磷酸化蛋白激酶AKT1抗体价格
产品名称 | 磷酸化蛋白激酶AKT1抗体价格 |
英文名称 | Anti-phospho-AKT1(Tyr474) |
规格 | 0.1ml/100μg |
英文名称 Anti-phospho-AKT1 (Tyr474)
中文名称 磷酸化蛋白激酶AKT1抗体
别 名 AKT1 (phospho Y474); AKT1(phospho-Tyr474); AKT 1; AKT; AKT1; AKT-1; AKT1_HUMAN; C AKT; cAKT; MGC9965; MGC99656; Oncogene AKT1; PKB; PKB alpha; PKB-ALPHA; PRKBA; Protein Kinase B Alpha; Protein kinase B; Proto-oncogene c-Akt; RAC Alpha; RAC alpha serine/threonine protein kinase; RAC; RAC PK Alpha; Rac protein kinase alpha; RAC Serine/Threonine Protein Kinase; RAC-alpha serine/threonine-protein kinase; RAC-PK-alpha; v akt murine thymoma viral oncogene homolog 1; vAKT Murine Thymoma Viral Oncogene Homolog 1.
浓 度 1mg/1ml
规 格 0.1ml/100μg
抗体来源 Rabbit
克隆类型 polyclonal
交叉反应 Human, Mouse, Rat, Chicken, Dog, Pig, Cow, Rabbit, Sheep
产品类型 一抗 磷酸化抗体
研究领域 肿瘤 细胞生物 信号转导 细胞凋亡 转录调节因子
蛋白分子量 predicted molecular weight: 56kDa
性 状 Lyophilized or Liquid
免 疫 原 KLH conjugated synthesised phosphopeptide derived from human AKT1 around the phosphorylation site of Tyr474
产品应用 WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
亚 型 IgG
纯化方法 affinity purified by Protein A
储 存 液 Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件 Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
实验流程:
基本概述:
乙肝表面抗体是人体的保护性的抗体,主要是乙肝病毒表面抗原刺激人体免疫系统而产生的抗体。它的出现,能中和掉人体内的乙肝病毒。具体保护人体的作用。其英文简写为HBsAb。
1、单项抗-HBs阳性
(1)接种乙肝疫苗成功的标志。
(2)抗-HBs阳性单价格低,有时为非特异性反应。
2、与抗-HBc、抗-HBe同时阳性
3、与HBsAg同时阳性
(1)感染了不同的乙肝病毒亚型。
(2)感染了S基因变异的乙肝病毒。
(3)免疫功能低下,抗-HBs不能清除HBsAg。
4、正处于抗原-抗体动态平衡阶段
磷酸化蛋白激酶AKT1抗体价格实验原理 :
(1)特异性结合抗原:抗体本身不能直接溶解或杀伤带有特异抗原的靶细胞,通常需要补体或吞噬细胞等共同发挥效应以清除病原微生物或导致病理损伤。然而,抗体可通过与病毒或毒素的特异性结合,直接发挥中和病毒的作用。
(2)活补体:IgM、IgG1、IgG2和IgG3可通过经典途径激活补体,凝聚的IgA、IgG4和IgE可通过替代途径激活补体。
(3)结合细胞:不同类别的免疫球蛋白,可结合不同种的细胞,参与免疫应答。
(4)可通过胎盘及粘膜:免疫球蛋白G(IgG)能通过胎盘进入胎儿血流中,使胎儿形成自然被动
免疫。免疫球蛋白A(IgA)可通过消化道及呼吸道粘膜,是粘膜局部抗感染免疫的主要因素。
(5)具有抗原性:抗体分子是一种蛋白质,也具有刺机体产生免疫应答的性能。不同的免疫球蛋白分子,各具有不同的抗原性。
(6)抗体对理化因子的抵抗力与一般球蛋白相同:不耐热,60~70℃即被破坏。各种酶及能使蛋白质凝固变性的物质,均能破坏抗体的作用。抗体可被中性盐类沉淀。在生产上常可用硫酸铵或硫酸钠从免疫血清中沉淀出含有抗体的球蛋白,再经透析法将其纯化。
抗体的鉴定:
1)抗体的效价鉴定:不管是用于诊断还是用于治疗,制备抗体的目的都是要求较高效价。不同的抗原制备的抗体,要求的效价不一。鉴定效价的方法很多,包括有试管凝集反应,琼脂扩散试验,酶联免疫吸附试验等。常用的抗原所制备的抗体一般都有约成的鉴定效价的方法,以资比较。如制备抗抗体的效价,一般就采用琼脂扩散试验来鉴定。
2)抗体的特异性鉴定:抗体的特异性是指与相应抗原或近似抗原物质的识别能力。抗体的特异性高,它的识别能力就强。衡量特异性通常以交叉反应率来表示。交叉反应率可用竞争抑制试验测定。以不同浓度抗原和近似抗原分别做竞争抑制曲线,计算各自的结合率,求出各自在IC50时的浓度,并按公式计算交叉反应率。
如果所用抗原浓度IC50浓度为pg/管,而一些近似抗原物质的IC50浓度几乎是无穷大时,表示这一抗血清与其他抗原物质的交叉反应率近似为0,即该血清的特异性较好。
3)抗体亲和力:是指抗体和抗原结合的牢固程度。亲和力的高低是由抗原分子的大小,抗体分子的结合位点与抗原决定簇之间立体构型的合适度决定的。有助于维持抗原抗体复合物稳定的分子间力有氢键,疏水键,侧链相反电荷基因的库仑力,范德华力和空间斥力。亲和力常以亲和常数K表示,K的单位是L/mol。抗体亲和力的测定对抗体的筛选,确定抗体的用途,验证抗体的均一性等均有重要意义。
BNC1/Basonuclin 1 碱性核蛋白1/锌指蛋白basonuclin抗体 现货供应
BNC2/Basonuclin 2 碱性核蛋白2(锌指蛋白basonuclin2)抗体 现货供应
BTBD1 BTB/POZ结构域蛋白1(丙型肝炎病毒的NS5A反转录蛋白8)抗体 现货供应
ANKRD17 锚蛋白重复结构域蛋白17抗体 现货供应
ARHGAP32 Rho GTP酶激活蛋白32抗体 现货供应
ASTE1 ASTE1蛋白抗体 现货供应
BCL7B BCversion":"10.1.0.7698"}')
维替泊芬 效价测定 Tulathromycin A
维生素K3,醌(标准品) >98%,BR,日本进口分装 Latamoxef sodium
维生素K3,醌 >95%,葡萄籽提取物 Procyanidin
维生素K1d7 UV>95%,分析标准品 Procyanidin
维生素K1 2,3环物 HPLC>97%,BR Piperine
维生素E琥珀酯;Dα生育琥珀酯 HPLC≥98%,标准品 Piperine
维生素E >95% Pneumocandin B0
维生素D3 βD葡萄糖苷 >98% Formoterol
维生素D2(标准品) BR,进口原装 Homatropine Methyl Bromide
维生素C棕榈酯/L抗坏血棕榈酯 >98%,细胞色素CYP17抑制剂 Abiraterone Acetate
α 戊二钠Novobiocin Sodium Solution2 ug
激动素NP40 Lysis Buffer2 ug
L 乳脱酶 ( 兔肌 )NP40 Lysis Buffer 2 ug
α 乳糖NP40 Lysis Buffer with Glycerol,2X2 ug
乳果糖NP40 Lysis Buffer,2X2 ug
昆布多糖NP40 Lysis Buffer,High Salt2 ug
卵脂 ( 大豆 )NP40 Lysis Buffer,Low Salt2 ug
卵脂 ( 蛋黄 )NP40 Permeating Solution in PBS,10X2 ug
L 亮氨NP40 Permeating Solution in TBS,10X2 ug
亮抑酶肽NR83832 ug
亮绿 SF( 淡黄 )NRK2 ug
脂肪酶NRK52E2 ug
化 ( 无水 )NTERA22 ug
L(+) 乳盐NTP Solution,10 mM2 ug
L 赖氨盐盐Nuclease ,Micrococcal 2 ug
公司专业供应的抗体,抗体是用于化学反应、分析化验、研究实验、教学实验、化学配方使用的纯净化学品,产品品质卓越,价格实惠,多种规格供应,售后完善。
单位名称: |
上海市金山区金山大道2788号
联系电话: |
Email: |
