公司专业供应的抗体,抗体是用于化学反应、分析化验、研究实验、教学实验、化学配方使用的纯净化学品,产品品质卓越,价格实惠,多种规格供应,售后完善。
| 产品名称 |
磷酸化二氢嘧啶酶样2抗体科研 |
| 英文名称 |
Anti-Phospho-CRMP2(Thr514+Ser518) |
| 规格 |
0.1ml/100μg |
英文名称 Anti-Phospho-CRMP2 (Thr514+Ser518)
中文名称 磷酸化二氢嘧啶酶样2抗体
别 名 CRMP2 (phospho T514 + S518); CRMP2 (phospho T514+S518); CRMP-2(phospho Thr514+S518); p-CRMP2(Thr514+S518); CRMP2/Dpysl2(DRP 2; Collapsin response mediator protein 2; Collapsin response mediator protein hCRMP 2; CRAM; CRMP 2; DHPRP 2; DHPRP2; Dihydr pyrimidinase 2; Dihydropyrimidinase 2; Dihydropyrimidinase like 2; Dihydropyrimidinase like 2 long form;Dihydropyrimidinase related protein 2; DPYL 2; DPYL2; DPYSL 2; DPYSL2; DRP 2; DRP2; Musunc 33; Musunc33; N2A3; TOAD 64; TOAD64; ULIP 2 protein; Ulip2.
浓 度 1mg/1ml
规 格 0.1ml/100μg
抗体来源 Rabbit
克隆类型 polyclonal
交叉反应 Human, Mouse, Rat, Chicken, Pig, Cow, Horse, Sheep
产品类型 一抗 磷酸化抗体
研究领域 细胞生物 免疫学 神经生物学 生长因子和激素
蛋白分子量 predicted molecular weight: 62kDa
性 状 Lyophilized or Liquid
免 疫 原 KLH conjugated synthesised phosphopeptide derived from human CRMP2 around the phosphorylation site of Thr514+Ser518
产品应用 WB=1:100-500 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
亚 型 IgG
纯化方法 affinity purified by Protein A
储 存 液 Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件 Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
实验流程:
基本概述:
乙肝表面抗体是人体的保护性的抗体,主要是乙肝病毒表面抗原刺激人体免疫系统而产生的抗体。它的出现,能中和掉人体内的乙肝病毒。具体保护人体的作用。其英文简写为HBsAb。
1、单项抗-HBs阳性
(1)接种乙肝疫苗成功的标志。
(2)抗-HBs阳性单价格低,有时为非特异性反应。
2、与抗-HBc、抗-HBe同时阳性
3、与HBsAg同时阳性
(1)感染了不同的乙肝病毒亚型。
(2)感染了S基因变异的乙肝病毒。
(3)免疫功能低下,抗-HBs不能清除HBsAg。
4、正处于抗原-抗体动态平衡阶段
实验原理 :
(1)特异性结合抗原:抗体本身不能直接溶解或杀伤带有特异抗原的靶细胞,通常需要补体或吞噬细胞等共同发挥效应以清除病原微生物或导致病理损伤。然而,抗体可通过与病毒或毒素的特异性结合,直接发挥中和病毒的作用。
(2)活补体:IgM、IgG1、IgG2和IgG3可通过经典途径激活补体,凝聚的IgA、IgG4和IgE可通过替代途径激活补体。
(3)结合细胞:不同类别的免疫球蛋白,可结合不同种的细胞,参与免疫应答。
(4)可通过胎盘及粘膜:免疫球蛋白G(IgG)能通过胎盘进入胎儿血流中,使胎儿形成自然被动
免疫。免疫球蛋白A(IgA)可通过消化道及呼吸道粘膜,是粘膜局部抗感染免疫的主要因素。
(5)具有抗原性:抗体分子是一种蛋白质,也具有刺机体产生免疫应答的性能。不同的免疫球蛋白分子,各具有不同的抗原性。
(6)抗体对理化因子的抵抗力与一般球蛋白相同:不耐热,60~70℃即被破坏。各种酶及能使蛋白质凝固变性的物质,均能破坏抗体的作用。抗体可被中性盐类沉淀。在生产上常可用硫酸铵或硫酸钠从免疫血清中沉淀出含有抗体的球蛋白,再经透析法将其纯化。
抗体的鉴定:
1)抗体的效价鉴定:不管是用于诊断还是用于治疗,制备抗体的目的都是要求较高效价。不同的抗原制备的抗体,要求的效价不一。鉴定效价的方法很多,包括有试管凝集反应,琼脂扩散试验,酶联免疫吸附试验等。常用的抗原所制备的抗体一般都有约成的鉴定效价的方法,以资比较。如制备抗抗体的效价,一般就采用琼脂扩散试验来鉴定。
2)抗体的特异性鉴定:抗体的特异性是指与相应抗原或近似抗原物质的识别能力。抗体的特异性高,它的识别能力就强。衡量特异性通常以交叉反应率来表示。交叉反应率可用竞争抑制试验测定。以不同浓度抗原和近似抗原分别做竞争抑制曲线,计算各自的结合率,求出各自在IC50时的浓度,并按公式计算交叉反应率。
如果所用抗原浓度IC50浓度为pg/管,而一些近似抗原物质的IC50浓度几乎是无穷大时,表示这一抗血清与其他抗原物质的交叉反应率近似为0,即该血清的特异性较好。
3)抗体亲和力:是指抗体和抗原结合的牢固程度。亲和力的高低是由抗原分子的大小,抗体分子的结合位点与抗原决定簇之间立体构型的合适度决定的。有助于维持抗原抗体复合物稳定的分子间力有氢键,疏水键,侧链相反电荷基因的库仑力,范德华力和空间斥力。亲和力常以亲和常数K表示,K的单位是L/mol。抗体亲和力的测定对抗体的筛选,确定抗体的用途,验证抗体的均一性等均有重要意义。
磷酸化二氢嘧啶酶样2抗体科研PF299804(EGFR抑制剂) 质量规格:>95%,BR LHRH (410)
PD98059 质量规格:>95%,BR Lymphocyte Activating Pentapeptide
PD184352 (CI1040) 质量规格:>95%,BR Melittin(Mellitin)
PD0325901 质量规格:>95%,BR Metamorphosin A
PD 173074 质量规格:>95%,BR NeoKyotorphin
p60 v结构域(137157) 质量规格:>95%,BR N䑏ぅ橎祫橎穉呎㵁⸧吠楨潣瑮湥⁴桳畯摬愠獬敢猠牥敶癯牥䠠呔卐.혟⮜
牛磺猪去氧胆钠 AR,>99%(GC) Dimethyl sulfoxide
牛磺猪去氧胆(标准品) >99.8%(GC) Dimethyl sulfoxide
牛磺熊去氧胆钠 分子生物学专用,≥99.9% Dimethyl sulfoxide
牛磺熊去氧胆 多肽合成专用 Dimethyl sulfoxide
牛磺脱氧胆钠 药用级 Dimethyl sulfoxide
牛磺(>98.5%,JP ) 0.98 2,2′Dibromobiphenyl
牛磺石胆钠(进分) ≥98.0% 2,4,5,6Tetraaminopyrimidine sulfate salt
牛磺鹅去氧胆钠 0.99 Methyl nicotinate
牛磺鹅去氧胆(标准品) 0.97 NMethylN(trimethylsilyl)acetamide
牛磺胆钠(标准品) 0.98 Orcinol monohydrate
pVillinCRESDS Solution,10% 2mL
pVitro2neomcsSDS Solution,20%,pH7.22mL
pBBR1MCS2SDS Solution,EG2mL
pVL1392SDS(Sodium Dodecylsulfate) 2mL
pBBR1MCS3SDSPAGE Loading Buffer,5×2mL
pVL1392XylESDSPAGE Loading Buffer,5×2mL
pBBR1MCS4SDSPAGE Reducing Agent2mL
pVL1393SDSPAGE Resolving Gel Buffer2ug
pVLT33SDSPAGE Running Buffer2ug
pBBR1MCS5SDSPAGE Running Buffer2次
pVSVGSDSPAGE Stacking Gel Buffer30µg
pWB980Second Strand cDNA Synthesis Kit30µL
pWHERESemi Dry Blot Transfer Buffer 30µL
pWHM3Separating or Resolving Buffer30µL
pWPXLSephacryl S100 HR30µL
