磷酸化APP淀粉样肽前体蛋白抗体价格
磷酸化APP淀粉样肽前体蛋白抗体价格英文名称 Anti-phospho-Amyloid Precursor Protein (Ser730)
中文名称 磷酸化APP淀粉样肽前体蛋白抗体
别 名 Amyloid Precursor Protein (phospho S730); Amyloid Precursor Protein (phospho Ser730); p-Amyloid Precursor Protein (phospho S730); APP (Phospho-Ser730); p-APP(Ser730); C31; C80; C83; C99; beta-amyloid precursor protein C-terminus; A4 amyloid protein; A4; AAA; ABETA; ABPP; AD 1; AD1; Alzheimer disease 1; Alzheimer disease; Alzheimer's disease amyloid protein; Amyloid beta (A4) precursor protein; Amyloid beta A4 protein; Amyloid beta A4 protein precursor isoform b; Amyloid beta A4 protein precursor isoform c; Amyloid beta A4 protein precursor isoform a; Amyloid beta A4 protein precursor isoform b; Amyloid beta A4 protein precursor isoform c; Amyloid beta protein; Amyloid beta-peptide; Amyloid of aging and alzheimer disease; APP; APP I ; APPI; Beta amyloid peptide; Cerebral vascular amyloid peptide; CTFgamma; CVAP; Human mRNA for amyloid A4 precursor of Alzheimer's disease; PN 2; PN II; PN2; PreA4; Protease nexin II; A4_HUMAN.
浓 度 1mg/1ml
规 格 0.1ml/100μg
抗体来源 Rabbit
克隆类型 polyclonal
交叉反应 Human, Mouse, Rat, Chicken, Dog, Pig, Cow, Horse, Rabbit
产品类型 一抗 磷酸化抗体
研究领域 细胞生物 免疫学 神经生物学 信号转导 细胞凋亡 转录调节因子 激酶和磷酸酶 Alzheimer's
蛋白分子量 predicted molecular weight: 3.4-9/83kDa
性 状 Lyophilized or Liquid
免 疫 原 KLH conjugated Synthesised phosphopeptide derived from human APP770 around the phosphorylation site of Ser730
产品应用 WB=1:100-500 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
亚 型 IgG
纯化方法 affinity purified by Protein A
储 存 液 0.01M PBS, pH 7.4 with 10 mg/ml BSA and 0.1% Sodium azide
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件 Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
抗体制备过程:
1.材料与试剂
a.提取的动物 Ig
b.弗氏完全佐剂和弗氏不完全佐剂
c.青霉素和链霉素
d.实验动物 兔
e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
ATM 毛细血管扩张性共济失调症突变蛋白抗体 现货供应
ATP2c1 钙离子ATP酶通道蛋白抗体 现货供应
phosphoATF4/CREB2(Ser245) 化活化转录因子4抗体 现货供应
phosphoATM(Ser1981) 化毛细血管扩张性共济失调症突变蛋白抗体 现货供应
ATF6 活化转录因子6抗体 现货供应
p107/RBL1 视网膜母细胞瘤样蛋白p107抗体 现货供应
phosphop107/RBL1(Ser975) 化视网膜母细胞瘤样蛋白pversion":"10.1.0.7698"}')
纤维素酶 >97%,BR,生化试剂级 Dapagliflozin
纤维结合素样神经肽;分裂FLRF酰 含量≥98.0%,标准品 Licochalcone A
仙茅苷 >98.0% Triclocarban
仙鹤草B(标准品) 供TCL鉴别用 Clofazimine
夏佛塔苷(标准品) 745~875μg/mg,USP Cefuroxime axetil
下钙素 效价测定 Cefuroxime axetil
细叶远志皂苷(标准品) >1500U/mg,USP,BR Penicillin G, potassium salt
细辛脂素(标准品) 效价测定 Penicillin G, potassium salt
细孔柱层析硅胶(300400目,FCP Grade) >98.5% Erdosteine
细孔柱层析硅胶(2060目,FCP Grade) HPLC>98.0%,标准品 Jatrorrhizine hydrochloride
金精三羧Mcilvaine Buffer (Citrate Phosphate Buffer),0.2M,pH6.0 1瓶
金 OMcilvaine Buffer (Citrate Phosphate Buffer),0.2M,pH6.5 1瓶
亲和素Mcilvaine Buffer (Citrate Phosphate Buffer),0.2M,pH7.0 1瓶
8 杂鸟嘌呤Mcilvaine Buffer (Citrate Phosphate Buffer),0.2M,pH7.4 1瓶
杆菌肽Mcilvaine Buffer (Citrate Phosphate Buffer),0.2M,pH8.0 1瓶
水解乳蛋白MDAMB1571瓶
脑心浸液MDAMB2311瓶
Nα 酰精氨酯MDAMB4151瓶
钠MDAMB4351瓶
5 4 3 吲哚基盐 (BCIP)MDAMB435S1瓶
苄眯盐盐MDAMB4361瓶
3 酰MDAMB4531瓶
N 酰 L 酪氨酯MDAMB4681瓶
6 苄基氨基嘌呤MDBK1瓶
N,N 双 (2 羟基 )3 氨基磺MDBK (NBL1)1瓶
磷酸化APP淀粉样肽前体蛋白抗体价格一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
单位名称: |
上海市金山区金山大道2788号
联系电话: |
Email: |
