抗体
磷酸化相关死亡促进因子抗体科研
磷酸化相关死亡促进因子抗体科研
Anti-Phospho-Bad(Ser136)
邦景
0.1ml/100μg
磷酸化相关死亡促进因子抗体科研英文名称  Anti-Phospho-Bad (Ser136)
中文名称  磷酸化相关死亡促进因子抗体
别    名  Bad (phospho S136); BAD (Phospho-Ser136); p-Bad (S136); p-BAD (Ser136); p-Bad (phospho S136); BBC 2; BBC2; BBC6; Bcl 2 Antagonist of Cell Death; Bcl 2 Binding Component 6; BCL X / BCL 2 Binding Protein; BCL X Binding Protein; Bcl XL/Bcl 2 Associated Death Promoter; Bcl-2-like protein 8; Bcl2 antagonist of cell death; BCL2 antagonist of cell death protein; BCL2 associated agonist of cell death; Bcl2 Associated Death Promoter; BCL2 binding component 6; BCL2 binding protein; Bcl2 Like 8 Protein; Bcl2-L-8; BCL2L8; BclXL; Proapoptotic BH3 Only Protein; BAD_HUMAN; Bcl-2-binding component 6.
浓    度  1mg/1ml
规 格  0.1ml/100μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Chicken, Dog, Pig, Cow, Horse, Rabbit
产品类型  一抗  磷酸化抗体
研究领域  肿瘤 细胞生物 免疫学 神经生物学 信号转导 细胞凋亡
蛋白分子量  predicted molecular weight: 18kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated Synthesised phosphopeptide derived from mouse BAD around the phosphorylation site of Ser136
产品应用   WB=1:100-500  ELISA=1:500-1000  IP=1:20-100  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  0.01M PBS, pH 7.4 with 10 mg/ml BSA and 0.1% Sodium azide
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
抗体制备过程:
1.材料与试剂
  a.提取的动物 Ig
  b.弗氏完全佐剂和弗氏不完全佐剂
  c.青霉素和链霉素
  d.实验动物 兔
  e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
CCL3/MIP 1α  巨噬细胞炎性蛋白1α抗体    现货供应
CCL4/MIP1 Beta  巨噬细胞炎性蛋白1β抗体    现货供应
CCL5/RANTES  T细胞特异性趋化因子抗体    现货供应
CCL6/C10  嗜粒细胞趋化蛋白CCL6抗体    现货供应
CCL11/Eotaxin 1  嗜粒细胞趋化蛋白抗体    现货供应
CCL12/MCP5  单核细胞趋化蛋白5抗体    现货供应
CCL13/MCP4  单核细胞趋化蛋白4抗体    现货供应
CCL14/HCC1  嗜粒细胞趋
水杨(>98%,BR) BR Ficol 70
水仙苷(标准品) >98%,BR Guanidine carbonate
水溶性四唑8;WST8 >98%,BR Hydrazine hydrochloride
水溶性四唑5 > 99%,BR Iron(III) sulfate, hydrate
水溶性四唑4 >98%,BC Methyl gallate
水溶性四唑3 比活性:>200 U/mg,BC Myokinase
水溶性四唑1 比活度:>1.2 U/mg,BC Phosphodiesterase II from Bovine Spleen
水溶毛地黄皂苷 >98%,BR Succinimide
水晶兰苷(标准品) >99%,BR 5Bromouridine
水合前胡素 >99%,BR ADA buffer, disodium salt
VE细胞株pFBHTA2 ug
VX2细胞株pFBHTB2 ug
W256[Walker256]细胞株pFCMEKK2 ug
WEHI3[WEHI3]细胞株pFLAGCMV22 ug
WI38 [WI38]细胞株pFLAGCMV32 ug
WISH细胞株pFLAGCTS2 ug
WPMY1细胞株pFLD1 Z+2 ug
Y1细胞株pFLDcat A+2 ug
Y79细胞株pFLDcat Z+2 ug
Yac1细胞株pFP932 ug
ZM755细胞株pFRLuc2 ug
ZR751细胞株Pfu DNA Polymerase 2 ug
ZR7530[ZR7530]细胞株pFUGW2 ug
pBlueScriptR PPP2R5 ApFUGWH12 ug
pBlueScriptR PPP2R5 BpFUW2 ug
磷酸化相关死亡促进因子抗体科研一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海市金山区金山大道2788号
