | EA | None | DOCUMENT HOLDER |
T_70117-987-141 | EA | None | HAND SPEC GLOVE DISP CLEAR |
T_70117987144A | EA | 化学泄漏急救箱 | KIT SPILL CHEM MULTI-AGENT |
T_70117-987-144C | EA | None | KIT SPILL CHEM CAUSTIC AGENT |
T_70117-987-144D | EA | 化学品紧急处理盒 | KIT SPILL CHEM SOLVENT AGENT |
T_70117-987-144E | EA | None | KIT SPILL FORMAL DEHY DE SOLV |
T_70117-987-144F | EA | None | ACCESSORIES REFILL SPILL KIT |
T_70117-987-155A | EA | None | GAS CYL BRACKET WALL MOUNT |
T_70117-987-155B | EA | None | GAS CYL BRACKET DBL WALL MOUNT |
T_70117-987-155C | EA | None | GAS CYL BRACKET TRPLE W/MOUNT |
T_701ES5400 | PK | None | WBC DILUTING FLUID 100ML 2PK |
T_701ES5401 | EA | None | WBC DILUTING FLUID 100ML |
T_701ES5500 | PK | None | HEINZ BODY STAIN 100ML 2PK |
T_701ES5501 | EA | None | HEINZ BODY STAIN 100ML |
T_701ES5600 | PK | None | RBC DLTNG FLD HYEMS 100ML 2/PK |
T_701ES5602 | PK | None | RBC DLTNG FLD GOWRS 100ML 2/PK |
T_701ES5996 | PK | None | METHANOL FXATVE 250ML 4PK |
T_701ES5997 | PK | None | METHANOL FXATVE 950ML 2PK |
T_701ES5998 | EA | None | METHANOL FXATVE 3.8L |
T_701ES5999 | CS | None | METHANOL FIXATIVE 3.8L 4CS |
T_701ES6050 | EA | None | GRAM KT 95% DECOLORIZER 250ML |
T_701ES6070 | EA | None | GRAM KT 70%BASIC FUCHSIN 250ML |
T_701ES6080 | EA | None | GRAM KT95%/BASIC FUCHSIN 250ML |
T_701ES6095 | EA | None | GRAM KT 70%CARBOL FUCHSN 250ML |
T_701ES6096 | EA | None | GRAM KT 95% CARBL FUCHSN 250ML |
T_701ES6097 | EA | None | GRAM KT ACETCARBL FUCHSN 250ML |
T_701ES6100 | PK | None | CRYSTAL VIOLET 250ML 4PK |
T_701ES6101 | EA | None | CRYSTAL VIOLET 250ML |
T_701ES6120 | PK | None | CRYSTAL VIOLET 950ML 2PK |
T_701ES6150 | EA | None | CRYSTAL VIOLET 3.8L |
T_701ES6151 | EA | None | CRYSTAL VIOLET SLIMLN 3.8L |
T_701ES6200 | PK | None | GRAMS IODINE 250ML 4PK |
T_701ES6220 | PK | None | GRAMS IODINE 950ML 2PK |
T_701ES6250 | EA | None | GRAMS IODINE 3.8L |
T_701ES6251 | EA | None | GRAMS IODINE SLIMLN 3.8L |
T_701ES6260 | PK | None | ACETONE ALCOHOL 250ML 2PK |
T_701ES6280 | EA | None | ACETONE ALCOHOL 3.8L |
T_701ES6300 | PK | None | 70% ALCOHOL 250ML 4PK |
T_701ES6320 | PK | None | 70% ALCOHOL 950ML 2PK |
T_701ES6350 | EA | None | 70% ALCOHOL 3.8L |
T_701ES6351 | EA | None | 70% ALCOHOL SLIMLN 3.8L |
T_701ES6360 | PK | None | 95% ALCOHOL 250ML 4PK |
T_701ES6381 | EA | None | 95% ALCOHOL SLIMLN 3.8L |
T_701ES6420 | PK | None | SAFRANIN 950ML 2PK |
T_701ES6451 | EA | None | SAFRANIN SLIMLN 3.8L |
T_701ES6455 | PK | None | BASIC FUCHSIN 250ML 4PK |
T_701ES6456 | PK | None | BASIC FUCHSIN 950ML 2PK |
T_701ES6457 | EA | None | BASIC FUCHSIN 3.8L |
T_701ES6458 | EA | None | BASIC FUCHSIN SLIMLN 3.8L |
T_701ES6460 | PK | None | CARBOL FUCHSIN 250ML 4PK |
T_701ES6461 | PK | None | CARBOL FUCHSIN 950ML 2PK |
T_701ES6462 | EA | None | CARBOL FUCHSIN 3.8L |
T_701ES6463 | EA | None | CARBOL FUCHSIN SLIMLN 3.8L |
T_701ES6465 | EA | None | CYCLOSPORA STAIN KIT |
T_701ES6466 | PK | None | CARBOL FUCHSIN 2PK |
T_701ES6467 | PK | None | ACID ALCOHOL(10%SULFURIC) 2PK |
T_701ES6468 | PK | None | MALACHITE GREEN 2PK |
T_701ES6470 | EA | None | CRYPTOSPRIDIUM STAIN KIT 250ML |
T_701ES6471 | PK | None | CARBOL FUCHSIN 250ML 2PK |
T_701ES6472 | PK | None | ACID ALCHL10%SULFURC 250ML 2PK |
T_701ES6473 | PK | None | CONC. LIGHT GREEN 250ML 2PK |
T_701ES6475 | PK | None | WAYSON STAIN 2PK |
T_701ES6476 | EA | None | WAYSON STAIN |
T_701ES6480 | PK | None | SPUTUM DIGESTANT 250ML 2PK |
T_701ES6490 | PK | None | SPUTUM DIGESTANT 950ML 2PK |
T_701ES6491 | EA | None | SPUTUM DIGESTANT 3.8L |
T_701AA5111009 | EA | POT HEPTFLRONIOBATE V 99.5 10G | |
T_701AA5111018 | EA | POT HEPTFLRONIOBATE V 99.5 50G | |
T_701B81320041 | EA | THRML TRNSFR TAPE SLIDEMATE EA | |
T_7012138127E | CS | None | RESERVOR RGT 25ML DVD BLK100CS |
T_70121-381-27F | CS | None | RESERVOIR RGNT 25ML DVD 50/CS |
T_7012138127G | CS | None | REAG RESERVOIRS 50ML 100/CS |
T_7012138127H | CS | None | REAG RES IND WRP 50ML 50/CS |
T_70113-626-113 | EA | OILTEST CENTRIFUGE, 115V | |
T_70113-626-122 | EA | ALL-LEVELS SAMPLER | |
T_70113-626-124 | EA | OXIDATION BATH, 2 PLACE | |
T_70113-626-126 | EA | OXIDATION BATH, 4 PLACE | |
T_70113-626-128 | EA | OXIDATION BATH, 2 PLACE | |
T_70113-626-133 | EA | EXISTENT GUM EVAPORATION BATH | |
T_70113-626-134 | EA | EXISTENT GUM EVAPORATION BATH | |
T_70113-626-135 | EA | LPG CORROSION TEST BATH | |
T_70113-626-139 | EA | COPPER STRIP CORROSION BATH | |
T_70113-626-141 | EA | COPPER STRIP TEST TUBE BATH | |
T_70113-626-148 | EA | RVP DATA ACQUISITION SOFTWARE | |
T_70113-626-150 | EA | REID VAPOR PRESSURE BATH | |
T_70113-626-152 | EA | REID VAPOR PRESSURE BATH | |
T_70113-626-155 | EA | WICKBOLD APPARATUS, 115V | |
T_70113-640-513 | CS | PH PAPER STRIPS 10.0-12.0 | |
T_70113-640-514 | CS | PH PAPER STRIPS 12.5-14.0 | |
T_70113-640-515 | CS | PH PAPER STRIPS, 0 - 14 SET | |
T_70113-640-516 | EA | PH PLASTIC STRIP 0.0-14.0 6/PK | |
T_70113-640-517 | EA | PH PLASTIC STRIP 5.5-8.0 6/PK | |
T_70113-640-518 | EA | PH PLASTIC STRIP 6.5-13.0 6/PK | |
T_70113-640-519 | EA | PH PLASTIC STRIPS 5.0-9.0 6/PK | |
T_70113-640-520 | EA | PH PLASTIC STRIPS 0.0-6.0 6/PK | |
T_70113-642-218 | EA | IRON TPTZ POWDER PACK 100 TEST | |
T_70113-642-400 | EA | ORION AQ3700 COLORIMETER | |
T_70113-642-602 | EA | REPLACEMNT PRINTER CARTRIDGE | |
T_70113-644-500 | EA | AQUAFAST VIAL CLEAN BRUSH, 5PK | |
T_70113-644-502 | EA | AQUAFAST SILICON OIL & CLOTH | |
T_70113-644-503 | EA | AQUAFAST 25MM VIALS, 3 PACK | |
T_70113-644-504 | EA | AQUAFAST AQ3010 TURBIDITYMETER | |
T_70113-644-506 | EA | AQUAFAST COD165 THERMOREACTOR | |
T_70113-645-085 | CS | FITTED SUPPORT BASE 1CS | |
T_70113-645-086 | CS | 1L FLASK 40/35 1CS | |
T_70113-645-087 | CS | 4L FLASK 40/35 1CS | |
T_70113-645-088 | CS | 300ML FUNNEL GLASS BASE 1CS | |
T_70113-645-089 | CS | 300ML GRADUATED FUNNEL 1CS | |
T_70113-645-090 | CS | 1L GRADUATED FUNNEL 1CS | |
T_70113-645-091 | CS | FRITTED SUPPORT BASE 1CS | |
T_70113-645-092 | CS | ALUMINUM CAMP 47MM 1CS | |
T_70113-645-093 | CS | 300ML FUNNEL GLASSBASE 4L 1CS | |
T_70113-645-094 | CS | 1L FUNNEL GLASSBASE 4L 1CS | |
T_70113-645-095 | CS | SINGLE CAVITY RESERV 1L 1CS | |
T_70113-645-096 | CS | SINGLE CAVITY RESERV 2L 1CS | |
T_70113-645-097 | CS | SINGLE CAVITY RESERV 5L 1CS | |
T_70113-645-098 | CS | SINGLE CAVITY RESERV 10L 1CS | |
T_70113-645-099 | CS | 3 HOLE CAP 1CS | |
T_70113-645-501 | EA | STAR A111 PH BTSTAR A111 PH | |
T_70113-645-503 | EA | STAR A111 PH BT KITSTAR A111 | |
T_70113-645-504 | EA | STAR A121 PH HH | |
T_70113-645-506 | EA | STAR A121 PH HH KIT | |
T_70113-645-507 | EA | STAR A112 COND BT | |
T_70113-645-509 | EA | STAR A112 COND BT KSTAR A112 | |
T_70113-645-510 | EA | STAR A122 COND HH | |
T_70113-645-512 | EA | STAR A122 COND HH KIT | |
T_70113-645-515 | EA | STAR A113 DO BT KIT | |
T_70113-645-516 | EA | STAR A123 DO HH | |
T_70113-645-518 | EA | STAR A123 DO HH KIT | |
T_70113-645-519 | EA | STAR A211 PH BT METER ONLY | |
T_70113-645-521 | EA | STAR A211 PH BT KIT | |
T_70113-645-522 | EA | STAR A221 PH HH METER ONLY | |
T_70119-059768 | DZN | None | MNS M WT LISL GLV HEMMD 12PR |
T_70119-059-800 | CS | None | COV POLY ZIP ELA W/A 2X 25/CS |
T_70119-059-801 | CS | None | COV POLY ZIP ELA W/A 3X 25/CS |
T_70119-059-844 | EA | None | HICON BOMBER JCKT LIME SM |
T_70119-059-845 | EA | None | HICON BOMBER JCKT LIME MD |
T_70119-059-846 | EA | None | HICON BOMBER JCKT LIME LG |
T_70119-059-847 | EA | None | HICON BOMBER JCKT LIME XL |
T_70119-059-848 | CS | None | LABCT POLYPRO NO PCT SM 30/CS |
T_70119-059-849 | CS | None | LABCT POLYPRO NO PCT MD 30/CS |
T_70119-059-851 | CS | None | LABCT POLYPRO NO PCT XL 30/CS |
T_70119-059-852 | CS | None | LABCT POLYPRO NO PCT 2X 30/CS |
T_70119-059-853 | CS | None | LABCT POLYPRO NO PCT 3X 30/CS |
T_70119-059-854 | CS | None | LABCT POLYPRO NO PCT 4X 30/CS |
T_70119-059-855 | CS | None | LABCT POLYPRO NO PCT 5X 30/CS |
T_70119-059-857 | CS | None | PYROLONPLS CVRALL BLU 25CS |
T_70119-059-915 | EA | None | MAIN FILTER FOR GM-80 |
T_70119-059-918 | EA | None | LN SAMPLING 5FT |
T_70119059925 | PR | 防水手套 | GLV CRYO MID ARM 14'XL 1PR |
T_70119-059937 | CS | None | GLV LTX PFTXCL10 12IN7.5 200CS |
T_70119-059939 | PK | None | GLV LTX PFTX CL10 12IN 8 50PK |
T_70119-059942 | DZN | 合成混合纱线针织手套 | GLOVE MED WGT KNT MNS 12PR |
T_70119-059943 | DZN | 合成混合纱线针织手套 | GLV LDS HVY PLY ACR KW 12PR |
T_70119060 | EA | None | FORCEPS KUEHNECVRGLASS ANGLED |
T_70119-060032 | DZN | None | BRN JERSEY MINI DT WM 12PR |
T_70103-171-213 | EA | None | 100X3MM 1.9UM HYPERSIL PFP |
T_70103-171-225 | EA | None | 125X4MM 5U GOLD C8 |
T_70103-171-241 | EA | None | 20X2.1MM 12U GOLD |
T_70103-171-242 | EA | None | 12UM 20X2.1MMHYPERSIL GD AQ |
T_70103-171-243 | EA | None | 12UM 20X2.1MMHYPERSIL GD PFP |
T_70103-171-246 | EA | None | 20X2.1MM 5U GOLD C8 HTS |
T_70103-171-253 | EA | None | 250X21MM 5UM HYPERSIL AQ |
T_70103-171-254 | EA | None | 250X30MM 12UM HYPERSIL GOLD |
T_70103-171-255 | EA | None | 250X3MM HYPERSIL 3UM |
T_70103-171-256 | EA | None | 250X4.6 HYPERSIL 3UM250X4.6 |
T_70103-171-266 | EA | None | 50X21MM 5UM HYPERSIL AQ |
T_70103-171-267 | EA | None | 50X21MM 5UM HYPERSIL PFP |
T_70103-171-269 | EA | None | 50X3MM 3UM HYPERSIL |
T_70103-171-297 | EA | None | 150X2MM 5U ASAHIPAK NH2P |
T_70103-171-299 | PK | None | 10X2.1MM 5UM HYPERSIL GD 4PK |
T_70103-213 | EA | 双层聚丙烯试管架 | SERUM VIAL SUPPORT |
T_701032131 | EA | Fisherbrand 微量管聚丙烯支架 | MICRO VL SUPPORT .55ML TUBE SZ |
T_701032132 | EA | Fisherbrand 微量管聚丙烯支架 | RACK PP MICRO SAMPLE TEST TUBE |
T_70103-215-5 | PK | 瓶塞 | BOTTLE STOPPER W/CAP 100/PK |
T_70103-225-5 | PK | 红色橡胶塞 | RED RUBBER STOPPER 100/PK |
T_70103-229A | CS | None | SG BOT THERMO ONLY 10+25 1/CS |
T_70103-230A | CS | None | BOTTLE SPECIFIC GRVTY 10ML 1CS |
T_70103-230B | CS | None | BOTTLE SPECIFIC GRVTY 25ML 1CS |
T_70103-230C | CS | None | BOTTLE SPECFIC GRVTY 50ML 1/CS |
T_70103247Q | EA | 铝制比重瓶 1EA | SPECIFIC GRAVITY PYCNOMETER |
T_70103-250-400 | PK | 色谱柱 | HYPERCARB SEP 50MG 1ML 50/PK |
T_70103-250-401 | PK | 色谱柱 | HYPERCARB SEP 100MG 1ML 30/PK |
T_70103-250-402 | PK | 色谱柱 | HYPERCARB SEP 200MG 3ML 30/PK |
T_70103-250-403 | PK | 色谱柱 | HYPERCARB SEP 500MG 6ML 20/PK |
T_70103-250-404 | PK | 色谱柱 | HYPERCARB SEP 1G 6ML 10/PK |
T_701ICN204715 | EA | None | 2-(O-HYDROXYPHENYL)BENZO 5G |
T_701ICN204728 | EA | None | GERMANIUM DISULFIDE 1G |
T_701ICN204757 | EA | None | 2,6-DIMETHYLPYRIDINE 10G |
T_701ICN204822 | EA | None | 2,4,6-TRINITRO-1-TERT-BU 100G |
T_701S103 | EA | None | ORGANIC STANDARD |
T_701S1030 | EA | None | ORGANIC STANDARD |
T_701S-1041 | EA | None | CYPERMETHRIN 5ML |
T_701S1042 | EA | None | ORGANIC STANDARD |
T_701S-1045 | EA | None | 2,4-D(2,4-DICHLOROPHNXYCT1.2ML |
T_701S1047 | EA | None | ORGANIC STANDARD |
T_701S-105 | EA | None | ACENAPHTHENE 1.2ML |
T_701S-1050 | EA | None | 2,4-D METHYL ESTER 1.2ML |
T_701S-1055 | EA | None | DALAPON 1.2ML |
T_701S-1065 | EA | None | METHYL DACTHAL 1.2ML |
T_701S-1067 | EA | None | TETRACHLOROTEREPHTHALATE 1.2ML |
T_701S-1068 | EA | None | MONOMETHYLTEREPHTHALATE 1.2ML |
T_701S-1070 | EA | None | O,P'-DDD 1.2ML |
T_701S-1075 | EA | None | P,P'-DDD 1.2ML |
T_701S-1085 | EA | None | P,P'-DDE 1.2ML |
T_701S-1090 | EA | None | O,P'-DDT 1.2ML |
T_701S-1095 | EA | None | P,P'-DDT 1.2ML |
T_701S110 | EA | None | ORGANIC STANDARD |
T_701S-1100 | EA | None | DECACHLOROBIPHENYL 1.2ML |
T_701S-1103 | EA | None | DECAFLUOROBIPHENYL 1.2ML |
T_701ICN90308505 | EA | None | YEAST, TORULA 5LB |
T_701ICN90308525 | EA | None | YEAST, TORULA 25LB |
T_701ICN90308580 | EA | None | YEAST, TORULA 100LB |
T_701ICN90324401 | EA | None | VANDERZANT MODIFICATION 1KGVA |
T_701ICN90324405 | EA | None | VANDERZANT MODIFICATION 5KGVA |
T_701ICN90328805 | EA | None | WHEAT GERM 5LB |
T_701ICN90328825 | EA | None | WHEAT GERM 25LB |
T_701ICN90328880 | EA | None | WHEAT GERM 100LB |
T_701ICN90331205 | EA | None | BREWERS YEAST 5LB |
T_701ICN90331225 | EA | None | BREWERS YEAST 25LB |
T_701ICN90331280 | EA | None | BREWERS YEAST 100LB |
T_701ICN90452001 | EA | None | CASEIN 1LB |
T_701ICN90452005 | EA | None | CASEIN 5LB |
T_701ICN90460610 | EA | None | MOUSE DIET, PURIFIED 10KG |
T_701ICN90460620 | EA | None | MOUSE DIET, PURIFIED 20KG |
T_701ICN90460650 | EA | None | MOUSE DIET, PURIFIED 50KG |
T_701ICN90465401 | EA | None | VITAMIN DIET FORTIFICATI 1KG |
T_70119-150-1171 | PK | None | WIPER NONWOVEN 9X9 3600/CS |
T_70119-150-1174 | PK | None | WIPER POLYESTER 9X9 150SHT/PK |
T_70119-150-1175 | CS | None | WIPER POLYESTER 9X9 1200/CS |
T_70119-150-1176 | PK | None | WIPER POLYESTER 12X12 75/PK |
T_70119-150-118 | EA | None | R6202PC RIBBON |
T_70119-150-119 | EA | None | R6206PC RIBBON |
T_70119-150-1191 | CS | None | BOUFFANT 1000/CS |
T_70119-150-1194 | CS | None | BEARDCOVER 1000/CS |
T_70119-150-1195 | CS | None | STICKY MAT 120/CS |
T_70119-150-1197 | CS | None | STICKY MAT 120/CS 36X45STICKY |
T_70119-150-1199 | EA | None | IQ EXPRESS DK STAT ENH VER |
T_70119-150-120 | EA | None | R6207PC RIBBON |
T_701ICN90468405 | EA | None | PEANUT OIL 05GL |
T_70113-645-524 | EA | STAR A221 PH HH KIT | |
T_70113-645-525 | EA | STAR A212 COND BT METER ONLY | |
T_70113645527 | EA | STAR A212 COND BT KIT | |
T_70113-645-528 | EA | STAR A212 COND ULTRAPUR BT KIT | |
T_70113-645-529 | EA | STAR A222 COND HH METER ONLY | |
T_70113-645-531 | EA | STAR A222 COND HH KIT | |
T_70113-645-532 | EA | STAR A213 RDO/DO BT METER ONLY | |
T_70113-645-534 | EA | STAR A213 RDO/DO BT KIT | |
T_70113-645-535 | EA | STAR A213 RDO/DO BOD BT KIT | |
T_70113-645-536 | EA | STAR A223 RDO/DO HH METER ONLY | |
T_70114-176-332H | CS | Nalgene 50铂金固化硅管 | TBG SILICON 5/16X1/2 50' 1/CS |
T_70114-176-332J | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/8X1/2 50' 1/CS |
T_70114-176-332K | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/8X9/16 50' 1/CS |
T_70114-176-332L | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/8X5/8 50 1/CS |
T_70114-176-332M | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/2X11/16 50' 1/CS |
T_70114-176-332N | CS | Nalgene 50铂金固化硅管 | TBG SILICON 1/2X3/4 50' 1/CS |
T_70114-176-332P | CS | Nalgene 50铂金固化硅管 | TBG SILICON 5/8X7/8 50' 1/CS |
T_70114-176-332Q | CS | Nalgene 50铂金固化硅管 | TBG SILICON 3/4X1IN 50' 1CS |
T_7011417634 | CS | Nalgene 180透明PVC管 | TUBING PLAST 5/16X1/8 50FT/CS |
T_70114-176-36 | CS | Nalgene 180透明PVC管 | TUBING PLAST 3/8X1/16 50FT/CS |
T_7011417638 | CS | Nalgene 180透明PVC管 | TUBING PLAST 3/8X3/32 50FT/CS |
T_7011417642 | CS | Nalgene 180PVC真空管 | TUBING PLAST 3/8X1/4 50FT/CS |
T_7011417646 | CS | Nalgene 180透明PVC管 | TUBING PLAS 7/16X3/32 50FT/CS |
T_70114-176-48 | CS | None | TUBING PLAST 1/2X1/16 50FT/CS |
T_70114-176-50 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/2X3/32 50FT/CS |
T_70114-176-52 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1/2X1/8 50FT/CS |
T_70114-176-54 | CS | Nalgene 180PVC真空管 | TUBING PLAST 1/2X5/16 50FT/CS |
T_70114-176-58 | CS | Nalgene 180透明PVC管 | TUBING PLAST 5/8X1/8 50FT/CS |
T_70114-176-64 | CS | Nalgene 180透明PVC管 | TUBING PLAST 3/4X1/8 50FT/CS |
T_701141766B | CS | Nalgene 180PVC真空管 | TUB VAC 1/4X5/8X3/16 10FT/CS |
T_701141766C | CS | Nalgene 180PVC真空管 | TUBING VAC 3/8X7/8X1/4 10FT/CS |
T_701141766D | CS | Nalgene 180PVC真空管 | TUB VAC 1/2X1-1/8X5/16 10FT/CS |
T_70114-176-72 | CS | Nalgene 180透明PVC管 | TUBING PLAST 1X1/8 50FT/CS |
T_70114-176-88 | CS | Nalgene 180透明PVC管 | TUBING PLAS 1/8X1/16 250FT/CS |
T_70114-176-90 | CS | Nalgene 180透明PVC管 | TUBING PLA 3/16X1/16 250FT/CS |
T_7011417694 | CS | Nalgene 180透明PVC管 | TUBING PLA 5/16X1/16 250FT/CS |
T_70114-176-98 | CS | Nalgene 180透明PVC管 | TUBING PLAS 1/2X1/16 250FT/CS |
T_70114-177-100 | PK | None | PHARMA TUBING 1/8 X 1/4 50FTP |
T_70114-177-101 | PK | None | PHARMA TUBING 1/4 X 3/8 50FTP |
T_70114-177-102 | PK | None | PHARMA TUBING 3/16X5/16 50FT |
T_70114-177-103 | PK | None | PHARMA TUBING 3/16X 3/8 50FT |
T_70114-177-104 | PK | None | PHARMA TUBING 1/4 X 7/16 50FT |
T_70114-177-105 | PK | None | PHARMA TUBING 1/4 X 1/2 50FT |
T_70114-177-106 | PK | None | PHARMA TUBING 3/8X9X16 50FT |
T_70114-177-107 | PK | None | PHARMA TUBING 3/8 X 5/8 50FT |
T_70114-177-108 | PK | None | PHARMA TUBING 1/2 X 3/4 50FT |
T_70114-177-110 | PK | None | PHARMA TUBING 3/8 X 1/2 50FT |
T_70114-177-111 | PK | None | PHARMA TUBING 1/2 X 11/16 50FT |
T_70114-177-112 | PK | None | PHARMA TUBING 5/8 X 7/8 50FT |
T_70114-177-113 | PK | None | PHARMA TUBING 3/4 X 1 50FT |
T_70114-178-104 | CS | None | TORQUE FITTING 20 MM |
T_70114-178-106 | EA | None | TORQUE FITTING 43 MM |
T_70114-178-107 | CS | None | TRQUE FITTING 38 MM 1/CS |
T_70114-178-108 | EA | None | TRQUE FITTING 53 MM 1/CS |
T_70114-178-109 | EA | None | TORQUE FITTING 48 MM |
T_70114-178-110 | CS | None | TRQUE FITTING 63 MM 1/CS |
T_70114-178-112 | CS | None | TORQUE FITTING 53B |
T_70114-178-113 | EA | None | TRQUE FITTING 83B 1/CS |
T_70114-178-115 | CS | None | TUBING 15X20 MM PCV 25' |
T_70114-178-121 | EA | None | FITTING 53B HDPE |
T_70114-178-122 | CS | None | FITTING 83B HDPE |
T_70114-178-127 | EA | None | FITTING 38 MM HDPE |
T_70114-178-128 | CS | None | FITTING 43 MM HDPE |
T_70114-178-130 | CS | None | FITTING 28 MM HDPE |
T_70114-178-132 | CS | None | TORQUE FITTING 38-430 1/CS |
T_70114-178-2AA | EA | None | LATEX TUBING 1/8X3/32 50FT/RL |
T_70114-178-2BB | EA | None | LATEX TUBING 3/16X3/32 50FT/RL |
T_701141782C | EA | 橡胶管 | LATEX TUBING 1/4X1/16 50FT/RL |
T_70114-178-2D | EA | None | LATEX TUBING 5/16X1/16 50FT/RL |
T_701141785A | EA | None | RUBR TUBING 1/16X1/32IN12FT RL |
T_70110-269-307 | EA | None | ACCESSORY SHELF-6 BASE STANDA |
T_70110-269-308 | EA | None | ACCES SHELF-3 NSF BASE STANDA |
T_70110-269-310 | EA | None | ACCES SHELF-5 NSF BASE STANDA |
T_70110-269-311 | EA | None | ACCES SHELF-6 NSF BASE STANDA |
T_70110-269-46A | EA | None | VAC TRAP BNCH 7 7/8 DIA 3/4 |
T_70110-269-46B | EA | None | VAC TRAP BNCH 7 7/8 DIA 1/2 |
T_70110-269-46C | EA | None | VAC TRAP BNCH 6 5/8 DIA 1/2 |
T_70110-269-50 | EA | None | FLASK FAST FRZ COMPLETE 40ML |
T_70110-269-50A | EA | None | FLASK TOP FAST FRZ 40 80ML |
T_70110-269-50B | EA | None | FLASK BOTTOM FAST FRZ 40ML |
T_70110-269-51 | EA | None | FLASK FAST FRZ COMPLETE 80ML |
T_70110-269-51B | EA | None | FLASK BOTTOM FAST FRZ 80ML |
T_70110-269-52 | EA | None | FLASK FAST FRZ COMPLETE 150ML |
T_70110-269-52A | EA | 烧瓶 | FLASK TOP FAST FRZ 150 300ML |
T_70110-269-52B | EA | 烧瓶 | FLASK BOTTOM FAST FRZ 150ML |
T_70110-269-53 | EA | None | FLASK FAST FRZ COMPLETE 300ML |
T_70110-269-53B | EA | 烧瓶 | FLASK BOTTOM FAST FRZ 300ML |
T_70110-269-54 | EA | None | FLASK FAST FRZ COMPLETE 600ML |
T_70110-269-54A | EA | 烧瓶 | FLASK TOP FRZ 600 1200 2000ML |
T_70110-269-54B | EA | None | FLASK BOTTOM FAST FRZ 600ML |
T_70110-269-55 | EA | None | FLASK FAST FRZ COMPLETE 1200ML |
T_70110-269-55B | EA | None | FLASK BOTTOM FAST FRZ 1200ML |
T_70110-269-56 | EA | None | FLASK FAST FRZ COMPLETE 2000ML |
T_70110-269-56B | EA | None | FLASK BOTTOM FAST FRZ 2000ML |
T_70110-269-57A | EA | None | ADAPTOR STRAIGHT GLASS 1/2-1/2 |
T_70110-269-57B | EA | None | ADAPTOR 45 BND-GLASS 1/2-1/2 |
T_70110-269-58A | EA | None | ADAPTOR STRAIGHT GLASS 3/4-3/4 |
T_70110-269-58B | EA | None | ADAPTOR 45 BND-GLASS 3/4-3/4 |
T_70110-269-59A | EA | None | ADAPTOR STRAIGHT GLASS 1/2-3/4 |
T_70110-269-59B | EA | None | ADAPTOR 45 BND-GLASS 1/2-3/4 |
T_70110-269-60A | EA | None | ADAPTOR STRAIGHT SS 1/2-1/2 |
T_70110-269-60B | EA | None | ADAPTOR 45 BEND SS 1/2-1/2 |
T_70110-269-61A | EA | None | ADAPTOR STRAIGHT SS 3/4-3/4 |
T_70110-269-61B | EA | 接头 | ADAPTOR 45 BEND SS 3/4-3/4 |
T_70110-269-62 | EA | None | FLASK FAST-FREEZE COMPL 120ML |
T_70110-269-62A | EA | None | FLASK BOTTOM FAST FRZ 120ML |
T_70110-269-63 | EA | 烧瓶 | FLASK FAST FREEZE COMPL 900ML |
T_70110-269-63A | EA | 烧瓶 | FLASK BOTTOM FAST FRZ 900ML |
T_70110-269-64 | PK | None | FILTER PAPER-FAST FRZ 1000/PK |
T_70110-269-66G | EA | None | FLASK BOTTOM LYPH-LOK 750ML |
T_70110-269-67A | EA | None | FLASK 25ML COMPLETE 19/38 |
T_70110-269-67C | EA | None | FLASK 100ML COMPLETE 19/38 |
T_70110-269-67D | EA | None | FLASK 250ML COMPLETE 19/38 |
T_70110-269-67F | EA | None | FLASK 1000ML COMPLETE 19/38 |
T_70110-269-67G | EA | None | FLASK 750ML COMPLETE 19/38 |
T_70110-269-68C | EA | None | FLASK 100ML COMPLETE 24/40 |
T_70110-269-68D | EA | None | FLASK 250ML COMPLETE 24/40 |
T_70110-269-68E | EA | None | FLASK 500ML COMPLETE 24/40 |
T_70110-269-68F | EA | None | FLASK 1000ML COMPLETE 24/40 |
T_70110-269-68G | EA | None | FLASK LYPH-LOK COMPLETE 750ML |
T_70110-269-69A | EA | None | ADAPTER 90 GLS 19/38-1/2 PORT |
T_70110-269-69B | EA | None | ADAPTER 90 GLS 19/38-3/4 PORT |
T_70110-269-69C | EA | None | ADAPTER 90 GLS 24/40-1/2 PORT |
T_70110-269-69D | EA | None | ADAPTER 90 GLS 24/40-3/4 PORT |
T_70110-269-70 | EA | None | 500ML LYPH-LOCK FLASK 19/38 |
T_70110-269-80 | PK | None | ADAPTER VALVE 10/PK |
T_70110-269-82 | EA | None | SEALING TORCH OXYGEN/NAT GAS |
T_70110-269-88D | CS | None | CRYOVIAL STERILE 3ML 1000/CS |
T_70110-270-1 | CS | None | PADDLE ASSY FOR 8L FLSK 1/CS |
T_70110-270-11 | CS | None | FTG 1/2IN MEDIA HNDLG 815L 1CS |
T_70110-270-12 | CS | None | FTGCMB 1/8 1/4 MD HND815L 1/CS |
T_70110-270-13 | CS | None | FTG DUAL 1/4INMDIA HND815L 1CS |
T_70110-270-14 | CS | None | FTG DUAL 1/8INMDIA HND815L 1CS |
T_70110-270-15 | CS | None | PDDLE ASSY ONLY 15L FLASK 1/CS |
T_70110-270-16 | CS | None | PDDLE ASSY ONLY 36L FLASK 1/CS |
T_70110-270-18 | CS | None | CMPRSION FTG 1/4C NK 815L 1/CS |
T_70110-270-20 | CS | None | CMPRSION FTG 1/8C NK 815L 1/CS |
T_70110-270-21 | CS | None | SENSOR FTG PH PROBE 1/CS |
T_70110-270-22 | CS | None | FTGCMB 1/8 1/4MDIA HND36L 1/CS |
T_70110-270-23 | CS | None | FTG 1/2IN MEDIA HNDLG 36L 1CS |
T_70110-270-25 | CS | None | SENSOR FTG FOR TEMP PROBE 1/CS |
T_70110-270-26 | CS | None | FTGDUAL 1/4INMDIA HNDLG36L 1CS |
T_70110-270-6 | CS | None | DLVY/VENT FTG 1/8 1/4VENT 1/CS |
T_70110-270-8 | CS | None | SENSOR FTG OXYGEN PROBES 1/CS |
T_70110-270-9 | CS | None | GAS DELY FTG 1/8IN INLET 1CS |
T_70119-813-352 | EA | None | MESH PS VEST ZIPPER REG. US |
T_70119-813-353 | EA | None | MESH PS VEST VELCRO REG. US |
T_70119-813-354 | EA | None | SOLID PS VEST ZIPPER REG US |
T_70119-813-355 | EA | None | SOLID PS VEST VELCRO REG US |
T_70119-813-356 | EA | None | MESH PS VEST ZIPPER OVERSZ US |
T_70119-813-357 | EA | None | MESH PS VEST VELCRO OVERSZ US |
T_70119-813-358 | EA | None | SOLID PS VEST ZIPPER OVERSZ US |
T_70119-813-359 | EA | None | SOLID PS VEST VELCRO OVERSZ US |
T_70119-813-375 | EA | None | WYPALL X50 JUMBO ROLL CS |
T_70119-813-382 | DZN | None | LATEX12 18MIL EMBFLKLIN YELL D |
T_70119-813-434 | CS | None | BOOTIES STRM FLP 4CS |
T_70119-813-437 | CS | None | BOOTIES STRM FLP 4CS |
T_70119-813-452 | CS | None | TYCHM 9400 NON ENCPSLTNG 2/CS |
T_70119-813-470 | CS | None | LABCT 5SNAP NO PKT 4X 30/CS |
T_70119-813-479 | EA | None | PADLOCK BRASS COMBINATION 5/16 |
T_70119-813-480 | EA | None | KEY NO2678 |
T_70119-813-483 | EA | None | MASTER LOCK NO220 |
T_70119-813-484 | EA | None | NO 2 LOCK KEYED DIFFERENT BLUE |
T_70119-813-488 | EA | None | #3 LOCK 3/4 INCH SHANK KEY #32 |
T_70119-813-489 | EA | None | #3 LOCK 3/4 INCH SHANK KEY #32 |
T_70119-813-490 | EA | None | NO3 BLUE LOCK KEYED ALIKE |
T_70119-813-492 | EA | None | PDLCK 3-LH KA REPLACES 3LH3898 |
T_70119-813-496 | EA | None | NO3 LOCK KA W/2 SHACKLE WHIT K |
T_70119-813-497 | EA | None | #3 PDLCK KA 2 SHACKLE YW BMPER |
T_70119-813-498 | EA | None | NO3 LOCK 3/4IN KEYED ALIKE RED |
T_70119-813-500 | EA | None | LOCK 2.0IN SHACKLE STEEL |
T_70119-813-502 | EA | None | #3 W/RD BMPER 2SHACKLE KEY DFF |
T_70119-813-503 | EA | None | MASTER LOCK PADLOCK 2IN BLUE |
T_70119-813-504 | EA | None | MSTR LCK PDLCK 2 W/NDVDUAL KEY |
T_70119-813-505 | EA | None | LCK RD BMPER KEYD DFF MSTR KEY |
T_70119-813-509 | EA | None | 410 YELLOW KA |
T_70119-813-511 | EA | None | 410 LOCK W/3 SHACKLE BLACK KA |
T_70119-813-513 | EA | None | 410 PADLOCK YELLOW KEYED ALIKE |
T_70119-813-514 | EA | None | MASTER KEYED LOCK BLUE 2 KEYS |
T_70119-813-517 | EA | None | PADLOCK 411 KEYED DIFF. RE |
T_70119-813-519 | PK | None | PHOTO ID LABEL F/411 LOCK 6/PK |
T_70119-813-520 | PK | None | PHOTO ID LABEL F/411 LOCK 28PK |
T_70119-813-521 | EA | None | 411 LOCK 3 SHACKLE KEYED ALI B |
T_70119-813-524 | EA | None | LOCKING DEVICE 1-1/2IN HASP |
T_70119-813-527 | EA | None | NO4 LOCK KEYD ALIKE 2IN SHACKL |
T_70119-813-529 | EA | None | NO5 PADLOCK KA TO KEYNO A1463 |
T_70119-813-530 | EA | None | KEYED ALIKE |
T_70119-813-532 | EA | None | 6121 LOCK KEYED-ALIKE |
T_70119-813-534 | EA | None | KEYED DIFFERENT |
T_70119-813-536 | EA | None | NO7 KA W/KEY CODE NO P383 |
T_70119-813-537 | EA | None | CO COMMON LOCK#7 KEYALIKE P812 |
T_70119-813-538 | EA | None | LOCK KEYED DIFF 1 1/2IN SHACKL |
上海辅泽商贸有限公司代理THERMO FISHER 实验室常规设备、检测分析仪器、实验室耗材如下:
实验室常规设备:净化防护、清洁纯化、温度控制、冷冻冷藏、混合破碎、离心浓缩、泵与真空、标签扫描 实验室检测分析仪器:生命科学与生化分析、理化性质分析、小型计量仪、 实验室耗材与安全防护:生物培养、样品采集与保存、离心与过滤、液体处理、色谱耗材、实验室常规耗材、安全防护
实验室常规设备 净化防护:生物安全柜、超净工作台、防护罩台、手套箱 清洁防护:洗瓶机、超声波清洗器、纯水设备 温度控制:培养箱(CO2细胞培养箱、微生物培养箱、低温培养箱、特殊培养箱、通用培养箱)、烘箱、炉具(马弗炉、灰化炉、箱式炉、管式炉)、水浴及水循环、干浴 冷冻冷藏:4℃冰箱、-20℃冰箱、-30℃冰箱、-40℃冰箱、超低温冰箱、深低温冰箱、液氮罐、液氮储存箱、程控降温仪 混合破碎:磁力搅拌器、顶置式搅拌器、振荡器、摇床、研磨机、分散机、超声波破碎仪、匀浆机 离心浓缩:离心机、离心浓缩仪、生物浓缩仪、冷冻干燥系统、快速蒸发系统、旋转蒸发仪 泵与真空设备:蠕动泵、活塞泵、隔膜泵、旋片泵、杂交泵、螺旋泵等 标签扫描:标签书写仪、编码扫描仪、标签生成器 实验室检测分析仪器 生命科学与生化分析:微孔板读数仪、酶标仪、洗板机、微孔板上样辅助仪、微孔板振荡器、热封仪、自动移液工作站、自动分液器、磁珠提取纯化系统、PCR仪、干胶仪、流式细胞仪、细胞离心涂片机 理化性质分析:天平、水分测定仪、电化学(卡尔费休水分仪、电位滴定、水质分析、PH计、电导率计、多叁数测试仪、电极、标准液)、折光仪、分光光度计、浊度仪、胆红素测定仪、热值分析、溶解氧分析、粘度计 小型计量仪:温/湿度计、风速计、转速计、计数器、流量计、压力计、数据采集、声光测定等 实验室耗材与安全防护 生物培养:细胞培养瓶/管、细胞培养皿、细胞培养板、细胞培养小室、细胞培养玻片、细胞培养载体、细胞刮刀/刮铲、多层细胞培养瓶、细胞工厂、果蝇培养、细胞培养皿、涂布与接种、红外接种环灭菌 样品采集与保存:样品采集、样品运输、样品保存、样品冻存(冻存管及配件、冻存管架、梯度降温盒、冻存盒、冰盒、真空绝热瓶、2D冻存系统) 微孔板与PCR耗材:Nunc微孔板、96孔板、384孔板、微孔板配件、PCR耗材 离心与浓缩:离心管、离心瓶、离心管架、过滤器、漏斗、过滤接收瓶、滤膜/滤纸 液体处理:手动移液器、电动移液器、连续分配器、瓶口分配器、分液器、移液吸头、移液管、滴管、滴定管、移液配件/储液槽、胶管、胶管连接 色谱耗材:National样品瓶和样品盖、气相色谱柱、液相色谱柱 实验室常规耗材:试剂瓶/罐、量筒、烧杯、容量瓶、锥形瓶、洗瓶、试管、称量器具、载玻片/盖玻片、磁力搅拌子、搅拌棒、比色皿、电容孔杯、干燥器/干燥柜、封口膜/铝箔、袋子、实验室文具/工具、推车、实验室清洁、坩埚/喂养针/研体 安全防护:生物废物处理、危险品存放、医药急救用品、个人防护、擦拭用品、环境防护
耗材: Axygen、BD、Corning、Schott、NUNC、millipore、merck 分子生物学:电泳、凝胶成像、分光光度计、酶标仪、洗板机、杂交仪、摇床等 细胞生物学:显微镜、CO2培养箱、液氮罐、细胞破碎仪、渗透压计等 药品食品:溶出度仪、硬度仪、崩解时限仪、粉碎机、制粒机、压片机、旋转蒸发仪、熔点仪等 物理化学:浊度计、光泽度计、白度计、色度计、防爆冷柜、氮吹仪、密度计、水分测定仪、定氮仪等 微生物学:微好氧/厌氧工作站、菌落计数仪、蠕动泵、培养基制备分装仪等 通用仪器:超净台、超声波清洗机、PH计、天平、磁力搅拌器、培养箱、水浴箱、灭菌器、离心机、安全柜、切片机、层析柜、制冰机、干式恒温器、混匀小精灵、微孔板的恒温振荡器、烘箱等 Thermo:CO2培养箱、纯水、液氮罐、马弗炉、细胞破碎仪、摇床、搅拌器、金属浴、超 低温冰箱、离心机、安全柜、离心浓缩仪、酶标仪、洗板机、分光光度计移液器等系列产品 Zealway:高校系列、GIT系列、GR系列 SCILOGEX:离心机、混匀仪、磁力搅拌器、摇床、旋转蒸发仪、金属浴、PCR仪、大容量电动移液器 金凤液氮罐:液氮生物容器、大口径液氮容器、自增压式液氮容器、贮奶桶 超微量分光光度计:Thermo NanoDrop™ One/OneC 、德国IMPLEN NP60/80 Touch Hair、-AUCMA:-86℃、-60℃、-50℃、-40℃、-25℃、2-8℃系列冰箱 SANTN:霉菌培养箱、恒温培养箱、光照培养箱、精密鼓风干燥培养箱、恒温恒湿箱、生化培养箱、 试剂:Thermo、Gibco、invitrogen、pierce、life、hyclone、peprotech、biolegend、assay biotech、Simga-aldrich、Qiagen、CST、Abcam、R&D、Vector、santa cruz、Novus、Jackson、MN、corning、Sciencell、ZYMO、eBioscience、NEB、oxoid、wako、amresco、biovison、biotium、takara、roche、promega、bio-rad、selleck、abnova、bd、cayman、merck millpore、yeasen、solarbio、excell bio、KleanAB、Sangon、rhawn、macklin、aladdin、Energy Chemical、biomerieux 耗材: Corning、Axygen、BD、NUNC、nalgene、Schott、、Millipore、Merck、 QSP、nest、pall、 merck millpore、JET、AMMES、Bio-rad、Eppendorf、 brand、Thermo Fisher、百得BIOHIT、BIO-DL |
上海辅泽商贸有限公司,是一家专注于生命科学领域的企业,是中国领先的实验室消耗品供应商。我们提供涉及分子生物学、细胞生物学、生物化学、免疫学、生态学、生物安全食品药品检验及临床检测等诸多领域的仪器和消耗品。
我们专业,所以值得信赖;我们专注,所以我们高速发展;我们信奉“客户第一,员工第二,股东第三”;我们坚持“团结创新,合作共赢”;我们将竭尽所能,为您提供最便捷、最专业的采购服务,节省您的时间和成本。
单位名称: |
上海市虹口区曲阳路910号复城国际1101
联系电话: |
Email: |
