抗体
磷酸化胞浆型磷脂酶A2抗体图片
磷酸化胞浆型磷脂酶A2抗体图片
Anti-phospho-CPLA2(Ser505)
邦景
0.1ml/100μg
磷酸化胞浆型磷脂酶A2抗体图片英文名称  Anti-phospho-CPLA2 (Ser505)
中文名称  磷酸化胞浆型磷脂酶A2抗体
别    名  CPLA2(phospho-Ser505); CPLA2(phospho-S505); p-CPLA2 (Ser505); p-CPLA2 (S505); Calcium dependent phospholipid binding protein; CPLA 2; cPLA2 alpha; cPLA2; Cytosolic phospholipase A2; Cytosolic phospholipase A2 group IVA; Lysophospholipase; MGC126350; PA24A_HUMAN; Phosphatidylcholine 2 acylhydrolase; Phosphatidylcholine 2-acylhydrolase; Phospholipase A2 group 4 A; Phospholipase A2 group IVA (cytosolic calcium dependent); Phospholipase A2 group IVA; PhospholipaseA2; PLA2G4.
浓    度  1mg/1ml
规 格  0.1ml/100μg
抗体来源  Rabbit
克隆类型  polyclonal
交叉反应  Human, Mouse, Rat, Horse, Rabbit
产品类型  一抗  磷酸化抗体
研究领域  肿瘤 细胞生物 免疫学 信号转导 转录调节因子
蛋白分子量  predicted molecular weight: 82kDa
性    状  Lyophilized or Liquid
免 疫 原  KLH conjugated synthesised phosphopeptide derived from human CPLA2 around the phosphorylation site of Ser505 [PL(p-S)PL]
产品应用   WB=1:100-500  ELISA=1:500-1000  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
亚    型  IgG
纯化方法  affinity purified by Protein A
储 存 液  Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件  Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
抗体制备过程:
1.材料与试剂
  a.提取的动物 Ig
  b.弗氏完全佐剂和弗氏不完全佐剂
  c.青霉素和链霉素
  d.实验动物 兔
  e.其它材料及试剂
2、选择实验活体。
3、进行动物免疫实验。
4、试取血样进行测试,查看免疫效果。
5、如果免疫成功,杀死实验活体,采集全部血清。
6、纯化出抗体。
7、鉴定抗体。胎牛血清(无菌采制)
几种抗体概述:
1.抗角蛋白抗体(AKA),又称为抗丝集蛋白抗体或抗角质层抗体。AKA是类风湿关节炎早期诊断和判断预后的指标之一,其对RA患者的诊断的特异性为94% ,而其敏感性为47% ,并是一种鉴别RA和与多发性关节炎相关的丙型肝炎患者的有效检验标记物。
2.抗核周因子( APF), 是定位于口腔黏附膜细胞胞质内的颗粒性蛋白复合物。可在RA患者的血清和关节液中测出,与性别、年龄无关。APF显示了较强的特异性(73%~99%)和敏感性。用间接免疫荧光法检测,方法精密度较差。
3.抗环瓜氨酸肽抗体(CCP),具有相对好的敏感度和特异性。其实,抗核周因子和抗角蛋白抗体,与CCP在化学结构上具有相关性,它们的表位都含有瓜氨酸,称为瓜氨酸相关自身免疫系统。
p, p’DDE标准溶液(100μg/ml,u=3%) 质量规格:>95%,BR Neuropeptide Y (236) (human,rat)
p, p’DDE(标准品) 质量规格:>95%,BR Neuropeptide Y (2236)
O酰洛沙坦 质量规格:>95%,BR Neuropeptide Y (336)(porcine)
O酰基蓖麻酯(>80.0%(GC)) 质量规格:>95%,BR Osteocalcin (719) (human)
O脱芳香基雷诺嗪 质量规格:>95%,BR Ost䑏ぅ橎祫橎穉呎㵁⸧吠楨⁳潣瑮湥⁴桳畯摬愠獬敢猠牥敶⁤癯牥䠠呔卐.혟⮜
牛磺胆钠 用于GC衍生化,≥98.5% 1(Trifluoroacetyl)imidazole
牛磺胆3酯二钠盐 0.98 2,3Dibromopropionamide
牛防风素;6氧基当归素 800目 Talc
牛蒡子苷元4'Oβ龙胆二糖苷(标准品) 药用级,325目 Talc
牛蒡子苷(标准品) 硼砂PH(25℃):9.18 pH standardBorax
牛蒡苷元(标准品) 0.98 3Phenoxybenzyl alcohol
柠嗪(>98%,BR) 半乳糖醛(干基计)≥74.0 % Pectin
柠檬一水 AR,99% Tributyl phosphate
柠檬无水(标准品) CP Tributyl phosphate
柠檬无水 分析标准品 Tributyl phosphate
pX260Sephacryl S200 HR30µL
pX320Sephacryl S300 HR 30µL
pX335Sephacryl S40030µL
pX334Sephacryl S400 HR30µL
pX458Sephacryl S500 HR30µL
pXeXSephadex G1030µL
pX459Sephadex G15300µL
pX461Sephadex G25 Medium300µL
pX462Sephadex G50 Medium300µL
pX260U6DRBBDRCbhNLShSpCas9NSLH1shortractPGKpuro  Sephadex G75 Medium300µL
pXJSephadex LH20 3000U
pXJ40cMycSepharose 2B3000U
pBBR22bSepharose 4B300U
pXT7Sepharose CL2B300U
pYADE4Sepharose CL4B300U
磷酸化胞浆型磷脂酶A2抗体图片一抗和二坑的区别:
第一抗体就是平常所说的抗体,即能和抗原特异性结合。
第二抗体是能和抗体结合的,即抗体的抗体。主要用于检测抗体的存在。
一抗是针对抗原的抗体,二抗是针对一抗的抗体。即抗体也可以充当抗原刺激机体产生抗体。也就是说,抗原进入机体刺激机体免疫系统产生免疫应答,由B细胞可以产生与相应抗原发生特异性结合的特殊蛋白质。
一抗二抗都是一种可以特异结合别的物质的基团,而且一抗可以至少结合两种其他基团(底物和二抗)。
一抗:可以特异结合底物,就是识别出我们想要检测的东西。一抗和底物结合与否用肉眼是看不出来的。
二抗:可以和一抗结合,并带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),作用是检测一抗。 如果一抗自己带有可以被检测出的标记(如带荧光、放射性、化学发光或显色基团),则不需要二抗。但这样成本很高,因为一种一抗只识别一种底物。所以如今的设计一般是二抗带上可检测标记,再来检测一抗。而一抗识别底物。这样,当一抗结合到底物上,就可以通过二抗检测出来。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)是一家生物企业,主要从事免疫学、分子生物学和常规生化试剂的销售。主营产品:生化试剂、试剂盒、ELISA试剂盒、抗体、重组蛋白、生化检测试剂盒、分光光度法检测试剂盒、荧光定量PCR检测试剂盒、细胞株、原代细胞、细胞培养基、标准溶液产品。代理并销售进口SIGMA试剂、abcam抗体、R&D抗体、CST抗体、ATCC细胞、BD公司、GE公司、赛默飞世尔公司产品。
上海邦景实业有限公司(Shanghai Bangjing Industrial Co., Ltd.,China)先后与天津中医学院、复旦大学、上海交通大学医学院、上海交通大学、华东师范大学、第二军医大学、南京大学,暨南大学,南京工业大学,曙光医院、华山医院、瑞金医院、上海有机研究所、中科院上海分院等多家单位建立了良好的合作关系。本公司可为您提供科研ELISA试剂盒,种属标本齐全,有专门针对人血清、血浆、全血、分泌物、尿液、细胞培养上清液、组织匀浆、组织液等标本的试剂盒;另有针对各种动物(鼠、兔、牛、马、鸡、猪、狗、山羊、猴、鱼)的科研试剂。
公司秉承“专注品质、信守承诺、积极沟通、创新服务”的企业文化积极参与生物领域的技术创新和技术服务,力求为我国科研事业更好的,更专业的服务!
公司售后服务宗旨:有质量问题可申请退换,有技术疑问可随时给于解答,一对一的客服服务,客户的需求也是我们不断的更新服务。
上海市金山区金山大道2788号
