蠕动泵/恒流泵
KEWLAB CPS-D600 蠕动泵
KEWLAB CPS-D600 蠕动泵
KEWLAB CPS-D600 Peristaltic Pump
KEWLAB
CPS-D600
请电询15168427495
产品概述:
CPS-D600蠕动泵让液体的传输分配变得轻松简单。它拥有3位LED显示,多种外部控制,RS232/RS485接口和精巧的机身设计。功能灵活,使用方便的特点让CPS-D600成为日常流体传输的良好选择。
产品特点:
• 可用按键手动调速也可用外控接口自动控制,操作简便
• 设有全速按键,可轻松填充、排空
• 具备定时功能,时间范围为0.5s-999s
• 内部与外控隔离,用户也可自行选择有源或无源的外控信号
• 包含RS232和RS485两种接口。用户可通过RS232接口将蠕动泵与PC相连,远程控制蠕动泵
• 大转矩,低功耗,适应性强
• 驱动电路散热好,噪音小,运行平稳
• 优良的工业设计:流线型机身,ABS工程塑料外壳,UV涂层
• 掉电记忆功能有效保证数据安全
• 拥有宽电压设计和抗干扰特性,适用于复杂的供电环境
• 电路板加喷三防漆工艺,防尘、防潮、防静电、耐腐蚀
产品技术参数:
型号 CPS-D600
转速范围 0.5-600rpm
(0-100rpm: 0.1rpm分辨率;100-600rpm: 1rpm分辨率)
出口压力 0.1MPa (0.86-1.0mm壁厚软管)/
0.1-0.27MPa (1.6-2.4mm壁厚软管)
显示方式 LED
外控调速信号 0-5V (标配);0-10V, 4-20mA (选配)
数据串口 RS232/RS485
电源 AC220V ±10% 50Hz/60Hz / AC110V ±10% 50Hz/60Hz
驱动器尺寸
(L×W×H)
261.4×157.3×236.9mm
功率 <50W
允许环境温度和相对湿度 0-40°C / <80%
防护等级 IP31
更多蠕动泵产品,请移步KEWLAB中国官网
KEWLAB主营产品有离心机、显微镜、磁力搅拌器、顶置式电子搅拌器移液器、天平、混匀器、超声波清洗机、冷水机、水分仪、高速均质器、蠕动泵、恒流泵等系列实验室通用仪器和微型光谱仪、照度计、激光光束分析仪、光源、积分球、光学系统、光学棱镜、光学透镜、晶体光学、平面光学窗口和反射镜基底等系列光学仪器和元件。KEWLAB致力于推进科学事业,做您身边的仪器专家。
官网: www.kewlab.com.cn
电话: 0571-28121709
KEWLAB is dedicated to advancing the cause of science, and we do that by supplying optics, photonics and scientific laboratory instruments to both the scientific and the industrial community. It's surprisingly uncommon to find your perfect job nowadays, and despite the odds, that is precisely what we have done! Everyone here is an energetic, brilliant science supporter.
In the beginning humans developed tools, language, agriculture, and leisure; we then had the time to figure out how most of the gross mechanisms on our planet worked. We traced our origins, what had preceded us, and found clues and hints about what the future held in store. Humanity embraced knowledge, shedding ancient superstitions, in favour of experiments, study, and replicable results.
Our amazing KEWLAB crew has decades of accumulated experience in this field; we're ready to meet your toughest technical challenges worldwide. You really need to experience our premium optics and scientific products because the simple truth is that if you cannot measure and/or observe something, it is extremely difficult to learn very much from it.
Describe your optical, illumination, photonic or any scientific needs and let us craft your solution. You show us the path to the future, so let our dedicated staff provide you with the tools that you need to light the way.
KEWLAB Pty Ltd
513/370 St Kilda Road
Melbourne, VIC 3004
Australia
info@kewlab.com
浙江省杭州市上城区民心路100号万银国际2406室
