显微成像
PF850激光自动对焦系统
PF850激光自动对焦系统
PureFocus850 Laser Autofocus System
进口
英国/Prior
PF850
销售商:
Description
PureFocus850 is a revolutionary laser autofocus for biological and industrial imaging.
Prior Scientific’s PureFocus850 combines advanced optics and intelligent in-built microprocessing to provide a real time focus system for infinity corrected optical systems. A motorized offset lens allows real-time adjustment of the imaging depth into the sample, continuously holding the precise distance between imaging focal point and a reference boundary of choice.
The PureFocus850 is easily adaptable to any optical system, it is suitable to both upright and inverted microscopes. The patent pending PureFocus850 system allows powerful automated autofocus functionality to be added to existing microscope systems by installing the unit into the infinity space (between objective and tube lens). The PureFocus850 is an integrated unit comprising of an IR laser diode, precision optical components, detector and signal processing electronics with on-board micro controller. Outputs directly drive a step motor or provides output for servo or Piezo drives.
With the ability to autofocus on different interfaces including slides, glass bottom dishes, flow chambers and many more.
Key features of the PureFocus850
• Stepper motor and analog servo and Piezo outputs all available from one controller
• 1 millisecond response time (typical)
• Simple dichroic adjustment for easy install
• Easily adapted to any infinity optical system
• 850 nanometer laser minimizes impact for fluorescence microscopy
• Software setup and control GUI provided
• Stores multiple objective parameters for single and multi-objective use
Features & Benefits
Features
High speed – 1ms typical response time
Software setup program provided
850 nanometer diode laser
Integrated stepper motor driver and interface to Piezo and other actuators via 0-10V analogue output
Configurable for multiple objectives and sample types
Compensates for microscope drift
Works with both upright & inverted optical systems
Benefits
Fast and easy to setup system and start focusing
Easy to mount in infinity path
No color shift; outside the visible light range
Outside the emission of most fluorophores
Works with your existing opitcal system
Easy to change parameters via PC command or keypad
Market leading system to reliably focus on slides and well plates
Maintain in focus images for long term studies
Application
MATERIALS
Metrology
Ink Jet
Razor blade
Reflective Optics
Photovoltaic (PV)
Diamond Fly Cutting
LIFE SCIENCES
Cell Culture
Confocal Imaging
Neuroscience Imaging
Fluorescence imaging
Cytology & Pathology
Well plates & Slides
Routine Microscopy
SEMICONDUCTOR
Data Storage
Semiconductor Wafers
Micro-Electro-Mechanical Systems (MEMS)
Laser Ablation
Other automated inspection and vision based applications
简介
PureFocus850 是一款革命性的激光自动对焦设备,用于生物和工业成像。
Prior Scientific的PureFocus850结合了先进的光学和智能内置微处理功能,为无限校正光学系统提供实时聚焦系统。电动偏移镜头可将成像深度实时调整到样本中,持续保持成像焦点与参考边界之间的精确距离。
PureFocus850 可轻松适应任何光学系统,适用于正置显微镜和倒置显微镜。正在申请专利的 PureFocus850 系统通过将装置安装到无限空间(在物镜和管透镜之间),可以将强大的自动对焦功能添加到现有显微镜系统中。PureFocus850 是一个集成装置,由红外激光二极管、精密光学元件、探测器和信号处理电子器件组成,带有板载微控制器。输出直接驱动步进电机或为伺服或压电驱动器提供输出。
能够自动对焦到不同的界面,包括载玻片,玻璃底盘,流室等等。
PureFocus850 主要特点
• 步进电机、模拟伺服和压电输出均可从一个控制器输出
• 1 毫秒响应时间(典型)
• 简单的二色调整,便于安装
• 可轻松适应任何无限光学系统
• 850 纳米激光可最大限度降低荧光显微镜的影响
• 提供软件设置和控制 GUI
• 为单个及多个物镜存储多种参数
特点及优点
特点
高速 - 1ms 典型响应时间
提供软件安装程序
简单的二色调整,便于安装
850 纳米二极管激光
集成步进电机驱动及接口
集成步进电机驱动和压电接口及其他驱动通过 0-10V 模拟输出
可配置多个物镜及样本
补偿显微镜漂移
适用于正置和倒置光学系统
优点
快速、易于设置系统及开始聚焦
易于安装在无限路径
无颜色偏移;在可见光范围之外
在大多数荧光发射之外
与现有的光电系统配合使用
可通过 PC 命令或键盘轻松更改参数
市场领先系统,高效专注于载玻片及孔板
保持对焦图像,用于长期研究
应用
材料
计量
喷墨
刀片
反射光学
光伏 (PV)
钻石飞切割
生命科学
细胞培养
共聚焦成像
神经科学成像
荧光成像
细胞学与病理学
孔板 + 幻灯片
常规显微镜
半导体
数据存储
半导体晶圆
微机电系统
激光消融
其他自动检测及视觉应用
Prior Scientific designs and manufactures a wide range of scientific instrumentation, specialising in microscope automation and optical microscopy. This has been the core of our business since 1919. Our experience is unrivalled and our commitment to engineering excellence is reflected in the performance and quality of our broad product portfolio. We offer a range of standard products, and also offer OEM and customised solutions tailored to your individual requirements. Many of the world's leading scientific instrumentation companies already benefit from Priors' expertise.
Prior Scientific设计并制造各种科学仪器,致力于显微镜自动化和光学显微技术。自1919年以来这些领域始终是我们的核心业务。我们拥有无人企及的经验,广泛产品的性能和质量体现了我们对工程卓越的追求。我们不仅提供标准化的产品,也根据客户的具体要求提供贴牌和定制解决方案。许多世界领先的科学仪器公司使用了Prior的专业产品和服务。
3-4 Fielding Industrial Estate, Wilbraham Road, Fulbourn, Cambridge
