抗体
磷酸化Bax抗体图片
磷酸化Bax抗体图片
Anti-phospho-Bax(Thr167)
邦景
0.1ml/100μg
磷酸化Bax抗体图片几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
磷酸化Bax抗体图片合英文名称  Anti-phospho-Bax (Thr167)
中文名称  磷酸化Bax抗体
别    名  Bax (phospho T167); Bax (phospho Thr167); p-Bax (phospho T167); p-Bax (T167); p-Bax (Thr167); apoptosis regulator BAX; Apoptosis regulator BAX cytoplasmic isoform beta; Apoptosis regulator BAX membrane isoform alpha; Bax isoform psi; BAX protein cytoplasmic isoform delta; Bax protein cytoplasmic isoform delta. antibody Bax protein cytoplasmic isoform gamma; Bax zeta; Bax-protein; Bcl-2-like protein 4; BCL2 associated X protein; BCL2L4; BAX_HUMAN.
浓    度  1mg/1ml
规 格  0.1ml/100μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Dog, Pig, Cow, Horse, Sheep, Guinea Pig
产品类型  一抗  磷酸化抗体
研究领域  肿瘤 细胞生物 神经生物学 信号转导 细胞凋亡
蛋白分子量  predicted molecular weight: 21kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated Synthesised phosphopeptide derived from human Bax around the phosphorylation site of Thr167
产品应用   WB=1:100-500  ELISA=1:500-1000  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
CACNA1A/Cav2.1  电压依赖性钙通道Cav2.1抗体    现货供应
CACH3/CaV1.3  L型钙通道蛋白a1型3抗体    现货供应
CACH6/Cav2.3  L型钙通道蛋白a1型6抗体    现货供应
DFF40beta/CAD/CPAN  Caspase 激活的脱氧核糖核酶抗体    现货供应
Casein  酪蛋白抗体    现货供应
Calcineurin A/PP2B alpha 1  钙调酶抗体    现货供应
Caldesmon  钙介质素抗体    现货供应
phosversion":"10.1.0.7698"}')
替拉替尼 >99%,AR Lithium acetate dihydrate
替拉替尼 >98%,BR Ficol 400
替考拉宁A2  >98%,BR 3,5Dinitrosalicylic acid
替考拉宁(标准品) >98% Sodium malonate
替考拉宁 >98.5%,分子生物学级 Sodium phosphate, monobasic, dihydrate
替卡西林,替卡西林二钠 >99.5%,AR Malonate
替卡西林(标准品) >98% Manganese (II) chloride, tetrahydrate
替卡格雷(标准品) BR Casein
替卡格雷 BR Vaseline
替加环素(标准品) >96%,BR Sodium orthovanadate
EA.hy926细胞株pCDF1MCS2EF1copGFP2 ug
EAC细胞株pCDFDuet12 ug
EBTr (NBL4)细胞株pCDHCMVMCSEF1copGFP2 ug
EC304细胞株pCDHCMVMCSEF1GFPPuro2 ug
Eca109(GFP)细胞株pCDHCMVMCSEF1Hygro2 ug
Eca109/VCR细胞株pCDHCMVMCSEF1Puro2 ug
Eca109细胞株pCDHCMVMCSEF1RFPPuro2 ug
Ehrlich细胞株pCDHEF1copGFP2 ug
EJ细胞株pCDHEF1MCST2AcopGFP(380)2 ug
EL4细胞株pCDHEFLuc2T2ATdTomato2 ug
ES2细胞株pCDM82 ug
F81细胞株pcDNA32 ug
F9细胞株pcDNA3 CFP2 ug
FaDu细胞株pcDNA3 Flag2 ug
FC33细胞株pcDNA3 mRFP2 ug
抗体制备过程:
1.材料与试剂
  a.提取的动物 Ig
  b.弗氏完全佐剂和弗氏不完全佐剂
  c.青霉素和链霉素
  d.实验动物 兔
  e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海市金山区金山大道2788号
